- I need to know where to get this relay...
- fuel rail adapter
- So what Gen mustangs can we beat?
- Lower Alternator Bolt
- Bumper got dented...
- Bolts for Strut Bar
- Looking to buy a NON-PR Ebay CAI. Worth the time/effort????
- 4TH GEN GURUs!!! - still have WARM CRANKING ISSUES.....please help $$$ reward
- Spark Plug Tube
- Pinstripe from hell - Recommendations?
- Which rims is this?
- Installing my 3rd Starter??
- how to change air filter
- no start
- airbag removal tips/tools ?
- Front Brake Caliper Rebuild notes
- A champ or what???!
- Master Cylinder Rebuild notes
- Interesting thing
- ABS light on with headlights ONLY
- PO440 and PO446 aka 0705 and 0903, help please
- I Broke My AC/Alternator Belt Tensioner
- open the fuse black box thing?
- Painting engine components bad for temps?
- after market springs with stock struts? Any issues?
- Adding keyless when it was not factory
- better dash kits?
- Got my car checked out at Nissan....
- 97-99 oem red/clear interest thread.
- quick ? about intakes.
- eBay style CAI hole in pipe?
- Power steering return hose.
- odometer/trip quit
- Interior restoration
- E3 Diamondfire Technology
- Valve body upgrade.
- Gas tank question
- MYSTERY BUTTON under dash next to deadpedal?
- Those with Hella air horns in their maxes...
- steering wheel shake
- Odd engine clicking
- Struts
- High mileage start modding or not?
- Leaking Manual transmission question
- turn off/on panic alarm?
- Timing cover gasket
- What is the quietest rear section exhaust to replace the stock muffler?
- Need some help with safc II
- Paddle shifters on a 4th gen? Can it be done?
- Consistent squeeking sound coming from one new Illumina strut
- A/C Compressor Type?
- Hub Tamer tool - anyone use it?
- EVAP question no. 1526641 and 1
- FSTB was causing my problem. Wow.
- Pictures Need, All Colors and Years of Maxima
- I30 taking 3-4 seconds to rollover at startup
- Clutch question before paying the shop
- Moving to a 6th gen
- UDP help!
- Boost/Map sensor
- Cheap ebay headers and y-pipe
- Opinion on this exhaust set up
- Bad axles... and clicking... Worst that can happen?
- dashboardd
- CAI, Y pipe, B pipe disadvantages????
- flushing transmition will mess up tranny?
- after market steering wheel???
- Put a new engine in, still have issues
- Pros/Cons of Mud Flaps / Rain Guards
- Rubbing noise/Lighting problems...
- Check Engine Light
- Need speed sensor wire color
- Door Replacement Questions
- Bi-Xenon HID Harness
- bound bumper cover
- Need a favor from 4th genners with OEM trunk spoiler...
- Ok, maybe its the calipers..
- HID in Fogs: Require Modifications to the Assemblies??
- Engine Mods...Help Me Out
- Question about intake
- AC bypass belt size?
- Obscure/Vague Q RE: Accessory Noise...
- Need Help Adjusting/Tightening E-Brake
- Motor Mounts
- replacing ac condenser
- Sport Light in dash...
- A couple Q's on auto climate control
- 99 maxima idle problem
- Is it possible to use the '03 torque converter in a '99?
- 4th gen to 5th gen interior swap help
- Auto-Rx Question
- Timing Chain Rattle?? But, Not The Tensioner
- I think I messed up!!! Please Help!!
- HID INSTALL....help
- What would cause a maxima to suddenly stop pulling? (no codes)
- Cam Position Sensor Leaking?
- Exhaust sound??
- I'm making infants cry...any chance of a cheap catback? ebay?
- cv joint!!!!!!!!!!!!!!!!!!
- Where's the Coolant Coming From?
- I have angered the anti theft gods...HELP!
- Hole in the side of my CAI...help please...
- best way to clean headlights
- 4.5hrs to not solve any thing!!!
- Installing HO Altinator.....
- Tranny Rebuild problems
- FSTB with the OOVI swap
- Usefull TSB All 95-98 owners should know
- 95-96 to 97-99 Headlight Question
- my RPM's high??
- Replacement Carpent Need Response
- Build AC from Manual to Auto?
- anyone ever break an abs brake line?
- Any way to adjust ECU/Speedo for diff. tire size?
- car idles then shuts off
- Failed emissions for the 3rd time, AAAARGH!!!
- Spare key for '99...
- Tein S.Tech .....Authentic?!....PICTURES!
- Ebay Turbo?
- Accessing the knock sensor
- Just installed a cold air intake, all of a sudden I have codes
- Where can I get facotry pearl white paint!?
- Thoughts?
- Code Help!!!
- 99 SE Stock Rim Bent??
- AC system and O2 sensor Questions
- are STRUT BARS effective at all??
- Too much MT Fluid cause 4th gear whine & 5th gear popout?
- Took my car to 3 mechanics, they cannot remove my driver's side axle.
- Grounding Kit How To?
- spoiler light replacement (other than stock)
- Cure for skippy cd player?
- oh great... now a knock sensor code... and 2 others
- help! starting problem (reward)
- Rough muffler sound on move-off
- Bypassing AC compressor=Shorter belt life?!
- ABS SENSOR WTF?!?!
- Differences between 95-96 Fog lights and 97-99 fog lights
- KNOCK SENSOR problem!!!
- Replaced rear calipers. Now the car does not stop as well.
- E-Brake Light Wiring...
- radiator problem?
- so my car was broken into i think?
- Battery/Ignition Issue
- Adhesive for Rear Spoiler
- cutting out at high RPM's
- Dropping suspension upgrade on my max? I'm not sure...Tell me if its worth it.
- Are seat belts interchangeable?
- alarm and cruise problem
- Testing O2 sensors ??
- Alternatives to OEM muffler?
- Looking for advice - what to do w/an old 95 maxima
- Can't remove spoiler. pics.
- Question: Custom OEM Fitted floor mats
- Bose stereo (pathfinder) question
- Dieseling and long starts
- Greddy Evo2 exhaust?
- i just recently got BEES......
- Factory alarm - How to diagnose
- got a new shift knob ....driving a diff car!
- New Starter-- Cost Labor?
- Aftermarket Y-Pipe Brackets???
- After all the maximas I have seen... I just seen ones with SE emblems on the door
- Just bought a '97 SE 5sp, transmission noise
- OEM knock sensors, A82 or A100?
- Trouble code relation?
- 5spd swap completed, ECM questions
- tein s tech- illuminas or other?!
- Shifter removal problem!!!
- Immobilizer help...
- My car wont move after Control arm install
- just got gf 4th gen, looking for springs, vets step inside
- I had NO CEL light, but checked OBDII anyway, got P0500
- 1997 Infiniti I30 grille emblem, any sources ?
- my car just ate a 2nd alternator
- SMOG LEGAL headers?? with cats?
- Clutch engagement problem.
- Troubleshooting help
- ? to those with portable navigation setup
- steering REALLY loose!?!?!
- transmission question??? need help asap!!!
- Rear wheel hub caps
- Starter Motor needs attention on my 98..
- Body Control Module/Keyless Entry Problem
- Need advice: Will an a/c compressor from 96 fit in 98?
- Has anyone ever put 350z exhaust on a gen 4?
- Summer project ideas: opinions?
- Decisions on summer mods
- Car wont start after filling up gas...wtf?
- No Compression?!?
- So who here has the highest mileage Maxima with a factory clutch?
- What in the heck is a boost sensor? In an NA car? lol
- Alutec FSTB and Paradox RSTB Installed
- ignition coil check
- weird suspension squeak
- Transmission flush question
- Where's the best place to get 03-06 Rims?
- rattle inside while engine running...
- Idle weirdness again (96 Max)
- What DO YOu do ABOUT RATTLE in the TRUNK!!!?!!?
- A/C System PAG Oil Viscosity
- Question about RE4F04A
- seperating engine from tranny, general swap issues
- Pass. side axle help asap..
- Anybody else have issues with static electricity??
- Great price on B&M shifters
- What's rubbing?
- Clunk sounds while going over a bump
- 97 nissan maxima gle knock sensor wanted
- changing out maxima steering wheel?
- What a weekend!
- PLEASE help with shaking problem
- Weird codes, dont know how to pursue
- Car overheated
- Word of advice... Never Adjust Pedal height and Freeplay at the same time... lol
- Creaky sound when right turn!!!
- Torque specs for a/t oil pan
- Opinion need on Head Light assy.
- PR CAI K&N filter question
- Sparkplug non fouler/O2 sim??
- steering wheel vibration
- Looking for a 4th gen...
- Quick Question About Bumper Retainer
- waxing the max
- seat belts gone bad??
- Engine rear main seal leak!
- Tokico Illumina lost red dial???...
- another LED Tail-light retrofit
- need help about lowering, and big break conversion.
- took the max to the shop
- Clutch Fluid Problems
- E-Brake Issues
- Installed larger wheels/tires now car shakes?
- Will a 5gen front valve cover fit on a 4gen
- 1 step colder with the plugs?
- pulley fell off!!
- cars running rich....and its making me poor
- Which looks better?
- Need Interior Opinions
- *SOUND CLIP* of my engine knocking. Check it out, give it your guess.
- anti-squeezing = friction tape?
- Stupid clutch problems
- Fog light rewire problem
- Clutch issue
- Welding Front Core Support
- Failed CA Smog (High HC)...Tips?
- Exhaust parts from EVO IX
- i need something to clean the road.
- Which tranny do i have?
