- How would these wheels look?
- Got my baby back!
- SE-L door badges
- dual exaust
- Hot Maxima
- Stuttering on acceleration and high speed cruising, checked stickies
- Removing ball studs from hood struts
- steering wheel
- Help!!! Stalling at low RPM's and idle
- need quick answer!!plz help
- Muffler
- Can someone help me? CEL code 07 02
- Oil Light Blinks A couple of times upon startup
- unplugging ECU.. dose it reset transponder key?
- neutral position switch?
- New pics i took after the wash ...
- i have poor traction upon high rpm's.
- Quick Injen question plz answer!
- ABS Light, No Power, No Start, WTF?
- Hit the pole with right front wheel, what did I mess up?
- Some coils more failure prone? which numbers
- 96 maxima 5spd ECU in my 96 5spd I30....7 codes
- Need to take off tint & replace w/ darker
- aftermarket gauges
- Nexxus bulbs in, What about side lights?
- intake gas mileage
- Anyone know the weight of the 97 stock se 16" wheel?
- I noticed strange behaviour with my 98 Max today
- anybody else think our maxima look funny with single projectors
- need help to replace two front struts
- What kind of paint to do the dash and center consle?
- Side mirror interchangeability across years?
- car allways has trouble starting
- HID bulb question
- sway bar question
- Does the GLE ALWAYS come with leather?
- Need Help on a brake issue ASAP
- egrc replacement??
- ks and egrc related at all?
- how do you know if you have keyless entry?
- DTM or Tinted Tails?
- Navigation system
- Help....
- where do u get your performance parts.
- Picking battles with my dealership over brakes
- Auto VLSD?
- New Battery.
- should i change out my o2's?
- Help with o2 sensor
- Flashing Power/Comfort switch at engine startup
- Can I run a 3.5 on 3.0 wiring and ECU?
- rough acceleration after dropping car
- Has anyone ever repaired stillen front lip?
- Just this one time I wish my alternator would just DIE please.
- Not Sure what the Hell this is
- Invalid ECU Code 0512???
- Fog Lights
- Need help. ecu code 0111.
- anyone heard of a brand called 'purolator' ?
- Auto 1st gear slow
- place racing intake
- Sticky starter solenoid
- Color Code location
- cyrogenic intake system
- Doing front brakes... Necessary to "Turn" rotors???
- Grinding noise
- Tell me what you think
- lowering
- how hard is it to take out the ENTIRE dash???
- 97 Stillen Lip on 95
- Big problem, You guys ever hear of this?
- Vitek LSD?
- Need pics of 4th gens with 6k, 7k, or 9k HIDs
- Loud humming noise around 2-3k rpms...
- Oxygen Sensor?s CEL was on now off
- Anyone with pics of White Maximas with black or gunmetal rims?
- so here's what happened....
- Want pics of a 96 max with 00 six spoke rims! please
- Help, some check lights came on at random
- is there an online OEM replacement source
- I JUST GOT SHOCKS&SPRINGS SHOULD I PUT THEM ON NOW?
- Ecu??
- stone racing y pipe
- oem Parts
- Timing Chain Cover/Oil pan leak
- Whose Max is this?
- 5 Spoke Wheel Color
- My Max with Racing Hart M5s
- What does the 5 speed transmission weigh?
- Please, answer fast
- Replaced Knock Sensor
- Knock Sensor
- i got a few busted bulbs.
- cobra rotors conversion and 300zx calipers
- Augh! Accident
- Question about 98 factory cd changer
- how do I reset ecu?
- brake leak aggh
- rear strut broke please help
- Help!! Somebody PLEASE buy my Car!!
- Dropzone!?!/2in drop setup help
- new to nissans
- best/cheapest stock muffler
- guys, share your experience with headlight bulbs and recommendations...
- Neutral Safety Switch
- *noob* just got my clear bumperlights. now what? yes, i read the sticky.
- Build a auto tranny, or swap and build 2k1 LSD
- TPS sensor
- engine belt noise
- Ebay CAI install
- 0430 Code
- Alarm Beep mod help
- Help ?How to attach a picture in my post?
- Sea foam?
- cattman exhaust/y pipe
- What's up with my idle?? Feels like the MAX is gonna stall after I rev it.
- Sticky updates?
- Fuel Injection Cleaner, Good or not?
- 100K Advice
- Auto Transmission Diagnosis
- headers
- ecu
- question about bulbs ?
- 4 those who are lowered!!
- need help...car wouldn't start
- Rattling noise right behind my center console
- How long does a Stock Nissan Heavy Duty Car Battery Last for?
- OBX Headers and Y-Pipe//
- Anyone here ever wire up their own alarm?
- why do my h3 fogs keep blowing out?
- K&N Air Filter DAMAGE!!!
- Took the max to Nissan Today
- Need a cool grill for black 99' SE
- CEL after conversion to manual
- how to clean a foam intake? vacum?
- Y pipe and Headers
- KS & Temp sensor
- Intake Manifolds for 4th Gens
- Need Quick Help on Suspension Replacement Parts
- Fog Light Bulbs?
- Vacuum Reading On Vq30de
- Cylinder deactivation...for better mileage
- Finally got pics..what ya'll think
- rear window tinting
- What stuff needs to be maintained?
- Will an SE steering wheel from a 98-99 fit a 98-99 GXE airbag?
- fuel injectors failing
- 96 airbox interchangeable with 99 airbox?
- Loud noise
- transmission problem? Help .org plz!
- I gotta heater problem, it's cold!
- WTF IS GOING ON, CAR GOT SLOWER, what could it be ! :( 1999 nissan maxima
- filling motor mounts...
- What do you guys think?
- braking = low light and no power?
- window tint
- anybody know of a thermostat
- WTF! Did all this and still having trouble starting in the cold....
- spoiler LEDs
- Misfire??? (CEL blinking)
- what to do at 112K
- HELP!!! i THINK ITS a TRANNY
- Greddy SP2 is final release for 97-99
- Struts are dead, suggestions?
- why does my car smoke white?
- 4th gen wallpaper
- Final say on 5th gen. pressure plate conversion
- Vq30det???
- OEM Fog Lights
- Figured out my weird idle issue...
- Tein S-tech and KYB GR-2 setup
- rough idle
- Passing inspection
- Sprint Springs (stock)
- Battery and Brake lights on
- my power seats broke :(
- Why don't they fit?
- Installing new springs!! what to replace while there
- Hood Struts for CF hood.
- Car "Shakes" sometimes
- Auto transmission problem
- ECU reset screw not found
- Control arm bushings
- bypassing the o2 sensors
- people with brembo drilled & slotted rotors
- Window motor
- Gas Fumes
- replacing a rear spoiler- suggestions on aftermarket spoilers
- My new Drop
- y-pipe durability
- 4th gen trans problems?
- Y-pipe nut size
- maxima turning off on higway.....please help
- stock fuel pressure
- New Google 95-99 A32 Maxima / I30 group! Sign up!
- ECU Code 10:01 is it bad to drive while lights on?
- Second battery + battery box needed for sound system?
- White lights: more light vs. color
- Ball joints
- Nissan ECUs more sensitive re: CELs??
- Flashing Air Bag
- help! bose inoperative
- Way to get your Car Sponsorship
- threw some codes
- stock remote no longer works
- is anyone familiar with the navigation/gps stuff?
- Limited Slip Differential
- finally got springs installed! pics
- Weird Idle Issue!
- Engine Coolant Temp Sensor
- VQPro
- my car was leakin for several months, when i checked the oil today it was BLEOW LOW
- Oh no! Car accident! Maxine!
- NGK Spark Plugs
- Need Help Changing the Knock Sensor
- new to the org.....code 0201
- How do you know if you timing chain needs adjustment?
- Can coolant leak from the thermostat?
- Loud squealing noise
- intake
- CV Joint
- need more HP!!!!
- Rear Spoiler Addition
- Faded Door Pieces (dont know what to call it)
- Going from MEVI fo 00VI worth it?
- Fixed my stalling problem and squeaking spring
- What will be required to make 350Z muffler work?
- help 99 MAXIMA window switch
- ecu 1008 revisited
- California vs. Federal
- Swapping motor, what to look for, where to look?
- WTF? Smoke from Engine.... Thermostat?
- belt part numbers
- i think my struts are blown
- Radio flickered out
- Those who had only WSP stage 1 SFCs and then went to stage 2
- anyone know were I can get instruction on how to change my Alternator???
- Does anyone have the xm radio? Where did you mount it?
- Starting tonight
- ? about IACV and setting idle
- battery for stock keyless remote
- y-pipe questions
- scratches all over body
- Eibach Prokit & KYB GR2 driving impressions
- B&G spring install which way is rightside up?? somone!!
- cleaning inside of headlights
- How can i tell if i have a CA emissions car?
- Does any one know the simularities between Gen IV Max and 90-96 Z's?
- auto tranny flush
