- Bought four new Dunlop tires - one is bad!
- Stock Wheel Size - 1996 GXE
- Idling problems
- Keyless entry stopped working... :( Help/suggestions? Please....
- what wheels are these?
- 4th gen shocks and springs in 5th gen?
- phillips hid kit
- Type II wing will be coming soon
- Please Help Me!!
- Anyone with Sprints & KYB AGXs?...
- suspension noise!!! help...
- parking lights
- Check Engine Light and gas
- TPS Sensor Question
- are nitto tires good
- H&R Impressions
- anyone besides Stillen make a SC for a Maxima?
- Does anybody have a pic of Stillen Vacuum hose kit on car?
- What are some performance mods that I can do without having a loud sound??
- Washing new tint
- Any one have really bad experiences with RSB?
- what are the advantages of RWD?
- Which light blinks on the altezzas?
- Problem after starting
- Changing my fluids?
- Bulbs. PLEASE!
- Amber Led Bulbs
- help with my spoiler.................
- To Turn or Not to Turn...
- loud noise above 120km's
- lug nuts?????
- Tenzo R racing seats...where to buy brackets?
- KYB AGX Struts!!
- RSTB, this has got to be DIY, right?
- Opinions on Montegi Wheels
- indiglo a-pillar guages
- Disabling ABS and things to look out for
- SC belt ripped to shreds
- Vq30det ????????? I Wonder.
- I want some pictures
- Question about 115 mph limit and tires?
- clear/red tail lights are fading...what to do?
- ****un Nissan
- 96 Altezzas HELP!
- Pic of Blue Needles and Blue A/C lights
- lowering question!!!
- Questions for buying a 1996 Maxima...need serious help!
- Heater fan
- stalling problem
- An option to debadging....
- Bushings
- Removing molding on outside of door
- Trouble Starting Car
- I have a 1k
- mustang rims on a 4th gen?
- WOW I fixed AC ligthings problem!
- Brake fluid question
- Wider Wheels...Additional Width on Inside or Outside?
- Scraping RSB?
- urethane engine mount thingys
- Where is the best place to get a short shifter?
- Nissan V8
- Brake vibration gone but starts to squeal
- Switch from Sprints to Eibachs was a good idea
- HP Rating???
- 9004 Xenon Headlights
- fliter adapter
- Close up of Red/Clear Tails?
- adjustment of fogs
- Front O2 Sensor
- Turn Signal Mod Question
- Where's my warm air?
- Different Shade of Black on Air bag Cover?
- couple o questions
- re: motor mounts for auto gen4
- what shock can handle 3 inch drop
- Clutch Life
- How do I make an upgraded headlight harness?
- what fifth gen parts are portable to 4th gen? engine ?
- NOS from jcwhitney
- gauge light wattage
- Speaker Removal
- What is the best looking spoiler for the money?
- Spark Plugs Changed - Rough Running
- 17x7 wheels?
- directions on getting door inserts off
- Pic of my smoked out taillights
- picture of my max
- whats the outlook on the 4th gen frame conectors?
- water flowing sound from dash???
- using keys in locks once in awhile
- Tailamp and Cornerlights
- wifes brakes?
- Anyone think I will rub with this setup?
- Got Into an accident
- Debadging
- Prospective Owner
- Check engine light won't stay off!!
- just cleaned my throttle body...WOW
- Stock Hp Rating
- end of this week Sprints will be back in the market!!!
- Need some help with appearance mods
- NO its snowing...is my new paint job going to get messed up
- Colored Altezzas???
- Question about leather seats
- Locking Differential?
- Keyless Entry for a Civic..
- Cylinder Misfire
- Made seat-lowering brackets...
- Shift Knob
- to those that did the poor mans grille in 30 minutes
- BELT tenioner question HELP!
- Loud Whining Noise from Engine and Idle Off...
- New Style Altezza's
- Attn: people with shaved trunks
- Cattman CAI VS. Place Racing CAI
- Powdercoating Springs, bad idea?
- Quife LSD by Cattman question
- Euro Tail lights on a 95! Yes or no?
- White Max Sighting
- Question about spring wrap (split from: Changing Suspension / Noise from suspension)
- looking for a quiet muffler
- Just got beat by a CRX, twice
- ABS vs. Regular Brakes
- Headrest not forward enough...
- just got my car painted
- Slower top speed because of Intake
- Heated Seats ??
- when to bleed brakes?
- just replaced my brake pads
- Cutting bumpstops with Eibachs??
- corner light and tailight
- wierd problem???
- LOOK! Muffler/exhaust
- Auto To 5 Spd Coversion
- Does anybody have a rattly muffler heat shield?
- What kind of life have you gotten out of your stock clutch?
- People w/ Stillen lip, how did you mount yours?
- Another Headlight Problem
- thinking of doing something new with spoiler led
- $2000 on wheels and it still rides terrible!! Help!!
- Check Engine Light- Misfire
- try this...
- is there a way to eliminate the rev limiter
- Cadillac STS vs 5spd
- Best Air Intake For The Maxima For The Money
- Reply to MaximaDriver.com reviews......
- To Turn or Not to Turn (rotors that is)?
- 3 Questions, need help, thanks you
- Check Out The
- torque convertor question
- Are headlights, corners and grills of 97~99 a direct fit on 95~96?
- loweing springs question
- Ideas? Uncomfortable driver seat - cloth
- Headlight problems
- Indiglo Gauges for GXE
- Fastest 1/4 mile
- Got new tires, got ????
- HELP: auto transmission shake
- diamond cut housing question
- My max is going crazy!! Help!!!
- Im bored...looking to make something for my max
- Reducing Brake Dust
- What psi for Fuel Pressure regulator
- Do our stock tires fit taurus's?
- Interior painting
- 3rd gen rims on 4th gen maxima?
- How to get rif of interior sqeak?
- A Gutted Cat?
- I've used 87 octane for 3 years and....
- Grille Mod Suggestions
- guess what happened?
- 245/45/17 tires
- JWT ECU is FINALLY on the way!!!
- Doy you guys think NOT having a rear O2 sensor can make your car faster?
- Group Deal !!! Mercedes Style Side Mirrors !!!
- anybody know a place that shaves stock flywheels
- Aquamist,etc...
- how can i remove a/c vents?
- Sway bar, y-pipe, exhaust...
- head lights are toasted, how much to replace?
- CAI and noise? (I searched the forum first...)
- Engine check light, knock and O2 sensor
- black widow BW FM 200 3000' range?
- 97 ECU Upgrade
- HID's from bmw Z8 on a max
- Dextron IIe ATF in 1997 SE
- questions on INTERIOR REPLACEMENT
- Do I need a tune-up?
- seek feedback from those with 98 Stillen SC
- KYB's
- i need to beat a lex IS300
- ECU upgrade for 98
- Finally got my Y pipe on
- Look @ what I am selling!!!!!
- Anyone had any problems with the rear brakes? (parking brake?)
- Technical Question
- Seat Problem
- Gasoline Questions
- is this for real?
- 98 max auto transmission problem/question
- Nissan Dealers
- need help: mesh on front
- Accident
- Underdrive pulley on an Auto
- Pictures of my 97 with 2k1 17's and B&G drop.
- Want to get a Air fuel ratio meter anyone know a good one
- They took my lights!!!
- Need help for installing CAI/SI
- JWT Pop Charger Question
- Reprogramming computer?
- Did any 4th gens come with BLACK floormats from factory?
- Brake Problems
- ZEX question - TPS voltage
- Help!!! Any new mods???
- Projector Headlights 96 MAX
- gas for '99maxima?
- paint faded
- catalitic converter
- Apexi Super AFC Questions
- Help: Got White Overlays From Importintelligence.com And Needles Are F^&*(d Up!![/
- Engine Swap comments...
- Upcoming Group Deal!!!
- Twin Turbo Maxima
- '96 Maxima Oil Transmission
- Best struts for B&G springs?
- Possible Variable Intake for the 4th Gen??
- Need Wheel advice
- My Max was Stolen Last Night
- Got Rearended!
- Brake noise question.
- Running lean question. (Don't have NOS)
- Brembo rotors for the REAR?
- CAI is awesome
- Has Anyone Added Heated Seats or FoglightsTo A 95 GXE?
- Help W/my KYB AGX
- Oil Leak
- I finally found the PCV Valve!!! WoooHooo!!!
- Anyone added dampening sheets to his/her max?
- Headlights off with alarm arm?
- source for plugs
- 98 se maxima wing LED
- Can Heated Seats Be Added to A 95 GXE w/Leather?
- Clear Headlight covers?
- Max exhaust and underbody neon !!!!!!!1
- has my tranny died?
- Easiest way to remove a radio from my '99
- 99 maxima rpms
