- clunking sound from addco?
- HELP how much to sell my max for
- car will die every now and then
- sqeeky suspension
- Car not starting.
- Fail emission - helppp
- 97 prelude vs 96 maxima SE?
- help me change Drive belts PLease...
- Oil Cooler
- quick AGX install question...
- magazines?????
- Possible 97 Max SE purchase but...
- Stillen Oil Cap
- Someone keyed my car! =(
- turbo or supercharger
- Please post what problems you have had/have with your maxima (if any)
- Mix and match
- Lowering car, best coil-overs, opinions please!
- xenon lights
- my freaking wheel bearing moaning again!
- Sexima Got A Cefiro!!!!!!!!!!!!!!!
- quick sprint spring question...
- URGENT: Will a 95 MAFS work for a 97?
- Carbon Fiber Altezza's for 4th gen.
- Brake/Rotor question
- Budget is god
- paint on door
- check engine light... not sure on this one
- Maxima's own Dialect
- Diamond cut corners for a 96 max?
- ticket for inspection sticker
- k+n cleaning
- A/C bezel, CF Gauge Trim
- 96/97 muffler swap
- liscence plate ideas
- who do u........
- Clear turn signals. A somewhat odd question.
- cold air intake question!!
- cv axles
- just got my keyless entry to work
- took me 3 DAYS but i finally did it!!!
- Regarding Clear Tail Inserts
- 60,000 Mile Tune-Up
- Just got the Max back from the dealer....
- oh man :(
- rb26dett swap?
- Why do bigger rims yield a harsher ride?
- Stillen kit without spoiler?
- Need help with this sensor read out
- cutting springs to match
- Coilover question? Help
- what gear do you guys do burnouts in?
- God Awful Choke
- Carfax Report
- My LIGHTS went out HELP PLEASE!
- Y-pipe + K&N drop-in = limited gains?
- Can you rewire the fog's so they run on their own w/o headlights.
- Should I buy Courtesy Nissan's aftermarket B-pipe?
- Life is good
- Gas Mileage Question
- jetchip ecu upgrade
- Project RedMax!!!
- Tires?
- How do I check/test my MAFS?
- made a cardomain.com site for my max
- Short throw shifters
- Clutch gets stuck and cant shift...
- Besides wheel imbalance, what else could cause... >>
- Damn Stinking Alarm, Flash you Bast@rd!
- what the...?
- 5 speed drivers, gas pedal needs light touch or heavy foot?
- Air Conditioner Stinks When Turned On..>How To Fix??
- headlights
- exhaust resonator?
- Who can Chirp 2nd ??
- erebuni kit...
- Are ALL Parents Like Mine ??
- Ecu problems!
- OBD2 scanning tool
- Third brake light cover
- Question about springs/lowering/struts.
- lowering springs
- Can someone help me with this code
- tire pressure for rear wheels
- OEM Fog Light Install ???
- altezzas or no?
- Looking for front Passanger Door Panel (grey Leather)
- Hung with an M5??
- Look for pics of 4th gen with 2k2 SE rims
- I Have 95K On My 97 (Highway) With No Leaks, Should I Swich To Amsoil?????
- Low Idling Problem-- NEED HELP ASAP
- Questions and problems this and that ahh
- How Much Nos Is Enough
- Brakes squealing out of control!
- fog light installation
- Steering Feels stiff now. Before was light as a feather
- Throttle Position Sensor
- should i get this??? HELP
- hayne's manual
- who is more beautiful..??
- What does my Maxima need at 60K miles?
- Manifolds for a Turbocharger
- Car is possessed.......Strange start
- Creaking Trunk
- pimpin aftermarket horn....install question.
- Need help with a couple of Problems.
- Sunroof broke, how to fix?
- First times at Houston Raceway Track
- body kits
- "leatherseats.com" and June 9th meet
- how do I test my MAFS?
- Does anyoen have H&R's with Stock struts/shocks?
- Whats the best type of foglight bulbs?
- creaking from right front Tokico, could it be a bad strut?
- New MAxima Driver....what should i do first?
- new mod this weekend -- sorta!
- Car just simply dies...WTF? I've tried EVERYTHING!!!
- All I30s (96-99) have tilted/adjustable headrests?
- 97 GLE vs BMW 325ci (Auto)
- Rebuild this 97 Max worth it?
- Question About Exaust?
- Need Suggestions please
- hookin up amp to bose subs = more bass?
- thinking of buying a maxima
- carfax report?
- How long did it take for your pace setter STS to break in?
- Yellow H3 Bulbs
- Finally have a chance...
- how are dropzones?
- Glass pack or something????/
- low idle problems
- Funny story today (long)
- State Emissions
- Many ECU Codes! Please Help...
- b&g springs
- 13.6 @ 100 Mph 2.100 60'
- 97 max vs 2k teg
- taking the grille off a 95 max
- question
- Installed Sprint/Agx Today
- B&G spring Install pics and ride review
- Transmission gear indicator bulb
- Blower is wacko?!?!
- mpg :\
- high flow cat mounted kind of slanted, does it matter?
- What Do U Guys Think Of This?
- Pics Of My Max -2002 Rims-gc Coilovers- Etc
- JWT Filter Cleaning...
- M12 lights
- Anyone in Dallas?
- New Rims
- people with beige maximas. NOthing Matches!!!!!
- Check engine
- Fstb
- door hard to open/close
- Airbag Light...
- Rattaching badges...
- Is the maxima the right car for me?
- spark plug???
- What do you think about an altezza mod like this? (photoshopped)
- Squeaks when it rains
- seatbelt light
- FLIP FLOP TRUNK .... pictures and install write up..
- Engine Mod...
- Nismo
- help me find a bra for my Max..please
- Who out here has a wood dash kit from JoshuaTree???
- Custom Truck Sub Box
- Question on E36 lights???
- kicked the 5hit out of a white 4th gen 5 spd
- AndyXXL, The leather is on it's way!!!
- What do you guys think of my drop and rims, PICS....
- Racing Pipe/ Test Pipe
- Post your idle time!! (when engine is warm)
- My CAI Said Hello Today.....
- Air Intake
- Really weird feeling when letting off the gas, like the tranny is loose..????
- I don't think many of you will like this buuuut, it still is a maxima-
- Pin stripe adhesive removal
- Beating the speeding ticket...
- Rigging Laptop to my AudioVideo System
- Max.. Accident :( -new bumper options?
- Atlanta 1/4 times!
- Thanks for everyones help...just drove home in my new Maxima!!!
- Rear Brakes - How To??
- Oil leak ---Oil change
- RSB nescessary with lowered suspension?
- Tire sizes...
- Rear Brake clunk and squeal from A/C compressor
- Anyone have unlimited Carfax? Can you run a VIN?
- Speed sensor and cruise control malfunctions...need some help/advice/ideas
- Need to find a good autoshop
- I need help choosing!
- S/C wit 100k miles yes or no??
- RSB installed
- Need Help With Brake Pads!!!
- help 95 max and rough idle in drive
- AndyXXL, Let's See the Bimmer!!!!!!!!
- 95 maxima and general scan tool
- Help! question about maxspeed springs
- drop it like its hot
- quick pacesetter question
- got new rotors and pads installed...break in period?
- Whats wrong my max!!??
- My baby is slammed! She rides good too.
- Help Me this SUCKS!!
- Dash question - what am i missing here?
- System
- 4th gens are everywhere!
- Memory Power Seats On 4th Gen Max...
- My Max has a black eye!
- First time at dragstip with VI
- Cutting Bumpstops
- Those of you with N02
- sluggish and bad mileage
- 96 SE.... CD changer question...
- Will a 95/96 grille fit my 98?
- Alaskan Maximas...
- Need help from you 4th Gen guys
- y pipe install
- Dynos for SC'ed Maxes
- Aftermarket for Maxima?
- Spring Install Cost?
- New rim on tirerack that is SOOO sweet!
- How to make a hybrid front end?
- Anyone have pics of 4th gen Max with Nissan OEM chrome 5-star rims???
- reverse indiglo gauges for 98 w/ digital odometer???
- Alarm Problems
- Maxima performance
- ran a 15.6 1/4 mile, is it too high?
- 96 trim level
- trenz grill
- 4 those w/ KYB struts
- Where Could I Find Gauge Rings For My 4th Gen?!
- update: reverse indiglo w/blue bulbs
- Water dripping in trunk
- turbo
- clutch...
- New member needs help!!! and some info...
- gauge face removal
- painting eyelids
- Vibration @ 40mph & Above
- Remote Starter.
- Skyline A** Complete!!!!!!!!!!!!!!!!!!!!!!!!!
- Anybody running 225/60/15 tires?
- Found a prospective purchase, need input, please...
- cant get windows up
- stop light here
- Bad EVAP sensor
- moon roof visor
