- im looking at a parts car to buy that runs but....
- Hey guys.
- Rear brakes moan when moving from a stopped position
- suspension question?
- Starter inhibitor relay
- Finally achieved my dream but it is now plagued with problem after problem
- Best short throw shifter to buy?
- mevi?
- Im back
- mysterious steering issues....kinda
- My car caught on fire.
- When you do the water pump, what else should you replace?
- CV Joint Testing
- rear struts go bad fast?
- Everytime i clena IAC it idles high 4 days later.
- Waterpump / Accessory / Rotational noise questions
- rack and pinion is going
- test drive experience
- Really strange problem- did I fix it?
- RPM drop when accelerating while low rpms.
- About to order Ksport springs...
- Continuity check between O2 sensor harness and ECM
- Passenger seat is stupid low+Power seat problem
- 37 MPG.
- anyone need/want an exhaust?
- Help With 99 maxima needed. Car hesitates or the clutch is slipping. not sure anymore
- AC Compressor year compatability
- OEM Indash CD Changer
- OEM Push Button Start
- What is this connector? (PICS)
- year changes
- Springs?
- OEM White Nismo Gauge cluster from JDM Cefiro
- problem installing headlights
- reposition windshield wiper
- Reverse light bulb lights up when I hit the brakes!
- Hood wont open, help!!!
- 95 maxima ac compressor making noise after W/p install.
- Installing Powered Seats on a 95
- Brake pads in need
- oh my god, i broke my MAF, i need one asap. anyone in south jersey???
- MPG figures
- Has anyone hard wired a radar detector to map lights or another source?
- this is the MAF sensor correct??? PICS!
- roof rack
- Missing part of my intake (OEM) (pics)
- Got the wrong intake !!
- Moisture behind instrument panel glass?
- Vision Motorworks shift knob review (don't buy)
- Deals on Magnaflow and Flowmaster
- Intermitten blower/fan motor for heat/AC
- Something inside the rear valve cover?
- Headlight Housing repair?
- Gold Intercooler idea....
- Finall decision 5 gen clutch over 4 gen, now what else do i need ?
- spec v 6speed swap is it worth it??
- Check Engine Light possibly burnt out?
- what brand exhaust?
- removing park/neutral position switch on a 5mt tranny? harness difficult to unclip
- High mileage
- Front Bumper removal
- Engine Swap Labor Cost?
- 96 MAX FOR $700...
- Headlight setup
- Your thoughts..
- HELP: Cattman headers gasket not same as OEM??
- HowTo Fix Clunking Noise in Steering Wheel
- How do you "drive" a automatic?
- Pretty Awesome
- Post pics of your 4th gen with other gen/model OEM Nissan/Infiniti Wheels
- car getting hot after radiator replacement
- Check Engine --> Cluster?
- VQ35 cams in VQ30de
- MEVI RPM switch
- Aftermarket HID
- Carpet
- Mevi with supercharger
- Tackling the EGR valve today!
- Bad sputtering and hesitation.
- Okay, my 2 front struts are blown, 2 rears seems good still. i want my car lowered?
- not again...iacv
- Supercharged vq35 swap
- complete 00vi kit with 4th gen fuel injectors
- CHTS question
- Starting Problems (when the car sits in the sun)
- Online source for quality "factory equivalent" parts?
- How to Change Cabin Air Filter &c clear A/C drain?
- Carbon deposits in Intake Manifold
- Misfires...again!?
- I need some Help with my new suspension upgrade!
- Front Right End Shakes Bad
- Stalling issues too. Making some progress but need guidance!
- Looking for a how to on a clutch job
- This car just never quits having problems
- Emission with supercharger,blocked off egr,600cc is it possible to pass?
- Is This What I Think It Is???
- Maxima GLE without leather seats??
- 5th gen Keyless Entry Remote with 4th gen Maxima?
- Electrical problems.. Please help!!!!!
- Where To Buy a radiator?
- Exhuast
- Junk Yard Treasure.... with rusted bolts
- Mysterious not starting problem
- octane difference
- Alternator test results...
- Vq35 throttle body spacer on the vq30
- original owners
- Passed emissions but just. ypipe to blame?
- New Jersey Inspection...Please PM me
- 95 Max exhaust manifold change
- 96 Maxima Bearing swap - DIY w/PICs
- Rear suspension problem!
- check out this vid for the new maxima.
- $300 maxima bad buy?
- Switchblade key for 4th gen??
- will these 8lug enkei rims fit my max?
- Guess the front end noise (Video Inside)
- ok, since i haven't found a thread on how to replace the water pump...
- Does anyone know if I can get the boots for the steering rack separately?
- CODES WONT DELETE
- New e-bay aftermarket keyless remote - review/pics
- black houses headlights or clear headlights for my white max?
- SLOW FLASHING AIRBAG LIGHT
- 300zx engine swap
- where can i get some nice aftermarket headlights, tail lights, side markers?
- okay whats the deal, why are these coilovers so cheap?
- 97 trunk on a 95 Gone Wrong..HELP
- vq 30de sc
- whats the color code for my pearl white 97 maxima?
- So I got $500 bones. Out of 2 types of Struts here are my poll choices.
- Where does everyone order their parts from?
- Starts...Revs Real High...then dies
- HELP my 96 maxima wont turn on
- Need some advice (LED Mod, Pre-cut window tint)
- For those that have done 5spd swaps
- OIL LEAK
- 98 Max: GXE to GLE rear suspension conversion
- Rotors making hissing/grinding noise after bearing replacement
- Could this be the BCM? Weird electrical problems
- Idle problem (please help)
- I officially hate my Max
- got a check engine light code need help
- CV Shaft Opinions
- Is it possible I have an original Nissan Battery when the car was purchased?
- Help with OOIV swap?
- m3 spoiler lip for our Gen 4s? Were are the LED ones?
- FAKE TEIN !!!!! **WARNING**
- Who made this y-pipe?
- Performance belts?
- EGR GUide tube - Bottom 2 screws/studs
- Bone stock 97 GLE what to do first!!
- Shifter return spring
- It's always something new to P*** me off
- Liquefied Petroleum Gas (LPG) equipped A32
- Wrecked My 99
- Overfilled Engine Oil ?!?!
- requesting pictures of your 17" rims Dropped and not dropped..
- drop scenario
- Weird Shift delay
- Sunroof will open but not close please help!
- My brake light and battery light came on today, any ideas??
- Knock Sensor harness - Correct Part Num?
- Chilton or Haynes manual ??
- I think my car is dying.
- Fan only works on high
- B&M shifters? Can they still be found for a good price?
- CHANGE OIL OR NOT?! FAST!
- Help with Rubbing - sneak peek at new wheels-
- 97-99 fog lamps with black housing
- Color Change Opinions?
- help with fuel level sender
- weird ignition problem, i replaced the ignition relay. opinions wanted
- 4th gen wheels on a 5th gen.....
- Need Advice On Starting Mod Process
- 00vi vias arm in UIM
- Dem the brakes...
- very bad misfire?
- Wierd series of problems, NEED HELP!
- AC experts
- 98 SE: Engine stumble, then CEL0608 ?
- EGR Tube removal...last resort
- Maxima Starter Will NOT turn over after new transmission install.
- Front Suspension - Again
- finally my first performance mod, many more to come this summer
- Replaced Rotors and have grinding noise
- Trying to figure this out.
- Random missfire...
- Really quick parts (rear window) question
- Removal of EGR FLow Sensor
- Rear Speaker size for a non-bose system
- IACV removal- quick question
- For those driving on 18" wheels
- Springs
- are kyb gr2's an oem replacement, or can i use with lowering springs?
- Ksports+19's+staggard+white=SEX-C
- Found an odd device under my dash...
- Hi haters :)
- Throttle body removal
- turn signal - loud buzzing noise
- Ebay knock sensor.. $20??
- question on rod and main bearings
- Custom Camber plates now avaliable! on the cheap but not built cheap!
- Throw out bearing
- ...So I'm getting the car fully repainted since I crashed it a month ago
- Anyone know where I can buy struts/springs pre-assembled?
- How hard to replace ac compressor?
- A/C Experts
- 17" Rims?
- Radio wire Harness..now where do these wires go?
- Really quick question about the horn assy
- Anyone here on CMS (Canuck Motorsports) springs? Any pics?
- low end power sucks in my max
- Lots of brake dust on one side
- DIY: 5th gen instrument cluster swap for 95-97's
- 3.5 swap for $900
- cluster issues
- Replacing windshield trim
- Rear seat removal
- Right front axle leak
- Underdrive Pulley on Ebay
- Tein s tech strut compatibility???
- 97 SE climate control lights out.
- Help my Max reach 300k...rough idle, idles around 500
- What are consequences to Compressor pulley bearing failure?
- Flywheel resurfacing versus new flywheel
- Car "puttering" when accelerating from stop
- mevi or oovi? witch is better?
- VQ35 swap, why am i running so damn rich?!?!?!?
- Fog Light questions and problem
- My new $225 GXE project car
- VERY FAST THERMOSTAT QUESTION!
- The LED Light Picture Thread -Interior-
- Exedy Stage 1 Clutch Vs. ACT Stage 1 Clutch
- 4th gen swirl valves?
- Interior LED's
- Stillen or W.S. Y ? Feedback please
- ? 5spd swap quick response plz
- Finally the job is done:
- Engine cranks then dies
- Cylinder 1 with bad compression results
- Overheating WTF???
- Difficulty of Radiator support Swap
- Guys wanting Hawk HPS or HP+ pads - use 00-01 Maxima or 03 350Z fitment
- Cam sensor leaking
- lol YES 3rd knocksensor. beat that. haha
- Quick stumble during acceleration (2000 - 3000 rpms)
- Nasty Smell on high rpms
- How did I mess up my transmission?
- Fuel Tank Support Strap
