- Auto Crank Pulley Removal
- Starting noise dont know what it is
- can some one help me
- Changing the spark plugs...Ran into a problem, Help!
- UPDATES: New Suspension, New pics!
- do i _have_ to buy dustboots for the AGX?
- What do you think of this deal on 97 max?
- Interior Help!!
- Q about my brembo drilled/slotted rotors
- where the hell is fuse 58
- Test pipe
- Engine Coolant overfill?
- installation fee for springs, shocks, dustboots, camber kit, and wheel alignment.
- Need Battery Suggestions ASAP!
- 17" or possibly 18" rims with Teins?
- what life from yr battery?
- Anyone here using PIAA Xtreme white 9004's?
- Rack & Pinion went bad...common problem with Maximas?
- How To: PS Belt
- Engineering supergeek Question - cubic footage of interior?
- wheel bolt
- Question for high-mile gurus...
- Fuse Question
- Starter????
- uh oh.....
- How to remove the black "hose" behind auto climate?
- What kind of taillights are these??
- changing clutch ?'s
- Car seem like it has more power now that it 0 degrees out
- Trunk light bulb size?
- How do I get a hold of BUDGET exhaust!?
- werd my post go
- Please Help, Car Shuts Off
- Budget b-pipe
- maxima advice
- Obx vs weapon-r
- 97 headlights and intake
- Ebay carbon fiber hood any good?
- Starter is in vegetative state :(
- Practicality of valve body mod.
- pics of your engine...
- People who have replaced axles. Please help!
- Guage Cluster Lights
- Opinions On Altezzas
- Energy Suspension Front Control Arm Bushing Install
- Lack of power after changing bad MAF sensor!
- thump at idle again
- Are these really necesary?
- Is this possible
- Just installed Silver Stars...Im liking em'
- Anybody know about (or used) those Hi Flow Cats on EBAY?
- Need Help with seats
- Stillen body kit
- quick question about changing and oil pan in 97 maxima
- Changing Struts/shocks tommorrow
- Trunk Portal
- Yay! Stillen Kit
- Streering
- Axles w/ ABS vs. axles w/o ABS
- #194 for the dash
- Do i need an upgraded harness?
- Transmission problem
- Loose Hood
- Need help putting in Shock Sensor
- some leaky under the hood...
- Transaxle Service
- Resealing the altezzas
- 95 5speed tranny question
- Help can u bypasses the knock sensor in the 4th edition
- coil packs 5 and 6 are dieing
- HELP! on identifying two things.
- What happens when the Torque converter goes bad?
- where to these screws?
- Anyone ever smell burning antifreeze?
- Ignition Key programming-99 SE
- Big Question... 5spd Or Supercharger
- steering wheel shifted after skidding on snow
- Steering Wheel Upgrades?!
- oil seperator?
- air/temp and knock sensor
- I've got an idea... fog light wiring... Is this possible?
- Electronic heating control 4 Sale
- Wow
- What's up with the e-bay CD service manual?
- FlexthaneŽ
- OBX Type-H Axle Back Exhaust w/Pics!
- alot of questions about my max (problems)
- power steering pump really whiney.
- Do 4th gens have LSD?
- sarona hood
- why our steering wheel is so lose ?
- Replacing Rear Bumper
- '99 Max Alignment Problem
- Are Tokico Illuminas any good?
- Antenna adaptor?
- weird noise when going 60-80- mph
- 5th Gen Muffler on a 4th Gen
- How long have you had your maxima?
- braking vibrations
- Moonroof off track?
- get tune-up from dealer?
- Completely re-done homepage
- ebay intakes
- Help me decide my future please
- Weird electrical problem.
- smoked or clear lights on blk max?
- Urethane kits deforming in heat
- 5 speed swap cheaper?
- Side marker...one is brighter than the other, why?
- wipers problem...
- SE-L... is it worth it?
- Carbon Fiber Front Lip
- Fan Issue started tonight. Help!
- Insurance Issues
- antifreeze qn.. please help
- Now that it is always below 25 degree's, my car will not misfire.. odd huh?
- Windshield cracked : How to fix it??
- Possible Problem. Help is apreciated
- cold start
- 2 Noises too many + windshield wipers wont work + CD Error! = PLEASE HELP
- Having trouble finding a tranny
- Question about Fog Lights
- Disgusting Front License Plate Mount...answers needed
- 2 problems please advise
- BLUE LED Window Switches Service
- How much $$$ do u think I can get for my car?
- Blinking Air Bag indicator
- Maxima Headers
- Key Fob on 99 Max
- high beams not working on upgraded harness
- Engine code 0302 EGR System Hi/Low Flow
- Automatics and OD
- little to no horsepower gains
- Horn
- Replace Fog Lights with GRILL MESH?
- Best setting for Summit Switch
- Overdrive question
- Fuel filter question
- Climate control stopped working in Maxima SE 1995
- Hey, all...please help, I've a car I need info on
- Question about y-pipe screws
- Blown AGX's???
- Removing rust around wheel well
- Removing the Center Console in search of Pepsi
- Tranny is shot, Which clutch to put with new one?
- Airbag Control Unit Help pls!!!
- Rough running/knock on cold restart?
- Some new pics of my car and the exhaust added!
- Waterpump..How difficult to replace?
- center console on ebay
- anyone had experience with www.xpel.com?
- Does anyone else's Max Hum?
- How can I get just a 1" drop?
- Need advice on matching 3 coat paint (97 pearl white)
- red paint on my tails is driving me insane!
- does anyone know how to make hyper blinkers?
- Auto tranny shifting WAY to early
- lowering max
- Passenger Seat Won't Move
- Clear out tail lights
- How to take out rear side marker?
- Starter fixed for free!
- Problem with Cooling System ?? PLEASE ??
- any pics of yellow Narva fogs with hyper white headlight??
- Keyless entry
- 17" with drop
- aftermarket y-pipes
- trouble w/cold weather ignition...please help
- wind noise
- coolant
- Testing the knock sensor
- another Fed or Cali thread...
- failed GA emissions
- 99SEL Tranny
- 2000 engine and tranny in the 1999?
- Air\Fuel ration gauge to ECU ??? anybod know...
- water running?????
- Could my clutch be causing this problem? (semi-long)
- What the HELL?!?! is that little light bulb!
- Will KYB GR-2's handle TEIN S-Tech Springs?
- How much for valve body mod and installation?
- how do you change front 02 sensor?
- Racing Tow Hook Question? ( pic inside )
- Power Seats
- Missing Front Strut Bolt
- tranny coolers?
- broken air vent
- Where can I find the Chrome/Wood shifter and e brake???
- Fog lights keep going out???? Suggestions???
- Ebay Axle Back exhaust: REVIEW
- should i buy this maxima?
- FSTB install w/ out Tourqe Wrench
- Cattman dustboots fit Illuminas?
- 95 Foglight relay/switch needed
- Is it possible to change the color of the gauge needles?
- question about needles in cluster
- Underdrive Pulley
- One day runner head light is brighter than other?
- JDM Chances
- Foglights keep frying the fuse
- How many rpm's at 70mph?
- ECU Questions...
- 0505 (good). Does ECU needs to be reset?
- Help with 1999 vs 2000 Max buying needed
- Re: Car Shakes
- RPM switch questions
- Front passenger brake producing more dust than driver side. Why?
- Removal of Upper oil pan?
- My Warpspeed Cali spec Y pipe impressions
- Shocked at fuel economy!
- will a 90-96 300ZX 5sp knob fit a max?
- KYB GR-2 VS OEM shocks/struts
- Foglight project, good or bad??
- Heat doesn't seem to work...
- help me please HELP ME PLEASE
- my CEL = P0325 & P0133.. i have a few questions.. help
- sunroof adjustments?
- Clutch pedal mushy/sticky in cold, same with shifter.
- Corner light rewire for '99
- Who can identify mysterious smells from my hood?
- EGR system Questions??????'s
- Hood Lift Supports
- What options do I have for foglight bulbs?
- would anyone want my car? how much would it go for?
- LED bulb 1156, front turn signal problems
- Who knows how much the rear bumper weighs on 4th gen ?
- accident pending .. price estimate ?
- Anybody else have trouble with CHILTON Online?
- EBC Greenstuff vs Raybestos QS
- Tokico Blues or Illuminas?
- idle 500RPM??!!
- Headlight Wiring Q's?
- clutch problem
- Head Lights & Fog Lights: Suggestions Needed... Whiter is Better?!?
- 6spd stick swap ?
- Keyless Entry on 99 MAXIMA
- No Headlights or Fog Lights??
- is this normal??? or do i have a problem?
- anyone think our reverse light isn't all that great?
- What are the most common major repiars for 95-99 Max?
- Need a how-to-- y-pipe install
- Replacing Windshield
- StreetGlow Questions
- Door Stuck Closed
- Where is headlight fuse?
- Suspension troubles. Long post.
- filter
- clutch question
- Taking out headlights???
- how hard is it to install MEVI?
