- Looking for LINK to .....
- sunroof won't close
- 1998 Bose volume control knob
- 97 SE 16" wheel and tires - need help!
- Place to buy random 4th gen parts
- Unsolved Problem
- Very Squeeky breaks
- Auto A/C control lights...
- '97 can't run on high RPM, no CEL?
- Quick lil teaser pic
- Car wont start... nothing
- Need Newer Bose Head Unit....Help
- Tie rods for 4th gen
- Antenna Wrench for 95 Nissan Maxima
- Cruise Control and Windows?
- Any body know where/how to get a performance program for my CPU
- interior lights all died at once?
- PBR Brake Rotors?
- new parts from k-sport w/ pics
- Air horn electrical question..
- squeaky suspension
- rotor cap question
- 7L:3S Three way Catalyst
- evap canister vent control valve?? Help?
- Long Day... bad engine... good results..
- clunking sond when i brake
- Hard time puttin in new ecu
- What am I doing wrong with these rear struts?
- Help needed, after fix Max won't start...
- intake
- WTF.... why does my clock auto resets
- 97 ECU question
- It's back!
- 97 Nissan Maxima SE for sale
- IS 300 Yellow Fogs Fit a 4th Gen?
- Any members in Southern Florida that would help me ?
- Failed smog, OBDII needs resetting. How?
- weird sound coming from suspension
- Gas tank o-ring part number
- Need some ECU help
- transmission swap?
- Clutch-a-fixer?!
- need help with coilovers
- 97 max won't start
- Loose seatbelts..
- Radiator Support replacement
- Help!! Need Info on High Quality Hid - Conversion Plug and play kits
- Motorvate.ca is down ??? alternate site?
- Thud Sound when applying brake after shift from Park?
- Wow! My maxima was in the Rides newest Issue!
- Reliability of a VQ35 in a 95 Maxima....
- 00 Q45 Rims on a 97 SE Max
- 555cc injectors
- This hot normal?
- how do i find stephenmax?
- Im an idiot, need help
- Heated/Electric Seat install
- Max stalling and hesitation issue.
- So I got towed...and...
- Nothing too serious...
- so my check engine light came on in my 99 max....
- The girlfriend's 2002 Altima
- Maxxx
- Trunk lip spoiler?
- Costs + Labor on KS and related issues ??
- SS Lines Install question
- doors stuck
- short shifter
- CD Err, and its solutions
- HELP! Trunk won't open
- Anyone bought this?
- Transmission problem
- Are these worth it?
- Chrome door pillers
- Grining/Vibrations only during/after long drives.
- New rotor dilemma
- Help another problem with my brothers car
- stillen body kits
- Anbody have these headlights???
- 95 Maxima HELP with recent issue (power issue?)
- car overheated, water got in
- just got cattman exhaust
- 95' Cali-Spec JWT ECU compatible w/ 96' Fed-Spec Maxima?
- where can i find out how much my maxima is worth
- Riadiator Flush? Do I need to do it?
- New rotors for my '95 Maxima
- my ac is going crazy?!!!
- Need help assembling Cig Lighter into shifter trim
- Cluncking noise
- Stock wheel idea...thoughts?
- Problem....
- what did I screw up now? no oil cap.
- What I did labor day weekend in pics
- Swapping in 300ZX MAF
- How to wire a turbo timer?
- Need help passing inspection!!!
- changing clutch
- Dash trim kit
- My new tint
- rough idle
- Favorite Oem Wheel on a 4th gen
- flat black max
- ugggg, cruise question
- suggestions on what kind of fuel filter to buy?
- to paint or not to paint
- Brake rotor replacment and pads
- Hey guys...
- G-Stop Brakeline Fitment Issues
- Strut bar broke a hose near intake manifold, now have CEL with no code...
- A $7 repair!
- Looking for good H.I.D bulbs
- 10k H.I.D.s + Cefiro Headlights
- Changing the A/C Expansion Valve/Condensor
- Cheaper to get new HeadUnit or replace Bose?
- Loose spark plug
- Bad Steering Rack & Pinion?
- 99 KEY question
- Cooling Question (answer is in haynes manual)
- Labor/Parts Cost, Water Pump / CV Boots
- Tensioner Question...?
- Rough Riding
- TSB went missing?
- Post pics off your center console
- Keyless Entry
- Left & right side of engine?
- serious negatives in dropping a car...if ur low step in!
- turn signal problem.......HELP
- anybody running 17x7.5 wheels at a +45 offset?
- My Maxi could be done-zo
- i just have to know...
- drunk problem
- ipod icelink
- Another dead I30 - will not crank up but for a click sound
- Replacing GOLD trim on the car....
- DO 5th GEN Struts fit 4th GEN
- LCA- New bushings or whole arm?
- WTF- I can't win with the max lately. More noises.
- My trunk light won't turn off!!
- my 95 se
- when im in the car and hit the door lock on the drivers side....
- Valve cover Gakset
- Clutch problemss
- would a bad cat cause cel 0903 and 0705?
- want to get new rims, but think its gonna need more than that...
- Y-Pipe sound issue, please help
- Tire Pressure.
- Anyone running on Gabriel struts/shocks?
- Window tint
- Having a lil trouble with replacin my front brakes
- Ticking on my 95 Se...
- Throttle body spacers??
- Clutch pedal making weird noise
- 5 speed swap questions
- Just finally ordered some gauges :)
- Clutch Fork
- Pointless n u prolly wont blieve but hey!!!!!
- Dragging noise when brake is applied
- Tranny Smoking?! *PIC*
- remote control (keyless entry) Problems
- Have to tickle my Maxima to get out of Park.
- Rear Fog Light Mod... With Jdm Switch
- My car just shut off
- Security LED question
- Leak from clutch
- im bagging my car next weekened
- Need help with CUSTOM GROUND POINTS..
- Want to know
- What to know
- 97 Auto Climate control fit into a 98?
- ss clutch line
- bad idea?
- Clutch pedal stuck to floor
- Tokico or KYB shocks for OEM replacement
- Raido dead after battery died.....
- Diagram/Picture SS Clutch Hose?
- What should I expect to pay for putting a manual tranny in
- Bad starter or something else?
- Pics of my tinted tails plus ques on how to remove VHT Nightshades?
- Fuel Filter change PROBLEMS!
- short air intake install. is this all i need?
- Transmission/idle problem
- My K/S and you guys rock!!
- alternator recomendations
- guage cluster swap
- Where to get a resonator?
- new exhaust almost done :-D
- Perhaps a few more years out of her, at least
- Hood Vents Installed **lots of pics**
- My Huge Battery Dilema
- car stalls in drive
- More electrical problems, Bat. discharging over night
- help, car dies when warm
- lsd stickey?
- Need help with choosing my exhaust
- Cheapest place to buy 97-99 front bumper?
- Help!! Stop me from wasting $$$
- Fixed the Flat Spot with Acceleration
- CV boot grease (torn)
- Are these headlights worth $200?
- Ionic Dynamics lip kit quality?
- Wheels for a 4th gen Maxima
- Couple brake questions
- Who knew the unluck button rolls down your windows?
- What tires?
- Question: Front camber adjustment
- how do u check by looking at tghe VIN if cali or fed?
- How much of your car is still stock/factory?
- dropzone springs
- brake upgrade for 16" wheels
- Damn I miss my...
- Weird Knocking while Rolling
- Serpentine belt
- Mevi part to consider
- P1445 - 1008 - EVAP canister purge volume control valve
- Moon/Sunroof issue
- Car Bumps at All Speeds from Right Front Tire
- Best upgrade for a 1995 Maxima...
- Spend Six G's On Car Or Buy Another Used?
- fog light question
- cruise control problems
- Coming out of storage...
- 6 speed on a 4th gen?
- Broke axle... but the outcome was good!!
- Starting problems
- Can it be buffered off?
- Guyz I'm getting tired of this!! Need Serious Help!
- New altezza lights...
- got an alignment after coilovers and this is result. *pics*
- Problem Starting!
- New tires
- Can a Tranny Flush be bad?
- Favorite interior mods?
- Car pulls to either side intermittently!
- got budget y pipe in...
- EGR valve
- skyline head lights intallation ?
- Name the most PIA job you did on your Max.
- $819 for a clutch job...sound right?
- New tails tell me what you think.
- Lug stud/bolt broke off?
- Installing Subs with BOSE
- Cylinder 2 misfire...but why!??
- Camshaft Position Sensor Leaking
- Jwt Reset?
- Write up on how to change atf?
- Really bad starts
- Injector cleaner VS. Fuel system flush ???
- SHORT VIDEO.... 3inch Y-pipe on VQ30
- loose/noisy strut
