- Bought my first A32
- Mechanic Bypassed Heater Core, Now Car overheats
- Need parts list for Rocker Cover Gasket job.
- I need advice on the first thing to do to my 99 Maxima
- power antenna stopped working after radio install
- Leak on passenger side near thermostat
- Time to bring back the Maxima.
- Long time lurker/reader.. :) Car won’t shutoff!
- CV Axle Recommendation
- help please. the fault lights on the instrument panel of my car are not lit. I checke
- correct air box bolts?
- Shift Interlock Soleniod
- Car won't idle correctly at times
- I need this piece of plastic, but also no turkey please somebody help me. 05061457903
- AC problems
- Refresh entire Power Antenna. What internal grease?
- 95 Remote Issue
- New Koni S.R.T. shock for 4th gen maxima
- A random spring fell out of my 5 speed transaxel
- Oil light flicker twice on every start ups
- Disabling shift lock and park position ignition lock
- Changed o2 sensor now cel is not on
- skidded to avoid raccoon now high idle
- No crank no start
- CV Joint Boot Leaking - re-boot?
- fuel trim -25 w/MAF unplugged, stalls when plugged in, P0300
- New to the maxima world #coilovers
- What type of LEDs to use for the guage cluster
- Car will start but security light stays on.
- Rockauto Closeout rear strut - Got slightly different parts
- 97 Nissan Maxima4th gen car stalls and stumbles at times. Crankshaft position sensor?
- Cruise control on VQ20DE
- Cheap license plate light fix
- Brake Light Switch Keeps Breaking
- I bypassed the ignition
- 99 Max - NATS? Off to dealer and.....
- 96 Maxima randomly throwing tantrums
- Won't rev over 2500 rpm
- Check wires to starter solenoid
- stalled and had to tow
- Strange P0301 Cyl 1 misfire
- Buying a 97 maxima with 151,000 and check engine light
- Replaced front shocks myself and now are doesnt move in reverse or drive
- Instrument Cluster intermittent Issues
- Need help with replacing auto shift knob
- By max
- Rockauto closeouts
- new engine or new car? ( non-maxima question )
- Idler Pulley nut stripped
- Starts but won't rev up
- Clutch
- Possible air in the cooling system after V/C gasket replacement?
- More power baby!
- Looking for entire Power Antenna set up including locking nut
- Grounding Kit Install Instructions/Graphics?
- ECU Battery / Memory
- 1997 Maxima, has a miss, littany of problems, trying to figure out issues
- Z32 BBK front lines
- Tan Door Panels
- Hitachi starter differences
- Vq35de swap
- Drive cycle Question
- Can overfilling (top off) once cause long term damage to my 1995 Nissan Maxima?
- Wheel bearing tool question
- My stubborn MAXIMA!!
- 1995 Maxima: What Quality Mass Air Flow Sensor Replacement?
- 99 maxima over charging 14.5 - 15 volt
- High pressure hose question
- so, i unplugged the maf and the max died.....
- drivers side mirror rust behind mirror
- Photo Survey | ‘99 SE-Ls Only
- Rear brakes / calipers on 95 Maxima - advice sought
- Fast and Furious
- Fuel rail to lower intake seal
- 3.5 4th gen swap revving high at idle
- P0138 got a question
- Dek swap advice
- Has anyone here used the Flennor Tensioner/idler pulley assembly with the bracket?
- Bluetooth/Aux for 1995 Nissan Maxima
- 97 GLE: Dash vibration in Drive and stopped, not in Park/Neutral or moving
- Driver Side Floor Wet
- took me long enough to hit 100K
- 99 max se no start problem
- PO110 obd code
- Subframe Bushings
- Car will not start po 335
- 98 Maxima Keeps blowing 140amp fusible link
- Quality difference in Flex Pipes ?
- Anyone who needs a new serp belt for their 4th gen, get it NOW
- 1995 Maxima QX A32
- I30 involved in front end crash...
- code p0443 causing rough idle and stalling?
- Info on this part??
- Misfire making me lose my mind
- !995 Nissan Maxima oil leak fix with at 205?
- High pitched whine above 2.5k rpms
- Brake pedal stop pad
- Bbk
- How to tell if my 1995 Maxima GLE have limited slip differential?
- EVAP canister purge volume control valve
- driving without power steering
- What type of gas and oil to use for 1995 Nissan Maxima?
- AC Readings
- 1995 Nissan Maxima Obd 2 or Obd1?
- Should I flush my trans, change it or leave it alone???
- bad strut mount=too much +Camber?
- Problem With Overheating
- Have you carbon cleaned your upper intake manifold?
- Speaking of Gabriel Struts ...
- Oil Leak
- anti-freeze behind the block dripping or spraying onto exhaust manifold
- Blown Head Gasket?
- likely culprit- fuel injector?
- Is $300 a fair price to have a nissan maxima alternator fixed?
- Where can I find a decent weather strip for the 4th gen trunk
- Battery Box/Cover/Concealer ...
- Help with AC on a 98
- random hesitation, stumbling, no codes
- Check Engine Light
- New rear strut clunking banging rattling
- Rack & Pinion Boot Cover Torn..
- Desperate for help...99 Maxima
- Maxima 95 SE tire sizes- where to find
- Mystery plate and hole in transmission: please help
- What is the part number to the exhaust manifold O2 sensor?
- Will 1998 i30 headlights fit onto a 1996 i30?
- A/C question - PAG oil and vacuuming.
- personalized TX plates
- Help with misc connector after SS clutch line install
- 98 nissan maxima 02 sensors sensor1 bank1
- No Tach Signal
- 95-96 Stillen Body Kit for Free
- Aftermarket Axle Output Shaft Seals
- No Spark starting after Home Clutch Job
- Six speed swap NYC
- what would you pay...
- New key fobs
- Need help
- What is this part?
- New Carpet Recommendations?
- Key Fob Not Programing
- Pas A Pillar drain working BUT water drips from top of A Pillar
- Going to grab this 99 Max Friday for $400...
- Purpose of cover behind pass headlamp?
- Tunning help
- smooth running from cold, misfire on hot retstart
- AC issue Please Help
- Differences between 99 Maxima vs 99 Infiniti I30?
- one last try to get maxy running
- 2L to 3L Swap
- Water pump mystery
- Is there any diff between oem and aftermarket keyfob
- Trouble with my tack
- Driver door lock and power windows don't work
- Weird brake issue on my 97 SE, kinda scary
- ABS sensor corroded to steering knuckle
- Fuel Injector servicing
- Had codes 1320 and 1445 -got them cleared
- Drain and fill radiator
- Windshield washer tank filler neck removal
- what ECU do I need?
- The whatchamacallit on the thingamajig.
- Ac bypass
- Hook a brutha up!
- Test pipe question
- Swirl Control Valve, P1130?
- Great repair place for our Bose head units
- cross section of lower radiator support?
- P0400 and P1447
- Dashcams and Android phones for CONSULT
- Moonroof Delete Soon To Be Available
- 1995 nissan maxina tac not working and stals when warms up
- Entertaining RegularCars YouTube video - 4 gen Maxima
- I discovered that the 5th gen sunroof is compatible with our 4th gens
- 2 water coolant sensors?
- 5spd just rebuilt - here are the bad bearings and possible cause
- Battery draining
- Door lock stuck
- Code P0420 questions
- Ignition Switch parasitic draw
- Front ABS sensor tests?
- Leaking Radiator Top Tube
- Fuel coming out of exhaust
- coolant change question
- 1995 Maxima 133,178 Miles
- Tips on Alternator installation by myself?
- 1999 maxima adjustable suspension and sports mode
- Battery light turns on a few minutes after starting
- 1995 Maxima Instrument cluster idiot lights and gauges not working
- do you think I have damaged catalytic converters? Smog soon
- lots of repairs done
- 1998 Nissan Maxima, owned since 2001
- Does 99 maxima have idle relearn procedure
- VQ30DE Swap No Start
- Power antenna motor/mast
- Any way to detect what gear you're in?
- Car is surging. Replaced TPS. Please help
- Sunroofs weather strip piece out of place.
- R34 (looking) Headlights - Water Leak Fixed
- Power Window Motor
- Replaced bulb in factory fog/driving lamp but...
- Motor Mount Replacement
- Fan Switch - Might want to inspect
- Not a good sign on the second plug in... $60 dollar hiccup..
- Which car should I keep (doesn't involve the Maxima)
- What "Sparks!" Your 4GM?!
- 1997 Nissan Maxima problem
- Rear PS Bolt loosening tricks?
- Car doesn’t turn over without pushing shifter forward
- 1999 Nissan Maxima GLE Muffler choice
- Does 99 maxima need reptogramed after replacing bcm
- Manual Transmission Metal Ball
- 99 maxima gas leak
- 99 maxima no power windows anf no power locks work.
- 96 Maxima coolant leak
- bad charcoal canister or leaking injector(s)??
- No throttle response in gear
- Headlights not working!
- I surrender to SYSTEM NOT READY
- Making torque converter not locking up bellow 43 mph
- Door unlocks or locks by itself
- Car sat in cold winter/snow now just cranks w/no start
- Cv axle replacement
- so i've tried EVERYTHING, car still smokes at start up
- IDing cupholder clip
- Post your A32 fuel trims
- Aftermarket radio not outputting audio
- Maxima R34 style Headlights a good buy?
- electric trunk release failure
- Getting the axle spindle out without pulling the ball joint apart
- deciding whether to fix my car or not
- Maxima
- Driver side front parking light.
- Replacing Front ABS sensors Wha2 Expect?
- horn(s)
- Tired of this intermittent idle issue.
- Catalysts 6 month road to redemption.
- Help finding or making a simple mod to my OEM trunk spoiler!
- Coolant leak, so that’s where the smell might be coming from?
- 7th Gen Engine and Accessories Full Wiring Swap
- Relocating battery to the trunk
- Dreaded simultaneous ABS, Slip and TCS-off lights
- Q50 wheels and tires
- Lets play, Guess the UDP!
- Which boots will work with Hitachi Ignition Coils
- Nissan Maxima 4th Generation Reliability?
- Backup & Dome bulb options. BRIGHT 2019
- High Pressure Hose To Steering Rack Hardline HELP
- Problems Lock
- Will OEM Ignition Coils From A 1997 Maxima Work In A 1999 Max?
