- Suspension help...
- Recent Max Mods.. (Pics)
- strut mount please help ASAP
- 00vi on Cali-spec
- Anyone Help me change Alternator in Jersey
- de-k swap Questions
- 2 back seat pouches??
- Loose Parking Brake - HELP!
- Alternator Died Today gaH damit!!
- Click and Clack on Installing Private Parts
- Do I need a new thermostat?
- Gas Pedal vibratin'
- part #
- Ebay Kyb Gr2 Struts
- One Touch Sunroof Mod - Update
- Another crazy idea
- Mods to be installed sooon
- Brakes?
- Last night my radiator took a leak
- write up for the spark plug tube gasket?
- Help 1999 won't start--starter? security key?
- Cefiro Headlight questions...need help
- Leaky sunroof issues.
- Fuel filter?
- Oil coming out of crank case breather?
- Stock plugs?
- crank no start, help!!!
- Up all nite in the rain doin my Suspension
- Rear Stance
- 97 steering wheel on a 95?
- WTF..Hu Problem
- New suspension
- How to replace EGRC Solenoid Valve
- I Hate This Guy!
- Can I make it so my A/C does NOT come on whenever I use defrost?
- Is taking off the catalyctic converter such a good idea?
- Digital A/C: Lower Temp=Less gas spent?
- Stock Intake question
- Driverside axle won't tap out
- 2 1/16" gauges that match stock SE panel
- Transmission case split..Dont see spalling on driver side
- Need help with parts
- Not a good day...
- Carsound Cat-Warpspeed
- WTF i failed inspection because of clear bumper lights?
- Rusty Y-pipe Bolts...Impact or breaker?? Help ASAP
- Catalytic Converter? which one
- power steering oil leak when replacing belts
- 4th-5th gen clutch
- 95/96 front bumper mod
- fender
- How manyof you are from Vegas?
- speedo not working
- cruise control tripping out
- illumina's and dustboots
- wheels or exhaust?
- tokico hp strut/spring question
- Y Pipe Gaskets
- drivers rear door will not lock
- Does my 98 GXE have keyless entry?
- oxygen sensor O2
- Dial Gauges Do Not Light Up
- Megan Racing
- Creak/rattle?
- Antenna Problems...
- How To: Remove Pinstripes
- 95-96 Diamond Style Lower Grilles
- Suspension / Front Sway Bar
- New Brakes... Still VERY squeaky!!!
- stock bose + wiring harness?
- Broken ECU??
- DAmn Parking LIght wont come out
- Steps to Clean Intake Manifold?
- Wheel bearing replacement
- Do not park on big streets.....
- B-pipe(w/ resonator)
- 15" Sawblades - BLACK?
- Anybody seen this radio setup?
- fiberglass fender?
- LED Brake Light
- Squeeky throwout bearing, soulution w/out pulling tranny?
- HOOD PIN pictures thread
- Questions
- rough idle due to air filter?
- couple quick flywheel install questions
- 97-99 cloudy/yellowed headlights fix
- 95 vs. 98
- turbo question?
- I need a Resonator!! Help
- Race Legal tommorow anyone?
- Frame Noise while braking on slow speed
- Help: Emanage or OTHER ECU???
- question bout head unit uninstall
- Pcv
- Grounding kit pics
- Ignition coils or something else?
- How to tame Eibachs?
- I need BBK!!!!! and some Q & A
- overdrive off light button not working
- Tranny gone ... selling 95 MAX, what can I expect to fetch ?
- battery dying in traffic - short somewhere?
- Urgent question/rant
- Idle problem?
- loud stock exhaust
- Maxima on 24's again!!!!!!!
- Need your advice!!!!
- how bad are my nuts?
- Say hello to paradise
- Frankencar Intake
- People with lowered Maxima's Please Read.
- My MAF unplugged itself... Damage?
- Where is Coolant Temp Sensor
- Automatic/5-speed swap questions
- 3 out of 4 pwr. windows will not work?
- Worth switching to 5th Gen Clutch so soon?
- anyone who has done a full interior swap, com on in.
- How to build light weight sub box mounts.
- tach dips to about 500rpm when braking around corners
- HELP! Need new MAF
- My car sounds like an OLD CHEVY LUMINA :(
- 5th gen clutch
- Radiator - Radiator Barn?
- Cattman Headers
- cruise control issue
- annoying squeaking suspension
- need 5 spd swap
- Anyone heard of Megan Racing?
- Am I a one-percenter?
- Headlight assembly
- speedomoter
- vibration from steering wheel
- I Got My Tint
- 96 max still making clunking noise
- Need to hook up mp3 player to a stock '96 fast! HELP!!!
- vibration help
- Coil overs?
- replacing y pipe
- Got/Fixed a Busted ECTS? You're cordially invited.....
- Exaust Suggestions
- K&N Cone filter part #
- Must be the new math
- Fitment of 95-96 ebay red/clears?
- Junkyard shopping cart.... what do I need?
- Front and Rear suspension measurements
- anyone in NJ fail inspection?
- KYB front and rear mounts.
- my max is poopin its cherry
- Head lights
- Anyone got a 1996 maxima emblem to sell to me?
- Clutch takes a dump
- people with/who had progress springs chime in
- Break-in necessary after resurfacing rotors?
- max vs i30 trunk lid
- Worth of 5sp tranny in need of bearing
- Some minor upgrade questions
- '96 max high idle sometimes?!
- clutch cant handle the powa ?
- can the jwt ecu....
- '97-'99 Apex i WS 2 catback
- Resonator or No Resonator
- Shaving Emblems
- I have power but the car won't even crank, and I just drove it 10 minutes ago
- Electronic control...limiter?
- Suggestions for replacement axles?
- NISMO Exhuast Hangers??
- Auto trans on its way out...
- Not in park...no start.
- MSD Digital Window Switch installation questions!
- Parking break cable
- Replaced my left driveshaft and now it's clunking
- Maaco Paint Job
- 5th Gen Clutch
- To those with 235/17's...
- Anyone changed the door shell?
- MAF Cleaner? Anyone tried it?
- Traction Control
- cafiro hood w/ grill
- fab switch
- Work in Progress
- Photoshoot: New purchase... 99 SE-Limited
- In regards to a replacement bulb harness.
- how can i ...?
- Tan interior with Black leather?
- Seafoam Verdict - Yes or No
- 98 bose HU
- wooohoo ..had a nice day today
- Accel After burner
- smoked turn signals
- wire mesh grill
- hood pins issue
- 0413 Oxygen sensor. LOCATION?
- I have LSD... Surprise!
- anyone sell maxima seats here and shipped them?
- front/rear engine mount replacement
- Rear Emblem Placement
- Walbro Fuel Pumps
- optima battery
- shaking idling problem
- Need some advice on a car.
- resistor assembly::car or tranny specific
- Greddy SP2 VS Apexi WS2
- Totaled my Max *My situation*
- Question about Door...Already Search
- Making cali spec y pipe fit a fed spec car
- Do you know if this will fit?
- Is the Redlinemax CF hood made by CarbonEFX? How is the fitment/quality?
- 15" se's or 16" se's?
- Startup Idle woes
- Turbos and Superchargers
- O2 Sensors
- oxygen sensor installation. you have to be fuking kidding
- Installing a VAFC II - Couple Questions
- 5th gen springs
- How the F#$% do you get the bush pin out of the LCA bushing?!!
- HELP/Suggestions re:P1320 & P0505... yes I searched already!!!
- Where can i get this kit?
- Help! Did the ECU self diagnostic and dont know what the code means
- A few questions about 4 gen maxima's
- warpspeed catbak
- Quick question, need SOON: Y-pipe-to-manifold fasteners
- Does anyone know to diagnose a defective MAF sensor?
- Home Link?
- Help please with injector o rings
- Taking off wiper blades
- need suspension advice...(tokico HP owners prefered)
- jerking when i drive and a rough idle when i stop....
- Does this look okay?
- differential bearing noise in an auto
- Where can I find instructions w/ pics how to adjust Idle
- looking at getting a 4th gen for $1000 to $1500...possible?
- Wireing Heated Seats
- Air Bag light
- Maxima Module?
- Axle removal/Tranny replacement
- Max is back firing!!! HELp?!
- steering wheel shakes on Highway
- Trunk lid sticks ... have to pull up hard to open it
- Need help with overhaul
- Drivers side A pillar removal
- What do ya'll think i should do???
- Where do u guys put switches?
- q45 calipers/ q45 rotors/ q45 pads
- Emission Test Help
- Gas Mileage Suffering
- Considering MEVI..
- Fleabay: Maxima Performance Chips $20-$69.99
- AE Corners
- what is te correct driving pattern to reset ecu?
- Wagner Ceramic Brake Pads
- Anyone know where i can find these....???
