- Do I need to get another alignment if I change the height on my tein basics?
- 4th Generation Maxima for college student...
- How do you know when your clutch is going to go?
- aircon and horses...
- recommend brakes
- anyone here ever replace the tip on their stillen muffler?
- removing radio
- carbon fiber door pillar inlays?
- HID kit 9004 plug and play part questions
- Need to know what kind of LED's to get for gauges
- ? about Cefiro headlights
- battery or alternator.
- CV Joint Boots / axles
- How exactly is a Cat Converter "high flow"?
- are there any signs i should flush my tranny
- hard start problems
- anyone have pics of the new 95-6 Red Clears?
- Help!!!My stop lights fuse keeps blowing.....
- Custom Enterprise y-pipe reviews
- I got BEES with Budget WTH
- what does the PCV valve actually do?
- best place to buy blembo blanks rotors?
- UR Pulley and more>>
- Engine vibration
- advice on returning to stock
- Oxygen Sensors
- Universal Apex'i WS Muffler
- can I30 motor fit in the max
- valve covers and so forth
- engine mount help
- Front wheel "bearing" help
- Need URGENT help w/ clutch job (axle nuts)
- how much did you pay for your custom catback?
- Who Has real HID in their Cefiro's (Projectors)
- Monroe or Gabriel
- What is the Difference ???
- Brake Question.
- Hows Tokico HP Strut/Spring Kit performs?
- Dash light bulbs access
- Help with some simple performance mods :(
- Quoted $350 for Clutch and Fly R&R
- Wheel application for z32 brake kit...
- need to change out front brakes....what do u recommend?
- adjust timing
- Taillight Harnesses?
- Disappointing Night!!
- stuff in oil, during oil change
- KS Torque/Purchase Question
- license plate relocator
- Gear replacements (Transmission)
- Keyless Entry Honk (Stupid Question)
- New Cefiro Headlights *Poll*
- help keyless entry oem won't work??
- Sts
- Rear Window Spoiler Pics??
- How long can i go with a leaking cv joint?
- Knock Sensor Replacement Question
- hacked intake benefits?
- how do i remove the clearance light(the one next to healight) ?
- Lost some oil.....
- Considering new supsension setup....
- how do i remove the headlight ?
- Dual Exhaust pics
- 00vi
- Show Off Time!!!!!!!!
- Disconnect alarm
- AC Vents
- Cryogenic Intake System
- Fog Rewire Issues
- Polishing the manifold and valve cover
- Is the 5th gen tranny a direct swap???
- Trans-Am Killer MAX
- Suspension recommendations
- Power Steering FLUSH???? HELP!
- valve cover leaking, anyone with experience?
- Axles
- Caliper Piston "tricks" Anyone?
- Windshield Wiper Issue Urgent Help Needed!!
- does anyone know how ?!?!?!?!
- Heated Seat Switch Replacement
- Wrong part or it's just me??
- Under dash neons
- HID mounting areas
- 0505 Cure me...
- Pedders
- Engine manifold taken off, but all fuel injectors test good
- ambient switch upgrade
- Front door speakers
- autometer Oil pressure sender
- How much???
- Cut shifter, and re-thread
- Should i get Stillen Hi flow intake or Injen CAI ?
- My New Max
- I got a Maxima problem.
- Brakes squeaks after coming to a stop
- I purchased a new max
- Shorten that throw
- Wiring Palm Pilot Charger to ACC.
- PLEASE HELP CAR not STARTING issue after window installation
- Bought the '97 Max!
- lip kit owners
- EGR code
- Here are the pics, thanks to bijangxe.
- tree on my car
- problem! sounds like i got a flat, but i dont
- Different clutches !!!
- DTM'ing the CE Tails
- 96 vs. 97 AC components
- Clutch break in
- Replacing Rear O2 sensor
- rear bumper gap
- 2.25 b-piping vs 2.5 is it worth it?
- How do you clean your engine like the dealer?
- Engine whistling noise- diagnosis
- Service Engine Soon light went on
- cheap drop, anybody have ideas?
- Alarm
- engine stop when idle
- Has anyone ever tried this Intake setup ?
- what difference would this make
- Adjusting camber
- Happy 4th of July!
- need some help here
- Did The Alternator Today Whoopy
- Where are the LED write ups?
- Front Strut Housing mod...?
- transmission
- Opinion On Seatcovers
- Which fuse is for the corner lights?
- NEW PICS!!! Illuminas, H-Techs, Enkei ZR-1's 18x8
- Pics - Need your opinions
- need new rotors
- which 02 sensor is which
- Door Panel is falling off!
- Quick, I need fuse # for tailights or lights
- For all those who have too much play in their steering
- Perplexed - Front Suspension Problem
- 97-99 b-pipe on a 95?
- instructions on how to AE mod corner lts...
- Diy on fender side markers???
- Bypass Valve Headache
- need opinions from people with either flowmaster or dynomax mufflers
- Tranny question.
- led mirror shells wiring
- Puttin the maxima on Ebay
- Fidanza Short Throw Shifter
- atf fluid
- disconnect tps
- How Do i Replace my Ignition?
- Check Engine Light on - Actron??
- People who have re-painted your car step in..
- Camber bolts/plates needed for Sprint drop?
- pictures of your muffler/exhust from under
- Keyless Entry: Need FCC ID for 95 Max Key Fob
- Interior instrument cluster lighting...
- Are velocity stacks REALLY necessary?
- engine misses at idle speed!
- ok those w/ magnaflow street series exhausts, step in or if u HAVE the apexi ws2
- How many of you use Royal Purp?
- wsp y-pipe still 160 shipped?
- led question
- No traction at the track problem
- Auto vs. 5spd ECU -- Differences??
- Service engine soon?
- closing in on 127K, time for new shocks?
- question about rim sizes and weights compared to acceleration..please step inside..
- Keyless entry
- is this the rare, quietest apexi exhaust? *pics*
- bose speakerss
- besides ebay and auto trader what other sites are there
- stolen bumper lights
- m3 vs x5
- How many miles per tank do you get?
- LED Taillight write up.
- [So] I drove a 6th gen...
- Anyone have 194 and 1157 led bulbs in corner lights....
- ngk copper sparkplugs
- Pics of springs on car
- Had the best day of my maxima loving life yesterday
- Need pics of aftermarket headunits with wood grain
- DropZone YES or No?
- Quick MEVI actuator question
- Changing door trim
- a bicycle smashed my car
- emblem question!
- Best Hood Pins?
- worried about coilovers....D2 problem
- Turn Light Off, Car Sputters
- stock 95 max -=vs=- 02 volvo2.0L turbo(stock
- freinds startin problem on max wrf is this?
- suggest a color..
- question about 00vi..please step in
- wiring and donating
- Another Max in the Family. A few Questions.
- 99 Maxima - Antenna Diversity Adaptor? Quick answer please
- 60000 mile service, need new link
- New Shoes
- tire size
- Symptoms of a bad brake master cyl?
- How many knock sensors do we have?
- Engine Valve Cover Seals
- any suggestions on a clutch???
- Updated interior :)
- Body Kit
- Dahsboard Gauge question
- ! Looking For Pics of 4th Gen Max's With Rota 16" Rims Please !
- 99 Maxima Buying Questions
- Smog woes
- Yet another alignmnet question
- Pics of new rims!
- Trimming Bumpstops/dustboots?
- Roof lining...
- Losing 100 miles per tank
- Need some help finding a Dash board
- Window Tinting
- Aftermarket Keyless Entry
- what's the best place to get swaybar links
- Can I swap an analog odometer with a digital odometer? Anyone do this?
- Emergency!!! Please Help!!!
- Bleeding ABS brakes- 4 connectors on actuator?
- show off your tint
- Help: AC Smells
- Car broken into...how much is it to replace window?
- another maxima with CE red/clears
- Keyless dome light mod
- Decisions....
- engine running RICH
- budget bs
- Motostorm Underdrive Pulley Question
- rear bottom out part
- Oil Change At 140K, which to use?
- White smoke coming out near the A/C compressor.
- going to install steering wheel need help..
- angel eyes on a max
- stupid little neighbors talkin **** about my car. kinda long
- Carfax Needed Fast!
- What do guys think of this body kit combination?
- Catback Exhaust, what do u guys think?
- loud screeching sound when turned over
- K-Sport Opinions
- Whats a good Cat-back
- How Hard Is It To Install The Cefiro Head Lights
- Suspension???
- pathfinder tb ques.
- horrible install of the y-pipe, story is long
- lowest price on SP2(i know repost x124 but help!)
- Do all max have a non-linear gas gauge?
- Y-pipe question
- Intake Manifold Removal
- Wilwood Brake Kit
