- I think i found a 4gen Turbo kit
- Value of car, opinions needed ASAP!
- Car wont start, something fried. Need help!
- LIM Bolt Size
- stall from a hard stop!? WEEEEEIRD
- Keyless Does not work
- Listen to this: Possible Wheel Bearing *Audio/Video Included*
- driverside fog light
- 96 max stalls rolling over bumps in neutral
- need little help ova here
- can anyone help me identify this problem my car is having
- Replaced o2 sensor--Check engine light supposed to go off?
- dash paint help
- Bumpstop trimming question. Please HELP!!!
- Help with buying at a dealership...
- Weird looking knock sensor
- Baking headlights, bumpers, and corners
- Weird humming/vibration sound?
- Toyota more loyal than Nissan?
- Dumbest, easiest to fix problem ever!!! But I'm a Dee!!!
- where did my clutch fluid go??
- 00vi help needed to identify parts on tb.
- Trunk will not open
- new help. instruction how-to REPLACE STARTER
- FULL custom LED manual climate swap ~PICS~
- Silly MAF question
- drifting?
- OBX Cat Back??
- Dash Cluster Lighting..
- Need advice, cylinder #1 misfire...
- Catback
- So this is what i get for stopping for ped's in a crosswalk
- Bose Problems
- Passenger Door issue.
- Finally done my engine bay
- 98' 5MT Overheating.....Highway Only?????
- Where is the factory alarm main unit located?
- Wheel bearing FRONT
- ECU question
- Are these any good?
- 2 concerns help
- front main seal help
- Intake manifold gasket
- timing chain tensioner
- will 03 maxima springs fit a 4 gen.
- I Am Going Insane (Parasitic Test)
- Tranny Issue.....
- I don't have windshield squirters!!
- HOW-TO: Install white LEDS for your AUTO Gear selector
- Check engine light code P1400 EGRC Solenoid
- Vac hose cracked/dissconnected. problems?
- Clutch Problem
- Adjusting my Clutch's Grab Point...
- Head cracked??
- How-To: Install AE Pedals + 350Z Dead Pedal On Your 4th Gen
- Broken Clutch Pedal Assembly
- Middle TN Meet!!!
- Rear Window spoiler (how do you stick it on)
- How much to fix AC?
- Rack & Pinion Bellow installing Bellow
- Tranny problem!
- Another mini project completed. custom passport install
- HOW-TO: Removing and Installing Exterior Door Handles (picture intensive)
- anyone have picrute of whats udner the bumper?
- Code But No CEL light
- why a 4 gen?
- Do I need factory camber settings with this drop?
- Shimmy Noise on Front Passanger Side...
- GI: A32 I30 CF Hood?
- 0102 MAF code, but it will go over 2500 RPM?
- NEW AXLES NEED ALIGNMENT AFTER???
- Removing Gas Pedal...
- clutch master cylinder rebuild kit part#
- Big 3 Upgrade Question...
- got alignment done. but what to do about the rears...
- 00vi help ....please
- Engine Removal
- Is silver carbon fiber real/good?
- 95 Se A/C type? R12 or R134a?
- Question about the R34 style headlights...
- Question on Maaco Paint Job...
- Anybody know anything about these gauges?
- Leaking Heater Core Issue
- Any New Developments?
- Why SAFCII over primative circuits?
- KYB AGX vs GR2s
- Please help big KS problem
- Dash Lights Are Out
- no air coming out of dashboard?
- prob stupid ?? EGRC
- need help/advise: car hesitates, will not idle or rev
- 99 GLE Knock Sensor
- Clock Not Holding Time?
- Removing AC Compressor
- In Dash TV
- Alignment Issues
- RSB puts more stress on suspension?
- This heat is a KILLER
- I NEED SOME HELP..QUICK HELP...
- Impossible to replace fuel filter? Especially with ABS
- Clutch Suggestions please!? SPEC sucks!!!
- Parts needed for rack & pinion?????
- How do you seafoam a car??
- handling FAQ?
- does anyone own a 5spd 98 SE CA spec?
- different kind of o2 sensor question
- msd rpm switch problem
- quick intake manifold question...
- weird accel problem
- blazt computer interface ???
- Now im F@#$@# Axle Replacement turned bad
- aftermarket catback, wtf????
- Jacking Heights required. Harbor Freight racing ok?
- Exhaust question.
- Is anyone running a non 99 ecu?
- Questions about fuse
- please need quick help on quick ac compressor pulley replacement
- Need Advise on Exterior modifications
- Time To Play... "Guess That Missing Part"
- looking at a 98 infiniti with 48k miles
- chrome maxima
- Passenger Axle seal
- O2 Sensor
- I GOT MY NEW WHEELS!!!
- starting problems(battery or alternator?)
- I have two question one has nothing to do with the other. One on KS and other on seal
- anyone know how to flush wiper fluid?
- Need advice, WRECKED my 95 SE
- ooops....
- Possible to throw off timing with an UDP install?
- Help with codes 0201 and 0608!
- HELP?!? I need spring isolators... TODAY!!!
- They dropped my tranny, STILL couldn't get the driver's side axle out. What to do?
- EverWear 3 step fuel system and induction system cleaning
- Trouble starting
- Need a CarFax report...can anyone help?
- 99 car/ 98 ecu/ high idle
- To Darkman looking for injectors
- Couple Issues
- Starting problems
- Anyone using autotap software on an 97 max???
- 99 GLE Terrible Mileage
- Getting noisier......
- The hazard button and rear defrost button illuminate when the parking lights are on?
- HELP...What is connected to this metal tube?
- good cheap upgrades
- Car shakes after 70mph?
- ok fine im sorry for the additude i just need straght forword answers
- Good improvement with Medium Brake Kit 5.5?
- Where Can I Get This Grille?
- Anybody seen these on a 4th gen?
- Trouble with A/C Unit
- Bleeding brakes!!! changed fluid... now no compression in brake pedal!! help needed
- Deer vs Maxima....( I lost)
- striped tails. $2.99 mod
- How do I take off the passenger side view mirror?
- New England Maxima Owners??
- Lowest times from a stock maxima??
- NWP Engineering spacers installed w/MEVI
- brake light cel....
- Cant get O2 sensor off!
- Never looked at a Y-pipe... Is this real?
- Car feels slow....
- Performance Fuel Injectors
- Timing Chain job cost $2,700
- Transmission problem?
- ECU TEST
- can't adjust rear height on coilovers
- Painting questions
- AC Want Blow on 4
- burned out dash lights?
- Clutch pedal question...
- Part Number Request
- Keyless entry not working
- Shudder in 2nd
- Tranny Help
- Exhaust fitment and quality questions
- First one who tells me what's wrong gets $20 via paypal
- Valve Cover Gasket Question
- spongy brakes
- Will these look good on white?
- gr2 with stock SE springs. anyone have this.
- stillen pop-charger......
- 97 black supercharged max, is it worth it
- LED license plate lights
- painted badges
- best way to red/clear tails, AE heads
- rpm gauge
- A pop and a shudder while turning
- air con problem
- A/C Clutch Disc Wrench Necessary?
- $850 - $900 for Tein Basic Dampers
- Tip of spark plug...GONE!?
- knuckles interchangeable? wheel bearing replacement
- is there a better strut bearing out there?
- fog bulb burnout issue??
- Maxima Gurus Please step in .... stumped here !!
- Starting
- Anyone have any idea what this might be? *vid included*
- the strangest thing that happen to my max
- camshaft pos sensor leak?
- lost the oil dipstick
- Replaced alty, now a/c doesn't work. wire on a/c compressor?
- Electrical problem
- Disassembling cylinder heads?
- Strange electrical fault
- axles, noise etc.
- Car "stalled" and would not start.
- A/C line condensation
- Best place to get an Alternator online?
- This is weird... three ribbed belt
- Brake light/Turn signal swap
- why can't I get this CV axle into the tranny?
- Switch placement
- Changing CV axles on 5sp - should I drain all the gear oil?
- how do i find a leak in my a/c lines?
- Summer project: 00VI swap. gathering all the parts. Have questions
- new y-pipe and cat, why is low-end dragging?
- Connecting H.I.D in fog lights
- annoying front driver noise
- Help changing PS belt
- Lateral link noise
- Front driver side suspension squeek w/ VID
- My soon to be I30t*Pics included*
- 02 Sensors
- the stealership that is nissan - my recent experience
- LED interior lights *PICS*
- Sound from wheel pissin me of!!
- why did you buy a maxima?
- squeaking in the rear suspension
- Are the R34 headlights any good?
- Any known mods for the maxima that will allow us to keep acc mode on without keys?
- Clear Tails Question
- Leaking Trunk.....any suggestions on how to fix this?
- OOIV swap help needed
- What are some good HID brands?
- Raising rear end..
- Comments on installing my UDP today.
- car shut off today when i threw it in neutral
- Ripped Hose - What's it called?
- Replacing axle seal
- Climate Control No Worky?
- 280 miles on a tank
- 5th gen mirrors install, need help with base
- Alternator R&R
- Clicking sound while cornering - but none at slow tight turns
- My right front fender is dented in...can I just swap it from a junkyard?
- 96 Max SE Oxygen Sensor and airbag questions
- 1996 GXE question
- B4 and after
