- Alternator?
- Timing chain kits
- LED turning lights
- Do i have intake spacers?
- Mystery Part - "white box" under dash
- odometer working on and off
- Weird smell when useing the turn signals
- 98 maxima se. How many wires on o2 sensors?
- I don't know how to make descriptive thread titles!!!!!
- 95-99 one piece headlights at ground dynamics
- Back windows tied into front windows switch?
- Owned my Max for 2 years. Now stuff starting to go. =[...And ? suspension issue
- brakes acting weird. First pump Low to floor, 2nd much higher?
- auto up and down on an 96 max
- KS, MAF, or something else? I'm stumped.
- Remote Program help - I'm not dumb I promise
- Just replaced KS..not bad. Thanks Max Org!
- Another new set of bumper lights
- 4th gen radiator supports
- Quick question about my tint?
- 95 maxima test and review...
- scoop and snorkel
- Gauging Interest: Billet 4th Gen Maxima MAF Adapters
- Problem with 1997 AC... how to determine Condensor as problem?
- Brake issue - Booster, Master Cyl or ?? Can't lock wheels up
- Lights not working???
- Suspension installation parts
- How do you disable the window auto-down feature???
- I want my Altima rims look more wider(offset))
- I'm ready to tackle water pump replacement...
- Water temp gauge
- How many O2 sensors have how many wires?
- Anyone ever seen a max on BBS RS's?
- averaging 12.8-13.2 volts on alt.. is this bad???
- Radiator FANS work but are not coming on!!!
- Need opinion on repair - worth it?
- Bad Battery, or Starter? Unable to Jump Start
- My Maxima in Super Street (pics)
- Bulb number puzzle for interior light?
- budget still around?
- Just changed engine and trans, car does not crank?
- Looks like courtesy finally has some MEVIs for sale
- Stupid Suspension Problems..
- p040 Code Whitch oxygen sensor to change?
- Just got my 5 gen muffler put on .
- Weird idle and sputtering issue ( Video's inside) Help !
- Big problem
- ecu for 99 in a bind
- Engine Mounts.
- Whos Maxima is this? Is he on the .org?
- 96 Bose problems
- Clutch system issues....mechanic ethics question
- Still have front end clunking...
- Electric turbo???
- Do i need an AMP. If i replace the rear speakers
- Need smog test advice...
- Worth It?
- What engine management werk?
- Quick ??
- Limited slip in non-LSD tranny?
- 98 ecu pin out
- Temporary rims on - spacers suck
- Changing valve cover gaskets, advice, suggestions?
- Bulb number for "Map light"
- Rough gear select (Drive)
- Anyone ever bought these?
- Performance difference with Exhaust silencer?
- Picked up a new gauge cluster.
- arm rest cover question
- unlimited cargo capacity
- anyone ever wonder what that Clicking sound is in the axle?
- Bye all, been fun!
- Auto RPM
- Knock Sensor Circuit Malfunction & p0400 Error Codes
- Exhaust Question
- Can't Explain blinking CEL
- HELP 97 SE BRAKES GONE NEED ADVICE
- Need help finding the TAM screw for RPM switch
- Hi-Way Blowout
- Does any one know of a nearly silent exhaust set up?
- Hardwiring Valentine Dectector
- 98 pin out
- Drop in MPG and HP
- Did anyone that just ordered a y pipe from warpspeed get this message?
- CV Axles.. what a PITA
- Having bolt removal problems
- P0500 and p0600, any ideas what to change first?
- Exhaust Help...how do you think this will sound?
- Driver windows rubber gear
- what causes starters to fail?
- Multiple electrical problems..?
- 2 years 2 Knocks sensors Whats going on???
- Knock Sensor SUCCESS!!
- Smoke from the steering wheel area when you turn the lights on?
- Great MPG!
- Need help with major problem $20 Paypal reward! Injectors not firing.
- Opinions needed! Best mods under $500
- Rear suspension problem...help
- Terrible time...
- Recommendation for paint job for Max
- O/D Light is OFF all the time
- vacum lines..help
- One last chance for this A/C !!!
- Lowered Even More FTL :( *pics*
- ABS warning light problem
- Map/boost sensor on 4th gen maximas???
- throttle body question
- piece of plastic under gas pedal
- A day early and $100 cheaper
- Loud clicking sound, especially when in gear - help!
- Fog Light Aim Question
- car keeps stalling!!!!
- QUICK STRUT ASSEMBLY?
- Doors locking automatically
- antenna suggestion
- Clutch pedal scraping
- Strut bearings and mounts
- Raxle Axles
- kek kuk,thats the sound
- Clutch Issue
- Help!!!
- 98 SE original exhaust calling it quits
- Blowing CV Joints
- hood question
- Does your Maxima do this?
- Car Stalling???
- Can anyone answere this?
- hard starting
- radio display
- Major torque loss
- kinetix intake plenum
- My left fender splash shield got ripped off nessesery to replace?
- at rpm shift points
- fog light bulb burnt out. changed the buld the light still dont work...
- Unveiled: Pioneer AVIC F-Series Car Navigation [PICS]
- Question about Superchargers
- Where to get red/clears 97-99
- Help with getting past fuel cut with EU!
- Odd rough running problem
- leak just before the cat, after y pipe install
- Am I crazy (trade I30 for 4th gen)
- Starting issues
- making corner lights orange??
- Fuel Smell in Vents
- HELP with suspension!! [stock]
- WTF- Goodridge lines don't fit my car, 99se
- Headlight question
- How do you get original keys?
- Photoshop Request !!!
- OSCAI - Plumber's CAI :)
- replacing starter solenoid
- Redesigning A32shop.com. Images?
- 4th gen in Dibs commercial
- Moog Sway bar links
- painted sawblades
- tokico suspension set up problem on 95
- WHAT WENT WRONG?
- Problem Shifting out of park! A/T
- Monza Exhaust
- Auto Shift boot installed. pics
- Maxima refuses to start
- HOW TO: Install the Suprastick V4 for your 4th gen
- I've read all the starter posts...
- Whats the deal with breather filters?
- darn airbag lamp flashing again
- strut install...need help
- 98 Maxima Day-run light dead
- Picking up new used car
- Any solution to the P0600 code?
- AE engine cover
- Maxima z32 300zx BBK Conversion?
- Bizarre electrical problem.....
- Another y-pipe question from me . sorry guys
- Exhaust install
- when to replace springs?
- quick question about a y pipe
- wierd noise when ac on... help pls
- 95/96 'Ebay/CE' Red/Clear question
- center console done! pics*
- Weird relay problem :(
- Quick question about engine bay cleaning
- Need help with pioneer install
- Need help
- G35 staggered rims. Can they mount without aything else?
- 96 5spd idle, stalling, deceleration problems
- My car wont start and I am stuck in parking lot
- 4th gen outside cab air filter
- anybody happy/unhappy w/aeroturbine?
- I need help with a hayden 401
- Factory Alarm and Intermittent wipers stopped working
- Overheating and weird starting
- Victory pipes on the max!
- installed new ss clutch line.....you guys must be lyin'
- Actor Morgan Freeman in a Maxima Car wreck last nite...
- suggestions about agx struts
- finally, it came in! suprastick teaser pics
- 5spd swap, shifter hits up against heat shield. what to do?
- cel still on?
- P0171 System Too Lean (Bank 1)
- ECU Code help
- engine stuttering... HELP!
- Steering Wheel CD Controls
- Air Ducts
- the best ingredients to black/clear tails
- Installing RSB- do I need rubber silicone spray/grease?
- have $3k to invest in a maxima sugestions?
- Inset rear wheels? Just curious
- question about coolant level check
- PIAA 2100 Fogs Installed (Pics Inside)
- HELP---Need to replace front wheel bearing....
- Help With swap in Dallas,TX
- $189 cefiros? ftw...?
- Monro Rip Off
- AC not cold after new radiator install
- Knock Sensor install on a 1999 I30t Cali Spec
- idle like a diesel??
- Cefiro Headlight Question
- Clutch and Flywheel ques.
- ENGINES SWAYS!!!!!!
- Painted SE 16" center caps
- What would cause abnormally high power steering pressure?
- anyone with conzult or similar here?
- replacing thermostat
- VQ35
- blinking cruise control light
- "Throttle Shock"
- SUSPENSION FOR AUTOCROSS!!!!!
- FULL EXHAUST
- MAXIMA BRAKING CALIPERS
- $600 suspension budget, option A or B?
- Warpspeed Lately?
- Looking at a 97 5spd
- Loose Sun visor, How to fix?
- 12k HID lights anyone have them? Legal?
- some help
- Looking for specs on a particular bolt
- Maxima starting problems
- FYI- new? smoked amber bumper lights
- Car will not start....no spark
- Its not the ign. witch or the starter
- No tail lights HELP
- intermittent brake issue
- CV Boot Replacement Time
- Leather repair question
- Speedo Problem
- Sounds system completely went out, head unit still works though
- where can i find a 5v source?
- jdm projectors ?any1 seen these
- ABS light goes on and off intermittently
- Heli Coil for Transmission pan bolts?
