- how to make fog lights be on without headlights.
- do i need it? ..cap
- Newbie quesiton about Ypipe
- ANYONE WHO CAN HELP!
- Replaced Belts and now there's a knocking noise
- very particular brake and gas pedal problem
- Whole car starts vibrating at 60+ MPH, plus shake steering wheel.
- Radiator does not fit
- 99 Rear brake/axle question
- 160k miles, should I replace springs, shocks, LCA, what about the ebay kit?
- Quick Question on Exhaust Gaskets
- Locked myself with keys in car while working on door lock Actuators - HELP no spare
- To Overdrive, or not to Overdrive?
- Front brace rusting out
- shudder on accel at low speeds
- Greddy ultimate
- After market coils
- Pulled the codes.....
- 5 speed conversion and abs
- Nissan and Infiniti factory service manual in PDF
- Simple Question - How to Remove Fog Lamp on 96 Maxima?
- door speaker "case" problem
- Tatanko's Christmas Thread 2008
- dead battery, where's the drain?
- I do believe this is a noob question
- Happy thanksgiving At Maxima.org
- Help! Car pulling but then straightens
- Heating problem and 02 sensors
- AG lowering springs...?
- transmission going bad?
- catch can install??
- Another security Q?
- How To - Install Headlights
- Drop Zone struts
- Maxima wont start after HID install.. Help!
- Car stalls, hesitates, after driving 25 miles and is warm
- Methods of securing OEM struts to FG/CF hoods?
- Ignition Problem
- A/C not working
- Racing Seats / Side Air Bag?
- Awkward gear shifting
- New C/V's installed / Loud popping noise + jerking under acceleration
- Ignition Switch?
- HELP!!! Reliable Mechanic in Atlanta needed
- VAFC II pink wire
- power steering pump may be going??
- Misfiring? Bad Gas? Any ideas??
- Acc. belt tensioner MISSING?
- Brake light lit
- H&R spacers
- How much should I pay for a ABS speed sensor?
- ruby pearls...almost extinct?
- brake problem
- Need your opinion
- my 96 black maxima i have some questions
- help me find my leak
- need nissan part #
- R34 Headlights run both High & Low beams at the same time?
- Parking brake sticks on when it is cold...
- Steering Rack - In Progress - Need Help
- My odometer and trip odometer just stopped working...
- Intake Resonator?
- Possible temp sensor issue?
- Help with Antenna
- Transmission Speed Sensor location
- Tail light problem
- 4th Gen Maxima Video from Nissan
- O no another retro.
- Quick question about my radiator
- Time to say 'bye'...
- need a car fax report. anyone
- Adjusting AGX's.....
- another "knock sensor" thread, but look!
- Got my Stillen lip kit today........
- gas smell at start up....
- symptoms of bad transmission
- mother nature meets the v
- Blinker Problems
- Antenna Mast no retracting - repair or replacements?
- Big Burn smelling at the WOT
- Great VID who's car??
- P0440 evap code?
- Which HID do you guys recommend?
- Exedy Stage 1 Overkill?
- WTB: 3inch exhaust
- Overheating and no warm air
- removing fuel pump?
- Would Someone Photoshop These For Me?
- Thinking about this car
- Weird Sound from Tire
- Weird hesitation and s sudden viberation
- Car doesn't start....HALP!!
- relay for turn signal and hazards
- VLSD vs. non-VLSD axle differences?
- late model manual tranny in 4th gen (possible swap)???
- PCV Valve
- ABS sensor is stuck. Help?
- would black signal lense look good>?
- Idler Pulley or AC Pulley Bearing
- ECU question ??
- WHO WANTS A CARFAX HISTORY REPORT?
- Fog Light Question
- clunk sound when put in reverse gear
- Starter Possibly?
- engine is smoking
- Anyone use 300 ZX rims on their 4th gen
- Oops, now what do I do...
- Lugnut threading problem
- Grinding noise after axles replacement.
- my little "build" need some help...
- LED Help and tips
- Do you have to cut anything when you install K-sport coilovers?
- VSS OD Blinking Problem
- OK what the heck is going on?
- 2000 Bose headunit fit/work in 98 SE?
- Re-wire the good one
- 2009 Calendar ready for purchase! Thanks Guys!
- Just to be sure...rack for 99 will fit 95??
- stillen lip kit price down
- Exhaust droning noise, not enough back pressure?
- USA Spec PA11-NIS iPod adapter
- FYI Guys... It's The VC Gasket Not The RMS...
- Will these 19"s fit the 4th gen?!
- Reverse Lamp switch in trans, help!
- projector fittment in r34's
- Mounting the ZUNE?
- Just installed front suspension (struts&springs), hearing noise, need help!
- Tire sizes
- o2 Sensor
- Good Mechanic in LV
- Repeated Injector Failure
- Looking to Buy First Maxima - Advice Needed
- Which fuse is for the driver's side mirror lights?
- looking to replace my Exhaust *advice*(*pictures*)
- Got a little rust
- transgo shift or reprogramming kit?
- code 0505
- WHY do I get 12MPG?????
- Codes, Codes, Codes
- Adding additional fog lights?
- Strut boot and bumpstops
- Wheel Bearing help (pics inside)
- Anyone else have uneven head lights?
- Lowering springs question
- trunk won't open
- cattman header question
- quality of megan lowering springs
- looking to get a 4th
- Grounding issue? Car starts, int. lights work, wiindows/radio/climate control don't
- ebay rack and pinion?
- Stillen Exhaust
- How to install 97-99 fog lights?
- DO NOT! I REPEAT DO NOT!!!!!BUY AFTERMARKET UNDERDRIVE PULLEYS!!!!!!!!
- quick dumb question on re-installing oem springs.
- Black headlights on ebay.....
- Bumper light help
- Size of the bolts for the air filter housing?
- Totalled my 97
- Final eBay Clear Bumper Lights Comparison Thread
- short shifter help? <<<Please Read>>>
- Just what you want to wake up 2!
- need help car want start
- About ECUs
- Change clutch now or wait?
- tighten your lug nuts!
- HELP NEEDED GUYS, car wont start :(
- electrical problem (hazard, rdefrost, and climate buttons)
- How will i ride on 245/45/18 tires??
- Suspension questions
- Car stalled when driving
- Washer fluid low level light... We have these?
- So apparently I have ABS?
- Spoiler Break Light
- Electrical problem- Help please!
- Need crankshaft position bolt size
- Mods NOT worth doing (9004 to 9007 conversion)
- wat model am i looking for??
- Ignition/Trans/or something else?
- Timing chain question
- Electrical problems?
- trouble starting in the cold/wet
- How should I clean my Rusted Rotors?
- Another Projector thread
- Corner lights dont get brighter when using blinker, Normal?
- Pioneer AVIC F-Series Navigation [demo video]
- Something new, Illuminated "MAXIMA"
- [IACV idle adjustment] What if the Throttle body stop screw is at its lowest setting?
- Strut/Spring suggestion?
- Clutch Slave & Master
- What's The Grade/Strength Of This Bolt?
- Backup lights dont work
- 00vi set up?? how do you go along about doing this
- Using a VAFC II
- fog light help!!!<<<<<>>>>>
- I NEED SOME HELP...UNDERDRIVE PULLEY?? HAVE AN IMPACT GUN?
- Your 2009 4th gen Maxima Calendar!
- clunking noise turning left, when giving it throttle
- ARE YOU FRIGGIN KIDDING ME?... Water Pump Bolt Sheared!!
- Strut mounts needed?
- MAP / BRO Sensor
- I30 headlight stalk fit 4th gen
- CEL Problem
- Alternator removal breaking my balls! Help!
- So...Is my diff/trans fubared? Clunking from right side under certain condtions.
- will a dead battery possibly cause a car to stall at low rpm's
- Engine Hesitate
- KYB and Moog strut mounts
- hazard light disassemble help!!
- engine stumbles, but only at low rpms, idles perfectly, no stalling
- Give Gas, she stalls....help
- sorry wrong post
- Intake leak...help guys.
- I keep burning out stock headlight bulbs
- Chain Tensioner Piece - Where's it go?
- Changing Gauge Cluster
- 96 GXE with 216000 miles
- ECU mods?
- Headlight Wiring Harness Upgrade?
- exhaust blue print?
- Click snapping sound when I push on door panel but not bumper?!
- Selling my max locally, Need advice on firm asking price. (pics)
- knock sensor question
- Water Pump Replacement Q - Coolant Draining
- Possible alternator problem
- vibrations - not the good kind
- they'll be bolts a snappin'
- just changed the clutch
- Window games
- Cost of junkyard 00vi?
- warpspeed y pipe? to buy or not to buy?
- $500 ecu chip = 50 HP on audi. anything like that 4 a maxima?
- Is this Bees in a can?
- Suggestions please!
- ks? tps? or tranny? or ???? issue
- Replacing LCA bushings without removing the arm from the car?
- Question about stiffness and blowing struts
- INJEN CAUSING HESITATION?
- please help!
- Instructions on how to remove Bose Head Unit?
- Wheel Bearings help.
- Moog strut mounts?
- Clunking on Right turns on front driver side wheel area
- E brake problems
- Help !!! my car is hard to start
- Please Help Me (MPG?)
- Steelies for winter
- what is this thing? pic in side
- All 4th Gens. Have Factory Alarm?
- One strut or two?
- quick question
