- Lowest drop on KYB-GR2 struts?
- Advice needed with installing new O2 sensors
- Quick Question..
- Slight steering wheel vibration on lowered max
- Heated Seats Question
- They stole my car
- Is this a good buy? (newbie here)
- I just got a little more serious about drag racing
- bumper lens question
- Rear Speaker Removal 1997 SE w/ Bose
- Clunk noise when turn wheel
- First time Swapping out Strut Springs
- exhaust question
- 1997 Maxima 5-spd parts
- Help me I'm havin electrical problems.
- I just replaced the knock sensor but...
- Nitrous
- wait
- Powertech 1002 / Budget Y Setup
- Trying to see if its a good deal or not
- Trouble taking my front rotors off
- From Pep Boys to the Dealer
- 95-96 max'ers or someone who knows
- Whats the word on Courtesy Nissan STS ?
- Valve float.....
- 18" lexoni crystal rims
- Clear Gauge Needles
- Fitting 95-96 exhaust on a 99...
- noise under hood
- replacing a KS
- What Exterior Mod next??
- 99 GLE Auto vs. late 90's V6 Camaro 5 speed. Who would win?
- My Car No Worky Now Help
- customed painted rims
- Tips for newbie 5spd driver?
- What are the Correct wheels for my '97 SE
- 0302 EGR Code thrown after New exhaust added. Input needed.
- Bose Sound system questions???
- changing oil pan gasket, plz help
- exhaust suggestions
- Lighting Questions
- need some help on this one
- JWT popcharger + Check Engine
- new mp3 player head unit..
- Those of you with KYB AGX's...
- Let's see your AE Headlights
- knock sensor not the problem??
- get the red out
- '95 Ruby Pearl Paint Color? (Pics)
- What about this, Heard it or of it.
- how much to change the trany
- My auto tranny has 120K will it last?
- Tint Job
- Knock Sensor
- Starting problems
- AT code help.
- need help wiring seats...guys with power seats or who have added them please check in
- My drivers side door lock isnt working....well kinda
- How/Where to hoist engine?
- I need help (engine problem)
- Intake Manifold Cleaning
- Poping out of first gear
- where to buy ngk copper
- GR-2/Maxspeed installed (PICS)
- stock muffler is rusting badly...
- HID beam pattern
- ATTN: Anyone who's done the 9007 conversion... Need Feedback
- Changed Knock Sensor, still pulling codes.
- VeN0m got a question about the ignition switch
- what type of after market fog lights do you have?
- VQ30DE high performance engine rebuild kit questions....
- where to find flowmaster duals?
- Axle and CV boot info needed.
- PLEASE HELP!!!!!!CAI question
- Clutch issues, please help! Do I need a new one ASAP?
- Help, Stalling Car, code 01 02 MAF
- Help, Stalling Car, 01 02, help me please
- Broke:( Tranny now so scared, what to do???
- PIAA replacement bulbs
- CD Changer
- my max failed inspection-help
- How much money Saved Since a Member??
- New Custom Enterprise Y-Pipe
- Do I need another alignment after swapping springs?
- Interesting Check-Engine-Light Issue
- Adding LED's to my speedometer cluster a few questions??
- Recharging Air conditioning
- Painting plastic bumper questions
- Does my y pipe sound normal?
- Rear engine mount, Is it hollow ? ***
- WTF! Maxine is pinging?
- How To's of Dual Exhaust
- Wheel Bearing Fix - what parts do I buy?
- Throttle body cleaning
- Rear breaks making noise only in reverse
- rear door pillers rusting
- Hypergounding Alternator...
- Need info about the rear brake piston.
- Do you like your Maxima's color?
- for daily, street driving, what RPM's you shift at?
- Abs
- 5spd Conversion Question
- y pipes
- '98 Max alarm keeps going off for no reason
- for those with OBX catback
- what does an exhaust leak sound like
- Code 10 05 EGRC Solenoid Valve
- GOD DAMN!!! Thats a lot of money
- Back WINDOW magically came down
- Pacesetter STS and third gear
- Winding sound until I put the clutch in?
- Can someone host a video
- Which CAI is better?
- just got my type II spoiler
- clock color change
- Types of tint
- Apex N1 Muffler SOOOOO loud!
- need help from someone with FSM
- check out my ride
- Parking Light Bulb quest
- steering problem.....maybe
- steering problem....maybe
- bleeding order for non-abs brakes?
- Fuel Filter.
- power changes
- HELP: E-brake is extremely loose after rear pad replacement
- Bypassing the fusible link on the positibe battery cable?
- How a Max is suppposed to sound (VIDEO)!!!
- LED question...
- Cefiro Headlights And CArbon Fiber Hood
- Clearance & Bumper Light options
- 99 Cali spec KS change on Long Island?
- Help. Weird Noise Coming From Transmission
- Causes of bad gas mileage?
- 99 Maxima SE-L SRS light blinking
- axles,CELs,Shocks &struts, and questions
- Pathfinder TB adapter plate info
- CV Joint Question?
- Recommended SuperCharger Kit?
- GXE/SE Front Bumper Cover Compatibility
- Finally fixed
- UNICHIP piggyback ECU for 98/99 Maximas available
- I give you my maxima AND 1,000 bucks! ... kinda
- Who has a 5th gen. 5 spd. tranny in their 4th gen?
- I need a grille!
- Replaced Rear Window Regulator
- How much should I expect to pay far a new 5SPD transmission
- a/c recharge
- E-Brake Boots And Auto Shift Boots
- Gear ratio differences btwn. 4th/5th gen. trannsmissions.
- Cost of 2000+ 5 spd. tranny to be used for swap...
- HELP!!! i got no tail lights...
- 95 Max Starting Problems... Again
- Bad noise when making a turn
- So I finally figured out what was causing some strange electrical problems
- Noise Wheel Bearings/Hub Assembly 1995
- airbags?
- homelink
- Engine code 0413?
- Best CF hood
- vi fixed...
- Car Vibrations *HeLP*
- my car idles at like 200 what do you think i should do
- PCV Valve
- Resonators...
- Simple Ques: Is Bank 2 the left or right O2 sensor?
- were can I fine a write up????
- How do you reset your ECU???
- 95 Motor Swap ???s
- New wheels = new problems? help plz
- ? about the air scoop leading to airbox
- Manual in another state - what bulbs in our foglights?
- Budget y pipe sound clips
- How to remove the rear spoiler?
- NEED HELP knock sensor code comes on but it says caused by another sensor?
- Guys, i need a how to for rear brakes
- Harlan's switch setting
- what to use to secure the urethene skyline kit to the body?
- lookin' at maximas and i have a ???
- What is "double clutching" and why would it be done in a Max?
- new max! budget!
- maybe 14's.. i hope
- Fitment for 98 Maxima
- Drives side door light not working!!!!?? HELP!!!
- Stealership said faulty O2 sensor in Front Bank 2. Is that left front or right front?
- Buying McCulloch HID kit -- anyone not satisfied??
- Climate Control????
- Why won't my car accelerate smoothly?
- 99 misfire code p0300 & P0301 COIL RECALL?
- Gas Issue
- Sprint springs
- changing odometer lights in 98 SE
- Where to buy new tranny
- Please don't flame me..
- i30 tranny in maxima work or not
- O2 Sensor Help : Looking for place to buy
- G/D on w/s y-pipe still going on ?????
- A/F Gauge Wiring
- mevi question
- New Pics Up Please Check Out!!!!!!
- Where to buy rebuilt tranny
- Just got dropped on Vogtland Springs!
- I rarely do this, but here are a couple pics
- Clearance/corner lamp rewire - overheat issues???
- Where did everyone use there grounding kits...
- best fuel shift points?
- Simple Question
- 95 Max Check Engine light, I reset it without fixing problem!!!
- Intake question...
- anyone got a good source for cefiro stuff?
- ebay fraud watch, AJDM is a crook, he sells Tien springs.
- OHG!!! Help Me
- Desperate need of help, 3m tape problem :/
- Where to wire an ignition turn on wire?
- Check out my projectors
- Tune-Up
- More details??? need advise...
- Clock Fix
- Axxis Ultimates Brake Pads (Not Metal Masters)
- NEW TRANNY""""Help""""
- Pearl White Paint Job
- nismo STS
- Code 1444??
- do you have 19" wheels on 4th gen?
- Knocking noise when I turn
- Spark Plug Ques...should it look so dirty?
- Oxygen Sensor
- Startup issue
- Can a Bad KS cause a code 0201
- Need some parts...
- Cruise Control issue
- Timing Chain
- Hmmm.. Alarm System...
- CEL Light
- Ebay Strut Bars
- installing autometer gauges
- buying K&N filter in 'Group Deals'
- such a rough start...
- ionic cf lip on 95max
- how much would u pay for full set of tires?
- Price of 4th gen Fog lights?
- Co2 Shot?
- So I got my car back...
- Anyone have valid link to the $15 upperintake pipe?
- difference between 95/96
- Question after Budget ypipe install
- CEL: EVAP canister purge volume control valve
- indiglo gauges
- Is it worth it to change my own O2 sensors?
