- Spark Plug in Oil
- APEXi NEO questions
- Front shock install question
- New springs
- Radiator support rusted out and fell off... :)
- '99 center dash hardware removal question
- place to buy alternator
- idler pulley, belt tensioner assembly
- alternator problem ?
- led's for gauge cluster
- loss of 1st and 2nd gears
- **HELP** on stock intake
- antenna mast position
- Is this motor mount looks ok ?
- Custom Consoles (ideas/pictures?)
- door handle variations?
- ABS code diagnosis help please?
- Lower Oil Pan Removal
- some one played with the idle stop screws on the throttle body :[
- bad battery?
- any suggestions
- Fidanza Flywheel:replacement parts
- So i made a lil boobooo today
- KinetiX intake manifold
- Does Anyone know how to contact Tilley?
- help with window regulator replacement
- transmission cooler
- Show Me Yer Grillz
- Need help with newer car info...
- 4th gen for Oct. MOTM?
- 95 bose headunit
- Anyone make a (Stainless) Test Pipe??
- power seat problem
- Stripped Strut bolt any suggestion HELP!!!
- Straight From Japan...
- Could cheap ground wires be making my car stutter?
- 4th gen 5sp VS 5th gen 5sp
- need some help with wheel bearing issue/mistake......
- Restoring the Max
- 2 questions about 95 bose headunit
- Left stabilizer link REAR
- No check engine light
- True?
- I just had a $400.00 car wash and wax!
- visor monitors
- New Head Lights
- stainless steel muffler>rusted hinges, will it rust through(pics inside)
- While cleaning MAF, I took it apart, the wrong way...??
- Head Light Wiring Problem
- Which wheels should I go with??
- The NEW LED Tail Light Thread!
- Anyone in Ma help install a exterior rear door handle
- Clicking sound
- V-AFCII - knock sensor circuit malf.
- P1336 - POS sensor?
- Air entering cabin while car is accelerating
- Trunk mat/carpet Dimensions
- Failed inspection
- V-Power, or Iridium
- GTR - Specs posted by Nissan
- Cannot loosen Power Steering Pump
- Question about o2 sensor
- Speedo Reading
- Anyone ever knew what causes the clock to go bad...
- creaking noise after suspension install...
- Maxima won't turn on... help
- alternator ground cable
- vq40de intake and goodies...on my vq30? !!PICS!!
- Second thoughts....
- help!!! de-k swap question...
- coil packs
- putting 2000 brakes on a 97
- Foglight Section Size Favor Help
- Jerky Car...Out of ideas
- bogging plz help
- Starting issue when hot.
- Spoiler clips!! Expensive
- Starting Issue?
- does royal purple oil really give you more horsepower?
- what size bulb corner lamp?
- My left rear door doesn't open....
- So whos doing projectors now?
- which rpm switch should i get
- Engine Stand
- ballasts and HID bulbs
- Sea Foaming
- Annoying and embarrassing issue...
- ECU ??
- Mevi help..again!!
- Water Pump Replacement Issue
- Hacked Stock AirBox Questions?
- Passenger Airbag cover is different color than rest of dash ?
- What happened to those Skyline style LED tails?
- have trouble w/ loose bumper lights?
- cleaning ur leather seats
- bad experince putting in O2 sensor and sts in
- Windshield wash fluid smell in the car
- Passenger Rear Door Sensor
- AnyOne Know anything about *UNDERGLOW*>?
- Need some help/question on these error codes I have
- 95-96 RED/CLEARS
- y-pipe talk
- Harlam rpm switch question
- question...Bpipe on my 97 what other maxima years???
- Power Locks Have a Mind of their own
- Dyno Pic Inside! Help find the problem and I will paypal you $40!
- 0302 code help
- Strange Sound under heavy acceleration
- TCS , Slip, CEL On. still can't fix!
- what are the symptoms of a bad cat?
- 97 Standard Maxima -- Starting issues. Electrical or starter, help?
- For those of you with leather seats...
- radiator question
- 2.5" exhaust tip on stock rear bumper
- VIS CF Hood help...
- Acceleration
- got in an accident, right fender crushed in.. need advice
- if my electric seat doesnt move...what could be wrong?
- cat gasket FYI
- Where to find a bung for rear O2 sensor?
- My front suspension is goin
- Need electrical help: How to diagnose bad connection?
- help full syn 5w-50 in my car SOL???
- removing rear window help
- Starting Problems
- Signs of a breaking clutch?
- E-brake
- MEVI rpm question
- alternator spacer ?
- NOT SURE WAS UP WITH MY CAR
- corner bumper light install....
- My moonroof is dead....
- NEED HELP WITH CODE
- who makes???
- O2 sensor question
- 5spd woodgrain trim bezel?
- Optimum placement to get a bung installed for a wideband
- Who knows locks?
- Stillen Sway Bar?
- Inspection time, need opinions...
- Should I start hacking away on the Sarona Rear Bumper ?
- Seafoam question
- Grounding kit
- Codes 1001 and 0908
- A/T ONLY: Who uses their E-Brake when parking?
- ok, new suspension but......
- Vac leak and wont run
- Add the OEM Spoiler
- Steering wheel vibrations over 70mph
- timing or drive belt question
- WIRING TO BOOST SENSOR (AKA INTAKE TEMPERATURE SENSOR)
- Wireless remote problems
- Exedy OEM or 5th Gen Clutch setup?
- Ebay is dead to me! (well kinda)
- Possible place to run wires to cabin?
- NEED SOME ADVICE PLEASE exhaust system damage
- window tints
- Maxima FSM available online
- I dont see a flat spot or anything..
- Gas smell
- MEVI activation using Emanage Blue
- trunk lip
- does anyone know??
- Headlight and Taillight customization.
- Udp+ Battery or Alternator? (longish)
- Center panel lights
- dek swap question
- my intake
- LED Boards For '99 tails
- price for the bearing job
- price for OEM water pump
- Lower Suspension Question
- What's this wire for ???
- engine mounts??
- Underdrive vs. Stock diameter pulleys
- Running Rough Issues
- How to convert 95/96 to 97-99 Front end??
- Questions on CODES 0705 + 0903 (related) and other random things..
- I swapped for another 97-99 trunkld for my 95-96..
- Upgrading headights from 9004 to h4
- Paint Codes
- Where can I get a black flesh grill setup like this on a 97-99?
- Need help on oem paint colors
- Somebody help!!!!!!
- Camber bolt/alignment help
- Any general interest in buying clear/red tails?
- looong cranks, losing fuel pressure??
- Helppp
- Cluster trouble
- doing a dek swap any tips??
- Need to know about which ATF to use, received no replies in Fluids and Lubs. Help!!
- Anyone using Mobil1 ATF synthetic in their Automatic 4th gen?
- MEVI Rpm Switch Question
- Megan catback for a '97---- Extra Sensor pipe?!?
- Squealing noise near starter area
- 97-99 bose speakers on a 95
- Ok...pulley problem....how hard to fix....(pics)
- Tint vs. Nightshades
- Can rear O2 cause EVAP problems?
- Program Sixth 6th Keyfob with 4th Gen
- 97 fogs in a 95?
- DIY Odometer Repair
- Strut replacement?
- Trunk Light fix!
- New Paint! v pics!
- Headers and Y-Pipe
- Suspension - Need Tokico Part #s
- wird noise from the tires
- Where is REAR Crank Position Sensor located?
- Decisions, Decisions
- Slight Shaking/rumbling randomly at idle
- fog light cracked
- TB butterfly valve alignment
- Opinions
- What's it called? Again...
- Brake Pads / Rotors Suggestions >?
- How much is OEM Antenna ?? $$
- Oil leak
- Tried to fix starter, noise did not go away!
- Running lean after complete exhaust upgrade?
- Codes
- 99 double DIN non-Bose radio = no worky w/o antenna?
- Bad Fuel Pressure Regulator?
- 3.5 swap!
- flywheel or no
- Black Bumper Lights
- brake jamming
- Help! With weird engine code light
- Y-pipe installatio guide (dont hurt me, plz!!)
- I need this part Number "purge control valve"
- Tornado Fuel Saver for the 4th Gen.
- auto shifter o/d ?
- Wind Deflector for sunroof
- Removing Door Panel
- Hood struts that dont blow
- Found why E-Brake light dies not come on (Pics)
- exhaust thoughts
- Steering wheel differences
- Where is the post showing a WOT switch?
- A heavy question about tires
- 4TH GEN. vs 5TH GEN. KEY FOB
- how do i swap 9004 bulbs to 9007's?
- Is this my IAT sensor?
- Security Code needed for 1999 Bose Headunit?
- megan racing coilover question
- Pic of where Camshaft Postion Sensor is located
- How do you tell if an AXLE is bad?
- Eliminate LED hotspots! Guage install!
- Rusted Rad Support
- so yea today my maxima got hit with a tree branch
