- 97 SE with clutch problems
- New shocks for old max
- I heart my transmission
- Quick question - Oil Pressure Gauge
- car alarm siren wired to stock alarm system???
- drop resistor mod???
- Too many code 34's lately!
- HELP!!! CELs ON, CODE "1105"
- Not again!!!
- punished my wheel on a curb
- Engine Resonance
- Rusty Exhaust Tip
- are all oxygen sensor brands basically the same?
- Mevi
- Best place to buy?
- Cattman exhaust
- Cooling Panel interest?
- 5spd swap HELP!!!!
- Heres to the good times
- Charging light??
- removal of molding around stereo ???
- Optima battery for '99 SE Limited
- I'm an absolute idiot
- To those that have done 5spd swap
- Rust on the bottom :(
- Needed - Strut Diagram
- foglight aiming
- * URGENT* Overheating Problem
- 9E000 filter design change
- OEM Motor Mounts are the best?
- Possible RSB rubbing issue...
- Noisy ac fan
- Large rims = axle and other problems?
- calipers
- midas ftl
- quick handbrake question
- Ball Joints
- well, it finally happened (5spd trans bit the dust)
- BBK Pro's.. step in
- strut mount?
- Electrical problem? Need advice.
- Strut+spring Combo question
- engine codes 0908 0103
- how does a bad knock sensor effect car? can it lead to shut offs?
- ebay exhaust - is this junk?
- Anyone know what this part is called??
- Pulley/Bearing Noise
- Do you think theses will look good on a black max?
- which light is the Maplight ???
- extra 26000$
- Ants in car
- BS Potenza G 009, any good?
- LED signals
- vq35??
- You guys seen these?
- Best Tie Rods?
- Uneven steering response, alignment issue?
- "Going Under The Knife"
- I bet none of you fools have this.
- headlight foggin up
- new fan resistor
- Horrible gas mileage < 17 (yes i read the stickies)
- Subwoofer Hookup
- How to get connector off knock sensor
- 95-96 red clears
- i give up. (95 cat 02 bung size) ?
- Wheel Bearings
- 3.5 Turbo?
- Evap codes 07 05 and 01 11
- low RPM's?
- Manual Transmission Seals and FAQ's
- wheel size?
- my LH headlight is not so bright as my RH side ! help please
- which coilovers are the best..
- Nissan Caliper ?'s fitting 11" rotors
- GLE rev limiter thing
- *Rant* (informative here and there)
- REALLY hard to start & no ECU codes thrown
- removing iacv
- LED Tails - taking it to extreme...
- does a lower temp tstat help?
- This is what I get for rushing..nothing too serious but will be costly..
- clear or smoked tails for sterling mist
- IACV Differences
- exhaust gaskets
- dang
- High profile tires and fender gap
- Code 09 03, 07 05
- Tokico Illumina-Dustboots
- Hestiation at 2000 rpm's
- Sunroof ratles when closed...fixable?
- ABS sensors
- Crown Brake Lines vs Goodman
- Car on the bumps feels all over the road!WTF?
- Engine Shutter
- Wheel Spin
- 95-96 All clear tail project
- Left turn signal light wire disconnected !! help ! PICS INSIDE
- brake question
- maxspeed springs..
- looking for 97-99 red/clear tail pics
- I shot some video today..
- Anyone got pics of z3 fenders on black max?
- replacement remotes
- Serp Belt replacement
- Help!! Car's Freaking Me Out!
- When did Nissan change out the timing chain tensioner?
- rear brakes
- Tensioner and Guide *Pics*
- normal compression 96 se
- Act clutch kit, street where can I buy
- Which Walker 02 sensor to buy (3 or 4 wire)?
- ..what I've been up to lately.
- CEL codes (P1446 & P0450) for EVAP problems, need help to pass inspection
- Replace/Upgrade 95 Maxima Suspension
- drivebelt adjuster does not loosen
- Thoughts on Exhaust
- Strange starting problem with my max
- need help....brake lights!!!
- How do I adjust my hood?
- Cattman headers/ypipe combo from CE.. Should I???
- what to look for in a 95 se
- sway bar link
- Sloppy suspension & steering..its getting dangerous!
- trunk lid question
- reset TCM or ECU?
- Few problems can anyone help?
- ??? on water pump installation....
- might buy a 4th gen.
- i need 2 front struts, want factory/stock feel
- 4th Gen ABS worth fixing?
- signal reset
- small bumper light: park to signal rewire -- front already rewired
- New Design for SFCs
- Anyone buy/have iPod adaptors??
- all clear tails?
- Stock shocks?
- 1157 bulbs
- 300ZX Calipers Vs. Q45 Calipers with Pics.
- tranny hard shifts...suspension related???
- Down Pipe brace
- Sway bar end link bushings nut torque?
- LCA Bushings Diagnosis?
- Can I switch O2 sensor harnesses?
- Rear Brake Job *Pics*
- air sound while accelerating
- O2 plug bolt specs
- Sweet maxima...BUT
- Blue Smoke in the morning
- Hey check out my cracked motor(pics)
- 4th gen max, low beam doesnt work, high does
- NJ Inspection...
- Longer wheel studs
- No Horns - Factory Security System
- One fine example of a custom 4th gen :yeahright:
- anyone know the dome light # ?
- LED car change over, I couldn't find this info anywhere
- help: oil on pcv valve
- Intake upgrades on auto max
- HELP Low oil presure light red is on!!!!
- Not Another A/C Wont Work Thread....Serious Inquire !!
- clip of me and friends civic
- quick ? anyone knw the size of rear axle nut
- How much 2 port n polish cylinders
- MAF sensor
- Knock + 02 Sensor
- Anyone have a problem w/ their trunk sinking in?
- need help installing shocks
- I can't search, so excuse me....transmission leak
- When I depress my clutch it sounds like an old mattress.
- Evap canister price..
- Which spark plug?????
- Stillen front lip install ?
- Maf
- 95-96/97-99 muffler question
- Datalogging
- Where to get 4th Gen FSM pdf?
- Y pipe removal problem (rust)
- Clear LED Spoiler Brake Light
- Were 1996 and later years OBD2? Is the 1995 model obd1?
- chrome shops in CT
- Raybesto brakes ?
- auto tranny hard shifting problem solved!!!maybe
- CEL bulb messed
- Squeaks and Knocking ,Go Away Please! Need Help
- Rear Brakes- AGAIN! how much $?
- blower problem 99se help 100 degeers!
- 0311 vacuum cut bypass valve..
- Best Radar detector
- Will 5th Gen Rearview Mirror (Compass/Temp/Auto Dim) work in 4th Gen?
- Turn signals will not work at all
- need help with removing something
- Ben's shock mounts?
- A/T solenoid
- Really annoying whining noise revisited (found TSB, need more info)
- A few motor questions
- To Believe or Not to Believe?? (Codes)
- Stock "Alarm"
- exhaust hangers
- Clock just randomly changes time
- 98 ecu on 99 maxima??
- mechanic told me platinum spark plugs are bad
- Wiper Help
- CustomMaxima + SCO Gripe.
- Would you buy your 4th Gen again?
- whats wrong with my clutch??
- idle speed
- idle problems & starting problems
- 271,000 mi and another radiator fliud leak. Help!!
- Are Maxspeed springs anygood
- Help with my 97max (grinding noise)
- 95/96 Cali Spec Maxima's...Chime In!
- well, my low fuel warning light don't work
- What's wrong with my dipstick?!
- Lights won't turn off
- Which tool for Oil Pressure Sender unit install?
- Where to install the oil into a new A/C compressor
- Weird noise
- auto tranny fluid
- Water Infiltration **Pics**
- My Maxima Idle's at 2000 PRM
- 1995 Maxima Cat Back Question
- old squeaky engine belts replaced
- RPMs Drop While Accelerating - Help Diagnose
- Repainting the max.....
- Steering drift?!
- About to order a Cattman FastCat...
- Help with codes
- Damn reverse lights, please help
- New Clunk/Pop after installing new suspension...
- do intake/exhast mods improve mileage?
- Question about Brake Torquing !
- Help with tranny removal...
- Big engine problem need help
- difference between 95-96 & 97-99 grills??
- Any 4 generation maxi use nxt for wax??
- Spring Seat Alignment?
- Ground Controls VS Springs and Struts
- Radiator Forms Crack
- How can i clean the engine bay ??
- cheap rotors?
- Steering wheel not centered
- Sunroof Repair
- ram air conversion kit
- Throttle Body Size
- washer fluid dirty, how can i clean reservoir?
- VW jetta Needles
- checklist for the track ...100 Octane gas?
- tire size
