- y-pipe power
- Vogtland Springs???
- life on stock Y-pipe
- Need a Good Exhaust Tip with Resonator
- pictures of broken parts!
- Clear Tailights
- What's the deal with wiper control stalks?
- How do I replace Hood Supports?
- rims or lower it first?
- Will 97 auto AC control work in 98?
- Complete suspension upgrade?
- Confirmation
- Heater Controls
- Short Shifter ?'s
- I know I know......
- 95-97 5 speed differential bearings problems
- Cold Weather start-up
- Improving gas mileage
- #1 and Freedom designs FSTBs at Nopi....
- Is this done during the 30k tuneup??
- HELP! Taking apart clearance lights, how?
- Guys, take a look....gained 20HP to the wheels!!
- Injen Intake difference between 5/98-6/98
- Gorgeous Weather in DC
- How do i adjust the headlights?
- What is this sensor on my 96 5speed?
- Where do I buy brake shims?
- Impressions on my OBX cat-back
- Is there any way we can get our maximas to handle like a New MR2 Spyder
- Question about fuses.
- 1) Cheapest/loudest/best workin intake...0303 code!!!!
- Fuel mileage
- How much did you pay to get your stillen lip painted
- Got 2 codes from ECU..PLEASE HELP!
- Bose amp?
- Intake/ popcharger
- front bumper conversion
- Brake Vibration
- Please help me wiht my air bag!
- Help W/ New Tach
- headlights on chime
- full synthetic or blend
- Malfunction Indicator Light
- Velocity stack
- good y-pipe? bad y-pipe?
- question regarding foglight wattage
- sound clips of 96 auto with my new intake
- RPM surge?
- Where should I mod, and with what tools?
- Wow..CAI for $50.
- disappearing/reappearing CEL..........
- Lifetime of VQ?
- Those with ACT clutch
- Can I program my remote myself..
- Cutting metal behind seats
- chrome gauge rings
- knock sensor question
- limited slip differential question
- valves knocking?
- blown fog light bulbs
- RSB Adjustments
- which one is the better deal
- Engine Lacks Power (From Haynes)
- Engine vibrates when....
- Clear Corners on Sterling Mist are sweet!!!!
- Sprints and Tokico Blues a good idea??
- 3/4th tails as an option for all the 95-96ers out there
- Top Speed
- How good are Nissan OEM brakes?
- question about brake upgrades...
- Car hesitates during acceleration
- Mesh inserts in the openings on the bumper...
- Fuel Pressure Question
- 95 exhaust..more mods?
- trunk lock and antenna...paint?
- Do i get CEL for Every............
- any news on the new budget y-pipes?
- does this really work?
- what rims
- NEW Intake from custommaxima.com
- Does this sound right, 02 sensor?
- Homemade midpipe
- ACT or JWT Clutch-Kit
- Need pics of mirror turn signals
- Whats your average MPG
- Changing PCV Valve
- New starter needed which one to get?
- New clutch?? where to look
- Can you help me?
- Charging system Problems
- KYB Dust boost.....where to order???
- cost of brake piston?
- Advantage to mounting battery in trunk?
- Write-up on Grounding kit??
- Cheapest place to buy Knock Sensor
- 100k tuneup and whistling noise
- Pictures of my SHAVED A$$
- Got Nissan dealer front brake job quote, brake job question?
- Front Seat Track Interchangeability
- What's up with Voxx Scorze and Discount tire?
- front right 02 sensor
- Instructions for belt replacements?
- best place to get motor mounts?
- Which Intake Should I Get (POLL)
- 350Z Centercaps on 97SE wheels ?
- 95 wheel alignment issues.
- Brakes squeak when cold
- Request from Russia. Infiniti I30. Need some tuning / upgrade. Please assist!
- knock sensor?
- Couple of technical questions
- Re: Grinding....Bearing Problem?
- Heavy clutch...need help
- Hayne's or Chilton's manual for struts/springs install? Which is better?
- Stupid brake pad question:
- ECU changes during model year
- I got into an accident got some questions
- Funny sound when I accelerate???
- Anniversary Parts: What does fit a 97???
- Progress RSB
- Crankcase breather and TB Cleaning
- HKS Intake
- For the people who did the 5 speed conversion...
- stupid maxima rant......long
- maxima studderz
- Goodbye, tax refund... rotors and a tune up. What do you think about this rotor price
- 5spd swap into a 1997 Model ECU question -
- remote programming
- Whats a good Performance Muffler?
- Full Exhaust? Staright Through Muffler? Static Sound?
- Trick trunk lid instructions
- loud racing noise at 300rpm
- Check Engine Light
- how do u re-wire the corners?
- Need to oil APC filter?
- suspension set up help
- 95-96 Red/Clear Writeup
- license plate bolts
- how to check airbag error codes?
- Stillen Intake (95 maxima)
- 95 maxima gle
- Strange stock shift boot placement
- Best Y-Pipe for the $$$
- MPG gets better when gas gets pricier
- Help! Factory Bose head unit problems.
- I need Factory Fog lamps?
- All 3 O2 Sensors go out at the same time?!?!? (long)
- I'm getting my 96 SE 5speed in exactly 12 hrs!!
- Trunk Leak
- Bad MPG .. Any Help??
- whiter/brighter cornering lamp?
- Best coilover system out there?
- What happened to all the Turbos?
- Keyless Entry problems
- 95-96 red-clear tail lights
- Keyless Entry
- Second thoughts about rear sway bar!?
- Uneven H&R drop? Why?
- 95 max parts swap to 97-99?!?!?
- MaximaRider going up my driveway
- is a AEM Bypass valve really neccessary for a cai
- Timing chain tensioner replacement
- Keyless entry (not programming :D)
- Will Anniv.Ed. Maxima knob fit 4th gen?
- Raybestos Quiet Stop Pads - Discounted
- where to buy engine code diagnostic
- repairing O2 sensor myself, have question
- What Kinda rims are these??
- More questions about purchasing 02 sensor
- HELP: car won't start
- FS: Rims, Body Kit, Springs, Shocks
- How much fluid will be used during brake line change & bleed process?
- When you purchase an 02 sensor
- I have 0 options in my 98' SE 5 speed
- Question: How to bleed clutch fluid?
- Any one with Rota Subzeros Please help!
- Need a new Fender (Front RIght) - Help
- Search for "0504"
- valves rattling.....
- rear brakes
- K&N Filter Number
- HELP! Clear Corner Problem
- SE with aftermarket fogs?
- Auto: having trouble getting into gear
- Light match?
- How to make your AUTO faster...
- Search Down, so Any idea about Engine Chirps?
- Will somebody do me a favor?
- Franken car arrived today, and was put in last night
- Nissan Accessories, Like a Trunk Net
- Replacement center caps and NO SEARCH?
- where can i find some cross an sloted roters?
- Oil Pan
- Tires
- I Can't Find The Screw On My Ecu!
- Opinions on Tokico Illumina's
- pulled some codes
- question: octane boaster.
- Replace strut insulators with new struts?
- Fast and the furious
- where can i get David L tail lights for my 95-96max **(red-clear tails)?
- Light flywheel + ACT = bad?
- Anyone with ECU upgrades?
- new hand brake handle cover
- touch up paint for wheels?
- Y-pipe removal problems
- the "other" alignment
- the "other" springs
- Fidanza FlyWheel Prices
- 5spd problem
- Plastic Cover broke!!
- How to make the gold shine again
- Where Is my Flasher Relay Switch
- Whats the best stuff to remove the adhesive?
- Tires (search not working?)
- 2 1/2 or 2 1/4 exhaust?
- transmission problem?
- ACT Clutch, my impression
- Airbag light, please read
- Those of you that have installed MEVI
- Stupid foglight bulbs!
- 1996 maxima 5 speed conversion
- Exaust Choking ???
- Leaving for 5-10 min. do you turn off the car?
- Side Marker Lights
- Turn Signal Help!
- How can you tell if a car has ABS?
- Car hisses...then dies? WTF??? Please read and help!
- Drop in K&N? Worth it?
- Changing a fog light is easy right?!! ............WRONG!!!
- Not sure which to do first!
- 99SE-L FSTB - 3rd nut won't fit - WTF? please help!
- Oxygen Sensor
- NEW PICS OF MAX *painted mudguards*
- Cut-a-Coil questions
- SE v.s. GXE = insurance difference???
- Knock Sensor specs
- H&R? Tokico? GR2?
- anyone mess with the "oil sender"??
- for franken hybrid air intake users
- mass aif flow sensor ?
- 0103 Engine coolant temp sensor
- OBX catback...
- Polarg bulbs...
- Cost of B&G Tranny Flush?
- Replacing Control arm bushings
- Any Pictures of Reflective tint on a Black max?
- 0201 code/SEARCH UNABLED
- alarms for 95 max
- Carbon Fiber Hood
