- MEVI/Summit issue solved
- legal illegal tint (many of u will like to know this)
- RACED: SL500 coupe
- PL solenoid regulator springs-shift accumulator springs mod?
- Where to get polyurethane hangers?
- 1995 Max ODB-l or OBD-ll
- Idle RPM.. and another q.
- WTF did I do??? BRAKE light now on.... Drifting involved
- Maxspeed springs... yay or nay?
- Haynes Repair manual question
- drop resistor mod switch Q?
- EGR malfunctioning???
- Whose max is this?
- Greddy SP on a GXE?
- how much for a trunk lid from a junkyard?
- new pics of my ride!
- What's a good rotor/brake pad upgrade from stock for everyday driving
- Ran MAx at the TRack
- ebay test pipe install sound?
- Aftermarket Dash Kit Questions
- write up:rear window switch led replacement *pics*
- HELP!! w/ diagnostic codes
- Check Out My Pics
- Shifter + e-brake boots
- Just a Random Question
- stillen exhaust?
- how does this door remote work
- air temp sensor
- **need help quick** ...installing indiglos...
- What's the best hyper ground kit to get?
- Differences between OEM and aftermarket Bumpers...
- How often do you clean your Filter?
- 95-96 headlights on 97
- got dim dere winders tinted :)
- front sway bar LINKS?
- 6th Gen 18's are on!! (PICS)
- MAF sensor problem.
- need auto tranny asap
- NEed help...
- Autometer Oil Pressure Guage
- Custom Catback???!!!!?? (pics)
- Messed up Harlan RPM switch
- going to use Seachem for the first time this weekend, questions
- stock se 16's to stock se 17's
- Brake caliper question...
- Recs on low maintanance intake
- Progress RSB from Cattman
- No EGR info in the FAQs
- Bad MAF? 0102 Error Code
- Question about gauge faces
- 95 Tach erratic
- Skipping gears with manual bad?
- Need help changing motor for power window
- where to get a radiator? FAST-by saturday
- need help, multi questions
- put back stock intake
- air filter size
- auto tranny mod??
- Foglights
- Interior Swap
- Clutch and Radiator question*
- check engine light question
- quick replies for magnaflow owners please
- brake pads
- where can i buy super white bulbs for my RED CLEARS?
- help me
- Nismo releases new Vq30DE head?
- spark plug gapping
- I need help!!!
- MAX wont start!!
- Greddy question
- cleaned battery terminals.. car startin weird
- Help my 97 maxima barely starts
- Removing the center console to install/wire new shifter...
- 4th Generation ! Trunk ! Shave?
- I30 auto-dimmer hook up?
- Would anyone be interested in a COMPLETE HID install write up?
- Cars with H&R's and MaxSpeed Springs plz post
- Changing Rotor and Brakes What Tools are Needed
- Maxima.org appreciation
- Orange Rotors...
- Knock Sensor
- anyone put a 95/96 grill on a 97-99?
- My car failed emissions
- RacingBrake TPM Rotors
- Painting Grille *to fake SE*
- Aftermarket Steering Wheel
- What is the deal with JWT cams?
- 98 Max Remote question
- Best looking clear bumper lights
- Question about seats
- Need Advice...bad injectors? Coils??
- Engine Coolant Temp Sensor?
- rear deck squeeking
- K and N panel filter question.
- Window rain guard
- weak stearing response
- VI cover...
- apexi exhaust!
- Blue lights in vanity mirrors...rice?
- some new pics
- rear sway bar question
- How many of you have a Fidanza Flywheel?
- wierd noise from back right wheel
- My slow car *Video's*
- need headlight housing
- Raising the limiter???
- squeal when engine is cold
- re engine codes
- my Hayden 404 just came in the mail. anybody else installed one on your car?
- B+G Reviews
- We need Carbon Fiber splitters.
- Good exhaust???
- I need vents
- bad KS + bad O2 sensor (slow response, bank 2) = SES light on
- Help and Advice on Changing Drive Belts.
- Shaking right rear wheel?
- Suspension Kit for EXTREMELY cheap!
- How many CF lip owners?
- How to transfer airbag
- Installed Carbon Fiber hood, lemme know what you think!
- got some new pic of my ride with a couple of new mods...
- Fidanzas don't fit on 1995????
- Has anyone successfully tinted their car themselves?
- what could be the cause, and fix, of engine "sputtering"
- Finally, misfiring problem solved but...
- Corner lamps on only when headlights are on?
- Climate control lights?
- Headlight swap
- Rear Brake Problem
- Top speed of 5spd?
- Bbk
- HELP! My late '99 is running rough
- car got broken into.....
- question about the GaS Millage Again
- how much for a brake job??
- What cheap mod can I do?
- Owners w/ Maxspeeds
- coils going bad or something else?
- clutch fluid
- How often are we suppose to change injen air filter?
- Code 0104 - Speed Sensor
- Questions...about B+G & Maxspeed lowering Springs
- iNSTALLING INDIGLO GAUGES
- Need Suggestions on CAI and Exhaust Pipe
- Ects
- blocking off coolant passages.
- Starting problems, acts like the battery is dead
- What kind of ATF do you guys use
- Major Water Leak Problem inside the car.
- Those with Big Brake Kits- what to do when u get a flat tire?
- HELP - axle/tranny oil leak 5spd
- Oil reservoir catch tank question...
- civic kid (idiot crap talker)
- HELP cannot put my 5-speed max in reverse
- What fuse does the power antenna run on????
- 300zx fuel filter part number confusion?
- Question about the corner/clearance lights...
- going to a 5th gen 5spd
- need help with codes.
- Anyone else's Warpspeed Y-pipe sprung a leak?
- Cleaning the Engine Bay
- car wont start??
- Springs and Struts
- 4x4 Max
- Where to buy H&R spring for cheap?
- maxima on chappelle's show
- Attention Mods:
- Life expectancy of O2 sensors & can they cause hesitation?
- Remote Window Down Feature
- phantom grip lsd?
- The GD u all bin waiting for!!!!!
- Question about different resonators, and Mufflers..
- Single or Double wall muffler??
- What do you think? ( Pics inside )
- Exterior lighting system is all messed up... need help!
- Who Has a Quaife LSD?
- A few n00b questions... please be gentle. :)
- HAI, eBay CAI, stillen, what to do?
- Big Brake Upgrade
- i finally got my car back and i'm so happy
- help. putting up a max for sale. how much should i ask for?
- frankencar midpipe fit stillen filter?
- plastic piece on side marker
- Any tips for a stuck oil filter.
- Source For Scanner Code Definitions???
- i just raced an m3 and...
- ECU Code
- Need some advise
- knock sens.
- Tint
- gap of NGK copper plugs?
- I'm goin away for 3 months, See everyone in September!
- trouble starting after maintenance
- please help locate wiper fuse
- Middle Eastern Maxima
- Is your MEVI switchover very audible?
- Is this normal???
- Questions about AE headlight mod.
- CF front lip
- california/federal y-pipe
- gas light
- ? on flex section on y-pipe
- Just received Trenz Grille?
- master clutch cylinder (how hard to change?)
- wow bling blings all over
- hacked air box worries
- air/fuel and water temp
- Removing buzzer?
- Muffler tip recommendations
- Projectors w/ Angel eye question.
- I'm now MAXLESS!!!...question??
- Camber adjustment for rear axle
- Stalling/Hesitating????????
- Bucket Seats anyone?...
- boring out TB or pathfiner TB swap?
- replacing brakes, need to assure sumthing
- SE Guys look at your engine bays
- car feel sluggish
- first axel replacement
- people who have done led window controls and dash lights...check in please
- looking to get quiet muffler...i'm sick of droning and noise
- Any feedback on Tein S-tech springs??
- fix motor or replace
- O2 Sensor Faults (right and left banks)
- Buying dashboard wood trim kit on ebay...
- KS and a 1999 w/TCS
- WTK "Ignition Signal Circuit Fault"
- WTK 1999 coil packs
- 4th gen cd manual?
- 98 Max Stolen Stripped Recovered...FCK!!!
- Maintence at 115K miles
- Can O2 Sensors go bad and not throw a code?
- Does anyone know about this exhaust??
- 96 SE Cruise Prob
- Anyone replace their MAF mass air flow sensor ?
- tranny rebuild
- Couple Questions
- Tack jumping around ????
- rear seat removal, need help ASAP!!!!
- 0111 CODE: please HELP!!!
- CV Boots Replacement
- Alternator replaced, Battery Charged, Now What?
- Whoever asked for 5th gen muffler videoclip...nothing special really..
- Does any beige max have this??
- How to UN-shave trunk??
- Installed Tok Blues & KYB mounts 5k ago - Now lots of noise over bumps!
- will this fit?
- Cattman Header People - Tech Question
