- 2002 Muffler installed...
- Bose code
- Stuff from an I30
- No coolant in coolant resoirvoir '97 with VQ35
- Swapping internals on a MAF?
- Rear Brake Issues
- yes or no?
- Anyone Have the CF HOOD from REDLINEMAX?
- black/clears?
- P0732
- Link to Ionic Dynamics Aero kit GD only 375, link inside.
- Has anyone tried to disable power steering?
- How to remove headlights
- Another EVAP thread.CODES 0903 & 0705
- compression & plug condition (pics)
- Horrible squealing from the rear.
- Painted Dash
- weird tranny noise
- can i make my 3rd brake light blink when braking?
- will this fit ...
- does wheel size matter when getting an alignment?
- Looking for smooth Idle
- Caliper fell off on the HWY thanks midus
- Would you sacrifice your whole AC for 400+hp/tq?
- high flow cat
- 1995 SE DTC0504 (A/T Control)
- suspension = neverending
- Does anybody know what size tap for the rear o2 sensor?
- Engine harness Q
- tranny shifts differently varying by rpms
- Need Some Opinions
- Low End Engine Noise
- Ok, replaced knock sensor and O2 sensor and engine light is still on?
- Camber kits
- Help programming garage door opener
- Would anything trip a MAF code?
- Flickering Alternator Light
- CEL came on tonight
- Replace clutch?
- intake piping size?
- I have a fog light with broken glass lens, any ideas where to get replacement lens?
- EGR Harness
- suspension question>?
- Finally buying my 4th gen
- Periodic Idle Drop... Can Someone Assist?
- heavy vibration
- write up for battery relocation?
- Car stalls out while driving need help ASAP!!!!
- my Brake Light won't turn off...help please
- Bodykit Paint Shop
- junkyard find
- Cold start issues on '97 with VQ35
- Fog lights fuses keep blowing..help!!!
- Did I get porked?
- Pics of CE's revised 95-96 red/clear taillights
- Think I have a bad passenger wheel bearing....
- Need Help For Great Handling
- interior leds??
- post accident advice- what should i do?
- Now an officail member of the 4th gen forum
- Why can't she just WORK!
- Now my O2 Sensors? What next?
- Just Tinted my tail lights...How long should i wait to clear coat them????
- Led Bulbs
- stabilizer links gone bad
- spark plugs
- Indiglow Gauges for 98 Max
- Ignition Coil TSB
- Airbag light blinking
- what is the most Quiet aftermarket muffler
- wheels
- wow i think its time for tires..
- shes allways wet
- Anyone w/ Illuminas and Stock SE springs?
- Hitting bumpstops?
- Can Anyone Help With A Governor
- Will a '00 VB fit in a '97 tranny?
- rear o2 codes and egr codes
- True Blue Interior: My LED Saga…ALL who have done LED interiors step inside! *PICS*
- Factory Remote & Strange Door Locks
- Passing Inspection With Mods You Wont Pass With
- Code 10-05 EGRC Control Valve
- whining noise in gear!!!!
- Leather Seat Conversion...HELP!
- max makin tick tick noise
- engine transplant
- What type of tires should I get?
- My car has a high irratic cold idle.
- Trunk Options
- Paint?
- Installing leather seats
- Pics of S-tech drop w/ 5 star 16" WANTED?
- question about newly installed suspension
- wheel stud and lug nut problems
- Turn signals dont work...
- Full cattman exhaust
- Remote trunk-release sticking!
- manual to automatic climate control
- What Should My Next Performance Mod Be?
- Anyone have experiences riding illuminas on the 5 setting on the front? good bad?
- Does anyone have pics of smoked tails on a white maxima
- Lighting
- how much stuff have you relpaced on your car?
- How long to put in new motor?
- straight pipe ???
- electical issues
- Touch up paint?
- Tokico Illuminas
- intake whistling noise
- Bank 1 Sensor 2
- Brakes Squeal
- pic of a nasty cv boot & short term storage question
- HELP quick! eyelid question!
- Bad TPS sensor?
- Need Help Bad
- Need Help With Safc2 Tune
- brake question
- Motor Question involving VQ30DE
- Dual Lights Movie Clip
- Y-Pipe question
- No Tach
- Do I need to take off the bumper to put on a fog light?
- Replacing struts, What bushings should I do?
- Brakes? Should I upgrade
- TPS question
- How do I get this *^&#ing driveshaft out??
- Wanted: Decent Shots of 4th Gens (preferrably night shots)
- *problem* my light bulbs keep breaking on me*
- EYELIDS ....step in
- Strange behavior
- 2nd gear grinding
- anyone want to trade a stillen kit for an ionic kit?
- cat bolt/nut part #s?
- AT fuild lines
- I have a question for the experts
- e46 Bi-Xenon projectors.
- Is my clutch or my tranny messed up?
- need pics of stock engine bay....asap
- CAIL or FEd Y pipe
- Overdrive doesnt kick in, light flashes wildly when pressed
- Clicking noise on drivers side when turning, NOT cv joint
- Heated mirrors
- CAI-done-Y-pipe back-done...what's next?
- Need some help with EGR & Canister Control Solenoid Valve...
- My max won't start
- Looking for a performance clutch
- Did I Get Ripped Off?
- Lightbulb Question
- need some help cars taking to long to turn over??
- Looking for more Lowend Torque
- spring problems
- OK Im confused...
- black mesh for the grill.
- redid my whole cardomain-check it out
- projector wiring help. please help
- How much for a body drop?
- Trunk Bulb application?
- Knuckles If You Buck
- Help with auto tranny filter
- !!!!!!!!!$20 Money Order for assistance!!!!!!!!!
- CLICK CLICK while turning
- engine oil in the spark plug hole
- car idles at 2200 somtimes
- new trunk lid
- Throttle Issues
- need help on decision
- Ceasars Chariot Dyno Video and #'s
- greddy sp2 on 99 maxima
- 1996 Infiniti I30 (VQ30DE assembled in 10/95) engine code P0136... O2 sensor?
- ARGH! Spark Plug issues!! help...
- Question regarding ohm meter reading on coil packs
- compression testing
- Burned out power window motor?
- how do you install a aftermarket gauge
- Where to get KYB Dust Boots
- Anyone port the stock intake manifold?
- Cattman Catback Owners - Lets see pics.
- Drilled/Sloted Rotors Vs Plain Drilled or Sloted?
- 99 Cali Specs, Nissan's First Attempt at VI?
- help w/replacing Katrina flooded SE
- Tried to open up Fog lights for Yellow Capsule mod=(
- Need new struts, need opinions
- vid clip of intake (cam under hood lol)
- Will coil packs or a MAF in a 2000 max work in a 95?
- Was driving then car turned off...
- Where to buy 00vi
- shift knob replacements step in....
- melting im meltingggggggggg
- knocking at start? step in....
- Fuel Pump Replacement
- Does Anyone in Mass Know how to install Cefiros????
- Grinding noise
- doh! did I get the right Spark Plugs???
- Who actually has the original tires?
- Your lock may be much easier to pick than you think.
- overheating?
- Maxima DEAD
- Replacing O2 Sensors?
- Is Pace Setter an alright exhaust?
- manuel tranny problem....wtf? :long:
- tranny question
- Bose System Has Problems
- Eating Up Too Much Gas
- my max is having trouble starting plz help
- MSD Ignition upgrades?
- Has anybody tried the "rust bullet"
- Y-Pipe, problem?
- Starting issue
- Rattles/knocks be darned! Where are they coming from??!!
- Still curious about splir fire Coil Packs
- FS: Engine...NEEDS TO GO
- Help ???
- SES/CEL code 0413 --P0154 -Not in stickies
- Question about knocking....
- Cutting Auto Shifter
- Heated Leather Seats
- Ignition Switch?
- y pipe makes screeching sound
- Walbro feul pump
- question to those who just received CE 95 r/c
- Shift Boot On Automatic With New Knob?
- Performance Brake Pads
- What can i do to gain HP
- Yokohoma vs. OEM for fourth gen?
- Question about Pulley vs Performance
- Help ASAP Y pipe
- How much wheel HP?
- Just got new brakes and my emergency brake is like super loose. What gives?
- help me out with my code.......
- bad relay?
- ABS light
- Rim Questions?
- can someone run a vin# for me
- Cefiro Install Help
- Spoiler Help
- Problem with Hawk and Powerslot Combo
- after 2 days at Nissan...nothing but a guess
- Speed Sensor Code
- Voltage and RPM gauge problems.
- 0135 02 sensor heater curcuit malfunction??
- will a 2000 mafs work on a 95 ?
- Harmonic balancer repair
- Quick tokico illumina question...
- Sarona Bumper
- any thoughts on installing an mp3 player?
- the weather's effect on performance
- Not another Intake thread!!!
- Parking Brake
- Exhaust Information Thread: (With Sound Clips)
- Where to put the speaker for alarm?
