- stalling problem what needs to be replaced
- OH NO! I put 1.5 lug nuts on the car instead of 1.25!!
- MAF problem/question
- Injen CAI or Budget Y first? (unique situation)
- How to run a wire from engine bay to interior...
- upper strut mounts/camber kit???
- RE: FrakenCar may just be in my head but......
- quick help with putting new wheels on. need info/specs
- Help! Sunrrof wont close!!!
- black guage pod in tan interior pics?
- Anyone want to see pics of the new Urathane Skyline Kit?
- Couldnt get my Old starter off...need help!!
- Pop Vs CAI
- 500miles or 900miles?
- parts...
- Budget B-pipe w/o resonator
- how do i get clock out
- Clutch safety switch?
- corner light problem
- Gas Mileage for full tank 1995 GLE
- Battery Question
- tires for 18's
- has anyone ever destroyed an ACT clutch?
- Detailing or new paint job
- Question about tire wear.
- exhaust poll
- NGK GP Platinum spark plugs?
- Frankencar questions...paranoia?
- motovational strut mounts
- Transmission Control Unit..HELP!!!!!
- can't get it up
- tranny.. what would you do??? -_-a
- Help a maxima in despair!
- knock sensor, Bosch or OEM ?
- 10 second max!!!! check it out
- power steering problems???
- Apexi or Greddy Catback
- Shaving the Letters off The Back of the Car
- Queston about Apexi WS and OBX catbacks...
- Budget Y-pipe, emissions?
- strut bearings for cheap?
- hazard and defrost button
- What gets the CRAP off my SE Rims??
- Starting motor without crank shaft belt attached? Possible?
- Adding an alarm beep
- MTEC Xenon bulbs. To Install or not to install?
- Suggestions for Catback exhaust please...
- help with BOMZ intake!
- Silverstars vs. BlueVisions
- Newbie questions
- Y PiPeS
- J-spec?
- Springs 1997 SE At Will Settle @ 1" Lower
- i'm still confuse about which spec of y pipe for me
- Light bulb blew up
- speaker connection
- Need help with insurance company
- Emission Systems Cleaning
- Looking for pics of painted calipers. All colors desired.
- Maxspeed spring interest
- Anyone have the Nokya Arctic White Bulbs from SW Autoworks?
- UPDATE on my 95 SE's MPG situation
- Is it safe to wash the engine?
- More fun for iansw 5-speed conversion project
- Left Front O2 Sensor - WHERE THE
- ypipe
- 180 km/h starts shaking
- Pics of my NEW 97 SE! :)
- JWT Pop Charger install problems
- Gauge Needles
- Can any schmuck with tools change exhaust?
- Wrong Fuel filter and PCV Valve ?
- 95 Plug Gapping? (GXE)
- Anyone have an extra OEM Tail (97)
- 9004 headlight harness
- How Do I Paint 95-96 All Clears
- New pics of engine bay
- Maintenance in Chicago!!!
- Interior chrome handles...Sentra parts work?
- Gas Mileage
- first post/pics
- Sylvania Silverstars, will they match PIAA EXTREMES?
- Problems with ECU Removal (i know)
- What breake pads do you recommend????
- Fuel pump shot?
- This is so funny
- I have a clutch petal problem
- Looking for people with Stock Maximas
- Trailer Hitch and Rear Sway bar...good combo?
- VI Installed. Working BACKWARDS! HELP!
- wrapping a y pipe? worth it?
- Rear Suspension Parts
- Headlight harness
- leather repair
- Need rapid response...
- MAFS bad? apexi air filter to blame?
- Indiglo Gauge Face -Install Questions
- brand x mid-pipe on ebay, hows it compare to frankencar?
- Lightbulb Help Please!!!
- Buffing: Good or bad?
- PIAA Xtreme White 194 bulbs in doors are a must
- Interior lights busted...............please help
- Do belts squeel if too tight, or only too loose?
- starter installation instructions??
- IACV related to hard starting?
- 95-96 All Clears
- KS for $1????
- How much HP from high-flow cat?
- 0503, 0304 -- Front Right Heated O2 Sensor & Knock Sensor...
- midpipe install problem
- PR Cai w/monsterflow filter...when should it be cleaned and how
- Frankencar Intake Problem
- ANY 1157's other than polarg??
- Blitz catback for the 4th gen maxima...
- How long did your knock sensor last
- Frankencar Intake
- why does my nissan not start?
- Help me if you can.
- My max getting old??
- Trying to find an ECU
- belts squeaking
- What Do I Need To Do To Lower My Car?
- K.S. replaced - great milage, horrible acceleration
- Who sells OE 5sp shift boot and ebrake boot?
- Problem: Engine Coolent Temperature Sensor?
- Do You Know What I Hate The Most
- !!!Help Me With My Timing!!!
- EVAP Sensor
- KYB AGX ADJ. for highways and city
- Can't find my color CODE HELPPPP!!!!
- Where to buy a new Brake LED
- Getting a clunk/groan from front end.......
- EVAP part numbers needed.
- Upgrades - ?
- Cheap Bastard! Spring question
- K and N filter recharge kit
- ANYONE WITH 17's please answer
- Volk TE37 - Should I buy these rims??
- any body BUY EBAY PIAA rated FOG LIGHT BULBS , were u happy with it?
- What line level converter do i need?
- How 2 remove metal clips from bottom air box?
- RAXLES.COM - any competition out there?
- best fog lights to buy
- Transmission swap questions...(urgent)
- painting rims?
- 60k Time...Opinions/Suggestions
- Car is choking when starting
- Replacing Courtesty light bulb???
- 99 Max GXE- HORRIBLE GAS MILEAGE! HELP
- Modding 95/96 trunk to 97/99 trunk
- Car Leaaaaans.
- What are the best 194 bulbs for the gauges
- fog lights blew out..
- Engine swapping
- Fuel Injector stuff...
- Just Got My Quaife
- For those of you who installed a ypipe......
- I'm not sure
- Rear Brake Lights!
- Headlight bulb color
- What Spark......
- Bose Head
- Chrome "Maxima" Door Sills
- Project Maxima / Hail Damage part 1 <pics>
- brakes
- Polishing valve cover
- How to read ohm tester to check knock sensor
- Just got my AGX
- Best looking pedals
- Best place to get parts online
- super white head lights
- 4th Gen Mods list
- my car is throwing 0304 code, please help
- Water pump nightmare (long)
- Is it easy to replace ignotion coils?
- Headlight Question
- Floormat post/tab?
- Y-pipe->2.5 Piping->Universal Ractive Spec V Muffler
- concerned with noise/muffler
- 1157 LED question
- fogs
- Those with gen2 altezzas
- VQ30 Questions
- Need a picture of altezza wiring harness
- Electric blower??
- Fluctuating RPMs when cruising down a hill...what could be the problem?
- What type of OEM brake pads?
- FIXED Rough Idle and Stalling ..finally
- Knock sensor?
- rims
- Would search...but...
- courtesy nissan's front strut bar
- URGENT: Windows not closing!
- MEVI hp gains
- please read and help me out
- Stupid newbie question:plugs
- Matching 97 SE Wheel Paint on Center Caps
- go to sale
- help me choose quick~~~
- Fog Lights on a 95-96
- Best brake pads for zinc coated rotors?
- O2 sensors
- Y-pipe installed..........
- How much for body work???
- Starting Car, engine revs up and drops
- advice on energy susp. bushings
- compression ratio
- What is the pupose of this part
- 95-99 rear e-brake problem
- Question about clutch
- Home depot intake
- painting my hood
- what type dome light bulb for 95 96 max?
- window swith LEDS (blue)
- 95 max, Vents let out heat for no reason
- exhaust, clutch, and suspension
- bad news from mechanics
- New suspension installed: now ABS light???
- New pictures of my Max!
- Encounters of the ricer kind
- More ECU questions....
- bad auto tranny??
- Muffler Poll...
- Car Show on Long Island!!!!!
- How much did you get on your belts?
- Performance ECU
- Wheels 17"
- Help, getting too hot for no air.
- MAK Energey Wheels?
- Stock belt part numbers
- What's the Highest speed ????????????
- 97-99 Nissan Maxima Front Bumper Cover New
- sorry guys another y pipe question!
- Anyone buy a Factory repair cd from EBay?
- question about converting a 5th gen eng. and tranny
- so cali org members help.!
- Budget VS WarpSpeed
- brighter corners
- worn out Springs and Struts
- 17" with drop anyone?
- NISMO parts for 4th GEN...
- Cheapest source for stillen intake
- anyone get the dual exhaust setup from CS?
- what setting for Kyb with Eibachs
- my car feels a bit sluggish
- Is this a Good Deal
- Just cleaned tb....
- wheel center cap replacements
- How do I remove my manual shift knob?
