- - Maximize Mileage -
- Brows Maxima.org Faster.
- Camber Bolts
- My check engine light keeps going on & Off
- No power to my power seat. Why?
- 90,000 tune up
- Se-r= Wow
- Hello to all
- starting problems
- Maxima got sick
- Updated "Higher Resolution" Pics
- 96 max, broken odometer, but speedo works fine
- how much can i sell my max for?
- Clear Corners
- Intake Idea
- Lowered my car and it wont stay aligned
- New Maxima w/ few problems PLZ Read
- need to contact kyb****help
- Afterfires are loud. Help!!!!!!!
- complete exhaust
- Aiming Cefiros
- tranny problems
- Gauge Problems
- Good deal for K&N drop-in filter
- KYB GR2 and Maxspeed owners
- back fire??
- Red/Clears, where?!?!
- Those who change oil in manual tranny, BEWARE!
- How Do I Find My Trim?
- apex`i ws / obx
- Oil Pressure and Water Temperature gauge install help needed.
- anyone have AIR BAG light blink before???
- Throttle Vibration around 2000 RPM. Anyone have any answers??
- Things to be done at 20k check up
- could relays cause start problems
- Day 3 with the 99 max
- DMS underdrive pulley
- bose speaker out (audio sec. can't help)
- engine cannot keep up with transmission
- ECU Code 1003 - Yes I read the sticky
- brake sound from front strut but it's not
- if using test pipe with o2 hole allow me to use sp2 on my 97 max?
- 96 maxima seat covers
- Interior Lights OUt
- Hesitation in upper RPMs.
- Loweiring spring installation - FAILED... help?
- Any suggestion is appreciated
- Any suggestion is appreciated?
- Weekend Kill
- clearance lights
- Random Vids - stupid, but you know you love them :)
- PCV valve
- Timing Chain Tensioner Issue, More info needed.
- Why does the front drop differ from the rear?
- Greddy sp and Y pipe loud??
- idle dips down whenever at a stop
- Is this a bad ignition switch? or starter?
- question about camber bolts
- ATTN: Those with KYB AGX/Progress Combo
- Need Help O2 Sensor Codes!!!!
- My baby is over the hill :(
- Indiglow Gauges
- Please help!
- Steering Wheel Vibrates
- any body have a write up on ps2 install on rear decK?
- Rear Speaker Install
- Cracking Foglights
- Need help for dangerous occurence on my son's Maxima
- Need your advice and some info
- Ripped off...$525...MS Member - 96MaxGLE
- 60K Service
- Ground Wiring Kit
- "STILLEN Style" Front Lip
- new CF hood for us! made by Aerogear...
- hesitation problems
- Crank Position Timing ring?
- Clear bumper lights?
- best Y-pipe?
- Headlight Questions?
- CEL every other week
- code 10-8, evap can purge vol ctrl valve
- Exhaust fitment issues makin me mad
- air conditioner noise
- Sticker residue.
- good deal??? confessed
- I need help with 2 codes.
- soundclips
- aftermarket b-pipe with super turbo muffler
- JWT ECU Worth it?
- Dropzone Shocks any good?
- does i30's(95-99) leather covers fits for maxima 95?
- eibachs and agx's installed!
- engine rattle
- Where can i find those shorty headers?
- Exhaust Cutout?
- Easy To Answer Noob Question!
- Redlinemax/custom Maxima
- led's
- Replace Max hood w/ I30?
- pics of lights after using kit from mdwholesales.com get the yellow out
- Link to taking the back bench apart...
- need shocks - where to get?
- Installed new shocks, Help!
- any of you maximas installed I30 autodimming rear view mirror?
- Foglights??
- Code 0302 EGR System Hi/Low Flow
- Questions on a Older 1996 Maxima
- Tornado
- AGX Struts/Dustboots..
- Good Deal????
- Help, code 05 05 AS SOON AS POSSIBLE, Please
- 2 strange things, clutch pedal and idle
- interchangeable engines???
- *pics* Sanded / Polished / Waxed my headlights (Yellow=ugly)
- Folding down back bench
- tach inop
- After Y-pipe install catback is way too loud! What are my options?
- IAC Valve Location
- where did u guys mount your HID ballasts?
- AE Headlight Mod
- do i need new struts if i lower my car?
- Need Help Asap: No Gears At All!!!
- Dynomax Muffler Question
- CF Trunk
- should i lower my car
- Rear o2 : Maybe I should just put a bolt back there ;p
- 60k mile tuneup is here
- exhausts
- CF hood options??
- 300zx brake upgrade and suspension install help ....
- transporting and storing a hood?
- cheaP ebay coilovers??? yes/no??
- better filter than magnaflow?
- greddy..obx..other ?
- K and N Cone Filter
- clearing taillights: too transparent.
- Need help with o2 sensor
- 1999 SE Starting Problem
- Intermittent high idle:1500 + on warm engine, temp sensor? IAC?
- Retrofitted headlight questions
- 60k service a DYI?
- Idler pulley replacement
- P0450 and P1446 engine codes
- Worst near accident or accident horror stories.....POST PICS if possible
- haedlights
- Any body know the coupling size for injen intake
- Another problem with my Indiglos...
- Painting Corner Lights. HELP!
- people with G-tech pro meter, how do u feel about the margin of error of this thing?
- Stock handling on Max
- does anybody have these?
- need info on frankencar or cattman cat-backs
- Stillen Lip ? For the DIY guys.
- Anyone ever buy a JWT intake replacement filter?
- OBD code 0600 Serial Communication Link Malfundtion
- Guages and clock dim instantly when hitting brakes
- How long do the engines last?
- I Bloody Did It!
- post accident repair pics
- Best place to get Catalytic Converter
- Finished LED tails. (Pics)
- tv's question
- keyless entry
- What are the standard features on GXE and GLE
- Suspension install questions ...
- Bright White Dome/Map Lights??
- FINALLY got my maxima
- HELP ME to get my back up lights work SVP!!!
- Rear View Mirror Upgrade... lol
- What indiglo gauges fit a 98 SE?
- Rear Anti-Sway Bar (RSB)
- Driver side CV install
- Up for grabs!!
- downstream o2 sensor
- could lazy O2 sensors cause code 0214?
- Questions about kits and radiators?
- My tranny is messed up local shop wants 1500 need help!!
- Can't check engine light myself!
- Strange ECU Code behavior. Please Help!
- Gas door doesn't shut....anyone know how to fix?
- AUTOLOC- st8000 shaved door handle kit
- My friends wrecked maxima
- Y-pipe installed/ only one problem?
- Want to Install Stillen V2 S/C, Intercooler, blow off valve, JWECU, all at once, help
- **VIDEO** - boredom and new dv cam combined!
- Looking for a rear suspension set up with my Intax springs!!!!!
- Just replaced tranny fluid w/Redline
- Flowmaster Muffler
- MEVI i just wanna make sure this is everything extra needed with the kit plz comment
- Where to buy spoiler clips and tint spray?
- ebay knock sensor
- What other places would normally carry gaskets?
- TEIN BASIC Coilover Kit vs. S-Tech w/Illumina
- hard starting- how stupid was I?
- How can i prevent my trany from failing???
- Ecu Messed Up?
- Oil Leak
- KS Repair?
- 18" Nissan Murano rims for my max! Got some questions!
- how would this exhaust setup sound?
- New KS....DOA???
- Strut Bar
- Rear Brake Lines
- does anyone have pics of their ebay intakes with K&N filter? Post pics please!!
- This has probably been asked...
- problmes with bose system on 97 SE
- Symptoms of bad EGR Valve
- help! need additional places to hardwired 12V devices (rices) inside my car...
- Replaced Alt., Battery light still on
- Question about the trunk
- Help? My doorlocks gone crazy
- What should I do?
- People with GroundControl colovers. HELP!
- uI have 165k miles, is it worp" my Max? Help!
- 30k mile extended tune-up, is it a DIY?
- PICS!!!! Finally have a cardomain page
- Removing tailights
- Any of you guys have experience with hail damage?
- Wheel Bearings Changed - Now Squeaking
- keyless remote entry question need help!!!
- storingm max for 3 months
- RE-Badging Emblems
- Reset ABS light
- new guy
- Terrible Luck Today!....Pics of car being towed.
- Front Strut Mount Gasket, where?
- Got 2 codes: 0510 and 0707 - question!!
- Can a bad motor mount cause engine knock?
- CUSTOM Plate Ideas?
- Help with car leaking
- Installation help w/ PIC
- should I replace stock fog lights?
- Scissor door
- 97-99 SP2 update***
- help stock intake - PIC
- Binding spring in front strut
- I finished me AEs....finally **56K DIE**
- Need help with remote entry
- Spark Plug Removal
- New wiring harness for lights
- security is screwed
- With a new KS i'm still getting 20-21 mpg
- Need some help replacing my antenna mast
- programming
- selling 1996 GXE...need to sell quick! best offer!
- $15 Upper Intake on a 4th Gen Max...
- headlight removal
