- ***APEXi WS<--- MUFFLER!!!, replacements?
- Got to drive a '91 Skyline R32 GTR
- Tokico Lowering Kit
- Blinking air bag light
- Rear Speaker Removal
- Ebrake Boot
- Where to Buy a MEVI?
- ~~ The FIX MY BRAKES THREAD ~~ *need some advice
- Clear Tails
- HKS exhaust
- ghost 0304 or real?
- i need a greddy WS replacement muffler!
- I'm concerned about my brakes, what could this mean?
- stripped the thread on a lug, how much to replace?
- mold in vents
- ohhhhh sooo sooo exciteddd
- my trunk
- need help finding the Intake Air Temperature sensor (IAT) Sensor
- Water in fuel or knock sensor? or other?
- Best combination for brake rotors/pads
- what do u guys think?
- lowering springs, air intakes, short shifters_which ones
- 97 maxima motor weight
- After rotating tires, getting alighnment done, and motor mounts replaced....
- Everybody CLEAN YOUR IACV
- intake question
- reverse indiglo gauges, chrome gauge rings, and led needles
- Has anyone replaced their motor? If so what did you pay for labor?
- Do u have this problem with alot of power and big wheels
- Loose Hood Latch??
- RedlineMax.com quality
- Bose Cd Changer Button for MP3 Player?
- tranny input shaft has alot of free play?
- how to change alternator in a 95
- Isnt fac spec on the KS 15-20 lb-ft?
- is 95 auto tranny same as 97?
- Check this out...
- Max wont start
- A good deal?
- Disconnected battery = reset ECU memory
- Udp??
- What settings do you have your illuminas?Fast Reply
- will this compressor fit my 99 gle
- For People with SPRINT Springs or Some knowledge
- Cut shift lever?
- Rear Wheel Bearing Problems
- High Idle
- AC stinks... how do i fix it
- Looking to buy a max
- just bought 95 clears
- illuminas vs agx
- Finally Got Rims on My Max!
- A/C compressor or belt squeal how to tell
- EGR Cleaning ?
- eibach + tokico illuminas
- 2 quick questions about Manual tranny
- Looking for a spoiler. which, where, how much?
- Manual Transmission (how long?)
- Leather Wrapped Steering Wheel?
- need opinion on shift knob
- Which aftermarket bumper?? And where to find it?
- How long does it take to my car get warm ?
- Need help with Tokico Illuminas settings.
- 6spd MT Swap
- Exhaust rattles? at higher rpms
- Type- S maxima
- Shift Knob Q
- Please - need 1 Kosei K1 Wheel
- Lower Control Arm Failure?
- Urgent. Horrible Tranny Problems !
- Here we go guys !
- Projector
- just filled my mounts with urethane
- Which engine
- after y pipe install, check engine light
- brake problem??
- Weird noise when i drive HELP
- What is best size tires to get on 15' Stock steel rims?
- P0440 Evap Emission Control system
- CustomMaxima released 95/96 red/clears finally...
- rusty trunk??
- Ouch!! My Babys Hurt...
- MEVI butterfly settings
- Are headers worth it?
- Eibach springs + Kyb agx struts good for ny driving?
- mannix car alarm
- Am i losing power due to a bad T/O bearing?
- already posted this in the boosted forum...but get faster answer here. buot a turbo
- MY 1996 MAXIMA 5SPD GXE (PICS LOOK! :D) <---
- Under Grill install (95)
- Rear GR2 + GC + Motivational Strut Mount Issue
- 17" 350z rims - acceleration equation?
- ENGINE UPGRADES? (several questions)
- Top Secret GT-R
- Axle Problem
- Who ever said that the AE tranny has a stronger 3rd gear?!?
- Suspension problems!!! Please Help!!
- Need Help Asap, Idle Problem
- Stickies-Troubleshoot EGR Problems
- Engine Service light on
- need help with smog fast
- Rotors and pads
- o2 sensor question (96 gxe - code 0136)
- Greddy or Cattman Exhaust
- what filter goes with the walbro fuel pump?
- ugh suspension trauma (coilovers or no..)
- Converting a 1995 Cali. Spec to a 1995 Fed. Spec
- experience folks with air system
- Paint available from Paradox any good?
- LOL ... raced for the first time and won ... see who I beat and laugh
- 96 Speed Sensor
- what are these devices ?!?
- UDP need some help...
- Maxima is no more...
- apexi w/s muffler???
- Brake lights not working
- Fogs
- Illumina's and H&R springs - Best source?
- nasty exhaust leak?
- alignment issue??
- How to get a CD out of Bose unit
- So I have this idea .. .
- adding to an incomplete wood trim?
- what other stock muffler (non-maxima) will fit?
- CVBOOT replacement
- please help me decide
- gauge lightbulbs?
- how do i check my coilpacks?
- Muffler Question
- KS checking, am I doing this right?
- The ultimate RIM!!!
- Question on the variable intake from a 5th gen
- LEDS in gauges help
- Uh oh... Bad Engine!
- coilovers
- what glue to use for nissan emblem on grille
- winshield wipers
- Breaks go SQUEEEKK!!! verrryy annoying...help!
- gas mileage gone, tried everything
- changing shifters
- Speedometer
- Y pipe install
- ECU pricing?
- Car overheating, please read.
- finally got some pix (56k warning)
- Read rotor removal how to ????
- New Wing Light
- can a s/c maxima beat a mustang cobra?
- Line pressure solenoid failure
- Anyone put Factory 5th gen HID's in their 4th gen?
- Car's not starting! Help Plz
- Clutch replacement..
- License Plate Frames
- Testors Candy Apple Red translucent paint
- Weird smell from car
- starting noise
- clear light bulbs for the overhead light?
- What Rev limiter are you using?
- pinstripe
- Exhaust systems
- Worst day ever
- Need a lightweight battery. Reccommend one for me
- what is HELLLA HORNS !
- Need help!
- faulty knock sensor
- My knuckles are sore from trying to punch..
- Pace Setter short throw shifter question
- My Wheels are Falling Off..... any insight?
- wierd control arm issue- i think
- Question for passenger seats.
- Temperamental tranny
- Factory alarm output
- KS install tip
- Got code p1400 what does it mean?
- how much would you pay for black leather?
- A/C work
- Weatherstripping around sunroof
- VB Mod or TS ECU
- Bolts for MAF/Airbox
- Traction bars for 4th gen
- Make some extra mod money
- where is a good place to get coilpacks?
- Somehow a camber bolt broke
- How many belts do we have?
- How to use the EGT gauge?
- Headlight Washers.....
- Help me decide
- Help! finding fuse for antenna
- Show me the mesh grilles for a 97-99
- AE LSD Trans into 4th gen - Speedometer issue?
- 95/96 Clear Tails coming Soon!?
- Wife just called with car problem, thoughts?
- Keyless entry reprogramming questions.
- Who else had ECU code 0702 ?
- gear oil?
- Coil Packs ???
- Front end conversion with or without foglights?
- Sarting problems
- Does anyone know if 95-99 I30t LSD axle will work in a 2001 AE LSD trans?
- Question about shocks and struts
- can we do this in the 4th gen forum?
- People with Gen 2 tails ! Check this out please
- Any 95 max with stillen kits?
- fuel pump or regulator???
- Cost for exhaust repair? For quote.. is it good?
- Windows wont roll up
- Car is kinda jerky and kicks back
- walbro fuel pump install
- Maxima Logo
- tranny problems are back !
- DC Clear Install
- Relaying a question from a .org member
- Polished ( CHROMED ) Valve cover and Intake Maniforld.
- rain causes strange happenings...?
- Key Value sucks
- custom maxima short shifter
- Lets hear it for progress! ...K-sports, headlights, maintenance...
- Rear Lights Won't Work
- Need Help! Car bucks and stumbles while driving...
- Service Engine Soon! KS
- How did you fix your 702 code?
- Who has a fifth gen exhaust.
- Knock sensor question
- Nice Ebay item
- NiSMo accessories!
- I need help fast!!!!
- Best Sparkplugs
- Limited slip diff....how to tell???
- stupid question...
- clutch slipping?
- Redlinemaxisajoke.com
- Sway Bar Bushings?
- steering wheel install
- tranmission flush
- no pressure in clutch pedal
- Question
- Warpspeed cat back exhaust
- Clear corner lenses
- Look for those powder coated lug nuts.
- Oil
- optimal shift pt
- Looking for the exact part number for the Gates Alternator belt used with UDPs
- Camber issues
- check light on and off
- DIY time
- Hissing sound from under the car...
- airbag lamp, no rhyme nor reason
- brakes grinding question
- Turbo Max
- Lookin To Sell My Stock Steelies A Few Questions
