- Simple Request
- ignition switch fuse keeps blowing...
- ?95-96 front bumper mod. (cutting valence seperator)
- Where is the PCV valve?
- Why does my car eat axles???
- bushings
- Friends car has problems
- Dont know what CEL code is
- which one is the parking light wire?
- The Ugliest Maxima Ever
- what are the best mods to make an auto faster
- Blitz sus air filter?
- Weight of these OZ Hydra wheels?
- aftermarket horn q
- Code P1105 Maufacturer control Fuel/air metering Circuit
- Anyone running 10mm spacers w/ out extended studs?
- security light question 99 max
- ECU code 0111, EVAP problem
- after market wood dash from ebay
- Trans Vin Number
- A Hiss Noise comes from the Rear end of my ride
- What do u guys think of this Max
- weird vibrating
- rebuilding maxima
- Lower Intake Manifold
- car wont start, stuck at work
- Hours of labor for an axle change + STS install?
- Finally got car back. Got Q's (Mevi)
- This Sucks!!! Got code P0136 and P0139!!!!
- Block Heater
- got another suspension question
- need new rotors and pads
- Hard to replace turn signal?
- Tranny question.
- Fog Lamps & their Durability
- need help - brake, battery & ce lights
- ypipe + Cattman b-pipe + Stillen muffler -how would this sound?
- Power steering fluid leaking
- Might be leaving the 4th gen Family...
- Quick question about sensor
- ypipe problem...56k warning
- Was bored, did this...
- Please post pics weather deflector pics...
- difference between ES andSE model??
- Ignition Coils from Autozone
- Bose system problem. Please advise.
- Pictures/Dimensions of SFC's??
- can i get a outside temp display?
- Getting new shocks
- Clicking Noise - Front driver's side
- CPS (ref) wire harness help.
- oil drain plug wont come off for the life of me
- O2 sensor replacement
- '99 Max coils: What and where to get?
- ***Need more Help Quickly***
- goo gone on the dash
- couple of questions...help please
- called a junk yard today; 95-96 and 97-99 fogs are different?? T of F ?
- Shifter bushings
- What is this s-foam thing? pics
- Questions about Coolant Flush and 60K Service Status
- VB Mod - SES light?
- Mevi help one last time.
- Passenger side clear/red tail, fog mount brackets, and PIAA 1156's
- extra Pre-cat on cali spec cause prob?
- ***Need Very Fast Help. . .****
- if replacing auto shift knob with aftermarket one . ..
- No residual fuel pressure...already searched...need advice.
- Slow Power Window - Suggestions?
- Found out why battery dies everyday, what now???
- Experience: Raybestos & Brembo
- do you have a green max and carbon fiber hood???
- D2 Coilover question: Does this look right?
- Got a carbon fiber hood today and weight of it.
- Kinda fun video...
- antenna replacement????
- Just ordered M bumper
- 97-99 trunk on a 96 maxima?
- ****Heated seat swap question****
- sound when turning
- Turning radius
- help, my car wont start.
- Filler Bolt on Tranny.
- what website has carbon fiber hood for the cheapest price? i forgot ionics website
- Electrical problem in dash
- cv boot/alignment question
- My Friends Car Won't Start
- Front brake piston seals
- those who have done projector retro
- Hot import Night in AC?
- Need New Front Rotors
- Swapped Auto trans now Ingnition Fuse blew
- KS changed in record time
- Auto 95 JWT ecu rev limit work on 97 5spd
- mileage improvements with ram/cold air intake . . .
- Tail light goop and other light question
- Odometer question
- 3.5 05 intake on a 95 Will it work?
- TRANSMISSION (locking or non-locking)
- BOSE stereo from 99 maxima to 97 Maxima
- Starting Problems
- OT.....free carfax???
- REQ: Speakers for 97 Maxima SE BOSE Stereo
- Rebuilt tranny problems
- Tooling the Driveshafts
- Changed my brakes! WooHoo!
- Question about rims...
- LED Tail-lights
- can i just throw xenon bulbs into my stock lights and have working high/lows?
- used car parts?
- sprint springs or tein s.techs
- Stillen Cat-back Exhaust 97-99 Maxima
- Taillight options
- High RPM's when in neutral???
- What forms do i need to transfer ownership (NYC)
- IAT sensor = hard starts?
- I need some code help...
- New sig pic...but
- Turbo Or Supercharge?
- Another Hit And Run
- Fuel Pump
- best head light/sidemarker replacements
- shutter at hwy speeds?
- Need help Please!!! AFR gauge
- How hard is it to take out a Engine harness ?
- Replacing Rear Struts...
- courtesyparts short shifter
- Caught on fire?
- light weight under drive crank pulley
- g35 skyline
- Bored so . .. whos got the most kickin bumps?
- ECU Codes, something that was covered but I couldnt access it . ..
- Y-pipe install...
- Is your ride comfortable?..no..well maybe its your air pressure..
- driver's window...won't go up quickly??
- Can anyone change my Knock sensor?
- Weighed the Chariot today "97 Maxima Se"
- Here's a video of me vs. mevi/jwt ecu equipped Max
- grounding kits
- Outta ideas, What's wrong??
- I can not change volume on my 97 Maxima..
- flex section broken
- Whats wrong w/ my car?!?!?
- two air filter intake?
- Boost Sensor
- Custom Front Lip
- HELP: Fuel Injector O ring
- Shift lock
- So lets further evaluate the RSB...
- rapair or replace exhaust?
- How to fix air horns?
- So sexy when she sparkles...
- Wheelskin
- Help: My cousin screwed something up on my max
- who caries flip top trunk kits
- With Tein-S
- SS brake line Q and brake system questions
- Changing spark plugs
- Oil pressure switch $$$!?!
- Another set of calipers bite the big one
- vq35
- H-tech on stock struts
- how to mirror polish engine>>
- crashed my max, need help with a vq project
- 4th Gen Maxima Diecast Model?
- Horrible 1/4 times
- Parking Brake Problem...Need Help!
- New rims and shoes! :)
- Driveaxle/hub Nut Loose
- Otto Racing FSTB..
- I Need A Photoshop Please
- realize theres another cat conv thread but need ur input
- Window won't go down
- 95 Max owners: Anyone had problems with stock alternater??
- Horrible jerky motion while driving (no pun)
- Help I'm Really Worried About This Noise!!!!
- Fuel Pump
- TPS settings recommended for 1996 Max.
- Spark plug heat range question
- Lower control Arms
- ODB II scanner
- Stock Catalytic Converter
- Does anyone have pics......
- Wtf!!!
- agravating problem
- Chariot Speedometer video - what is going on ?
- High pitched whistle?
- 4th gens with g35c 17"s - Quick question
- Tint/Smoke side markers?
- Good job NIssan on front marker lights
- How to clean hard-to-remove crap from rims help!
- flip flop trunk
- 4th Gen (95-99) Carbon EFX Carbon Fiber Hood - Interest check
- Clutch... not working...Maxima sad...
- I need instructions on how to get the alternator out of my 95 GXE
- heated Seat switches
- Engine making noise in 'on' position...
- Need Help Fellas: Car Idling High
- 6th gen rims on a 4th gen???
- will a FC intake for 5.5gen fit 4th gen?
- Catback Exhaust System
- need suggestions on a frotn bumper
- knock on startup
- read somewhere EL/indiglow gauges burn out quick, true?
- HOW To disable traction?
- Mevi??????
- fog light help please????
- Any Recomendations?
- Clutch Assembly
- when to replace pads?
- Headlight assembly removal?
- sunroof mods
- cf trunk and stock trunk weight savings
- where to buy weather strip
- are aluminum dash kits ricey?
- Tranny Rebuild - for those of you who have done yours
- Questions about Gaining power
- Traction control
- some bad knocking
- Replace Starter, Hard?
- where did everyone buy their H&R springs from?
- lol this is bs
- What am I smoking?
- car sat for 1 1/2 weeks and bat is dead???normal
- 9004 to H7 bulbs
- SES light on after engine repair
- Reasons for weak idle....
- Aftermarket Tensioner fittment
- anything else before installing new suspension?
- HELP!!!!Lost lug nut key
- What is the base white in QNO pearl white
- Tein Basic coilcovers
- Battery or Alternator? help..pls
- Help Please!
- Stainless Steel Clutch Lines?
- m45 SPORT rims?
- HELP! Where does this hose go?
- Ahh! D@mnit people piss me off sometimes....
- Anyone install Yellow Capsules from HIDTech.com??
- no power
- S-Techs vs Eibachs
- wat would cause a ks .......
- Help With Tires
- Tail lights
- Hi Flow Cat Question
- PCV Valve?
- help, in garage now, where is my pcv valve located
- got a 97 interior free
- 4th gen headlights?
- jerking/hesitation @ idle
