- pcv valve jiggling??
- modifying Ebay Cais
- Hi-flow cat?
- WTF more tranny problems
- Help-a-noob out? y-Pipe/exhaust questions
- Chrome Exhaust Tip
- Getting the clock bezel off
- tein springs
- How much do you love your maxima?
- taking off headlights
- Accident!!! Worst Day Ever !!!
- Cylinder 3 missfire after changing plugs
- Anyone use Motivational Rear Mounts?
- Anyone have a custommaxima y pipe??
- Painting Calipers = Squealing Brakes?
- OBDII code scanner/sensor monitoring
- Bose stereo lights are out on my 95
- Tachometer going CRAZY!
- Makoto Bumper Lenses Off Ebay...
- New York State Inspection Receipt
- EGR, Exhaust Leak, and O/D
- 99 DIY clear mod EMERGENCY question
- What about these coilovers?
- BOSE stereo questions
- hyper grounding....has anyone made their own kit?
- problem changing ATF
- Need help regarding coolant leak
- loss of power :(
- Help Starting Problems Same old problem need new idea?
- "CHINK" noise over bumps
- This damn CEL light.
- Porting the intake manifolds a good idea?
- knock sensor fail....negative effect?
- HELP with FSTB install
- 99 C/C And Radio on 95
- transmission problem??
- Starting Problem
- 9004 100/80w need harness?
- Is It Just Me or...
- Changing a pcv valve
- Torque specs help
- Another gas light question:
- help. am i right and if so....?
- Trenz Grill...
- spring and strut recommendations
- 96,000 Miles?
- Headlight rwire
- Glow Gauges
- Hid
- Looking for website that sells...
- tube off stock intake scoop?
- Cattman CAI vs Place racing CAI???
- Clear cut bumper lights
- Taking Apart Headlight in a 99
- Araffios car got robbed!!!
- fastest/most hp max on the org?
- Performance CV Shafts
- Upgrading 9004 light bulbs to 9007?
- CEL, 1003? PARK/Neutral Switch?
- AGX Coilover idea?
- Night-time pics
- front bumper
- new exhaust and clears
- Are 97-99 lights interchangeable with 95-96 tailights
- "SE" emblem on 4th gens
- aluminum brushed kits
- Apexi WS Catback w/ which y pipe?
- ECU Code 1207
- Problem with Indiglo gauges
- My locks work now!!!!
- Question about a Grille?
- Anyone going to NOPI Atlanta?
- Disable/Enable Alarm
- I need some Help
- Front Right Brake Squeel
- Maxima 1997 GLE??
- Indiglo reverse Gauges
- What size belt for UDP w/ no A/C?
- My car has 92,000 miles.
- Battery for 97 Max SE w/cold pkg
- 1008 Code -Evap Canister Purge Volume Control Valve or Circuit Fault
- Place Racing CAI install instructions
- Do the left and right clearence light run on different fuses?
- Question about 5sp tranny
- I had a 4th Gen once, what is new with them?
- GEARS/Smaller front tires
- Need Help Fast!!!!!!!!!!
- car keeps dying out...
- HELP! Need specs for re-aligning my car after 1.5 inch drop
- Getting Ready to Buy My First Maxima...
- Looking for a MEVI: where to find one?
- alternator dying out
- Clear Corner rewire mod gone Bad
- 4th Gens: Wheel Spacers for Rear Wheels
- decided to get tint after 3yrs.. step in..
- Max is totaled, :( What to get next?
- Some interior lights (LEDS) are out
- Need help quick on homemade Red/Clears....
- ignition coil
- instrument panel bulbs
- I need help ASAP - got ticketed! Need help! WILL compensate!
- who does provide aerosol spray paint, DJ2?
- DR causing my CEL
- having key copied
- Brembo vs OEM
- Rear Bose Amps question
- I need help quick about resetting ecu
- front axle
- LED Window switch HELP!
- passenger door light
- The maxima all year long????
- DR mod with an in-dash LED wiring help
- check engin light on
- I got the blues but she dosen't
- Detailing and trunk repair
- JIC, TEIN, Ground Control??
- Change LED color in side mirror cover
- good brand of cv shafts???
- 98 tranny rebulid
- bug deflector on hood?
- Racks on a Maxima
- Front wheel play (bad wheel bearing?)
- Need Help With replacing Struts!!
- Help! What Wilwood Calipers Do I Have?
- New tires -> less miles :(
- Need Help with trunk lock assembly
- Engine Coolant Temperature Sensor
- Switch for heated seats
- How long can I drive around with the 0304 CEL?
- air intake restrictions?
- Autometer gauge problem
- gas grade and oil type...
- rear brake calipers
- Strange speedo problem
- Finally my Maxima is lowered! No more 4x4!
- Why does the steering wheel vibrate?
- ES bushing creeping out of the bracket
- another noise/feel guess game
- Size difference of front stabilizer bar?
- NismoMaxman: Update !! Suggestions NEEDED!!
- Sound coming from Engine bay when car is Off
- help my fog lights are not working
- technical 5spd question
- Money is no option
- Cutting 95 bumper to fit grille
- check out these wheels
- brake noise, help!
- Clutch problem
- Carbon Fiber hood on i-30
- maxima 98 smoke
- Is this the OEM starter for the MAX ??
- Grounding points revisited...a few questions?
- Will 5th Gen Starter fit on 4th Gen ???
- Need Suggestions on What To Do Next!
- Koni Sports = Koni Yellows?
- Where Can i Buy the MM Evo 5 wheels?? or does anyone have any to sell??
- Stillen Intake and gas mileage
- black triangle piece on top of door panel
- how to gain access to ECM
- Did anyone buy the eBay Skyline kit ?
- Maxima headers on Ebay
- Tire Wear
- where is the dome light fuse?
- Auto trans resistor
- Walbro Fuel Pump, Does anyone know the part # of pump & install kit?
- Auto Trans problem
- CEL light...When does it light?
- cutting stock springs
- another 'i updated my cardomain' thread
- Got some stuff done to the max....
- just got a used maxima...need some advice
- loss of power on acceleration
- does anyone know how to wire subs to your factory bose system
- most common problem with radiator??
- mushy clutch
- Cleaning plastic wrap off of new bumper...
- problem starting the car
- 97 maxima.. maintenance for noob.
- Video: Exhaust driving by camera
- sunroof drain leaking into car
- Maxima Insurance
- Where to get strut boots?
- sunroof installtion (N.Y area)
- two questions...
- Newbie here...
- Absolute Pressure Sensor - what is it?
- knock sensor wiring???help!
- knock sensor flex socket?
- Is this my ignition coils going bad?
- Tire inflation
- Resetting ECU deletes other problem codes permanently?
- Problem with temp....Help???
- Can anyone host some videos for me?
- I killed my side view mirror help plz want m3 ones
- What DONT you like about Your Car?
- Parking lights
- what $6000 in Damage looks like.....
- How long in oven for red/clears?
- Auxiliary Input Converter
- 2 different model's of eibach spring for the 4th gen?
- Stillen aero kit question
- starting car after 3 months
- Dont Have a clue.
- knock sensor replacement in Northern NJ
- Headlight + Parking Lights
- I need wheel spacers....help!
- quick question. im lowering my car today
- Denso Iridium Power Spark Plugs VS NGK Platinum
- EGR Flow malfunction ??????
- will an out of spec TPS affect performance?
- DIY for wiring a shift led???
- Gotta hit 13s....What is the DR mod?
- knock sensor driving me crazy!!!
- My Favorite Pic of My MAXIMA
- Anyone have the OBX headers installed?!
- Troubling Noise
- how to fill spoiler holes?
- Help - Starter over-cranking after car starts
- Flat Tire Question????
- Is the owner of this max on here?
- Engine is misfiring, hesistates at stop lights
- What should I do??
- ECU is this for real?
- Bought a used Y-pipe, problems...
- suspension set up questions?
- button under hood release?
- rewiring bumper lights and clearance lights
- Hooters meet NJ (PICS)
- URGENT! Window won't go up. Please Help.
- 300zx clipers on a 95 max, is it possible
- brake rotors
- eBay FSTB
- silence.......of the maxima!
- carpet color
- New Mod- Before/after pics
- motostorm lightweight underdrive pulley?
- Stores, Where Are You..
- Headers too???
- Custom B-Pipe's Post Your Info
- this grille rules
- PSI on tires
- Clunking in front end
- Who has gunmetal or hyperblack rims on a 4th gen?
- Ebay Cyber Body Kit
- Aux gauges lighting to dimmer?
- Custom headlights! anyone tried these?
- Need Help window wont go up
- Anyone else's 3rd gear grinds?
- Dome Light
- Headlight upgrade from 95 to 97> ?
