- Maxima Smuggling Compartment (WITH PICTURES)
- Cheap Suspension set-up
- i thought i fixed the damn thing
- Control arm question
- 98 Maxima rear brake
- HELP!! car wont let me shift!!
- rear brakes on sale at rock auto
- Help Gauge not illuminating
- Shifter housing lens has a blue tint?
- Good Place to get an A/C Compressor ??
- suspension question
- To clear up any confusion - this is supposed to be securely attached to your engine
- Y-Pipe hiss fix?
- Noisy climate control fan?
- Power or Looks?
- axle seals
- SES light disappeared?
- DIY Question (alarm beep)
- No gas mileage improvement
- what next...
- Top Speed video..(140 mph)
- 4th Gen Oil light
- Week of exhaust questions..got another one. Greddy SP2 fitment..
- not again....ebay com'mon
- Clutch Pedal... leaking
- whats needed to do a 95->97 grill conversion
- Well today my front lip was.....
- rough idle problems
- Fog light keeps blowing fuse
- Clutch Re-condition....
- can't solve p1320 code, replaced all parts HELP
- total loss with this much damage???
- where do you put in your oil?
- Floor jack block--what's it called?
- Strange diff./ axle seal problem
- please help....big egr tube
- Fuel Filter Replacement
- Strut bearing price
- Cattman vs. Apexi WS2
- Split A/C Hose
- Those with z32 calipers and cobra rotors, im getting grinding noise need help
- Head Gasket Sealing Liquid?
- Not another HARD START thread...
- Front Suspension Problems
- Car crash, seek advice
- Time for a major tune-up, need help
- whats a good suspension setup
- filling my motor mounts...
- frequent CEL 0505 code, plus engine ticking, and manifold leak
- Please post pics of VAFC/SAFC install
- Reseting ECU
- Cattman vs Greddy SP2
- Smaller tire diameter
- serpentine belt snapped
- Replacing antenna mast
- Pic request: 97-99 w/ CF Hood + Stock SE Front
- Replacement help...
- Suspension Renewal
- 95 Max stalls and hesitates
- Will it kill me not to repair these right away?
- Nismo Short Shifter
- Faded Pearl White roof?
- You can't have a hotrod without pinstriping....
- Is it possible to replace front struts & rear shocksfor $500 including installation?
- my prediction for th week....
- quick starter question..
- axle seals
- In "___" *blank* miles, My 4th Gen is the Best
- remote door locks
- my baby got stolen
- 1995-1996 Fog Light Removal
- Another o2 sensor thread
- grrr...still stalling!
- A few problems I need help with...
- Problems with RPM's and Idoling.
- Strut Replacement
- Shuddering
- Problems with clutch slave or master cyl
- Fiberglassed a hole in my fuel tank
- JWT ECU - beter fuel economy
- Muffler installation cost?
- Death of my Max :(
- OBX Short Throw Shifter...
- I searched... what kind of gas mileage are you getting?
- todays new updates....
- 5spd swap'd... PROBLEMS!!
- HELP!!!!!!! I broke it!!!!!!!!
- quick 02 question
- budget fitment problems lately??
- knock sensor
- Making turn signals runing lights
- Anyone Order a Budget Y-pipe lately?
- errrrrr wheel hop
- So, anyone managed to accomplish this?
- Overhaul a window lift motor
- Pre-painted bumpers/parts off e-bay?
- ebay is using someone picture!!!
- 95 SE, A/C intermittent between cold and not cold
- how many of u?
- so i used sea foam..
- Do I need new Rotots?
- Car Starts and then dies, what gives?
- David L red/clears for 95 96 available
- got a/c clutch off!!!
- lug nuts
- need help installing ground kit
- Clutch pedal issue
- Non Bose Head Unit
- which mod next?
- Where to buy MAF..Autozone is $230.WTF
- changing rear brakes
- Recall- 1996 SE
- How to adjust clutch pedal? my clutch pedal is stuck and I need to pop this thing out
- Car goes in gear w/o clutch
- GAS guage?
- Speed gov'nor?.
- Vulnerability of O2 sensors on aftermarket Y-Pipe?
- Intake Manifold Discussion
- Lssexhaust.com....Where has it gone?
- Blown Rear KYB AGX
- suicide trunk
- Let's play, "NAMETHAT NOISE!"
- Suspension Combo
- Ksports on E-bay
- Fuse question
- Help.!!Wont go into programming mode.
- CEL Code P04000
- How long do ignition coils last?
- anybody recently got an injen knock off from ebay?
- fuel injection cleaner
- Fluttering temp gauge and inop climate control unit
- Summit RPM Switch Question
- Speed sensor bracket.
- Yet another clutch goes down to the floor problem… little different this time.
- Steering wheel vibrations over 70mph because of worn suspension ?
- GXE's come prewired with AutoClimate UNIT?
- Suspension clicking noise question.
- Speaker whining noise
- Whats Up Guys
- Cheapest place to get rear calipers?
- engine swap now code po320 need help
- manumatic tranny
- how much can a 5th gen clutch handle?
- control arm question......
- rack&pinion bushings
- what year tranny will work for a 97 auto
- passenger side axle seal leak
- Replacing cv axles!
- How about some 4th Gen Nissan Maxima Drag Racing Videos ?
- I30 gas door switch on my Maxima
- can I do this???
- fed spec
- Which wire is brakes: Green_w/_White or Green_w/_Yellow?
- 5spd swap question
- 97 front end
- Diagram Dashboard Disassembly
- Returning problem when put in drive
- 97 SE Not starting - cranking - help!
- Driving lights (or lenses) to fit stock fog light location?
- changed fuel filter getting 0901 and 0902 codes
- complete clutch line schematic
- Hard clutch problem… How to bleed air from clutch line?
- My wipers stop at the middle and blocking my windshield… any thoughts?
- what do you guys use to clean your engine bay?
- winny,squeeky noise..cant figure it out.
- Any strut suggestions?
- SARD torque control valve?
- Front End Noise fixed - Bad ball joint
- Question about FSM (yes I know where to get it)
- Flakey Speedo!
- AEM FPR going wonky please help!!
- is this y-pipe cali or fed????
- Probelm:Popping sound/HP loss
- Got Gas, Lost Power and Dies
- Repair questions...
- Please help with codes and part numbers
- autozone or raxles
- Where to purchase A/C clutch puller KV99232340
- Can you tighten a sun visor?
- Complete suspension overhaul?
- Black smoke on start
- obx sts
- 5th gen clutch for 4th gen part #s?? Help! Search not working..
- Car putters, won't shift into gear when not warmed
- 97 SE with issues - 5-spd
- suspenstion part prices.
- A/C Condenser replacement - do I need to do Dryer
- What does SES Code P0430 Mean in a 4th Gen?
- Best Coilover Setup
- 00vi/mevi? wtf?
- A/C condensation water and Service Manual
- How to replace rear calipers on 98?
- Tokico Illumina Rear Bushings
- Help: Stupid metal bar put a hole in my gas tank
- The Clock Issue
- Just finished putting 02 spec-v speakers in my 95 GXE
- Read faq's, but wanna be sure everything I read is correct
- budget y pipe = 0302 code - then fixes itself ??
- Eliminating brake fade???
- What parts needed to lower Maxima??
- Can't get passenger side axle out, can't get new driver side axle in
- Boredom + A32 + tools readily available == these videos. Open manifolds.
- Starting problem once in a while 1999 Maxima
- Silence is Golden - Fixed Front /E Squeak
- Front Driver Side CV Boot torn
- dont be like me, check/replace your hoses
- Problem With 1997 Maxima
- Trunk slamming while closed?
- Is this a suspension issue?
- A/C near freezing. Thanx everybody
- Suspension and Brakes done! HUGE difference!
- cant remove driver side axle
- KS question
- hotter temps affecting engine???
- Thermostatically controlled radiator fan
- Clutch all the way to the floor, wont come up
- Question: What feels like a flat tire but is not a flat tire?
- Do springs ever wear out?
- Brake & Altenator light blinking intermittenly
- Transmission Problems, Help
- speedo working when it wants to
- GD on Matt's Grounding Kits
- PLEASE somebody help me (drive belt install)
- removing c pillars
- Highway Partol 1: Me 0 (Damn U Procrastination)
- where can i get one of these?
- Who has used o2sim's heater?
- tein basics vs. ksports or others
- Any Interest in Custom Stickers/Decals?
- CV Outer Boot
- Allignment/steering woes
- Three Way Catalyst Efficiency Code
- Deciding on Wheels...
- Discharging a/c
- JWT ECU -- auto in manual
- !Starting Problems!
- size of the front speakers?
- can someone direct me....
- While riding or idling car just shuts off? WTF
- My clutch is toast!!
- How to wire side markers to blink with blinkers
- Looking for a Y pipe
- Starter hesitation/delay
- Rotor Removal
- for those of you that have done brembo rotors/brakes help!
- ebay knock sensor
- strange shaking problem. help!
- A True Story hehehehehe
- 0702 and 0703 codes
- ECU is fuxored....
