- Are the stock mufflers the same for all years?
- just for fun...
- 99 fog lights install on a 95
- Can someone help with a carfax report?
- A/C switch only works on highest speed (4)
- question on intake
- 98 SE fog light rewired (pics)
- Parents and Modz. HELP!
- Folks with CAI & A/T
- How to install altezza tails?
- What is wrong with my headlights?
- How do I get a sub battery cable through my firewall?
- car wont start. need some help.
- EGR System Hi/Low Flow?
- How much is my car worth?
- jerking and slight hesitation
- Rear sway bar problems?
- engine and tranny bullitproofing
- Is There a 5th gear in my auto Max?
- Clear
- JIC Coilover Owners *Please Read*
- What is the right Idle at a stop?
- Whinning Noise
- Help with TRENZ Grille
- Any maxspeed complaints?
- Best suspension/noise
- You Don't Wanna Miss This!!!!!!
- Idler/Tensioner pulley...
- what can i expect from the weapon-r dragon intake on my 95 max?
- Knocking noise
- Engine Issues.. HELP
- i need help pls!
- Q about oem springs
- looking for 3" y pics
- Fluid level after break change?
- Horribly loud squel coming from Front Right Wheel.
- clicking noise when trying to start car
- NEED HELP. Can to detach EVAP valve from canister
- Car has a very slight tremble/shake at about 65-70mph
- Weapon R coilovers????
- **QUESTION for peeps using KYB dust boots***
- Exhaust shaking/rattling Problem
- Service Engine Soon light came on...
- Sunroof/moonroof problem
- Coilover question
- Help!!! Tail lights
- Securing Clear Corners on 4th Gen
- check engine light
- Bolt in your clear turn signal lights!
- Exhaust replacement - intermediate pipe
- Having a hard finding why my car is overheating
- CEL problem - fixed problem but still tripping!
- Pics of body-colored door pillars?
- Power Steering Fluid
- 04-13 error code - need help
- question for suspension gurus
- argh.. another problem. stalling?
- Alignment and Camber help...
- Something happened to my tranny!!!
- Dash kit Peeling!
- mesh grill pic?
- ECU CODE 0412 undefined please help
- Maxima With Prowler Tails
- Help - High Pitched Noise Coming from Engine
- Which One of These???
- control arms
- heater resistor is not the same size?
- Tinting tomorrow...what do you think
- 6th gen's front brakes to 4th gen
- transmission
- Micro-second pauses in acceleration - Going through HELL!
- Made a cool wallpaper
- Taking interior apart (exclude center dash)
- Need Part#
- decision tomorrow..need help (tps related)
- How to rewire 4th gen foglights????
- Frankencar whistle???
- energy suspension bushings
- Those with Hanabi Kits
- fog light ?
- I'm at 55K miles. What the hell should I DO?
- Removing trunk lid tension rods......?
- Help fixing ecu codes, what needed to rid of them??
- STS Short Throw Shifter ! Does it make any difference at all ?
- Crank Pulley: Unorthodox Racing or Definitive Motorsports
- Having suspension problems, need help!
- Difference in in-cabin noise!?
- looking for 98 Maxima/I30t catback exhaust
- leaking coolant!!!!
- Excessive steering wheel play...Need help!
- Fellow Automatics: Do you shift?
- Need some help form you fourth gens....... I have a third gen
- Heater Fan
- Engine swap related transmission questions...
- someone w/ walbro 190lph fuel pump help
- Towing revisited
- Does 95/96 Stillen lip fit '97?
- For all those converted car people
- max 97 grille
- Dif between intake gains?..
- The sound of Cust. Max. dual exhaust???
- Recharging AC - stumped/tried search
- Brake noise
- New belt size
- My whole car has to be repainted, please help!
- Head Liner Glue
- supension brace from GTFabrication
- Side Mirror Installation Help
- Has anyone changed the lighting in the air conditioning unit?
- H&R with GR-2s
- frankencar intake deal for straight-pipe owners
- Stillen FSTB?
- Which spark plugs are best???
- what's the difference between 95-96 & 97-99 rearend?
- ?Question For All You Bass Addicts?
- Big weekend for the max!!!!! max goes 7 - 0.
- remove throttle cable?
- Manumatic Finished
- Help Finding Dash Kit
- Kind Of A Big Weekend For Me
- Brakes squeaking and squealing all the time
- Rear brake drag
- rear sway bar
- Question about 194 Harnesses
- problems electrical system, please help
- injen intake
- Brake upgrade calipers and fluid
- Intake/AC connection?
- Can feel liek a clack in sterring wheel when turning
- 96SE - Replace Manual Climate Control with Digital
- HKS Rear Section Muffler Curse
- KYB Dust Boots
- Apex-i vs K&N (Frankencar Application)
- belt path diagram?????
- Wheres our Tein springs??
- Question for suspension pros
- question about a 'autozone' tuneup vs 'nissan'
- 0505 Ecu
- 5spd converted guys - how many bolts in your clutch pedal
- broke a stud on my strut tower...
- Power door lock issue
- quick need brake pads when for my brembo rotors
- D2R Bulbs-FOCAL POINT
- High-flow racing pipe
- Post pics of H&Rs
- 9004 Dual Beam Catz HID released
- Tried a search- but no help. Quick Question
- EVAP replacement?
- Front suspension questions
- went to buy 4th gen
- Port Polish - Recommended, Tried ??
- Is wiring the HIDs straight to the battery a good idea?
- power steering fluid
- Y-pipes and their legalness in california
- Purchasing CV Shafts
- trans cooler metal tube?
- Very Importent!
- Easy ?'s about injen intake install
- clicking noise when steering at a stop
- 97 SE 5-spd VS 00 GLE Auto?
- Corner light problem
- Reverse Problems
- Exhaust
- My 99 Se Vs. My Friend's '00 Se
- My findings as of late.
- has anyone tried the exedy clutch on ebay
- question about sensors on stock intake piping...
- air ride suspention
- Cheap
- ECU fault codes....
- Why is it hard to get 95-96 red/clears?
- Intake: Cold Air vs. Short Ram?
- Saw a rather inexpensive max today...
- Aight this is the real one: '98 SE 5spd VS. '02 GT convert 5spd
- No more 4x4
- homemade intake
- Need opinion on Quote
- crankshaft sensor
- passed fed emissions today!
- Check Engine Lite
- paint bumpers
- Spark Plug Gap
- Steering Wheel Vibration past 65mph
- Mud Flaps
- High wattage fog lights
- Struts
- Do I need Camber Caster Kits?
- Need Info on automatic Tranny!
- still hesitating w/ hard starts
- 12V DC output
- polishing manifold
- '98 Maxima VS. S13 Silvia(240sx) VS. Harley F150 VS. Lightning VS. civic VS. 5th gen.
- Slow leak from Clutch fluid....
- QUICK ASAP someone with FSM look ALTERNATOR WIRES
- Upgrading Ignition and fuel system
- Foursome
- Brake Problem: Irregular Pad Wear
- Squeeking noise -- brakes?
- pacesetter isntalled today..idea on bal joint dremeling problem.
- NARVA RALLY GOLD h3 yellow fogs
- Bad O2 sensor, rob power?
- Spring question: Which end is the top?
- Shift point
- polishing intake..... need new gaskets???
- Shifter Seal Help, Please!
- Will a 98 BOSE h/u work/fit in a 96?
- Where can I find Chrome Rings for my gauges??
- Clear tails Q's
- Question on jacking up the car from one side only
- Burnt out Headlights
- Braking doesn't feel normal, need help
- HELP! I have a problem....
- **HELP** Wheel Lock Adapter
- 4th Gen Manual VS. 6th Gen Auto
- Are these real rear Brembo rotors?
- Help.. i need a new muffler
- Screwed by the body shop? Advice needed.
- Brembo Slotted and Drilled Rotors -- Shipping box broken
- HELP! need parts list for new suspension....
- WTF Very Bad Day also very long
- Canadian Maximas
- LSD Tranny $895 !!! Rebuilt
- LSD question
- need help buying cooling fan ASAP!!!
- throttle body cleaning question
- electrical probs with taillights...
- Bleeding the brakes with ABS - need advice...
- Timing Chain Rattle?
- Service engine is off, but wrong resetting?
- 2000 rpm buzz?
- I30 Hood on 96 maxima
- jackpoints?
- H&R's need a camber kit!
- 02 sensor question
- Inhibitor Switch Repair
- question on nissan brake pads
- Hella Install ?
- Sponsers?
- Are Y-pipe upgrades worth it for California emissions Maximas???
- 5th gen tranny
- Axle removal
- alternater fire
- A/C.... need help please!
- Help you guys! Rpm's going crazy and car stalls.
- Poll: People Responding to your Y-pipe
- In serious need of some help!!
- Spotted in OKC
- fuel system cleaners?
- coil overs
- BOSCH platinum plugs SUCK!!!!!!!!!!
