- will 96 seats fit a 99?
- Better prices on new ignition keys?
- Installed my new fart can. Pics!
- o2 sensor replacement cost quest.
- 1995 Nissan Maxima Factory Servce Part Manual
- Air filter question
- just installed sprints. not happy.
- Does the brand name of the FSTB matter for our cars?
- The Butterfly Effect...not a movie, well, there are movies now & *pics*
- 6 Speed Transmission in a 99
- What Kind Of Gas Do You Use On Your Max?
- Whats are the signs of a bad alternator
- Eibach Camber Kit?
- Clearence Lights
- Which wheel bearing to get?
- Maxima HID projector retrofit!
- Orange Race Lowering Springs On E-bay
- Drop at Idle ?
- is this a good deal?
- How fast can you replace a Knock Sensor?
- Can Crankshaft position sensor results no start?
- What's the best tire size for AE wheels
- People need to learn how to drive
- Bought VB mod... solenoids???
- Where can I get a 9004 connector?
- anyone have a PS fstb?
- Got my Greddy SP2...something is not right
- 96 5spd start problem
- 9004 HID beam question
- riding it hard
- starter question
- Fluid In Wrong Container.!!!!!!!!
- 300 zx breaks and rotors and injectors
- Brake Problems
- keyless remote entry
- Hood adjustment
- Master Cylinder
- Slightly rough idle
- Rear brake
- Rainy season coming up....what wiper blades?
- where can I get a 1999 front license plate holder?
- few new pix, nothing special
- Intrax Springs
- Intermittent Starting....Clutch Switch???
- Is the Boost Sensor important?
- How do you know if you have a Y-pipe
- Did anyone here changed thermostat ?!?
- Passenger door panel- Window Motor Swap
- 99 se rims....how to polish lip??
- Where PRECISELY is the immobilizer chip located on the key?
- Seems I broke a rear strut.
- Changed to a lower thermostat and did some other things
- Stone Racing Headers Questions
- Smog test problem / "#0325 Knock Sensor"
- will the 1996 front license plate holder fit a 99 model?
- Did 1997 Se Ever Come With A Chrome Grille?
- ATTN ALL 98 Maximas with airbag light problem...
- Help is needed
- Parking lights no longer working while locking/unlocking with remote....
- Ok, new problem
- Throwout bearing and pilot bearing- same thing?
- Stiffen motor mounts without removal?
- Megan Racing Lowering springs?!
- 17 X 7" with offset 42 on a 4th gen?
- Question about ECU
- springs with stock struts
- I Need Obx Header Pics
- Hello Every One Im New to the Site.
- what's next for my auto???
- 03 09 CEL, Vent Control Valve. How to fix?
- Advice on Exhaust
- crank position sensor
- Help! I was trying to do a diagnostic...
- Where to get cheap savage auto insurance?
- MTM pics 56knotagoodidea
- neutral safety switch
- Got a Cel Need Help
- Finally got my Cardomain page check it out!
- wtt: vq35 crank for vq30 crank
- timing gear tensioner r&r...how hard
- help with part # for armrest latch
- License plate blocker for red light camera?
- Ok, I looked at the stickies...
- Electric Supercharger?
- Hi-New with some ?'s on a 1995 Maxima!
- Catback and gaskets
- front end rebuild
- Has anyone tried putting on a q45 throttle body?
- Bomz intakes on ebay
- '96 QX front Exhaust problem
- no start problem
- Last post, leaving the ORG.
- How do I change a spoiler?
- WTH? While at the pump....
- cam sensor ?
- P105--circuit sensor issues?
- International Maxima
- Help choosing a new muffler, opinions please
- Cruise Control Light "Blinks"
- benefits of S-AFCII on a 95 max
- timing chain tensioner 95
- Where can I get headlights
- Why is OE intake so stupidly complex?
- Ack - engine code P0154 --- 0413
- Warpspeed, Cattman, Or Budget?
- Door lights dont work :( help
- RedlinedGoods 4th Gen armrest cover anyone in here have one?>
- 0407 Crankshaft Position sensor (reference)
- knock sensor is bad !!!!!!
- mud flaps
- Selling or trading the max for.....
- Need help Installing SunRoof Deflector
- Braking Problems Help !!!!!!!
- POLL: How long did your original auto tranny last?
- rear wheel bearings
- Crash...then burned!
- ground wire hook up and where
- H&R Springs w/5spd- will rear be lower than front?
- windshield wipers dont work...
- Reprogram keyless entry remote from a 2000 Maxima?
- 99 Maxima SE Ltd ECU ERROR CODE 9 1
- Engine Problems. Don't Know What To Do!!! (Do Not Buy From Action Nissan-Nyack,NY)
- need some help
- This thing is driving me crazy!!!!!!
- 2 CEL codes
- big power steering leak
- 0503 front 02 sensor ?
- O2 Sensor question
- Best Y-Pipe Or most liked
- K&N cone filter # and breather filter?
- Nissans and high mileage
- pics of tint!
- posting a pic
- which breaks are better?
- Maxima Octane
- Do I have LSD in my trans?
- power steering noise....help!
- 99 SE manual with p1706 code HELP
- Tires squealing
- does anyone have any feedback for the Warpspeed "quiet" catback?
- No cheese with my whine...
- Diamond Clear Corners from Procarparts.com
- Best 4th Gen Headlights Ever...
- Rear strut bar. Is it really needed?
- No hot start
- have money in a couple months....advice!!!
- A proud Owner of a Maxima (again)
- how about these taillights on our maximas
- 5th Gen Motor and Tranny in 4th Gen?
- New Guy 2 Questions
- Strut replacement parts questions
- Slow Oil Leak
- who doesn't have a y-pipe?
- Thermostat not Opening?????
- Muffler quest
- christmas came early
- Chipped up hood came out great...
- 2K 5 spd in 98? Possible?
- Stainless Brake lines and Pads
- Clutch I bought..
- Whining Noise at Idle
- HELP!! clearance light is out
- Drop Resistor
- Best 4th gen clutch for overall drivability?
- Rear Brake problem - Can I replace only one caliper?
- maximas and o2 sensors
- Unorthodox Racing UDP: Cheap Source?
- Ludalip
- Two Questions
- Question about grounding kits
- Stock keyfob window up mod???
- random ?
- ADDCO rsb install, need help...
- Think i've got a wiring problem and could use sound advice.
- Need Help Real Quick!!!
- Is it difficult to chech engine oil level of 97 maxima
- What the f^%k is wrong with my car.
- Finally some new pics
- Max Nyer's
- 99 to 97 ecu?
- Cheap oxygens sensors
- Best brake pads????
- Check my racing video....
- Need: A shop in Atlanta
- New tail lights for my 95!
- a fresh alignment every day!
- 1107 CEL code
- agx's squeak, way to stop?
- Fenders
- Looking at 4th gens, what should I look out for?
- what 97-99 parts are a direct bolt up to 95-96
- B pipe
- strut install......
- Help!! Front springs flip-flopped!!
- Door handles
- Brake service
- how to replace left front wheel bearing?
- Better handling/ firmer steering
- ?'s for 95 foglights
- New Rims... pics... 56k death
- Question on car lowering/rims
- 96 GLE electrical problem
- b-pipe
- lowering springs
- weird noise not able to locate it!
- torque conv
- rattling suspension fix
- 300zx Brake Upgrade?!?!?
- Anyone have carputer in their Max ?
- Lowering questions
- Only 1 fan speed working
- Rattling Sound from Cat.????
- Who has 19's on their max??
- wierd thunk when at a stop?
- Passenger foglight won't work...WHY?!
- Side air bags problem
- Give me the link?
- power seats install on car w/o
- Pics of members Cars`
- Best way to 200whp
- Jumpy Idle, help before i go to the dealer please
- button under hood release on 96???
- p1400 egrc solenoid valve
- Automatic Transmission
- cheap stock muffler
- weird Idle problem
- Question about acceleration
- New pics of max + Pics of Carbon Fiber Dash For those who asked (56k DIE!!!!!!!!)
- *** D2 VS. Tein Basic - Official Thread ***
- Passenger door light wont turn off? why?
- Looking for CF sheets come in!
- carbon fiber hood price
- Cheap Knock Sensor
- Change chk engine bulb
- Installing FSB/RSB
- Does Anyone Have Instructions On Installing Ground Wires.??
- Est. time for shocks...
- Are 95-96 OEM fog lights the same as 97-99?
- Noob Question, but need input. Which dashkit should i get? please vote
- rear 02 sensor question
- Need Opinions on Most Likely Cause for Code 0308 and Service Manual
- Dash Removal Diagram!
- Where might I find..
- NEX Coilovers?
- HELP Smog emission!
- car idels weird
- bpipe selection
- question about gas + break pedals on a 98 GLE
- is my CEL for EGR slowing me down??
- CEL: intake?
