- AC CHARGE HOW TO??
- Blower motor stuck open?
- OBDII -- Consult / What's New?
- Alternator Wiring Upgrade - Please Clarify
- quick interior question
- Is there a write-up for heater core replacement?
- Does your Modded 4th gen attract too much attention?
- y pipe compatability
- Cattman Headers owners - Please step in.
- Fog Light Output Issues
- IPS bearings again?!?!??? phantom grip inquiry.
- transmission f'ed up one time?
- Tem switch electrical issue
- 99 ECU - how to reset
- Noice and jerky shift from P to R
- Car No longer overheating after....
- New ebrake boot.
- Question about seats
- front lip?
- Wont Start - Alarm
- Current leak tkhrough fusible link f -- source?
- another one about e46 projectors
- Spark plug tube seal direction
- Low usage advice
- Personal impressions about "seafoaming" the intake manifold
- Crank Seal? Which one?! Help!
- Sway Bar Endlink Boot Question + Pics
- very unusual fuel leak, help!
- How to properly ground a Maxima alternator ?
- Corner light replacement
- evap canister purge control valve relocation
- window regulator and motor question
- Blower Fan
- WHO HAS THE HIGEST MILEAGE ???
- Steering Wheel Conversion
- clock and climate control display.
- Timing chain upgrade
- ANOTHER CAR WON'T START THREAD!!!!
- Newest Pics - Blue Pearl Coat
- sunroof deflector clip
- How get at circuit breakers?
- CAR SHUTS OFF
- Jerking and popping under hard acceleration
- Idle troubles at red lights..
- seafoam - no smoke - wtf?
- code 0702; caused by y-pipe?
- slow acceleration
- Choice CF Hood and Trunk
- Need Help buying 1st 4gen
- Exhaust falling apart
- 350z injectors
- P0600
- Trans. leak
- Knock sensor and harness
- both front wheels lock up
- Brake fluid leak
- Will an 06 Maxima steering wheel fit a 99?
- What are these codes ?
- Fuel Filter Replacement Suggestion
- Car won't start
- Trunk rattle under trunk, in between Right rear fender and trunk
- Need Help with sunroof.....
- New Knock sensor boosts performance ?
- Diagnoses of O2s being lazy
- How can I tell If I have a locking or open diff.
- EVAP canister question
- Diagnostic Computers Work On The Maxima?
- Passenger side air vent removal
- Auto climate control won't shut off
- Battery Problem! Need feedback Please!
- teRough idle? Change your power sering fluid.
- changed transmission now wont start....help please
- Keyless Entry Problem
- Can CEL truns off by itself ?
- Broke one of the 21 tranny pan bolts
- Transmission fluid leak
- Pro Line oil filter from Pep Boys???
- Anyone running 35w HID Bulbs with a 55w HID Kit?
- IACV and TB Torque Spec
- lowering the 95 max.. difficulties!
- P0744 Code
- Hard & Rough spotty steering when rack/car is cold?
- Engine cranks but wont start.
- Why is my air conditioning cold at 65 but hot at 66?
- Suggestions for my situation, shop crashes my car...
- 2 QUESTIONS shaking and tranny question please help?
- Horrible gas mileage drop
- foglight bulb question...
- is it too much...?
- Removing hood and then putting it back...
- question about MAP-ECU2
- Timing chain rattle experience
- How do I get the EGR tube off?
- Throttle Body bolts
- Rear Caliper tool
- 3.0 parts..
- Automatic transmition flush ??
- Loud knocking, no vibrations thou???
- ok.... time for a complete turn around on my maxima
- Wierd noise from transmission..not starting
- vacuum hose reattachment
- PCV grommit in the crankcase
- Maxima...working? whaaa?
- What more should I do to my Max
- Ptatohed's "Padded leather 'mom-made' elbow/armrest pads"
- How hard will it be to pop out this dent on the trunk??
- Front 1156 led blinkers not working- rears work.
- need help with how to install sunroof visor/wind deflector
- Accident repair help
- Wideband Placement.
- Door lock/unlock PROBLEM!!!
- Imagine rubbing a spoon against a cookie sheet in a circle - that's the sound i have.
- Going with a new cluster !!
- Best replacement door mirrors?
- Fan dial selector malfunction
- Knock Sensor
- megan lowering springs?
- help mechanics cant figure out whats wrong with my car
- 1/2 mile drag strip, why am I beating all these cars?
- Projector Retro
- help keep gettin cel
- weird starting
- Tsk Tsk
- issue with e46 headlight
- Help with code PO400/0302
- emergency brake button driving me nuts
- TS ECU in 1999
- need help finding this pic
- Intake Manifolds
- RPM Bounce. Annoying as all hell. Tried a lot.
- Mevi Question
- HVAC fan only works on speed 4?
- Easiest way to disconnect front left speaker
- For the noobs... and for the other members that are not noobs..
- Good High Quality Slotted Rotors..?
- Shutter upon shifting into 4th gear..?
- dropzone
- whiring noise from front left
- 14.5 mpg
- 350Z BRAKES?
- Front end question...
- Error code 0505
- questions about h&r spacers
- Timing chain cover oil leak/ o-rings?
- 95max bought new in 95 still original Spark plugs
- Old wheel bearing?
- Hello 4th gen section ( 97 i30)
- im trading my 4th gen ????
- My Maxima Scares Me....
- Smoked Tails
- Bad Alternator?
- Replacing both rear view mirrors.
- question about fpr?
- My axle seals are leaking help..
- Fuelly MPG Thread
- mAd tYte jDM HiDs y0!!!
- CEL flashing while driving, IACV underlying cause
- White grill pics...
- Power stering hose
- Belt dressing helps squeaking belts?
- Seeping engine oil from this sensor. Photos inside.
- help w/phenolic spacers please!!!
- Uneven Exhaust Noise and Minor Idling RPM fluctuation
- HID question and what HID bulbs that fit.
- Blue Fog lights
- Trunk stuck closed! HELP
- 4th gen max with different trunk lid?
- Clanking/Clattering From Rear End - Video
- LED Tail Retros
- Trying To Remove Silencer From OBX Catback..
- Help with repainting door pillars
- need help check engine light keeps coming back
- New Wheels and few mods
- CEL stuck on
- Engine Swap: No Start, just crank HELP
- Noise coming from front end when driving over any "not smooth" surfaces
- water pump woes.
- 4th Gen w/ 5th Gen GLE/5-Spoke Wheels?
- Bose Unit Retrofit?
- Magnaflow 14316
- RMS or Upper Oil Pan leaks
- JDM Power fold mirrors
- Question about obx headers/cat back exhaust
- Multi Use key opener problem
- Antifreeze Leaking...
- How Do You Get The EGR Solenoid Out?
- drop
- front lip
- Painted wheels.
- Green 4th Gen
- Are the 98/99 GLE/GXE gauges different from the 98/99 SE? (besides the white faces)
- PIAA extreme white bulbs
- Uneven brake pad wear
- Question on headlight Retro,
- What will happen if I say "FO" to CEL light ?
- eBay Exhaust
- Windshield Noise
- Getting Back into a 4th GEN!! Help me out.
- Sports springs on stock struds/shocks?
- squeaky serpentine belt
- A/C Compressor Clutch is shot????
- Just a couple questions for installing aftermarket glow gauges.
- Cloth to Leather door insert swap?
- Alternate signal for TPS?
- Spacer Questions...
- Price of new stock springs
- how could i verify if my car is off timming
- ecu differences and compatibilities
- 5 Beeps before starting the engine ..
- What fuel to use ?
- Help!! Anti-freeze odor and cloud of "smoke/fog"
- Vin Check
- knock sensor? will it do the job?
- leaking gear oil
- Goldtooth?
- only two coil without sparks, the car no start
- Rear window removal replacement "port window"
- rev limit
- LED Strips
- Door Hinges seem weak? Sags a little.
- Just finally my car after two-weeks
- Steering Wheel Question
- I Need Help!! I have a question about my axles!!
- Parking Brake Sensor
- H&R's + Lipkit Any issues?
- Will a 96 ECU work in a 95? (both 5 speeds)
- replaced knock sensor..now whats wrong
- Still have a problem with the r32 after putting silicone around
- fail safe mode
- Looking for information on KS bypass project (470k ohm resistor)
- Cloth Seats to Leather?
- Lowering Cold Start Idle
- What would clean my grills?
- Does it matter if i have an ABS front right hub, but dont actually have ABS?
- Headlight mounting bolt
- Car Stalling...Now Not Starting...
- WTH ECU??? emissions rejection
- Crashed my max =/
- Slight shake and vibration when shifting from 4th to 5th on hwy.
- what a bug out- car turns itself off than back on
- Need Some Advice on A/C -- Not Cold...
- cleaning iac
- Anyone ever had this problem?
- 1997 maxima 5sp tranny saga contines....
- Clunking noise from front end
- rear brake light is always on
- New brakes and rotors why are they smoking?
- BALL JOINTS/ STRUT BEARING??? or BOTH ??
- Speedometer swinging between on and off !!!
