- something wrong with my ecu?
- How Many Inches With D2 Coilovers
- 5 spd vs auto rpm @ 70 mph
- exhaust installation
- ES Motor mount inserts installed..
- Replaced alternator, car now squeals
- Gauges?
- whatever happend to the big sadler?
- Can We Stop The Y Pipe Posts?
- Lighting Problem - Parking,Fog and Corners Out
- NYC inspection nightmare...
- Wierd noise
- tailights
- 5Spd Manual tranny leak
- Auto trans experts come inside and give me your insight.
- Too higher octane a waste of gas?
- what do you think, eBay
- Rear view mirror problem...
- backfire!?!?
- Anyone use the generic knock sensor (non-ebay)?
- post pics of your engine covers!!
- For those with body kits...
- Turn signals don't work! Help!
- would ngk iridium ix plugs reduce performance in NA engines?
- Airbag question?
- random pics... 56k get the fcuk out..
- Electrical problem please help!!!!!
- How Does This Look To You Guys??
- Brakes are finished...Take a LOOK !!
- Clutch slave cylinder replacement???
- Vq30de Injectors...
- *Custom Boots*
- Big ugly steering wheel
- brown to black interior changes, blk door panels, blk leather seats, email for pics
- New Pads. Now Brakes are making awful noise
- Removing Exterior Pin Stripe
- When Tinting the car ....
- ?weird noise,front left wheel?
- 95/96 red clears found for sale
- Fuse Keeps Blowing!!!
- ??High Flow cAT??HELP
- Fuel Pump
- whats going on???
- Replacing Antenna?
- Coil over ques,
- Cefiro HID l??
- no one with a turbo
- monroe shocks
- 95 grille to the 97 to 99 grille
- Which Y is better then the other?
- odo quick fix.
- (y pipe)
- 1205, DR mod pull this up?
- alignment
- HP Evo fitment on 4th gen
- Another new cardomain site!
- High-Flow Cat worth it ?
- Need some help finding center caps...
- Tokico Struts
- SP2 or the magnaflow
- car isn't starting
- Resonated or Non-Resonated B-Pipe
- People with a custom midpipe come inside!!!!!
- New pics of the stillen kit on!!!!
- Steering going to bad to worse
- 0707 after ts install
- 97-99 front conversion pics...
- Flip Flop Trunk
- Problems with warpspeed superflo!
- wiring up 4th gen heated seats in 3rg gen
- Replacing Wheel Bearing
- rear suspension problem: Lateral Link
- spoiler question, how to shine old paints and patch vinly?? on handrest ...
- How Fast Is Your Max???? Mine Sucks...
- Humming Sound from Right Front Wheel
- replacing thermostat...cant get hose clamp off
- Failed Emissions plz help A.S.A.P.
- Clutch losing tension and fluid...
- 5th gen 2k, rims painted black
- Anyone have a hitch?
- Y-pipe is finally on!
- Fog light Question
- cattman headers
- I need to learn how to fix some thing myself
- Driving a Manual Transmission...
- Car won't start need help
- ks question
- downshift with or w/o rev match
- Keyless Question
- Car is dead, no lights, no horn, no sound when starting
- infinity 3.5 onto our bottom end?
- exhaust piping
- need your guys help
- vg30dett
- 95 96 owners with fogs
- Towing
- Painting Calipers ?
- brake question
- Bass Drum/heartbeat noise coming from engine bay...normal? misfire? predet?
- Power loss, no codes, not knock sensor?
- 98 Maxima starting problem....
- Should I just get a GXE instead of waiting for a SE
- sprint struts
- Coilover $70!??
- ~~~~nipples~~~~~~
- buying a manual transmission
- Is Hacking Airbox Good?
- Rebuilt, used, or new tranny?!?!
- Quick Question About Alternator
- Former Maxima owners needs the .org's help!!
- Steering Rack Boot?
- Urgent, project in progress-how to get door panel all the way off!
- A couple of strange things happening to my car
- rear strut bar?
- Question about my starter (8 or 10 tooth?)
- BOMZ Cold Air Intake pictures??????????
- Updated cardomain New wheels and grill
- Not sure what color to make my Caliper's (Blue CAR)
- skyline front bumper grille question?
- got pulled over an hour ago...
- best shocks to pair with Tein S-Techs....
- I got rear ended
- Worked on the headlight lenses tonight
- Intake!!!!!!
- CAI installation question
- post pics of your car with 350z wheels
- what would i experience if my timing chain was tensioned incorrectly ?
- First time Insurance Claim - what to do?
- rear section an b pipe match up question
- Name These Sensors Please
- Swapping Tail Lights???
- next mod...
- weird tube...where does it go?(maybe only for 96 gles? doubt it)
- need help. about power door lock
- Replacing Exhaust Gaskets - Part Numbers?
- 0311 code????
- Manual doesnt list the kind of light bulb?
- First Car domain
- Always Drop Your Car Before....
- What are some of the better Reverse gauges?
- Buying S-Techs, what ELSE is needed?
- please help,no answers from 1/4mi forum
- engine check light
- 97+ 02 bung?
- Coilovers Question
- Question on SS Brake Lines ?? please read
- Gauge location ideas
- car starting very erratic nowadays
- russians in 4gens..
- Is this same as stock?
- Any Reason Not to get 99 if want to mod
- o2 sensor and CEl light situation
- What's with this HIDEOUS sound!?! [9.43MB Video]
- The fourth Gen auto tranny disposition
- What are the size of screws that i need for fog lamps?
- dual exhuast
- car jumpy
- anyone ever take off the mud flaps?
- Should the Keyless Remote make the lights blink???
- Input on Bumper cover replacements any suggestions?
- Mechanical Oil Pressure Guage
- carbon fiber turn signal mirror shells....
- a few pix of my car finally
- Code 0401 Air Intake Temp. Sensor
- Questions on intake...
- Does this '95 SE seem too good to be true?
- Hydraulic clutch hell...
- Rear end feels completely loose
- Exhaust Question
- Rare colored 4th Gen post your pics!
- Diamond Cut Clear Corners?
- Painted front engine cover black, pics
- 01 cluster in 98
- What color should I paint my brake calipers
- Updated my cardomain page with my new stereo Pics
- Startup noise
- problem.. what could it be???
- trunk lip?
- anybody know how to make a mid-pipe?
- Short Shifter
- Cheap place to get Injen CAI?
- 2001 SE 17'' Rims fit 1995 Max???
- shift_performance
- Stillen kit install instructions
- Who has the Apexi catback on their Maxima?
- Front Control arm bushing kits recommendations? polly or not?
- Antenna relocation: VW style
- Flickering LED in A/C Control
- Help clearing a cloudy lens?
- Fuel gauge messed up!?!?!?!
- Alternator part #
- Quick Knock Sensor Question
- Clang when pressing the clutch pedal
- Signs that you've tightened your throttle cable too tight
- 4 momo arrows 18" chrome....
- well ****... 1106.. any thoughts?
- Exhaust Noise
- GR2 Question
- exhaust help
- Problems today.
- Exhaust Help and Opinions
- Need a lil help with this "antena" mod
- Squealing sound coming from right front wheel, any ideas?
- Odometer stoped
- Yous guys this this is a good buy?
- Misfire
- Finally got a CarDomain page up Tell Me What You Think!!
- fender fitment
- Any suggestions on how to improve this?
- cel codes
- grille
- quick question: sunroof problems
- Post Pics of your Painted Calipers
- shock and springs
- gotta get this fixed quick....please Help
- immobilizer
- how to ship skyline front bumper?
- Apexi exhaust
- So does anyone on the .org actually have Traction Control??
- any place online to buy the following?
- rear seat removal
- Translate this code:
- eBay Mufflers
- 5spd Tranny Upgrades
- check engine light code's
- installing leater seats
- Good Price For Eibach Springs???
- MA inspection with the 20% tint?
- BOSE audio problem - no CDerr or No Display
- SS brake lines
- sry for the newbish ?...How does the Cattman Y pipe sound?
- Do I have Locking Differential ?
- Need New shocks!!!
- anyone heard of these guys?
- Need to change brakes for my car soon
- What should I replace at 120k miles?
- Cattman engine mount inserts (PICS)
- Squeak Squeak...help!
- Warpspeed New vs Old design, quick questions
- My review on getting my MEVI extrude honed
- Diff Bearing Failure or Bad Axle Seal?
- Climate control unit backlight bulbs
- side skirts
- Which way to install slotted rotors? ASAP replys are needed
- differences between Greddy and OBX exhaust catback's ??
- keyless entry stopped working
- this morning! no start!
- questions???
- CEL 0903 "EVAP Canister vent control valve" Fixed?
- 18" Murano Wheels
