- APEXi Air filter size
- Start Up Issue (after driving for a while)
- prepped
- tcs and auto lights.
- Spun rod???
- Car smoking and idk why....
- Tein s springs. which struts ?
- Knock Sensor triggering CEL question
- Front-end suspension loose? Banging from bumps on corners
- The Official 4th Gen Exhaust Clip Thread
- inconsistent start
- Final Goodbye :(
- how to make rear marker light blink with turn signals PICS inside
- New Max - Couple of small issues
- First Maxima! New to the fourms and need help Plz!
- speedometer stops working til i tap it
- DIY eyelids
- 13 Cobra sourcing? Link??
- Need some sun roof help
- New Maxima maintenance - am I on right track?
- CXJ PERFORMANCE INTAKE SPACER GAUGING INTEREST
- My Max Hit & Run Caught on Video!
- Rear Sway Bar options to Help Understeer
- Ap1 S2000 Rims
- Wish me luck...
- Water Pump/ Timing Chain Cover Removal PITA **pics**
- Headlight questions
- new life pt.2
- HEY GUYS!!! NEW LEDS OUT! STILLEN BODY KIT FOR SALE!
- Erratic speedo
- Fog lights keep shorting out
- Car died while on highway, lost power steering and power braking
- Replacing front electronic engine mount with a standard one?
- Wierd sound when starting *video*
- torque app not working for the 4th gen
- P0500 code, no tach and flashing overdrive light
- door lights
- Poll:fully synthetic vs. conventional
- LED gauge's
- big windshield crack
- Swapping Out Rusted Fog Light Brackets
- snow? what snow? (video inside)
- high idle after NWP spacer install
- drive axle ?????
- AEM Bypass valve with injen cold air intake?
- What year g35 leather seats will fit 4th gen Maximas?
- ShocknAwe's Performance progress thread
- Need Advice On Buying A Project Max
- EGRC Solenoid Valve Replacement
- Exhaust Sound Clip
- o2 sensor
- Nh
- Anybody use these(yellow fog lights)
- 3.5 swap emu tune
- Anyone set up rear defrost on their Viper Alarm?
- Help! Electrical power 'blinks' when I hit the brakes.
- How I plan to spend my tax refund.....what are your plans?
- VLSD and me. Odd issue.
- WHAT IS ROBBING MY MPG
- belt tensioner pully problem.
- turbo or supercharger? need advice and opinions
- O2 sensor question
- Key fob question
- Help on springs!!
- New prodution for 4th gen Cattman y-pipes
- Maintenance costs getting out of hand
- Mantual Trunk Release Question
- Where to get nissan qx windshield nozzles?
- Ground control owners chime in.
- Brake master cylinder seals?
- Looking for Advice, Starter Motor/Solenoid
- NEED HELP!!! Car wont rev past 2500rpms
- Rear clunking after replacing rear strut
- red/clear eBay taillights question....
- Short shifters
- timing issues? camshaft position senor threw code...
- Cattman 2.5'' exhaust owners step in
- FCP Groton Control Arm Kit 8-piece
- Problems with keyless entry programming
- Convertible 4th gen?
- Inner Tie Rod Replacement?
- I NEED ASSiSTANCE FOR NEXT 2 TRIBUTES!
- Replace radiator support without welding (status)
- What kind of exhaust is this?
- 4th gen maxima making sucking noise at 3000 and ip rpms
- Relay For Fog Lights
- endlinks need to be replaced with sway bushings?
- I want complete 2 and half inch exhaust system for my 99 max!
- $2500 a good deal? How much would you pay?
- Allow me to reintroduce myself
- Alignment - 2 or 4 wheel?
- 05 altima ser rims
- does the A32 cefiro parts on ultraracing.com work on our 4th gens. anyone experienced
- 95 Maxima GXE or GLE for $2400??
- Tweeter Woes
- How to torque the crank pulley bolt?
- Rebarrelled/ widened steelies on a 4th gen?
- MAP sensor issue
- What will set off a 95 GLE car alarm?
- Anyone Ever Watched This
- Fan question????
- Adding fog lights
- Replacing 98 SE bumper with 99 bumper..small issue.
- thanks maxima.org
- What is the fuel capacity?
- Body damage......is this worth making an offer on?
- Brake issue
- Killed my tranny
- 4th gen manual tranny compared to 5th gen
- How to replace alternator bearing??
- cat converter break in time??
- 95 max parts car
- WHERE IS CYLINDER NO 1???
- What do you do when your Y-pipe gaskets won't seal correctly?
- Clutch Bleeding Issue
- LF Billet MAF adapter
- 3 of 4 Problems done. Last problem need of help.
- Mystery spring in tranny pan--HELP!!
- 4th gen tire size?
- strut mount/ bearing gone bad?
- 2 1/4 exhaust and cheap muffler?
- another 4th gen in a fast and furious!!
- Spray-painting grille
- Spoiler LED Brake Light Options
- AUX into bose problems
- 5 Speed Swap
- Koyorad
- Dim parking lights; bad ground?
- My car after one year not running
- Car shakes at 500rpm
- I cut off my muffler!
- A/C Buttons no longer illuminate after replacing Bose Head Unit?
- heel-and-toeing issue
- Everybody's favorite topic...Spending other peoples money!!
- HELP! car starts up then dies everytime.
- Clutch Issue / Manual
- Flashing CEL, misfiring..help!
- LCA BUSHING DIMENSIONS?
- Strange stalling issue on auto tranny?
- Bad Clutch pedal?
- '97 GLE w/ timing chain rattle
- Checked out a 4th gen. Need advice
- "Euro" Headlights I found...Yes? No?
- Car Shakes During Acceleration but not in Neutral
- Nissan accounting for mishaps in their design
- PLEASE PLEASE HELP!!!!!!
- RHD Maxima
- Check engine light cycle time
- Could this be a bad timing belt?
- AC delete - in the cabin?
- My New Ride: 96 Maxima SE
- spark plug gap
- Installed Ebay front strut bar
- 4th gen maxima in rise of the planet of the apes
- Lower Radiator Support pics and helpful hints
- Finally I have a car kind of worth showing- 98 max
- $1,000 maxima, but needs differential, is it worth it?
- Starter (i think) noise sometimes
- Possible to put 97-99 rear bumper reinforcement onto 96?
- rusted exhaust nuts/bolt
- Crusie Control not working...HELP...
- Hating my maxima right now
- Very unusual misfiring
- 1995 se problem
- Down but not Out
- Miss at idle, hard to start when cold
- Another testament to 4th Gen reliability...
- Am i getting screwed?
- Your experience with Ebay Bumper lights
- Just saw this story on Reddit, figured I'd share!
- Looking for ideas for custom top hat/temp fix for crappy plastic one I have now
- 1 click at starter solenoid no start?
- ground effects/headlamps/tail lights.
- Ebay Find, All 4th gens should check out!
- Please Help. 95 Maxima has trouble starting
- slammed on 22's, hmmmm
- Ideas for new 4th gen. car audio write ups
- Problems with STUPID electrical connectors
- How tough to install new headlights?
- y pipe question
- Transaxle and Radiator Question
- 00vi swap high idle help
- What system would be best 150 dollar budget.
- 95 bleeding the radiator ?
- high pitched sqeak at start-up
- man i'm fed up!
- You can do the math :/
- wheel split in two
- KYB AGX Adjustable Struts for 4th gen
- Ignore BOSE???.. rear speaker problem
- Windshield washer fluid motor
- 1997 Maxima fog light.
- Replacing control arm bushings
- Particles coming from defrost onto dash
- 6th gen rotors and caliper in 4th gen
- check engine light
- BOSE?????
- Catch can. Pic needed. Suggestions? Tig weld practice
- free stuff
- yellow fog light bulbs
- Used Progress Coilovers
- Why is the ride still rough
- Lowest 4th Gen Mileage?!
- BAD CAT???
- making suspension noises and wheel wobble
- beater is throwing some codes
- Anyone Tried E3 Sparks plugs in their 4th Gen?
- Rear brakes
- 1998 SE Wing install
- LED turn mirrors
- big problem
- Need Help. Clutch replacement question 99?
- Illumuna + Red spring question
- 1998 Spark Plug?
- Leaking valve cover
- Aux port in stock headunit
- Repair manual
- I think I've found my fuel leak. Your opinion
- Digital Odometer Wrong
- Brown Dash Annoyances
- can i use a non locking tranny in locking tranny car?
- Weird Gas Problem
- lower control arm...
- BYE BYE 4th Gen Hello 5th gen
- Another 4th gen core support nightmare- without rust
- Power Window Woes...
- clock, headunit, wiper blades, cig. lighter, etc. don't work!
- look what i found
- Aftermarket Ignition Coils
- New alternator mounting problem
- How hard to pry on TC cover?
- is she worth keeping?
- Has anybody used g37 projector shrouds in maxima housing?
- Car can't start without 3 injectors unplugged leaking injectors?
- 4th Gen maxima.org maximas are on Youtube
- Lookie What I got at the Junk Yard today!
- Ball Joint Bad?
- Someone replaced the Odometer?
- Block heater specs
- Abs light
- top hat for lowering springs???
- bad steering rack??
- Adjusting ride height for linear spring coilovers
- Doing wheel bearing, problems inside w/pics...
- CARSTALLING BOGGING OUT EVERYDAY!!2 CODES!! PLEASE HELP!
- my mom needs your help
- crystal tail lights for sale 100 GA
- ECU
- mevi and vi??? whats the differnce
- Spoiler Hardware?
