- AC blower motor - Stuck on Removal *See Image*
- CODE# 0807
- Little annoying Ticking sound
- autoseat help
- Intermittent cruise control
- Tokico blue front and rear still a good way to go?
- Hesitation Issue - Possible Fix? (spring stretch)
- Speedometer and whole bunch of problems!
- Cattman Y Pipe Group Deal/Production (4th/5th Gen)
- 5th gen LCA on 4thgen?
- 4th gen gets flattened in Memphis
- Food in the valley lol
- 00vi Swap?
- Time to start my Build thread
- to sell or not to sell!!!!!!!
- Help needed with moon roof!
- buying this max that needs clutch work and has no AC?
- what should i price my maxima at?
- How to remove small rear glass?
- Multiple indicator lights on 95 Max?
- a few problems with my car, help please.
- Workin on headers
- Performance issues
- Two weird problems
- Very odd steering issue
- Bad Mileage - What's next?
- P0443 EVAP
- Multiple Misfire
- lost my gas cap
- What slides thru the right rear drain hose grommet?
- has anybody made sequential turn signals for their max?
- Complete Spark Plug Failure?
- HOW-TO SET TIMING ON 4TH GEN VIDEO
- egr code saga
- trembling when gas is hit and at idle.
- Redline MT-85 75W85 GL4
- "00-01 coils in a 4th gen"
- Reseting Timing on 4th gen maxima
- 4 cylinder maxima
- Need some suggestions...
- "Cylinder 3 Misfire" Help
- Disable SES/CEL help?
- Windshield replacement! OEM or aftermarket?
- KSport Coilover not for A32?
- Can't say no to this offer on a 2008 VQ35DE Engine!!!
- Good-bye maxima.org....
- J30 Retrofit in Progress
- High idle and more...much more.
- P1320, redux
- new rear rotors and pads and hanbrake dont work?
- what size sway bar bushings
- To those with HIDs and Retrofits
- crappy mpg's, please help!!!...
- Speed record for changing the battery?
- Rear Wheel Spacers
- replaced power steering fluid...is this okay?
- auto car wash damage
- another retrofit in progress..
- Having a odd issue...
- Selling Your Maxima
- First Time, Nooblicous DEK swap. Need help guys, NY'ers welcome!! Brooklyn!
- Maf (am I crz)
- Clogged CAT?
- Question on coil pack?
- Fuel injector cleaner preference
- VAFCII install question!!!
- Help no MAP signal to the ECU
- another lighting question
- all out of ideas-electrical woes
- lca question
- Emissions
- How dangerous is riding around with a leaking pass. axle seal?
- Oil Change
- 95-98 A/C compressor wont fit my 99??
- bout to give up on the car:( more dek swap idle issues.
- help with lighing
- HID problem....replacement bulbs
- drill rear firewall behind rear seat
- Whole mess of issues...
- Map sensor
- No fuses blown but clearance and 3rd brake lights are out
- DIY Toe Alignment!
- Headers and exhaust
- 02 sensor help and yes i searched
- Looking for a brake setup alternative?
- Air Mix Door Motor issues
- Rear Tokico Blue HELP (QUESTION)?!?!?
- Sound up front... seized caliper or wheel bearing??
- HID's Or Projectors?
- quick question about manifold gaskets
- New clutch installed...pedal too light?
- suspension
- 2 Quick MAF Questions.
- Valve Covers, now rushing coolant out beneath, wtf?
- Speed sensor code
- Question about removing side skirts and putting them back on
- 3.5 swap! help me get on my way!
- 96 vacuum/whooshing sound from passenger rear
- JUST SEAFOAMED THE MAX-sorry no pics
- Thule Roof Rack
- CEL on, but "no failure detected" when diagnosed
- Taking apart R34's
- 4th Gen CLASSIC.. MUST SEE!
- KSport Coilover rebuild?
- Guess This Part
- Tarmac Sports Euro headlights
- Changing Map light.. Now none of the Valet lights work
- Few things happening with my max
- get a nice performance muffler ?what kind ?
- Axle problems
- Gas mileage woes. (6mpg!!!!!)
- Air Bag Computer Replacement Questions
- UIM Gasket and RTV gasket maker
- DEK Swap Dyno Session
- ECU Reset ?
- What's this switch for?
- Hi, again.
- Did i fry my MAF?
- Keyless Entry remotes
- Removing door bumper molding "Questions"
- Idle Speed Control Engine Code
- Water Pump Replacement...Need help ASAP
- H&R springs
- New "special" paint job ;)
- Belt Whine / new am alternator
- R34'S IN WITH FOG MOD
- Optima Battery
- lower oil pan gasket
- PO1447 HELP
- CEL CODE p0138: High Voltage
- Aftermarket b-pipe
- Greddy SP2 broken baffle..HELP PLZ
- Best clutch for the 4 gen?
- Reminiscing the old .org
- Help identify this sound...
- Leaky sensor
- New "Ram-Air" set up!! Professional install...
- PICS OR YOUR 4TH GEN DECALS/STICKERS
- A/C Compressor Suggetstions
- Maxima wrapped in Matte Black Vinyl
- confused with codes
- Squeaking noise coming from Front Driver Side Caliper
- clean your maf!!!!!!
- PO340 and................
- VIAS Power Wiring.
- Install of A-Pillar gauge pod
- 5 speed trans issue need input
- For those of you who have done a clutch job....
- exhaust pops and crackles?
- To the guys (or girls) with 3" exhaust
- AC Recharge in a '95 SE
- getting 9-10 mpg what to do??
- buying a 4th gen with problems? anyone may know whats wrong?
- Couple Codes Here
- Pl0x Halp Me - Find the Alternator Ground
- To change or not to change, Rear output seal on boosted 4th Gen
- Greddy SP2
- trans problem
- MAF Question
- Shortened Koni Yellow & KYB bumpstop questions
- Cruise Control dash switch for DRLs
- Restoring headlights.. Help / Idea's
- STRANGE stalling problem
- A/C and fans always ON with climate on, normal?
- take a look at this picture and help me with my noob question (exhaust)
- led door handles
- New Headlights installed R34
- wheel fitments.
- what happen?? o.0
- custom maxima springs
- idler pulley bolt is loose
- Changing My Spark Plugs Again!
- oil pressure switch question
- does anyone have their map sensor hooked up with their 3.5 swap
- Wheel size debate
- Drivers side drive axle automatic
- DROP ZONE SPRINGS??
- I have Tranny problem :( bad tranny? Synchros?
- Is it time to clean my EGR tube?
- side molding on doors
- Quick question about o2 sensor location..
- Which spacers to buy??
- Cooking coils like mad
- No ABS on a 95 SE Auto?
- Grease leak, how bad?
- Valve Cover Gasket Replacement...
- Nissan no longer makes valve shims!
- sounds like wheel bearings but ??
- wow!!! maxima with over a million miles!!!!
- 95 SE Noise Problem
- Clunking noise when turning
- 4th Gens with I30t BBS Wheels
- Hood bouncing?
- Swapping my 350z rims to my 4th gen maxima
- Installed Injen CAI today
- Brake swap Question
- how much to repair broken check engine light???
- Mirror shell
- Everyone Welcome, Need Advice!
- AC comprassor not starting
- Decompressing shock springs on struts DIY
- Brake Pads and Rotors
- Found some Strange looking Hanshin's..
- Remus Muffler
- 97 heater not working
- Ordering parts for tranny rebuild
- 3M Headlight Restoration success
- Knock sound at starup?
- 4th Gen DIY website is back: motorvate.ca
- Just got my Blues and H&R springs
- Anybody have greddy e-management in their 4th gen?
- Off-season tires go flat during storage
- 00vi VIAS Control Solenoid Valve Current
- My car shifts wierd at 60-80
- HID troubleshoot
- Headlight R34 clear plastic discoloring/cracking
- People with H & R Drops..
- Question about gauge cluster and center console lights..
- Metal sound clicking when motor is newer ?
- Brake Upgrade
- idles high and wont pass 2000 rpm
- How wide is the back window on my 4th gen?
- can you fix THIS Light!
- Wiring through Door Rubber Boot
- Which to replace first?
- Wheel stripping and repainting
- TRANSMISSION SOUND AFTER 5 SPEED REBUILD?!!!
- 4th Gen LED Dome, Map, Licence, Trunk Conversion Write Up
- Stech or Eibach
- Issue with Vacuum System, maybe?
- truck lid opener?
- water in rear light - pic
- Noise from brake or belt
- Signal to starter but no crank-running out of tests
- Car runs like crap in drive.
- Phone apps
- Practical Suggestions for a Tall guy ...
- Gear lever stuck in reverse
- Name That Part
- NEED BIG HELP ENGINE FLUSH OR NOT????
- eBay parts...
- Drop in MPG after using premium
- Hole in EGR Tube
- car making wierd noise when starting (starter?)
- Can I use the steering colume from a 1995 in a 1996?
- idle issues
- MPG increases - plz help brainstorm
- Chirping from the clutch?
- I have a p1336 code
- Weirdest DEK Swap issue
