- quick question on tire pressure
- Got An Ecu Fault :(
- finally got my bodywork done
- Y-Pipe for 98 i30(maxima)
- courtesy light is dim.
- Gold Foglights
- Blower motor on fire?
- SP2 vs. Evo2
- Crank NO Start--Any Ideas? PLZ HELP!!!
- Euro Clear Black Headlights
- cheap mods from ebay
- installing digital gauges
- Serious modding decisions and I need help
- 0304 code gone after new plugs!
- any ideas on how i fix my stereo? (CD Player)
- 95 Maxima Belt Tensioner needed
- '96 Max actining up, CEL and stalling.
- Got into a car accident..need decent in-expensive bodyshop
- Please Help!! Should I Use Seafoam???
- Paradox Spoiler!!!
- 95-96 fog brackets vs. 97-99 fog brackets
- New Springs....
- How many???
- Changing Transmission oil
- To people who have sarona grills
- Torque Wrench -- Knock Sensor Q's`
- Startin to feel harsh gear change!
- struts gone bad
- spring pics please
- Rear Sway Bar
- anyone riding on ebay coilovers?
- wtf is the little light in the brake light for?
- sprint/agx sucks...
- Big tax refund!!!!!! time for Illuminas+S-Techs
- what's the belts name?
- will a 96 warpspeed pipe fit a 95, does cali spec matter?
- Mesh grille pics
- switch placement for my cold cathodes
- mevi question
- What Is The Point Of This???
- need a favor from 95/96-ers with cameras
- 18" g35 coupe rims on a max
- tinting tails gone wrong..
- Starter getting old?
- HELP: noise when turning the wheel (slightly)
- Lyell Exhaust VIDEO!!!!LOOK
- Where can I buy a ABS cable for driver side (front)
- Shock sensor question???
- Trouble starting - wasn't neutral safety switch
- New Brakes, Oy! *Pics*
- the damn roof leaks!
- where to put seafoam?
- warpspeed y-pipe mandrel bent bay area
- 1999 max wiring diagram
- about to smog this week, any advice...
- Refinishing Rims
- Hit a pot hole/ HELP!
- chances of getting hydrolocked with CAI
- Auto - Manual Conversion
- Losing engine oil after long distance
- Header and Y-pipe install
- Can't Get Rear Caliper Piston IN!! HELP ASAP!
- Lowering the max
- Help
- About to do some maintenance. What do you suggest??
- Surging at 2000 rpm
- My exhaust setup....
- Red/clear tails from cm question.....
- Pulley problem on 97
- ACT Stage 2 clutch?
- Injen Cai
- Tint pricing?
- Bumber Clears
- 02 Sensor and Spark Plugs (Sorry Couldnt find Search)
- Center Console
- strut bar problem...
- What trim is this? NEED HELP ASAP!!!!
- I Was Tricked!
- Fusible Link # Battery Question
- Good makers for Y pipes?
- Need help diagnosing O2 sensor problem...
- Problem with chrome door handles
- Found Red Clear Tails On Ebay 95-96
- Need opinions on this new dash gauge install
- Adding automatic climate control, how difficult?
- what is this?
- Need HELP!!
- removing steering knuckle
- rats chewed thru my wiring harness.
- Type II Wing
- RSB and ride comfort
- Which one to buy? Need some help
- Full Suspsnsion Recommendations? (Shocks/Springs/Sway/Strut Bar/etc)
- Light whir/rattle on startup...
- Skyline Tail light mod
- civic lip custom fitted to max...help
- oem replacement struts
- Does anyone have the 12k HID kit from cutsommaxima.com?
- Need advice/help on changing Water Pump
- 95 GLE Strange Stalling Problem
- license plate lights??
- replacing antenna: outside nut removal
- anyone have this kit
- Clean car, new pics
- $20 off Fortis Grill Guards!
- anyone ever hear of this brand of HID's?
- 9004 to H4 conversion?
- How to...
- Ok here are my issues can u help?
- Got a question.
- anyone have this picture?
- O2 Sensor codes/No Radio Display
- will these melt harness....
- slowly but surely
- Knock sensor was replaced...
- mevi install help
- AE mod and angel eyes installed.
- New Guy In Town
- what is this?
- reasons to die on start
- 20 mpg @ 90% highway @ 75-80 mph?
- Aluminum trim
- strut replacement
- Alarm Question????
- Possibly getting new 4th gen
- stalls
- Will they fit ???
- Bulb Q?
- flushing radiator fluid
- Should I put evo 8 seats in my maxima?
- Stuck Anntenna
- Removing wood dash kit..
- painted door panels and engine cover!!
- ? regarding leaking cv boot grease
- Key hole Camera
- Leather door panel inserts
- mass air flow / front left htd o2 sensor.....dies on start
- wtf car wouldn't turn over
- Cleaned Throttle Body
- Changing security light color
- Good chicago weather, took pics*
- Suspension question
- S-tech's + 18's
- Exhaust recommendations
- Help!! Suspension question
- 97 Max is in the shop, I don't know why yet...
- anyone know anything about/ or have BSA wheels?
- Upper Strut Bearing replacement
- 95 maxima wit 05 altima ride height
- Need rims for mym95 maxima. forest green
- I need help wit rear struts
- looking at wheels...what size tires should i use on the 18's?
- what security do you use
- Does My Slave Cylinder need to be replaced or something else? *pics*
- oil pressure gauge install
- Gauging interest in
- Proper Ignition Circuit Condensor resistance
- Clutch gradually grabbing higher!
- Need a picture of behind the Instrument/Gauge Cluster (w/Airbag Light Bulb) 96 Max
- Outer tread
- Chrome handles with woodgrain switch covers (pics)
- Difference between 2K and 95 Engine
- Suspension
- how are 4th gen rims made? cast or forged??
- Need headlight pics
- HELP! highbeam indicator stays on no matter what
- Muffler Recommendation
- 350Z Sport Horns - 4th Gen Plug and Play?
- Bomz cold air intake..... Good??
- b-pipe + muffler
- K&N conical air filter...
- cv joint boots?
- 1995 Maxima ECU A18-E24-ER5 can you help with information.....?
- Is It The Clutch?
- part number for 5spd cali spec ECU?
- how big of a job is it....
- Need a Y PIPE That bolts directly to stock Mani!!!
- problem wit sidemarker rewire
- Coolant leak (from near oil pan)
- Longevity of VQ and Auto trans?
- What spacers are the best
- rear wheel camber adjustment?
- HID not lighting up, what to do?
- Armelius's POMOFOCO Sound Deadening
- My tinted tails.....
- Starter Problem-Help
- O2 sensor RUSTED STUCK HELP!!!!!
- How to aim headlights?
- New pics of my maxima, tell me what you think
- Clutch Noise
- bomz intake hole
- Cat back exhaust??
- Needs help with knock sensor replacement "How to"
- damn drunk people... leather's a precious thing
- spark plug question
- Pls help: Brake caliper piston wont retreat
- Spilled fruit punch on carpet...best carpet cleaner?
- Vibration through gas pedal when suspension unloads... ideas?
- Best Aftermarket Alarm? Maybe remote start...
- help needed!! maxima 96 cigarette lighter not working
- paint between front and rear door
- interior lights
- What size super bright leds for the clearance lights?
- Grounding Kits
- Hacked Air Box mod....awesome mod
- Car Start Problem - Seems to stay in gear
- Alignment problem
- Anyone have a HOT pebble beige maX?
- 98 maxima headlights..
- cars in the shop..
- how to make turn signal and clearence light alternate?
- HKS catback...
- wondering what to do next
- best place to get higher wattage harness for PIAA headlamps?
- Clutch Slave cylinder?
- cold and warm start<~problem
- knock sensor harness question
- can i buy the lights for auto climate/ hazard etc?
- Eibach Springs (what do they look like?)
- Another repaint thread
- Anyone have a Tein-S tech drop with a Stillen lip? Clearance issues?
- part1 es bushing install...
- question for brake guru's about the rear caliper and how to remount it
- Help, how do you pop out the hazard and defrost buttons from the housing?
- weird
- Starting Problem
- Supercharger Like Whistle Sound, I Like It, But Wheres It Comin From???
- alignment questions (after lowering)
- SES light blinks then disappears
- 98 GXE Transmission Problem - HELP
- MEVI w/ no ECU upgrade on AUTO
- car making koud noise
- underglow help
- coilovers or H&R springs?
- visual differences between generations
- what kind of short shifter do u use?
- Sterling mist?
- Stone Racing Headers
- Dash Reverse Glow Gauges Replacement
- Will new Knock Sensor get me better milage?
- Stillen Front lip installed :)
- What does ur max idle @ in drive?me=850
- How ANAL are 4th geners v2.0
- Headlight housing fried?
- Rough idle when in gear help!!!
- where is the IACV located????
- Front Strut Nut Problem
- Auto Tranny - Non-locking to locking?
- Reprogramming computer
- Coil down....need help!
