- Post Pic's of your 4G Maxima!
- Switching to synthetic oil
- Quick question
- 1998 maxima oil on the engine issue
- Have fuel + spark but not starting
- 97 Overheating. $20 fix or blown HG?
- How do you disassemble the key fob?
- Puzzled revolution sensor code stored in tcm.
- Spoiler
- What would cause my radiator fan to burn out like this...also looking for new harness
- Confused..
- Brakes Suddenly Stop Working
- TC Tensioner Transplant
- Tail light wiring
- Front caliper question
- My Time Capsule '98 Maxima SE
- Rough Idle Help
- Purging the smoker stench?
- Battery/alt.charging issue
- Low profile tires ?
- Cranks but won't start
- What is the bolt size holding the rear valve cover ?
- Lowering 97 Maxima GLE
- Automatic Transmission Shifter Suddenly Hard to Move
- Strut Access Hole Plugs
- Acu 124
- Ordering parts for '99se with 3/99 production date
- Parking Brake Cable questions
- Waxing interior vinyl
- I can't believe what keeps happening to me! Wrong A/C Part!
- What Size is the Steel Brake Line Tubing?
- A word of appreciation for this community!!
- Engine overheating
- Operation abort: EGR is not getting replaced. Will it live?
- strong gas smell in garage after driving - evap canister?
- Tc-w3 additive study
- My Maxima cost me $425 in damage to other cars
- Trip B resets itself
- Need help
- Where to go to have A/C vacuumed and refilled
- Hood Liner/Insulation Repair?
- Help with a 99 Cal spec part ID
- Wheel hub
- Fresh Air Improvements With An SRI ...
- Feed My Frankenstein
- idle screw is stripped....
- idle drops below normal + service light, codes coming
- 97 3.0 issue
- Put it back together and horrible knock sound
- Manual transmission noise
- Two Fuel Pumps - One Weekend
- Water draining from trunk tail light
- Center Dash A/C Vent Problem Resolved
- where is this part on the intake?
- Different tire size and rim
- 95 maxima will not start after it gets warm
- Help!!!
- Cluster Problem & Solution 4th Gen Maxima
- Codes and Instrument issues...
- OEM SE Springs colored paint spots?
- is my idle too low? 500rpm
- LIM Fuel Rail Thread Broke
- Mystery: P1493 EVAP Canister Purge Control Valve
- Smoke coming from starter, no start, please help my dudes.
- (Reference) Tinted tail lights comparison
- Good or Bad idea to get a junkyard A/C condensor?
- K6 Sport Mirror With Turn Signals
- Need Help Please! Internal steering wheel parts needed asap!
- Overheating when in traffic
- The pull-a-part gods were very generous
- Check engine trouble code links no longer work
- Gauge Cluster LED Hotspots
- 1996 Sedan - Quality
- Thank you Orgers
- Rear caliper brackets loose
- Part name
- Alpine 3342 equalizer
- Best aftermarket struts front and rear
- How Test Or Evaluate The Gas Cap?
- [Speaker wiring help] Bose system to aftermarket - IMAGES
- Where to buy idler pulley
- Front Strut Dilemma (or not)?
- maf sensor wire is jet black..
- Really want to save this car but dont know where to start
- fender hood bumpers
- Stalled, Barely Start/Ran with Gas Smell
- 99 I30 Maxima trunk lid brake light question
- Gasoline Fill Area Grommet Reinstall Help!
- WARNING: These bulbs do NOT fit the 4th gen climate control 95-97
- Can't seem to diagnose heavy shaking from steering wheel...
- A/C system refrigerant leak fix season
- rubber sleeve inside coil spring torn
- Rough idle and chugging under acceleration.
- piece of vq30dek on vq30de
- Is $600 labor a fair price for radiator support replacement?
- Y Pipe Exhaust Leak
- rear calipers & cable replace advice needed
- Starting issue, HELP!
- 99-mair cond sight gage?
- Fuel Injector Rail Plastic Washers
- Anyone use the ACDelco Professional High Pressure Power Steering Hose?
- Stillen kit/Performance mods
- 00VI issue
- Nissan PSF "equivalent" to Dexron II ATF?
- Alternator Area Smoking Won't Start
- '99 Max Having Trouble Climbing
- Door Locking issue
- oe resonator diameter or circumference ?
- Installation for Lower Control Arm Plate
- EGR valve replacement
- Clamping Triangle Flange Together?
- My Maxima is still overheating
- Door is locked shut. Can't find answers
- Fan Tstat Issue
- Fog Light Sub-Harness Damage | '99 SE-L
- Do I have to change automatic transmission fluid?
- If you ever need to replace the radio, get these tools!
- Possible Bad Knock Sensor - 22060-30P00
- Misfiring
- Installing Steering Rack Boots
- Projector lighting question
- Motor Mount Electrical Sensor Wire?
- bank 1 sensor 1 (o2 sensor) location
- Adding Exhaust Hanger
- Wheel Color Change
- NGK IFR5G-11 fixed engine pinging rattle
- 99 Maxima crank no start debugging
- Changing and Bleeding Brake Fluid - In a hurry.
- where to find i30 trunk lid emblems
- Solid metal lug nuts
- 4th gen maxima rad support
- Scanner recommendation (<$100) that will show CKP Sensor Info on Crank?
- How long till the ECU detects change from sensors
- Subframe Bushings???
- Emissions testing repair for codes..
- wrayth motor mount review
- 1998 Maxima Cold Start issues
- suggestions for a new muffler....
- Forgot to unhook battery now car wont start
- What is this hose?
- Replacing fuel filter hoses
- Is it possible to hard wire door or trunk switches for testing?
- 98 maxima keeps shutting down at red lights
- Power Antenna probs
- finally tackled the egr valve.....
- started to install my amp and found this
- Sunroof tilt open only works
- little concern about idling.
- What else to replace
- Maximustang has passed on.
- Idles at 400 RPM
- Making Cold Air Duct For SRI
- Different sway bar bushings for different trims??
- How / why do tie rod ends & ball joints lose grease?
- Blowing 120 amp fuse
- Coilover Install - Steering Knuckle Won't Go Back?
- Electronic suspension
- Help With Adjusting Ride Height on Coilovers
- HEAVY stumbling on acceleration - no code
- Keyless entry question
- New Injector Cap Slightly Broken After Install
- glove box is broken, how to fix?
- Can I use a thinner cotter pin for axle / wheel hub?
- Nut Came out with Stud, o2 Simulators, RTV for Exhaust?
- Paper on top of strut
- Axle seal dust cover doesn't fit new axle
- Recommended Coilover drop?
- Passenger side cv axle stuck hard
- Stalling unknown cause.
- Rusted Exhaust Bolt No Longer 14mm
- how to replace negative battery cable?
- Theft Prevention Question - Do I Have Immobilizer?
- Blown Head Gasket ?
- EGR Exhaust Pipe Wont Install
- Low oil light came on
- Axle won't go in all the way
- Faulty Steering Wheel Ground
- Extracting this Broken Bolt
- did nwp make an egr block off plate for the 4th gen?
- 1st Cylinder Much Cleaner than the Rest?
- Painting My Max: Need Help
- 2nd time, serp. belt gets edge torn off!
- Ideas for new suspension setup
- Getting the axle seal in straight
- Smoke on Acceleration
- Rear Valve Cover Bolt Broke
- Huge Favor - Take Pics of Your IACV For Me
- Removing Top Rear Strut Nut?
- Inner tie rod lock plate
- Help Salvage this IACV
- Help with Removing UIM
- Tie rod thread direction
- Rear Strut Bolt Came Out Stripped and Then Got Stuck
- Help with Coilovers vs. Lowering Springs & Conversion?
- Clicking in passenger footwell
- Where does this wire go (alternator)
- Ghetto but functional torque link!
- Speedo cluster repair in UK
- Oil Leak Pictures
- Making the 4th gen safer in collisions
- Axle Shaft End Snapped inside Transmission
- Removing the top bolt from the right hand drive axle carrier
- 95 Maxima rough shaking in (Drive) gear
- Cat Delete Sound Concerns
- What should be plugged in here? (pic)
- Will two different brands of shock on front affect performance?
- 1996 Maxima GXE lost electricity power while driving
- Finally sending the speedo cluster out. Who did you use?
- Low End Power N/A Catback 2.5" Mandrel, 3" Crush, or 3" Mandrel?
- Can someone tell me where this sensor plugs in the engine bay?
- Busted axle or wheel bearing?
- Inner TC oil leak.
- Do I, or Do I not pressure wash the bay.
- H&R 53059 Sport Spring [Pictures]
- Shoutout to Warpspeed for my custom exhaust solution
- small dent on hood by support lift - how??
- Decent wheel hubs assemblies?
- CV Axles for open dif 5 speed
- Transaxle output shaft seals - manual
- P0304
- Help identify this sound. Exhaust manifold?
- Pulley or just Alternator?
- New Ignition Switch for the 98 Model
- Is it worth fixing?
- Car starts, idles okish, power quickly drops off under load
- o-ring on the motor oil dipstick?
- What do you guys think
- My new (1995) Maxima, and engine noise
- Weird CEL problem
- brake hose life
- Leaking radiator fluid/water pump
- 1996 Maxima - How is idle controlled?
- Ecu and vin number question
- Tips on inner timing cover o-ring replacement
- Gains: OBX or Ebay Headers+Warp YPipe?
- door fitment
- Best Filter for Changing Clock Color
- Hood Prop Rod Interchange?
- Parts Needed if Getting Tein Basic Coilovers
- Applying Brakes blows stop light fuse please help!
- 5 speed tranny question....
- Custom Header YPipe for 99 CA Spec?
- Maxi leaking oil once again...
- KYB SB104 Boot Fitment Problems - What am I missing here?
- finally!!! got a code after months with a p0300....
- How do I reset the tps sensor
- new "value advantage" air filters from Nissan?
- acceptable tps voltages.....
- Clear Bumper Lights - 2nd set - different 4th gen
- Need help !!!
