- stock wheel sizes?
- Outlet size
- Changing color of stock foglights bulbs to yellow
- MEVI is installed
- looking for low profile sunroof wind deflector
- Suspension debacle- How should I fix it?!?
- Strange clicking sound in first and second gear?
- Anyone Try Hyper Ground Wires?
- LuK clutch installed
- Maxspeed Springs
- Grounding the Transmission
- K&N air breather question!!!
- MSD DIS 4 Ignition System
- Straight Pipe…
- Buying a 4th Gen Maxima soon... Which one!
- custom made grills
- B&G Sag - again
- looking to lower and rim my car
- Hyper ground wires
- Just Installed LEDs on the brake light. but...
- Looking for KYB GR2.
- Is pushing down on the front/rear end a good way to compare stiffness of suspensions?
- Quick Y-Pipe questions!! Please help
- Nissan Consult
- i found my annoying rattle!
- Blue LEDs in switches
- 0-60 good 60-0 priceless
- Different Style REAL Chrome Gauge Bezel!
- Front door speaker grill?
- Is my odometer not working correctly?
- new pics, check it out!
- Feel the need to babysit your Harlan RPM switch? Look here...
- error codes
- ionic dynamics + stillen
- car squeeking at low speeds
- Aluminum Dash Kit
- Selling the max
- Muffler Tips
- wiper fluid adjustment?
- higher sunroof
- please post if you have mesh wheels
- Middle Eastern Variable Intake (MEVI)
- Anyone have/know about Excel wheels?
- cleaning Headlight?
- Blue Light after market.
- ~ two Questions ~
- Front Personal Light
- Tint = broken keyless remote
- A/C Controls
- My car lower???
- Wiper arm
- is my act supposed to chatter like this?
- Part number?
- Serious decision to make about my maxima!
- slightly ot but has to do with my max...money order question...please help
- floormats
- found out why my car is pulling to one side
- Ypipe install
- This is what happens when your MEVI doesn't open in 3rd gear at the track
- Last Weekend First Time At A Track
- Got into accident Saturday...
- BEST CAI for under $225????
- does the maxima drive faster after 30000 miles?
- What Tire Pressure Becomes Dangerous?
- how to get my name off this site
- No NGK coppers for '95???
- indiglo door sills & turn signal mirrors
- Whose car???
- Bosch spark plugs from dealership?
- Warm engine sometimes takes long time to turn over. why?
- Mix Matching Aero Kits Stillen and Sarona..Opinions needed !
- I have a clutch question
- Just got the Maxima couple questions............
- Heating Device broken?
- directions on how to get seats out ASAP PLEASE
- does anyone have part # for K&N intake to adapt onto CAI setup
- Frankencar - Are they screwing me?
- Help, someone with FSM
- finally got pics of my maxima
- CF Hood
- Sprint or Eibach Springs with Sarona Kit
- Could this be a starter problem?
- 96 SE strange acceleration condition
- Anyone have pics of Chrome Rings?
- Windows roll down with remote...SWEET
- Fail Safe Mode
- carbon fiber door pillars
- gaugeing interest in dash mount gauge pod
- urgent please help rewire - blown fuses
- How soon should I change out these dust boots? (pic)
- anyone know where to buy a cheap clutch?
- for someone that knows of electronics
- Cuse is in the house! Oh my god! Oh my god!
- 97es300 vs 97 auto max
- Any suggestions on what next??
- Has anyone ever tried these?
- how much
- Calling Out All AUTO MAX....
- Abandoned 95 SE in Huntsville
- reverse glow gauges
- help me... how to change REAR brakepads??
- Interesting Ebay find
- People with aftermarket HID - Please Read...
- When airbags deploy, do i have to change the sensors?
- Nissan Maxima Injen Cold Air Intake : Does anyone have this?
- car vibrating at idle
- Skyline Tail lights on black MAX
- cold air intake
- Some pics of my lightly modded '97
- Castrol GTX High Mileage (green bottle)
- I just paid $250 for KYB GR-2s......
- Who has eibach pro springs?
- Do you have to replace the strut mounts when you replace the struts?
- anyone with the search function help!! BODY KIT!! COMBO!
- Pathfinder TB Pt. II
- second post: Stalling problem
- '97 SE Stock Theft Deterrant System Location
- Installing Remote Start - where's the alarm brain??
- Clock rewire so always on?
- having big problems installing ebay CAI
- weapon-r/ ram air kit
- ECU reset?
- 2k2 GLE wheels on 4th gen pics
- Bro Just Got A Max.
- Rims from Acura fit on Nissan?
- Maxspeeds or H&Rs??
- Hmmmmmm.... Will this wheel size fit?
- quick question
- Pathfinder TB
- y-pipe for New Yorkers
- 02 sensor part
- How many HORSEPOWER do these modifications add ?
- 17"s or 18"s???
- Octane Boost?
- help me decide... what ya think??
- Alignment Question: Camber and Toe Setting
- Replacing OEM Fog lights w/ Aftermarket ones
- Defcon6 RIMS for MAXIMA????????????????????????
- Guys I NEED help
- engine specs on J30
- Rear Window Molding
- Are these really that bad?!
- Knock sensor - where to buy
- All lights off
- 99 Maxima Corner Lens
- Anyone with a factory, hanes, bently, etc. service manual
- Cheap Mods
- Door Lights?
- FYI for people looking at AGXs with Ground Control Coilovers (&maybe other coilovers)
- Which Radar Detector?
- Silver Stars
- Z3 Fenders.. Opinions..
- Starter won't crank sometimes
- Blinking AirBag light on panel
- Putting an x86 computer in car. Anyone want to help? (long)
- Whats the deal with these 1157's PIAA
- Overdrive and gasoline
- Problems with suspension install...H&Rs and Tokicos...
- battery and abs light on
- A/C Problem...maybe
- Raybestos Quiet stop part numbers
- Dunlops SP A2s vibration
- Jwt Ecu
- VERY quick (and easy) questions!
- Torque Specs please- tranny
- Any other CORNER LIGHT colors other than polarg?
- first time at the track and ran 14's
- Some good seats?
- Stalling - check engine/slip/TCS lights all on!!
- Newb question, are these real?
- 100k tune-up??
- Help Me
- What type of light bulbs?
- Engine Question???
- Trunk Mechanism Question
- complete step
- Unkown Maxima Owner
- bypass blower? (belt size)
- Changing the side parking light next to the headlight
- Choke?? TPS????
- Where did you get your FSTB and how much was it?
- Gapping
- blew away acura
- injen intake filter
- Installing RSB - Need a HOW2....
- problems. help!
- TRENZ grille and painting...
- new intake
- Rant and Rave: bad day
- BIG Problems!!!!
- LEDs in all external lights a good idea?
- Sound..
- More power & a smoother engine, I did 60K service this weekend
- All Clears
- Will INTAKE along with Y-PIPE do?
- whining noise when accellerating and braking what could it be?
- Putting on a hitch...good idea?
- Window making loud buzzing sound over 70mph
- Clutch slipping
- Take my name of the 4x4 list
- I have wear on the inside of my back tire. Why?
- Stalling Problems
- Ripping apart SE Fogs
- belt change/ how to HELP
- Clutch
- New S/C kit for the 4th Gens
- wheel alignment question
- How to brighten clearance lights?
- Switchin' Grilles
- ran against CASS98SE last night
- Would it be worth spending extra money to buy a 97 max rather than a 95 or 96?
- Corner lamp removal
- Wiring Diagrams?
- ECU Problem? Recurring 9-1 code after replacing O2 sensor. Please Help
- 95 SE stock tire size
- Which Tranny Cooler
- ADDCO RSB... it's adjustable.....
- *gauging interest.. Chromed Intake Manifold and Valve Cover
- Max just bashed by HUGE hail!
- Does anybody have aftermarket cams??
- Brake question...
- Tranny broke PLEASE HELP!
- ahh!! what in the heck did i do to my tranny?
- JWT cams and ECU
- Got my Maxspeed/Kyb Gr2 installed today!
- How do you like your MEVI for daily driving?
- Custommaxima.com Discount?
- ATTN: ALL suspension gurus.... what will i need??
- whining@high rpm
- Someone help! Carfax needed
- Daytime running lights
- Lighting problems
- Engine oil change
- Tire Size, did I screw up?
- aftermarket foglights install
- What should I use to reattach my nissan emblem?
- Sh*t..do I Need A New...
- How bad would it be to drive with tires from 2 different brands?
- *New Pictures* -- GTR_RIDER
- 96 Max timing chain\belt problem. Help please.
- Frankencar: Apexi or K/N
- Color of Power Steering Fluid?
- Dyno video from my Max
- Alarm Siren Location??? Where is yours?
- had tranny rebuilt and gauges dont work?
- Reverse-colored Nissan emblems?
- how to remove stock ebrake handle...
- Trying to put in 1157 bulbs
- I'm Getting Sarted.....can anyone help?
