- Sarona Bumper
- any thoughts on installing an mp3 player?
- the weather's effect on performance
- Not another Intake thread!!!
- Parking Brake
- Exhaust Information Thread: (With Sound Clips)
- Where to put the speaker for alarm?
- 2k4/5 Rotors, Brakes -> 4th gen?
- Rought/lumpy idle on start up?
- 1996 Max torque converter issues?!
- where to get rpm signal?
- Cryogenic intake.......
- Best intake system ever!!!
- so this lady hit my front end...what now?
- greddy vs apexi
- Whats a good place to get O2 sensors?
- what do you thynk of these mirrors??
- Interest in 95-96 CF Trunk?
- Lowered with stock wheels
- '98 foglights?
- Carbon Fiber Lip installed.. Tell me what you think?
- Help please-just finished brakes all around
- How Dark Should I Tint?
- I finally finished the how-to write-up for "Ptatohed's back seat fold up mod"!
- Pics Of Blacked Out Tail Lights Please
- MAP solenoid valve
- 99 gauge cluster in 95 = NO!
- H Tech springs
- sputtering like a miss but only at idle in drive
- Installing OEM wood dash kit
- Help with installing HID
- HELP PLEASE-Alternator
- Door Lock Remote Problem
- whos the guy that made the custom shift knobs??
- can I pass inspection by resetting SEL?
- Anyone experienced the car locking by itself?
- Spoiler Question
- urgent my battery ran out. help someone help
- trunk mechanism won't latch
- Custom Maxima -vs- Redline Max clear/red tails
- stoopid clock question
- Braking caused engine stall?
- Surging Problem - KS or TPS?
- Good quite muffler
- Trunk Gasket Leaking
- Lookin For Silky Smooth Idle
- what are the right type/style lug nuts??
- stock exhaust with y vid and some...lol
- Estimate on painting rear bumper
- How many pennies to paint/install lip kit?
- Trans Fluid
- morning starts (cold) throttle response is this the ecu?
- Ground Controls w/????
- About knock sensor
- So how are Bosal mufflers?
- Broke the clutch pedal - 5spd converted gle
- warpspeed is doing the ypipes for 160 for another week
- How about an Exhaust soundclip sticky?
- what next
- Altitude Change...Anything to Worry About??
- speedbump damage to my exhaust
- Just how harmful is the knocking?
- crashed my max today :(
- 1999 Maxima Factory Manual
- Cleaning out throttle body
- Quick question guys, long time no post, so work with me
- Those with ES CA Bushings Step in.
- Sylvania Silverstar = Short Life Span
- RPM gauge goes CRAZY!! Can I fix?
- Bose stereo buttons broken, can I use a non-bose?
- what is this??????
- Anyone have a setup like this?
- Black plastic cover under engine
- side view mirror help needed.
- noob debaging question
- pebble beige people come
- I think my oil pan is wrecked!
- Best 4th gen. header/Y-pipe combo?
- Suspension - springs, struts, coilovers
- gas light
- Timing belt slipping after RWD conversion
- homepage just updated! XBOX, TV's, System, 18"s!
- My Stillen exhaust sounds like ****! Anyone notice this?
- Please Help!!!! Car won't start!
- To those with airbag lights on...
- Weird idle problem
- How much is resonable price to buy used A/C Compressor???
- 0409 (rear bank 02 sensor) code keeps coming back :(
- increasing low end
- Installed ss clutch line having problems PLEASE HELP
- gen ll tails
- ks question
- Flipping out! Car wash f'd up my rims!
- belt size for udp and only alt
- 5th Gen clutch question
- New headlights, now I run lean?
- CE Red/Clears sent out today
- how much for a tran. swap?
- new coil overs and springs
- car locks by itself
- Digital Odometer question... Help please...
- CF Sunroof deflectors?
- Check Engine Light Off But Can't Pass Inspection
- In window vent visors...
- camber plates for H & R's??
- z32 bbk people STEP IN.
- oil filter bypass valve - opens at high rpm
- New STILLEN Supercharger kit for $3000 at SCO!!
- People with Illuminas
- Ummm Problem again!
- Car will not go into reverse
- z32 calipers and stainless lines
- need help with 09 02 cel code ?
- topspeed y pipe . ..
- Need alignment after lower control arm replacement?
- technosquare ecu MEVI program?
- taillights for 97-99 will they fit?
- Acetone in your gas tank!!!!! EVERYONE READ THIS
- Few questions regarding the rear main seal
- Going to get a paint job this weekend....
- Trunk leaks!! WTF??
- What is the smartest way to replace my chrome door handles and window with SE parts?
- knock sensor tutorial
- Totalled the max...
- wheels weight
- 266k miles and OH NO......PLEASE HELP!!!
- Nissan Maxima Keyless Entry Remotes & Programming
- Brake upgrade - stop 'n go environment
- Shifting an Automagic?
- Axle Boot Failure
- 300zx Brakes
- Piston Spinning
- Question on a y pipe
- knock sensor
- A/C Trouble
- Painted Mud Flaps
- need help ..have to replace my windshield
- Leaking oil.. but where?
- I got no muffler or resonator
- NTBK 9007 upgraded harness low? high?
- Stalling Issues
- help w/. weird elec/fuse issue
- stillen rear valences are boring....
- used, or cheap motormounts
- Tearin' it apart! Intake-Man removed (pics)
- Electrical issue
- Questions regarding HID
- how is the topspeed y pipe?
- Question for a rook
- how do you install a muffler
- What causes high idle?
- Hood lifter holder supporter thingie... CF hood owners plz help
- will i see a diffrence
- All Ones Baby
- Dirty White Paint
- M-bumper
- 0446/0440--evap system?
- Vehicle Speed Sensor 0104
- Non-Boss Stereo from a 2001 Maxima in a 1997 Maxima
- braking problems
- Windows And Antenna Not Working
- Annoying noise
- Legality Question
- EGRC Solenoid valve... CEL
- Help! Clutch Problems! Wierd..
- can some one point me in the right direction
- Gasket Set Part Numbers??
- I'd like some opinions please
- Help me please.....!!!!
- Whats the best intake for 4 GEN????
- Idea for 3rd brake light in rear window spoiler
- ABS/Fuse Questions for you guys!
- Which NGK spark plugs to get?
- quiet muffler
- jim wolf tech cams!!!
- how to find an exhaust leak
- MAXIMA'S & CEFIRO'S QUESTION
- my Y pipe got owned
- alternator recall????
- how to re-attatch muffler?
- Bolt Size Question
- z32 maf on 96 maxima!!!!!!!!
- Need some help on rims guys....??
- Alutec FSTB review (purchased from Paradox Systems)
- emergency help
- BS or No?
- 17 X 7 rims, Yea I searched...
- Another Picture
- These are NOT the same as CM 'smoked'
- Bright lights are dim?
- Spring Wrap Method?
- ECU - Can you tell what year/trim by looking at it?
- In search of 95-00 5 speed manual
- Kyb Gr2 With Eibachs
- what do you think about grounding kits??
- Great DAY!!!
- what bulbs do you have in your corner lights??
- Nice Muffler?!?
- under drive pulley UDP, what is it.
- what do you think about this
- anyone have the factory window roll down with an aftermarket alarm?
- HID glare
- 4th Gen vs. 02-up Sentra
- Fully loaded SE vs. GLE
- Paradox RSTB Info
- this sts?
- stock alarm wiring
- Crank Shaft Pulley (Harmonic Balancer?)
- Broken Screw. HELP! on injen intake bracket
- Help with flywheel tq specs
- Need Special Spring Mounts??
- interior paint
- Need Help With Bose Subwoofer Malfunction
- Front wheel bearing died
- Automatics with over 100K..step in
- Budget Y follow-up
- SP2.... Burnt Hamburgers?
- 98' Urethane rear bumpers.
- re Confused over type of spring
- Wheel/Spring ????
- can clutch over heat?
- wtb summit rpm or any rpm switch
- Picture of smoked clearance lights wanted...
- How Many Miles On Your MAX?
- Major vacum leak!
- Wheel Bearings...
- Q's on DE-K VI & VQ35 cams...
- Another Squeky Noise Topic
- Interior Light Problem
- Changing Main Pulley Seal ?
- Motor mount ?
- ksport coilover owners step in. *confusion while trying to adjust !*
- ceiling lights and ignition ring light
- Sunroof Wind deflector for 1997 Maxima.
- LEDs in Corner Lights
- O2 bung in SP2.. Size? quick plzz
- Squeeky noise
- Dealer Repairer Complaint
- car shaking annoying
- gauge cluster lights
- Calling all those with stock muffler on aftermarket b-pipe
- bad start today..coils??
- i need free carfax report...
- Cefiro headlight question...
- Electrical / Ground issues!! Need help!
- Question
- 3d model of 4th gen
- pics with wheel spacers?on your car
- First mod ever cool
- Can the odometer be rolled back?
