- '00VI vs. USIM - Video Comparison
- quick question
- Removing the engine harness.
- Performance Suggsetions Please.
- Rear struts rattling....again.
- Installed a 03 xterra Rockford Fosgate in dash 6 disc (have questions)
- 99 maxima cali spec front converter
- Ebay "Supercharger..." Hmmmmm...
- quick coil pack question
- Pictures of Hood Please
- general help
- CB radio static noise common in Maximas?
- How do I tell if I have a Federal or CA spec 1996 Maxima?
- What rpm's are you turning, esp when cold
- Let's play find the flaw!
- Quick Starter help
- Check Engine light, Weird code
- WTF! Where to buy Walbro 190Lph fuel pump?!?!
- Turbo on my 95 maxima
- headliner
- Anyone ever meet a Spec V owner thats thinks they are faster then us?
- Should I get it?
- Front spring orientation??
- Tranny Swap
- Clunking in Front Driver's side
- Windshield Wiper Removal
- Is this a Deal??
- Fender Liner Mods?
- higher wattage headlights
- starting prob's
- Removing ENTIRE Dashboard from vehicle.
- Anyone have an pic of the strut mounts dissembled
- k so i need help now...
- ODBII reader says catalyst not ready
- Swapping clusters
- Universal Oxygen Sensor?
- Where to get : Shifter buhsing
- heated mirrors
- Oil pressure light
- I don't even know what to call it but help please??!!
- Body work - car repaint question
- ignition switch or starter??
- Headlights w/ HID's that offer best lighting before retrofit
- Can't find cefiro install instructions
- Clutch pedal
- How much to repaint a rear door and quarter?
- Advice on buying 1996
- Cylinder 5 Misfire - ECU On
- White smoke is worrying me
- Does it matter what kind of transmission 4 a cluster swap
- need help w/suspension install
- Rock chips / paint chips
- Car Paint!!! What your pait!?
- Front suspension issues and ride quality questions
- Where to get Mevi Kits?
- Trouble Aligning Fog Lamp
- What screws needed for mud guards install?
- can u buy clear corner light and red and clear tailights as a set?
- what if i dont want stock fog lights?
- h3 minis /h3c hid bulbs
- Fog lights
- Technosquare ECU seemingly not doing its job
- got a free ecu with the JET chip in it, should I put er in?
- starting problem maybe crankshaft sensor(ref)
- EGR problem again!!!! NEED HELP!
- Some wiring help
- Upper Intake Manifold = Impossible
- Help. Any way to find out mpg ....
- need brighter reverse light
- wierd idle
- Snomax's LCA Service
- Best Way To Remove Smells?
- Help me with Mods on my maxima??
- Pics of newly installed hids w/ new lip
- Brake pedal bouncing
- Code P0300....
- check engine light back again(any answer)
- 95 300ZX Throttle body Fit 95 Maxima??
- 5th gen motor in 4th gen
- Air relieve for coolant replacement?
- Energy Suspension LCA Bushing help.
- When changing a caliper is it totally necessary to bleed the system?
- lexus rims on a 98 GXE
- quick question on injector compatibilty
- Bypass A/C pulley
- VQ hesitation issue.
- Seat rails and steering column
- Magnaflow/Y-pipe Exhaust video up... all intake?
- Diamond Cut Clear Corners (99 Max)
- tranny.
- Core Support Removal pics...
- By any chance do 5th gen strut mounts match 4th gens?
- Cruse Control Light Blinks
- 4th Gen With LED Tails
- New mod on the streets...
- What Colors Look Best?
- lowering the max
- Farewell 4th genners
- Drivers Side Halfshaft Removal
- So who's making the cleanest and best fitting red/clear tails these days for 97-99?
- my car won't go above 110?
- Daytime Running Lights not working
- So ignoring issues dosent help... i need help
- EBAY Maxima performance chips
- Map Light Problem
- Interior Gremlins and electrical issues
- Took old "aftermarket" wires out and now won't start
- Whats the deal with car-part trannys
- Gremlins under the hood... some weird problems
- Intake suggestions
- is this what i need to replace suspension?
- Maxima project.Quick help!
- There is oil leaking by the oil pan
- Accenting the Center Dash
- Sticky door locks ... anyone else?
- The life of a headlight lamp?
- Fuel gauge reset.
- reverse light help please
- code P0130, P0136. bank 1 sensors
- axle seal where did u buy?
- How easy is it to do Bushings on the whole front end ?
- Planning a dual exhaust.
- Codes thrown* need advice
- wiring harness question??
- 4th Gen in the snow
- ecu code undefined: 1406
- Quick Radiator Fix????
- engine swap?
- Has anyone ever had EGR issues or threw a P1402 SES before?
- Another Newbie with Max troubles
- Write up for rear shock removal and reinstallation
- dont get ripped off if your a 95
- Full Exhaust Install
- Our awsome car
- Removing the door Bumper Strips
- Transmission oil cooler lines replacement
- Change what 1st? O2 or KS
- i hate my car
- VSS anyone have this problem???
- How do i take off my oem tails
- very good write up on a 5sp conversion
- Which LED Tail Design Do You Like Better?
- How do I tell an Auto ECU from 5spd ECU?
- Installing KYB AGXs need a lil advice
- Wow i punched my max for the first time
- Steering Issue...
- Ques about EVAP Canister Purge Volume control valve?
- Power Steering Pump Leaking ...
- Will these fit? Please help...
- 95-96 APC new clear tails on ebay
- Radiator Replacement Report
- ECU Question
- Has anyone purchased the amber fog lights from custom maxima?
- need help: auto climate control light problem
- ECU said cylinder 3 was misfiring, replaced coil pack, misfire went away...till now
- ROUGH VIBRATION FROM FRONT END
- Air Leak/Air rush sound on highway
- Undercarriage Rattling Noise... ANNOYING!!!
- Stillen High Flow Intake
- Searching For JDM Black Parking Lights
- how hard is it supposed to be to remove the harness for the coil pack?
- ignition switch has anyone had problems???
- 2000-2003 Bose HU in a 95?
- MAF sensor issue
- best tires for 15"??
- Timing Chain Tensioner
- Do i need a mechanic?
- Let's play name that part (intake)
- Should I change my short ram warm air into a true cold air intake?
- APEXI SAFC NEO
- Clear Coat Peeling
- BANGING EXHAUST
- Finally *PICTURES*
- good quaility clear tailights?
- NWP Engineering Phenolic Thermal Intake Spacers - VQ30DE PROTOTYPE REVIEW
- Bad knock sensor and rear o2
- Check engine light is on again!!
- Starting problem w/0304 & 0901 code Help
- NWP Engineering Phenolic Thermal Intake Spacers - 4th gen VQ30DE Maxima
- Oil Pressure Light
- Just wanted to thank the 4th Gen Forum
- KYB strut boots/GR2 struts
- Tach signal on ECU, this correct?
- how much shall I offer for these used parts?
- Replacing hood lift supports
- Possible fuel gauge issue?
- HOW TO CHANGE THE BLOWER RESISTOR
- Interior color codes?
- What else should I replace when lowering?
- Suspension cost (vs. D2 coilovers)
- OBX performance
- Need help with the screeching sound from my car
- Car got hit by Old Lady neighbor, she denies it. *PICS*
- battery light came on
- Pulley help...
- SO...for a windshield wiper transmission...you can get these gears?
- Should I buy these? will they fit? Please help!!!
- Taillight Mod? Completely Lost!
- HELP
- Fixing the shifter position when using 5th gen MT
- need help with codes 0732 & 0733
- Problem with H3's in stock fogs.......
- What Tailights Shuld I Get?
- where Can I find different centers for my stock se wheels?
- Power steering leak.... anyone had experience?
- Check out my new cheap and easy alternitive LED gauge cluster mod
- What's your engine's "Sweet Spot" (or "Flat Spot")??
- Radiator Help ! Which one would be good and any tips on the job?
- 97 MAXIMA TRANSMISSION
- powering lcd clock/climate control (pins?)
- Need help locating a part
- clutch question
- water pump bolt snapped, should I do a 3.5 Swap?
- Can someone take a picture of their trunk torsion bars for me please?
- Starting problem. Please help!
- O2 Sensor not communicating?
- Difference between 97 and 99 Climate control
- How to tell the difference between Stillen V1/V2 kit?
- need a pic of underdash where clutch petal mounts
- A32shop.com/Chillin014 Prototype LED Tails
- brake problem
- drive axle boot hlep
- Murano windshield spray nozzles on a 4th Gen
- Rear brake piston won't compress. Bad caliper?
- exhaust leak noise during right turns..
- Fuel injection question
- how do you calibrate speedo needle?!
- funny door locks
- Maximum wattage for for light bulbs?
- Viper keyless entry/remote start HELP
- Bad sensor... Not sure which one
- thank you and good bye
- different types of Rims on1997 SE?
- Need help with THROTTLE CABLE and GOLD 1/2 moons.
- How To Remove Pinstripe? HELP
- FINDANZA RING GEAR PROBLEM THREAD for replacement from Fidanza(everybody should look)
- Ghetto Airbox Mod
- is this "the" M3 spoiler i see on other 4th gens?
- CAI that's not a popcharger or FWI?
- are maxima's not great in the cold weather?
- 12 mlies/ gal.(premium)
- Questions about Custom Cefiro Headlights 95-99?
- Indecission Feb 14 2008:Tokico HP or Gabriel Ultra
- quick question just changed ecu
- ok now that I have a Maxima, what are your favorite sites?
- Miss firing?
- H TECH OR S TECH????
- knock sensor
- Aftermarket Parts - Good or Bad?
- car cranks but won't turn over ...
