- Accelerator and Car shaking
- need help!
- Tachometer Dead. New ECM ?
- Great Butt-Holder
- Alternator/Wiring problem.
- VSS and TCM....how do i change them?
- Help! Slow acceleration, 0-60mph in 11+ secs :(
- tinted maximas
- What do you guys think? Should I buy these?
- Who can service my 96' A/T Max in IL Area
- MAP sensor. where? how? why?
- Free 100pt Inspection By Stealer
- Is there something to be said about the O2 sim?
- Getting new muffler tomorrow, need suggestions...
- what am i doing wrong?????? (struts)
- 00vi ??'s
- Help on RSB installation.
- Can someone further explain how to fix these CEL CODES
- Urgency of Code?
- E brake and Battery light flickering/ Bad MPG?
- Drop'd and Tint'd Part 2 :)
- unstable idle
- Nissan/Datsun Z show in Mobile, AL
- Can I take centercaps off?
- good deal?
- does this look legit?
- help! in middle of changing struts....
- Finding a new MAF
- Is 100 bucks fair?
- A picture of my Max
- A33 5spd question
- '99/'99.5 SE-L roll call!
- OH SHIX 95/96 Max in Tokyo Drift!
- New Motor Mount?
- 1996 Maxima SE 216,000 Automatic... is AutoRx dangerous for me?
- I'm proud of her
- Best DD springs...
- Need Help!! Rear License Plate Light
- HELP: Car will not move. Clutch in or out. 5 spd.
- Sprint to 85 done in July VS. one done last nite
- which red/clears?
- where can i find smoked turn signals?
- AC Compressor clutch does not engage
- wing
- SS Clutch lines for lower hose
- Foglight question...
- Installation instructions: Shocks
- tranny id plate...got a new VSLD i think I might have gotten ripped off!
- Which boots/bumpstops for Tokico blues?
- Glass Headlights Are On!!!
- Alternator from 350Z ?
- Needs some help guys
- Rear suspension on GXE
- Any One Have Carfax ??
- Its that magical time of the year....
- help w/ lowering rear of my 4th gen
- vaccum line open - is this right? (pic)
- Couple ?'s: Fog light and timing adjustments
- 99Max brake pads fit 97 correct?
- Clutch replacement time...
- How many ORG members have done the 3.5L SWAP on their 4th Gen?
- CAI 3" hole template
- Fail smog test due bad ECU help!
- question about getting new TIRES
- weird starting noise, not the normal complaint
- 4th Gen Forum Rant
- Battery - Need Group Size
- starting problems???
- Help probelm with manual AC controls
- grounding kit?
- shocks and struts
- Hey guys...PLEASE look in "ALL MOTOR" and read my 3.5 swap problem post!!!
- put in 96 ts ecu got some expected codes.
- Venom400 Control Module
- Tranny Swap
- Hks Hi Power On Max?
- Great source for 13" rotors
- car misfiring, no codes.
- Straight Pipe or close to it?
- Power loss with dual exhaust?
- Axxis/PBR Deluxe Plus Pads ?
- ground control coilovers
- help with parking cable
- Help with dead cylinder
- Should I lower my max?
- Update.... Exhaust Question
- Mobil 1 Oil Change , How Many Quarts Of Engine Oil ?
- Sudden increase in gas milage
- aftermarket fog lights
- FS: clear bumper lights
- Poll: Wheels All Bronze, Or Bronze W Polished Lip????
- Tips/experience cleaning mud from leather?
- How often do you break brand new axels? on your 4th gen
- when i turn off my car it groans (fuel pump?)
- Is this the MAF?
- cyl. 5 misfire....help!
- cv axle
- Does you exhaust look like this?
- I love this max who's is it?
- Need HELP W/starter and throttle body
- Catback System
- After repair list is completed...
- 95-96 exhaust on a 99?
- Seafoamed Today But No Significant Results
- Help!!! Car won't idle.... have tried almost everything!
- Steering Wheel Vibration- need help please
- Clear corners
- Please help rear strut ASAP (agx and stock spring)
- Please help Dino ATF
- autozone 02 sensors any good?
- Parts that make up the upper strut area?
- Do 350z pedals fit the maxima?
- Egr Clog?
- Damaged ECU?!?!
- The Max Has Been Raped
- Fog Light Bulbs
- My dad got a Pathfinder and that 3.5 is a BEAST! I WANNA SWAP SO BAD!!!
- Airbag Light Question
- '95 5spd hard start, not cranking
- Clear Coner light Question
- Small noise from under car back seat middle FUEL PUMP?
- Axle shakes when applying gas
- estimate of power and times of the max
- Fog Light Question
- Needed Transmission Flush Symptoms
- Heater/AC wont turn off
- Who has had their 5spd rebuilt?
- Just got in an accident FTL
- Just need a few answer
- how much??
- how can i tell if i have ABS?
- Gas Door Jammed
- front strut bar
- fitting subs n trunk
- A year later.
- bumper lights rewire question ?
- Some times you gotta Megiver that sh*t
- Suggestion for bose headunit replacement
- Serious carbon fouling after TB cleaning *PIC*
- in need of new axles and wheel bearings
- OBD II on a '95?
- Will I feel a difference with this?
- Tranny Problems?
- taking out a/c condenser-bad for radiator?`
- Stock se wheels
- Intake in lower front of bumper?
- New headlights!
- rant...
- question on 9004 bulbs
- I need a new clutch... I think
- just curious
- Vent tabs
- VERY hard starting when cold - smoke & dies..
- What strut bar do you have?
- Just when I thought I fixed my CEL codes
- I30 Door Panel fit into 99 Max?
- 1996 Maxima Automatic troubles
- How to remove taillight?
- SCARED TO DEATH ( Maybe TRANNY ISSUES) Over Drive Light Flashing
- ligit races?
- I Have Leak On The Axle Driver Side
- '97 ayto (GLE & SE) slight squeak from trans? Lost..
- CF Hood, Stillen Kit, Klasse Full Detail..BIG PICS
- replaced knock sensor and harness, 0304 still there, help!
- Need Help With My Ksport
- keyless entry help
- Need Help ASAP! Electrical Malfunction
- 36mm AXLE NUT
- Are you kidding me??? We charge for How too's???
- low idle: ECU diag. screw related
- Tranny problem
- Mirror Question?
- another tranny problem?? please not again
- Cefiro HL bulbs
- Good ebay CAI?
- right rear clunking over speed bumps and pot holes
- Re-man Starter
- question about a thread Please HELP
- ANy positive remarks about SEAFOAM Transtune?
- Bought a 99SE and already having problems.
- Passenger axle bracket
- Quandry! In need of the Max nations help!
- tinted corners and turn signals
- question on rims
- An interesting observation - what can be the cause of it?
- suspension troubleshooting, grinding noise..
- Advice on pulley!
- projector/reflector headlights???
- hard to start, need suggestions
- Fuel Injector Removal
- Exhaust Setup Comparision: Test Pipe vs. Stock Cat
- What did I do wrong?
- factory keyless
- Need Help Picking Short Shifter
- Opinion (Body kit)
- Starter compatibility
- Where can I find a double-din storage pocket?
- What Struts and Shocks do you reccomend
- CA spec exhaust what do I need?
- CEL will not turn off
- Want to replace Springs
- Sweet max at stonebriar chevy in frisco, Tx
- normal ignition timing and KS help.
- Plastic bag stuck to my y-pipe
- new intake filter
- How to remove rear bose speakers from a 98 se?
- CV JOINT help
- The End Has come. ByeBye Maxima......
- CHanging struts - Can I get hurt doing this?
- Broke the damn ECU screw
- How Much $$ To Make Off Parting Out
- Alternators Goin
- what is a TRUE 3.5l conversion?
- In tank fuel filter?
- Hangers..Exhaust Hanger replacement ideas
- I got spiders and dust flies in my car...
- Paint hood/cosmetic repair cost, advice.
- Lawsuit Advice_ Mechanic blew transmission
- knock sensor????
- M3 Mirrors installed (Pics) 56k Major unhappiness!
- tip on getting the stock ECU out of that bracket?
- Front stabilizer bar from 98 fit in 96?
- Cattman cat-back installed
- 02 Maxima Navigation Display
- Short Shifter
- Max is not starting......
- Intake Manifold Cleaning+Vacuum leak+New Gasket = Unstable Idle
- High Mileage
- Put in the Tokico Illumina set... a couple of question
- fog light
- tips on putting in 00 5spd
- Test Drove a 1998 SE auto is it supposed to be like this?
- knock sensors on ebay, legit?
- Cant figure it out charging problems
- simple question here : help me clarify something to someone else
- just dropped my car need help
- chinging pasenger side axle
- Yet Another Misfire
- link for repainting SE wheels????
- NEED HELP NOW!!! Installing STS and nut turning with stud
- Help location knock sensor and Engine Coolant Temperature Sensor
- Infiniti Auto LSD to 96 Max swap complete
- 95-96 rear bumper on 99
- ECU code 0702 on 99 Cali Spec: Bad 02 sensor?
- Window fell down
- repainting the maxima! want advice
- My Stall when i was driving
- few pics of egr tube removal
- Does anyone know where i can find these two parts?
- Rear Rotors And Brake Pads
