- 95 5sp maxima 235k mi - hesitation, etc
- 96 maxima leaking coolant from behind the thermostat housing?
- Revving from 700 RPM To 6.5k+ RPM! FEELS GOOD!
- Motor mounts making transmission shift hard sometimes or something else?
- 1998 Nissan Maxima Won't Start
- Anyone interested in another tuning solution? MegaSquirt MS3 Pro
- :video: 1999 max, passenger side noise
- '97 Maxima engine stalls and dies randomly at low RPM and hard to start back
- Fuse type/Size Question
- What brand of shock provides the softest possible ride?
- Salvage Title for my Maxima GXE 1998
- alternator/battery/regulator issue?
- Metal/Clamping Sound Only At A Full Stop
- Ice Chunk Breaks 99 Model's Spoiler
- where does this vacuum line go
- 95 maxima idle and wot issue
- starting problem
- Your thoughts on these springs
- engine whine diagnosis
- 1995 standard maxima - confirmation please!
- Performance Rebuild kit good, or nah?
- 1997 Maxima GLE P0340 Code
- will a clogged cat cause an 02 sensor to fail?
- HVAC only out vents
- Anyone Ever Made REAL CF mirror covers?
- Water in the rear floorboard
- Exhaust replacement- did I get ripped off?
- test pipe?
- Car runnling lean-Open loop idle issues
- Rock Auto FTW. Gasket set.
- How long will my car last on battery? is it my alternator or battery?
- tachometer-rpms dropping too fast?
- can i use a california cat on my fed 95 max?
- tachometer
- Lower Control Arm As Jacking Point?
- Questions after Cold Air intake
- Wiper stalk question
- Replacing these nasty floor mats
- 1999 Anniversary edition struggling to shift gears
- New member,just new to me 4th gen
- Radiator cap help
- Aftermarket high pressure power steering hose.
- valve spring retainer question
- Cat-Converter Replacmement Recommendations?
- Help with hard cold start
- Source of Overheating?
- NSK Wheel Bearings
- Ashtray light bulb
- electrical problems
- Front axle boot ripped
- Does this sound like calipers or steering rack?
- Does clear liquid fluid stain the ground?
- Grounding kit vs big 3
- Nissan Maxima 1999 start rattling at 40 MPH
- 96 maxima hard start, no idle after 00vi install
- Tension Pulley Bolt
- 1996 Maxima idle noise
- I'm not sure what the title should be...
- Climate control
- Outer CV boot torn.
- 97 5mt - odo now works after seafoam treatment.
- What is it when battery and brake lights show up?
- Anyone have instructions with pics or videos how to dissamble rear spoiler?
- Would you trust the quality on a rack and pinion from eBay?
- what is this metal "vibrate" cracking sound?
- Does Infiniti have compatible window regulators?
- Right front wheel noise. Axle? Wheel bearing?
- What fuse would cause my car not to start? (95 nissan maxima se)
- Y pipe options
- 97 I30 running like crap HELP!
- 96 112K 5spd miles with some issues...
- 95 Maxima-Ghost issue at 35-40mph-3rd gear issue?
- Axle question!
- Fuel injector?
- z32 calipers on infiniti i30 97
- 99 Maxima Security Issue?
- LED DRLs
- I think it may need a new speed sensor??
- CNET On Cars - Top 5: Most durable cars
- flashing cruise control light
- Fixing up the Pearl white Max.
- car overheating
- Front control arm bushing
- Free maxima I got needs some work done.
- advice on coil packs
- Installed 12.6" 6th gen front brakes on 96 Maxima
- New Maxima owner, where to get parts
- Air Mix Door Motor No Longer Available From Dealer?
- Nissan 97 max shifting problems into reverse and jerking
- Troubleshooting My Manual Climate Control (All I Get Is Hot Air)
- Specific Heater Core Bypass Question
- Help car wont go onto gear and bangs when did!!!
- sunroof problems
- need new radio
- Cant stay in OD off for long...thinking of towing a trailer
- General Electrical Diagram Question
- Suspension recommendations/ near mint I30 update/ Pics for fun
- Photoshop test fit of a 94/95 accord bumper
- Bought another max, some electrical Qs
- Two (2), Hopefully Not Idiotic Qs ... My Totally Flooded '99
- Maxima 97 misfire only while driving
- my 97 nissan maxima wont start
- General mechanic or Maxima specialist for valve cover job and rear main seal job?
- will the tps go bad and not throw a code??
- Do I have an Intake/Exhaust Manifold leak? See pic
- Does an old engine still need the recommended gas rating?
- 96 maxima code 305
- What size driver wipers do you use? It could be wrong
- NEED HELP!! 97 3.0 AT No crank/No start
- Motor finally blew at 397k miles
- 99 Maxima running after the key if off
- 95max auto...losing power electricity
- noob needs help
- 1996 engine in 1999
- help . came out of work this morning and my car wont start
- Some drunk b*tch hit me...
- Gauge cluster issue...probably a dumb question...
- 3.5 swap problem
- Replacement Electrical Connector Resource?
- Potential 2004 Maxima purchaser
- Map baro switch p1105 what is it really?
- Planning to replace both valve cover gaskets
- Ruining my Maxima
- Where's the gas light located on a 98 maxima
- Shudder on Acceleration after front strut change
- 1998 ABS Ring Tooth Count
- Price for exhaust installation at a franchise chain?
- Oil or fuel smell on a cold morning
- Tie Rod End Adjustment
- what is the name of this piece and were can i find a mini filter.....
- '99 Injector Rebuild Kit ...
- My 150,000 mile repair history of a 1999
- Anyone have second gear slam into gear on your maxima?
- 2011 maxima wheels 50mm
- So ... Do Injectors Just Fail With Age Or What?
- Need help asap-can't switch gears while driving
- VIS CF hood quality control issues
- NOS question
- 4th Gen Picture Post
- Got me a "new" maxima, looking for info
- 1998 Maxima-Temp Gauge going Crazy-Car Not Overheating
- Battery Drain
- EMU - can't see RPMs on live log
- 4th gen maxima idle troubles and stuff need quick help
- Does anyone know how to reset check engine light on a 98 maxima?
- No Codes Hard start after multiple parts changeOLD problem New Thread
- hit a pothole while auto was changing gear
- Steering or Rack Issue?
- Oil Leak Question
- will 96 i30 parts fit my 95 maxima
- 98 maxima jerking and shut off
- Add that $50 code reader to your kit.
- Aftermarket steering wheel and cruise control
- Install Walboro Fuel pump
- 97 maxima has electrical prob for $1000obo
- Odd problem after alternator replacement
- **Solve The Wizard's crossword puzzle for a chance to win free Maxima.org stickers!**
- traction sux on my non-lsd 95 max....
- need motor mounts
- smoke coming from behind engine
- 97 GXE Alternating Between 2 Check Engine Codes
- 3rd Time Changing Rear Valve Cover
- Fuel Line / Hose Size?
- 2000-2003 (a33) coilovers on a 1995 Maxima?
- 95 Maxima Smog Failure High NO
- Anyone getting a "hot" misfire.
- independent Fog Light
- Custom 3D Printed Third Brake Light Cover!
- How to avoid ripoff mechanics and mis-diagnosis 101?
- Transmission Noise
- Spec tires for 1995 SE 215 60 R15
- Pass D/S issues
- Need help with codes
- 99 Maxima Stuttering
- New owner of 1995 Nissan Maxima GLE 58k miles
- supercharge or all NA
- ECU Pin connection to EVAP Canister Vent Valve
- Driver side courtesy light not working properly
- Anyone run across this one before?
- Cold weather can do some weird thing, electrical cut off
- I need to "glue" down a part on my engine. What should I use?
- no heat, done everything, please help
- It's a very sad day...
- Please help me with a brake decision
- MAF and intake gasket manifold done- now check engine light
- Spark Plugs
- Hard starting
- Ebay idle air control valve
- Changed my sparks plugs with platinum at 100K now at 215K should I replace?
- Alarm issues
- Front Crank Seal (99 Auto) Flywheel lock?
- Tail pipe tips
- Can a Beck Arnley tie rod break in less than a year? (Alignment experts welcome)
- Radiator support rust
- 97 max been sitting for a while...
- Car won't crank.
- 1995 timing questions
- Heater core pipes snapped at firewall
- The Pull of a VQ30DE with 400 000 kms
- 98 Maxima Transmision failure
- 4th gen sude airbag light
- AC Compressor Clutch Bearing
- Retro problem......
- This car has never died on me until now
- Tighten glove box door?
- MEVI-Rod broken
- Modify lights to tutn off automatically
- Aftermarket fog light options
- 97 5-speed se NATS problem....
- A little help from my SE brothers
- Grounding Kit
- hello i got a problem with my gauges
- E85 stock maxima
- Securing your front lip?
- Broken rear strut !
- Question on Replacing Thermostat (Service Manual vs. Haynes Repair Manual)
- hard start issues
- Need Help In Understanding Timing
- Not sure if my water pump needs to be replaced
- Plug and plug wire recommendations, please.
- Fuel pump location
- Automatic trans upgrades?
- Power Steering pivot bolt not fully tightened?
- 95-96 o2 sensor bung size for catalytic converter
- What's this Noise? Bad Ac Compressor???
- charging issue
- water sloshing noise behind dash
- How do I remove the sunroof motor? I've searched...
- Rear Struts, Problem Installing
- Econ button doesn't work
- Nissan Maxima 96 power antenna replacement
- 5.5 Gen Steering Wheel w/ Radio Controls Upgrade Mod
- oil leak near oil filter
- Gas mileage is killing me
- maf sensor code
- starter? and p1400
- Gear jams while shifting from parking to reverse/drive
- Ball Joint breaking my Ball-oons!
- Transponder Key Replacement
- 99 Maxima Blowing out hot air only.
- Fuel pressure regulator
- Front Sub-frame Bushing Replacement Question
- can i replace just 1 hid bulb??
- Smell of gas coming via the air blower inside the car
- Timing cover oil leak....fix or replace??
- Alarm issues- Goes off Randomly
- Help please - car overheating
- 96 with 230,000 miles. stutters in drive at a stop. goes away in neutral. Automatic
- question about Lowering my maxi
- Should I drive my 225k miles '96 across country?!?!
