- Steering Upgrades... are there any?
- Fog lights out: Help Please
- Ebay coilovers?
- Checking ECU
- nebody seen this 4th gen bodykit b4?
- Where to get a spoiler for a '97 SE
- JC Whitney Muffler and Cat
- The Mod Bug Bites hard...
- Are people retards
- Smokes when cold starting
- Need Pics: White Max with white wheels
- Help! I broke the belt tensioner
- driver's seat problem
- Power antenna & Front lip spoiler
- Did blinker re-wire. Blew fuse?
- Shift Not Smooth
- Legality and Emissions
- Where can I find:
- Ebay Coilovers question...?
- Best Year(s) Maximas
- auto tranny temp gauge?
- s13 sr20det for max 5spd?
- A road trip with the max... (4 speed auto)
- What bulb should I get?
- JIC FLTA2 for Maxima A32
- Tranny problems! Cryo treat while I'm at it?
- Radiator Problems w/ '95 SE
- Injen Installed.......
- engine wiring harness
- Southern Auto Auction
- Are orange rust spots on rotors normal after it rains?
- Will stock muffler fit on Apex-i B-pipe?
- Need Front Strut Bearings part number
- electricity! smoke!
- i feel horrible.
- Pics of 35% or 20% window tint.
- Why?
- Air ride equipped questions??
- down hill - brake pad
- newbie with noisy springs,,,I think
- EVAP Need Help!!!!
- those with Aftermarket Exhaust...how do you stop B pipe from rattling?
- Question for those who have done five speed Conversion
- I need help locating a prob....
- Need Help Please! can figure out how to purge my clutch
- Paint Job
- Stock fog alternative for a 95
- Please help me. 1493???
- aluminum or wood dash kit?
- speedbleeders for the Clutch?
- sprint + tokico illumina combo?
- Who has a 4th Gen at Queens College WIth Turbo Sticker
- Need To Be Contacted!!!!!
- My Tach Is Annoying
- IACV what does it do?
- new member
- So sad to tear everything apart coz I am going to trade my Max for 350z
- Lowest with stock shocks/struts.
- 99 Max and idle vibration
- Replacement Alternator Leads
- Smelly Leather Seats...
- My max shakes when reacking 60 mph
- HELP! I broke my MAF putting on my intake! Cheap replacment?
- Head light
- Power Antenna from Ebay
- TYC taillights/altezza skyline mod!
- Apples to Oranges? 300ZX to Maxima?
- where should I put this maxima emblem...
- swapping engines
- staggered setup possible??
- looking at buying a 4th gen
- How do you install chrome gauge rings?
- Two simple questions
- Cold Air intake
- Redmax TV owners.....
- Which Yellow Top Should I Get?
- Magnaflow..14827 or 14832?
- question on doors
- Installed Budget Y....Leak?
- Smoked Headlight lenses??
- Shift knob vibration at idle
- for you 4th gen ONE PeICE HEadLIGHTS
- BOSE indash problem
- Anyone know where you can get chrome rings for my gauges?
- Fog Light Probs..
- car moving to the right
- Please help! I checked EVERYTHING!
- Need a new battery. Any opinions please?
- anything else I should clean?
- Passing inspection with Random Tech Cat
- accelerator cable adjustment help
- Ac Fan Speed 4
- Knocking and pinging
- Idle problem ' 96 GXE
- grimy, stained rims ... help
- LowGlow Install??
- Shopping for PIAA Xtreme White 9004 headlights; where to buy ?
- quick question....
- Was i screwed by dealership? Left vs. right wheel bearing size
- Clutch problems after conversion
- Steering wheel solution.
- strut dust boots
- I want this!! You have to see it too...
- brainstorm on new intake idea!!
- low fuel light
- noise after shutoff
- I need HELP - ASAP!
- Cracked windshield with no apparent cause??
- how do i remove the headlight?
- SMOG CHECK: OBD-II and EGR problems..
- no spoiler
- Digital Clock Problem
- Suspension Combos-Need to decide-Poll!!!
- A/C Pressure Switch location?
- home made tail lights
- After how many miles did your OEM clutch wear out?
- Would dropping my max 2" affect acceleration at all??
- Question on 9004 headlight bulb!!
- Guys with SPRINTS come here!
- all red taillights - how?
- KS q... quick quick
- Knock sensor (Round 5)
- Please help with a battery / electrical question
- For anyone who also has an unexpected turbo "whine" engine noise:
- !!!!!!!!Need more SPEEEDDD! Gotta Get rid of the "Party Pooper" Governor!!!!!!!!!
- About the INTAKE hole...kinda hard to explain...
- How to get Apexi WS catback to fit on '99 maxi?
- '96 J30 seats in a '97 Max?
- Report your Brake Pad Experience; Porterfields, Axxis, Hawk
- Project-Scoop Is underway
- Plea For Help Before I Sell
- Favorite Intake/Y-Pipe
- ebrake light on?
- Help setting up Tokico Illuminas please
- Line pressure solenoid circuit is shorted or disconnected
- Next Mod???
- Cig. lighter, bummer ?
- I can't find this code
- Painting '96 Max. Can side mirrors covers be removed?
- Iridium Spark Plugs ?
- oil in sparkplug wells
- Is my transmission ****ed?
- 300zx and the Maxima
- Swap 5th Gen Tranny into 4th Gen
- Floating feeling - need bushings?
- remote for a 99..how to program
- intelliglow needle kit
- Clock Digit Intensity Problem
- Cheapest Oxygen Sensors online???
- Hacking the stock airbox. What does this mean?
- motorvate.ca Updated: B-Pipe Dyno Results, UDP Pulley & Alternator Output, and more.
- Okay, before I start messing with the idle screw
- About how long should Axxis Brake Pads Last on Dimple/slotted rotors.
- Idle starts really high and jumps AFTER cleaning TB.
- Help! Car won't kick over!
- ive about had it.....
- Attempting Rear Timing Cover Oil Seal
- My car got hailed on, but im happy!
- My 20 mile Progress Rear Sway Bar Review
- What color should I paint my Calipers ?
- aftermarket flywheels
- Need A New Radiator
- Spray Paint
- Need help with O2 sensor
- New wheel bearings last 10 days! PLEASE HELP
- I scored a loaded, 97 se 5 speed!
- Need help: New Antenna Wiring
- y pipe clarification please..
- rotors
- Maxima Hunt
- Any1 know how 2 reset tranny ecu?
- Over heating*****
- Does knock sensor mfg matter?
- PIAA Hyper Whites (Doh!)
- Question regarding Calsonic Radiators
- Need help! Oil Leaking (esp. enging rebuild guys)
- Ignition Timing Advance vs Knock Sensor Operation
- Simple Exhaust Question
- help needed
- I don't know if anyone cares>>>Cefiro indiglo door sills (ebay)
- Is there a write up for installing Sprints & AGX's??
- wher'd the power go?
- 95 fogs
- I'm worried,,,90mph @ 0nly 3000rpm
- What gauge to use for battery relocation ?
- nice new exhaust for us
- how to remove engine coolant sensor
- a/c working, but not as cold as i think it should be
- what does a y-pipe do
- daytime running lights
- how do I reset my ECU after fixing the code??
- Were do I find Instructions on changing my knock sensor???
- Nissan made a mistake with GLE vs SE
- Clearing the ECU....
- Air Intake Temp sensor
- transmission fluid hose
- Knock Sensor Update on Infiniti I30
- Clear Taillights
- 2000cc vs 3000cc
- 97 fogs on 96
- installed Injen "CAI"...not impressed
- clicking noise coming from dash area
- HELP!!!!!! My car won't start, Please Help.
- Side view mirror passenger side wrecked by careless ambulance driver!!!!
- E-bay Front Strut Bars . Are They Worth It?
- Check it out!
- Driving for 8hrs at 3000rmp
- How to Install Air/Fuel guage in max?
- Will 3rd gen radiator fit 4th gen??
- Procarparts CAI question
- Y-pipe or cat-back?
- Injen Intake install help!!
- White Smoke + Gas Out The Exhaust
- Free Maxima.org Wallpaper - Download Inside !
- Caster is off!! what can I do to adjust it?
- So how do I test an ignition coil?
- What RPM??
- Engine flush
- Anyone have pics of a 96 w/ a 97+ rear bumper + Stillen rear valences?
- Oil leak (Valve Cover Gasket??)
- Should I buy this car??
- Coil Problem ? Tests ? Fast failure ?
- Clear Corner Bulbs
- CAI : What type of filters can you use ?
- HELP-rattle noise after install of Ypipe.
- Which Y pipe is better
- Cruise control mod doesnt work?
- Skyline Body Kits
- fast blinking turn signals? how?
- Ready to tint my max...but...
- drive axle seal- yes, I already searched
- Questions with 95 to a 98 front vconversion
- GXE Speed Limiter
- B-day presents for my max's 100K!
- cup holders...
- 96 Auto ECU compatible with 96 5 SPD ECU?
- Does anyone own the Weapon R Circuit Pro coilovers?
- tail light poll for my 95...
- WHERE is the knock sensor?
- fuse issue for 99 se
- rear end conceversin????
- ?where to find and how 2 install clear tail lights?
- Who makes the best CAI for the $$$?
- New Clutch = Ahhhhhhhh
- HELP!!! Exhaust system layout question
- "clicking" from left front wheel well...
- Cool! Better MPG with the Frankencar intake on!
- Pilot bearing/bushing
- Weezing?
- pics of M5 spoiler lip installed
