- Blow-by hose- What size?
- Anyone had that kind of problem with them?
- Who makes the softest riding struts/shocks?
- Normal or bizarre? Revs increase when steering wheel is turned
- RPMs drop then shoot up to normal 1-2
- How long does it take to install Ypipe?
- new b&M STS? never seen this before
- headgasket replacement..anyone did?
- clutch (hydraulic problem)
- Axle replacement how to?
- Start up squeak
- Code#0807 / 1008
- 95-99 NISSAN MAXIMA 1PC HEADLIGHT possible repost
- NEVER DONE BEFORE HEDLIGHT RETRO. HomerMAC a pioneer on the headlight retro front.
- Car dying after start up...NEED HELP
- dying in the cold?
- 5 spd problems
- Very little heat! Hang with me on this one..
- Transmission Problem....(uggghhh)
- WEIRD AUTO TRANNY PROBLEM. No Reverse, No Neutral. WTF? Help please...
- What color to paint car.
- Fuse keeps blowing for fog lights...
- How do i test a damged (stuck) caliper?
- Vibration between 700-900 RPM...
- Coilover Binding noise? Suspension related....Video
- New ride for my daughter?
- Y-Pipe/new Cat Converter...before I install...
- Some engine help please
- Clutch makes loud click when pushed in
- FYI...Good Price on Knock Sensor
- Car smells like Gas
- Opinions Defi Blue or Blitz BLM gauges?
- I need help finding a part....
- Gauge Lights
- a couple or things (brakes + 02)
- Tighten your throttle cable
- Rpm jump at start-up and ticking noise
- help maxima is sputtering
- Coilover Coments
- how much do you think i could sell my salvage title max for?
- found leak after seafoam
- Airbag Module Replacement
- Budget Y + Cat + SP2 = Weird Noise
- Installing Indigo Gauges
- Audio question
- Door Lock
- clutch problem
- Kill 2 birds with 2 stones
- Removing the speedometer needle?
- Warpspeed ypipe question.. please look in...need help...
- serious gas mileage drop
- Possibly selling the max
- goodbye...............HELLLLLOOOOO!!!!
- HELP! Car Runs Sluggish Won't go Over 30MPH/Shuts Off!
- Chrome Bulbs?
- engine bore
- Clutch swap done (v. pix and profanity)
- please help: part fell out from under my car... can i still drive it?
- huge alternator problem
- Wow i need help real bad!
- anyone know how to hook up o2 simulator?
- WANTED: EGR and IACV Cleaning Write up
- so... i need help! please!
- vg30de > vq30de?
- is there a way to eliminate rear o2 sensor?
- Axle play... Diff bearing problem for sure?
- 0304 and 0102 After cleaning TB and IM?
- Torque steer?!?!
- What kind of wheels do you all have?
- Removing starter motor attachment bolt
- 3.5IM Fit on a VQ30?
- Will my rear progressive spring coils touch and squeak?
- Clutch problem in cold weather
- Storing a car for 3 months
- Techbical advice for no crank
- anyone with 99 cali spec with DEK engine?
- y pipe and mileage
- So, I broke my car.
- KA-CHUUNK... Engine Misfire? Faulty Starter? HELP PLEASE
- So I got some codes
- changed PCV valve- now its making a whining noise.
- knock sensor frequency
- Blown fuse? Or worse?
- Exhaust piece removed, how important is it?
- Reccommended Sticky?
- what kind of oil for wintertime?
- i think i blew a fuse
- Tire PSI Question
- Which color temp. for HID?
- ongoing starting problem now car doesnt start
- how do i remove the rear speakers??
- HELP. Im Stuck Removing Rear Bumper
- Exhaust system
- HVAC control question
- Freaking passanger door is not locking....
- So is anyone rockin yellow bulb headlights?
- belt squeel ?
- I have a really quick question if someone can answer!!!!!!!!
- Engine swap question
- door open switch not working
- Disconnecting starter motor trigger wire
- Help with Installing Rear Bumper and Trunk Lid
- Squeaking When Turning The Wheel
- power steering problem
- Alternator removal
- Has anyone used body parts from Pershing auto body on ebay?
- WTB LEFT REAR bose speaker
- need help with the radio......
- wow
- Any of you guys still does CARFAX reports?
- ebrake question
- Idle bump(drop) and WOT stumble
- are coilpacks interchangeable?
- upgrading timing compenent
- Oil diluted by fuel
- exhaust with supercharger question
- Anyone want to reupholster their leather seats?
- PICS Check it out.
- RPM's drop out, car stalls while moving
- Motor mounts from ebay???
- so i bought Q45 calipers and im missing half of them..wtf
- battery draw
- will these rims fit my 4th gen?
- Repair Fog Lights / Where to buy
- Radiator no coolant at all?!!!
- Not a bad deal!
- Slight exhaust leak.....gas mileage/power...
- 3.5 altima muffler
- Last call - STARTING PROBLEM
- Car wont stop running RICH
- dash swap
- Finally fixed stalling issue by grounding MAF sensor
- NEED SURIOUS HELP with gas mileage!
- Some power windows dont work
- O2 sensor signal wire from ECU
- Front left O2 SENSOR LOCATION
- My Max almost overheat. HELP~~
- Do I get new struts or tires first??
- knock sensor question
- Hunting for negative battery cable bolted to block/chassis
- Where's the first place I should look for a coolant leak?
- Would the Ionic Dynamics lip fit on my car?
- Actual yellow fogs?
- got a code: 0302
- clutch problem
- I35 engine swap
- Constant power supply in dash
- Look what the UPS and FedEx men brought me!!
- To anyone having seasonal coolant leakage
- instructions on taking off interior pillars?
- 98-KH3-5MT-SE Crew Step Inside
- Waterpump going bad? Vid inside
- Do you drive with overdrive on or off?
- License Plate Lights
- How much trimming to fit 5th gen muffler?
- Doing a 95-96 to 97-99 font end conversion. Question about fog lights.
- Completely Totally OWNED!!!
- Clutch problems
- How to take off headlights??
- Allignment
- what happens if you fun fuel reverse through the system?
- How do I put "Cruise Control" on this steering wheel?
- Clutch pilot bushing question
- Motor mounts taking a crap??
- Rough Idle?
- DEK Swap...coming soon
- Stiff Power Steering?
- stupid me... ne1 good with wiring?
- !!help noob with suspension please
- Doors locking on their own at times
- Ques on O2 Sensors
- strange intermittent clutch problem
- Belts/pulleys starting to squeak???
- Attempting the impossible?
- Alternator INFO
- 98 MAXIMA WHEEL Question
- heavy shaking when accelerating
- ZACk342 Questions about your original 99JWT ECU
- EBay O2 sensors
- Urgent! Loud Squeel at startup. Starter?
- tire size Q (slick size)
- A- pillar and headliner removal
- which filter
- 95-99 NISSAN MAXIMA 4PC JDM AMBER BUMPER LIGHTS (installed)
- Lots of sludge
- 5spd in Neutral when changing axles?
- HUGE HESITATION help!
- Wiring
- EGR solenoid valve removal?
- Whistle from intake at cruising rpms
- Thanks all!
- Help - car won't start!
- Broken Nissan Wheel Lock Key
- Oxygen Sensor 2 Bank 2
- Neutral safety switch?
- Chrome Trim Removal
- Warning do not buy PCV valve from autozone
- HID fog light recommendations?
- 245/40/18 will they rub?
- Need a link for yellow capsule mode(LOOCKED THROUGH STICKIES)
- Part # for 1999 Chipped Key?
- PIcs needed of R34 rear bumper and opinions
- in need of help!
- Steel clutchline question
- Interesting way to flush out engine
- Clutch Problem.. please help
- wheel bearing replacement
- Best NON-synthetic oil for 97 max?
- What car do these come from?
- Leak
- Where can i buy the S5 grille?
- why does everyone say drill holes to hack air box?
- left headlight doesn't work and can't figure it out
- Can't find coolant temp sensor
- New to Forum, Where should I start?
- "Sporty" hubcaps for 1998 Maxima GXE
- Damn hood shocks
- Need help about leds
- Rear Tail Lights
- LED standards*
- sunroof dome light assembly
- 95 ecu fed or cali spec??
- Grounding kits?
- 97 Maxima Vs Rotary Powered Lawnmower Van
- I'm a BAAAD, bad man....
- I'm going to do some maintenance (first time) some questions before i go about it
- rear door power window
- Throttle body Vacuum line... connected to?
- drop resistor mod installed
- Clutch Questions
- Water pump/coolant leakage!
- Help! Bolt snapped
- So I've converted.
- What the EFF is up with my radio?
- Transmission Fluid, API GL-4 right?
- Which do you prefer? Painted interior or not?
- Need help diagnosing Hard Starting issue
- Anyone done this before?
- Removing Dash Scratches Question
- I Need Help!!
- Fan speed control resistors
- Rear Bumper Cover Removal
- Steering problems after strut/shock installation
- HID's installed, now car stalls
- Annoying Dashboard Squeaks
- Aftermarket Security System LED
- Flashing Dash
- No ABS???
