- walmart bag
- hickuping lagging studdering, bogging down help please!!
- camber issues!!!
- Rotor warped?
- Maxima center cosole light
- '95 Maxima misfire help!
- Bad fuel injectors
- opinions needed: caliper colors
- Slight dilemma...maybe just spring fever though.
- Rotten Crossmember
- stone mountain racing headers
- drain vale on caliper: What size is it?
- Fog light questions
- are there any DOT approved 1pc lights?
- Difference in 95-99 armrest cover?
- 97 Infinity I30 Auto Trans
- Front Wheel bearings still going out...HELP
- my door is stuck! help!
- LED Guru's I need help w/ LED tails
- ~~~~Need yall's advice!!! help please! ~~~~~~
- SPEC stage 3 clutch on ebay
- Takin the max to Vegas and back... checklist?
- Got Board w/ razor blades and goo gone (pics)
- LCA Ball Joints?!
- BBQ Paint on Calipers
- New mirror and bumper lights
- Need help on figuring out the problem
- Coolant leak possible? I might have one...
- Changed accessory belt and now it squeaks when starting
- Abs Light!!!!!!!!!!!!!!!!!!!! Is On!!!!!!!!!!!!!!!!!!!
- Fuel related "Check Engine Light"?
- How long before ur new KS bring back power?
- Testing Coils
- regular, or hot/cold sparkplug?
- will 95 exhaust system fit 97 maxima?
- A/C not cool at all
- Buying a ’97 GXE – need HELP with these leaks
- bose ?'s
- Downshift Error
- Blown Head Gasket Replacement
- What do you call this
- LED information auto-climate
- Stolen Maxima
- O2 sensor quick question
- lug nut question
- Fuel Injector cleaner any recommendations
- Gas Tank Supports
- Need to change transmission oil. How many quarts?
- Front Brake Question
- HID's with cefiros
- lowered(H-tech/Illumina) & uneven tire wear
- Clock not lit up, emergency signal and defrost do not light up
- Fuel Injectors
- No turn signals or taillights...
- Apexi WS2....yet another thread....
- Help!! bought LED bulbs but don't fit
- I searched - how to remove stock stereo???
- Clutch Problems ... need advise
- The squeak is back
- So looks like im getting new axles
- anyone ever use any of these?
- lost wheel lock
- fuel filter pita - HELP trying to replace
- Strut bearings on Ground Controls?
- Idler Pulley Nut Stripped
- INFO on a GOOD starter for a 4th gen?
- 245 + 2" drop?
- Clutchless Gear-Shifting--Does it hurt anything? Why do it at all?
- Idle surging problem on a cold start...
- Is Winter Over ??
- Knock and O2 Sensor Heater Circuit Help!!!
- A32 I30t vs. E90 328i
- Trying to make my car safer
- Loud Clunk Upon Acceleration/braking
- 4th gen parts used...different forums?????????
- Whats the REAL diff between 95 FED and 95 CALI spec?!
- AT Transmission Pan....HELP!!!
- Can someone HELP!!!
- 5th Gen FSTB on 4th Gen
- Which NGK spark plugs should I buy?
- Is my starter going bad?
- another R34 retro
- humming sound - need input
- what is a bank 1 sensor?
- Can Back Pressure or an Exhaust leak cause low idle and stalling?
- Time to flush coolant before the summer, how much?
- PCV valve quality differences
- Anyone done a flush retrofit before?
- wow you do really cut up your hands...
- OS front and rear
- what happened to the Code sticky
- torn flex section on y pipe
- Front Brakes pads and rotors. Should Replace or Repack Wheel Bearings
- CEL Code P0010 and P0400
- hazard light question about disassemble.
- Side Mirrors Defrost?
- CarPC is done!
- Hard Starting
- Tie rod end popped out, steering rack damaged
- what kind of video headunit do you have or like
- Spark plug problem...need advice (how to fix)
- Tockico Illumina HELP
- What catback exhaust do you have?
- Fixing Up Car - Need Advice
- Micro vision screen Q's
- Proper touchup paint application?
- Fog light installation on '96 GXE front end
- In the middle of changing Knock Sensor, need help
- 00VI egr plumbing
- Name these wheels
- My AMB Button
- HID installment question
- Suspension mix and match question...
- Low idle, when stopped at lights
- ya so i got ripped off
- Need Help On A Size....
- seafoam power steering???
- what fluid goes in here?
- Help! an engine bearing on it's way out? :(
- Poor Maxi had a rough day...
- headlight poll
- I need o2 sensor opinions.
- spark plug indexing??
- Easy Out a Simple Solution?
- What chip should i go with?
- So I finally got my auto-folding mirrors from Japan.....
- Switch from Mobil One to High Milage?
- EVAP System Question
- The Fruits of my Hard Labor!!!!
- Question about tires on 4th gen
- Weird brake problem, need advice
- Rear window spoiler... Painted or leave it?
- My poor maxima.....
- Back Pressure vs Exhaust Velocity
- How important is it to torque to spec?
- Who to trust for a tune-up of the Max?
- Need a new car. PLEASE LOOK!
- they said it couldn't be done...BUT yeh
- What could this noise be??? (3rd time posted no help)
- Manual to Auto Swap
- Car dies...please help.
- 5 MM Spacer question
- Should I expect better 1/4 from vlsd 01 ae trans?
- slow tranny shifts
- Need Help in Denver-
- Are calipers easy to install?
- Hids
- Does Bosal make good exhaust products?
- Lost 2 Tenths? What?!
- Valve, and engine cleaning trick!!!
- Starting Problem
- Labor Rate on V/C gaskets
- bbk
- Front Right Heated O2 sensor
- All Maximas post 1995 are OBD II compliant.
- rim fitment possiblity
- Was there more than one beige or gold?
- Odd hum sound
- o2 sensor simulator question
- Did i just skip a tooth on my timing chain?!
- noticeable pull to the left
- just bought a y-pipe, a few questions
- Spacer Mod, interest needed
- 97-99 carbon fiber front lip pics??
- What was the reason you bought your first maxima?
- Dont Know What To Do! I need HELP
- Clearance Light Question
- Polyurethane Control Arm Bushings... ?
- antenna advice
- Attention MA area maxima owners
- Anybody who needs some hood struts...
- Which Optima battery should I get?
- windshild washing- cleaning?
- Brakes brake fluid
- thought some of you guys would be interested...
- can this be welded
- abs on after hub change
- Odometer problem
- replacement bumper lense clip in plastic things
- New Hawk Hps + Brembo Blanks = Dark Rotor?
- Brakes?????
- Engine making weird noise at startup! help!!
- Replacing the stereo HU question...
- Big auto tranny question! Auto owners! Come in!
- Killed another battery last night, Need help for rewire of heated seats
- Question about the airbag light
- Stuck bolts
- Hydrolock.questions and opinions....
- Yes, Virginia...the AGX's finally softened up!!!
- Are All 4th gen hoods the same?
- Stillen Flywheel??
- 3 questions regarding tinted tails (baking, paint thinner...)
- O2 sensor replacement
- Received a Replacement Altenator Free Under Shop Warranty.
- Maintenance Question..
- Running Lean
- Difference in starters?
- Has anyone ever told you? USELESS thread of the day...
- Seized Caliper: Drivers Side Rear
- Help with Red/Clear Taillight Install
- tranny leak from shifter rod?
- INJEN CAI Intake Install Help
- quik question about 01 vlsd tranny in 4th gen
- noise?? wondering if you have any ideas?
- Need some info.....
- Changed my alternator now nothing works, please help!
- Front Brack Repacement Pads and rotors. 1999
- well i guess i finally did it.
- paint/body guys step right in....
- 00vi upper with 98 lower..help..
- 1157 corner lights
- 97-99 Lip on a 95/96 Bumper **WTB as well**
- No 3rd Gear Maunual Trans
- What to use to cut strut bodies?
- Buying: 04 Maxima or 03 G35 Sedan?
- Factory Nav. On A32
- has anyone seen this before?
- White SE cluster w/blue LEDs (KEPT OLD ODOMETER TOO!)
- Problem With Screws On Fog Lamp Brackets
- Squeaking Clutch
- Door Lock Problem... HELP
- Key Code?
- Radio Buttons Falling off
- Hard starting+Knock sensor
- HELP! SES Randomly Comes On...
- 04+ Gauge Cluster in 4th Gen
- need help with making a wire harness conversion H3 to 9006
- pics of my car
- Replace 'oil cooler hoses' oem or not
- about to install coilovers...what should i also replace?
- fuel hose
- Why is my steering so sloppy/loose???
- Idle Problem
- hard to shift into gear
- O2 sensors voltage range
- Both of my Rear calipers are F'ed up...
- New rear shocks problems!!!
- Quick Question ABout Carparts.com
- Clicking when turning the steering wheel?
- IMPORTANT info about the STICKY threads- PLEASE READ!!!
- SE-L owners: who has the highest mileage?
- Studdering problem on rolling acceleration
- jeff/matt
- anyone rockin' 350z seats?
- Car sounds like Jet engine plane??? WHY?
- strut and spring day - all done
- FED spec ECU in a CALI spec max
- Heater blows lukewarm and temp gauge shows "C"
- changing out the corner bulb
