- 97 engine
- Suspension Squeak, please help?
- CEL on Airbag light flashing. Need help..
- B Pipe Problem
- What should i do SUGAR IN MY TANK
- Do you need to take Dashboard off for this?
- Cf Hoods Yo
- Effects of an Xterra on a Max (56k no way)
- Anyone with problems w/ EGR system
- Clutch Master Cylinder Dead
- What's wrong with my ENGINE???
- More problems ...
- Need some help... mystery suspension noise
- Touch up paint
- Maxima Video
- Microvision 7000BCT 7" LCD Monitor
- power window problems, please help!
- I Need Advice On Either Taking Off The Gauges Needles Or Not
- installing bodykit. any suggestions?
- Rear Hub assembly
- Silicone Tape at Radio Shack
- Car is dead! Won't fire at all. Long story.
- Cattman Fast Cat
- anyone have oem pads matched with brembo rotors?
- code 05 05 but i know i have stuff wrong, whats up?
- eliminate speed gov. no CEL
- New Paint, New Wheels
- Gauge Needles
- I got a 99 maxima, will a 2000-01 y-pipe fit?
- How many miles did your max have when you bought it?
- O.e. Suspension Parts?? Ever Hear Of??
- help installing Hella Supertone horns
- well i think its my clutch
- Anyone used the G2 caliper paint?
- Post Pictures of your Intake Setup !! (Intake Photos)
- my car is truely falling apart
- How Tight do I Tighten Knock Sensor?
- My I30T 5speed Removal.The mission so far (PICS)
- Car trouble
- Will shops like Midas install a Y-pipe?
- how to install aftermarket side mirror?
- ANY1 ever change thier steering wheel????
- Clicking sound when I turn tight.
- 97 Automatic folks?
- Replacing Resonator/Pipe and Muffler
- Power antenna stuck
- Reverse Camera
- Weird noise coming from passengerside of engine.
- 4th gen AIM Buddy Icons
- Car is having a hard time starting.
- best hood pins?
- KSport Kontrol Coilover Kit
- Big Electrical Problem!!
- symptoms of a bad PCV valve
- A/C compressor making a rattling noise
- Half of interior lights not working
- Shifter gets stuck and sometimes wont move out of park! Please Help
- can an ECTS make engine loud?
- Engine Swap Question 2001 into a 95??
- 95 Maxima Self Diagnostics
- Knock sensor harness part number
- Brake And Charge Light Question
- Transmission
- 97 Parts List
- Ebay suspension parts questions.
- Header Question..
- should i get these for reverse lights???
- Low Fuel Lamp
- should i stay away from used parts?
- I think theres a spider living in my car :(
- Help me, 3 ECU Codes
- Greddy Sp 2??? should i get it???
- HID Harness
- Tire sizing question for SE rims!
- New TWM Performance Short Shifter for 95-99 Maxima!
- Installation $$$
- BBK conversion question
- start and then die...
- Part Out or sell as Whole ?
- Eyelids!!
- Sylvania SilverStar VS PIAA XTREME WHITE
- Need some help on a decision.. 5.5 wheels or Cefiro Headlights!?!?!?!
- Cv joint question
- once again. anyone who has taken their Bose off those damn brackets. step in
- how much is average UDP install
- Thanks all for encouragement to install y-pipe myself!
- found top strut nut loose, now it wont tighten and the strut is moving all over!
- 0706 Does anyone know what this means???
- $349 Worth it for ECU upgrade?
- Trunk Lid Issue!!
- Stock Boost Sensor??
- Some1 offered me $7500 should i take it
- 9004 to 9007 wiring???
- anyone have screeching front axxis ultimate pads??
- my story for the weekend (a noobs try)
- Cruise control not working
- Strange thing happened today
- lookin for pics ot thoughts on M bumper
- And to think, I just washed... (56k go home)
- O2
- owners of aftermarket steering wheels
- Hub Centric Rings w/Enkei Wheels?
- Corbeau A4 Racing Seats
- weird engine noise...car is really loud
- Deep ****, car dead---Need help ASAP
- Help
- 1156 or 1157??
- I Hate Potholes
- Those with Half Blacked out tailights on Sterling Mist?
- help with LED taillights
- Major prob with 95 max engine helllp
- DC Clears
- Need YOUR input on next set of Springs (Vogtland)
- Where to buy engine mounts??
- spark plugs.
- Spark Plug GAPS????
- CAR INSPECTION FAILED !!! ARRGhhhh
- thoughts on ebay sway bar?
- help with paint
- Muffler Question
- Ceiling Panel
- Trunk button on remote stopped working
- Skyline VS 300ZX brake caliper BBK???
- strong vibration
- Transponder Key
- Difference in appearance
- Car won't start I need help FAST!
- gotta repost this im having problems
- I have a hard time believing this but it happened...
- Removal of Cloth Door Panel Insert? HOW?
- Where to find a RHD A32 Front Clip?
- Advice requested on KS and O2 Sensor
- Removing Side Marker Light Bulb
- Pace Setter?
- HELP!! Interior Illumination fuse keeps blowing
- vibration while braking
- Code 0126 oxygen sensor?!?!?!??!
- Y-pipe install quick help needed
- reset ecu
- YeaH BaBY
- Question for Flood99
- Rear speaker removal
- kyb dust boots
- where to buy 97 radiator drain plug?
- Just Replaced Ks And Harness....but Now I Have A New Problem
- LOUD rattle/buzzing coming from exhaust.
- Anyone have: Illumina Series Suspension Kit (from custommaxima)?
- Platinum Corners
- 300zx BBK Complete!!!
- Lowered 4th gen owners step inside....
- New Coliovers Links and Pics (56K Dont Even Try!)
- Horse power and automatics
- Sizes?!?!?!
- where can i buy eibach springs?
- !Emergency! brake experts help me please ..
- Finally pic & updated my homepage
- How many qts. of oil? 4 or 5?
- New EGR valve and Check Engine light is on again!!
- symptoms of...
- Collecting some info for a Catback. Can someone help
- CV joint will not go back together
- Cardomain webpage updated....take a look
- SeaRched stickies and posts; WHERE DO YOU GET SQUEAK TAPE!?
- what does this connector go to?
- Tein basic question..help!!!!!
- Connecting Indiglo Gauges: anyone know where headlight power supply is?
- suspension conversion complete. from gr2's to illuminas - review
- Intake was loose. Got 3 CEL codes could they be related?
- onboard Painting
- Building trunk floor questions
- Heated Seats
- alternative tire sizing for stock 15's
- how hard to replace alternator
- o2 sensor?
- Grill Options
- A couple lighting questions
- Noise when idle
- new CF hood, check out my latest mod (56k NO BUENO)
- drivetrain noise??????/
- Tranny or what????
- problems with car help me
- Anyone w/ Sarona Grill w/ stock bumper?
- Strange sounds after install
- Loosy Goosy Spoiler
- Oil Pressure Question
- Quick Question about cv boot replacement
- 194 LED Bulb- questions
- Bad hesitation
- y-pipe install problem...am I missing anything?
- everytime i start my car i smell a thick aroma of gas.is it leaky injectors?
- Trouble removing pass. side axle
- The 411 on coil packs...
- List of good sites to buy Max parts...
- Alternator test
- ecu codes
- just installed brembo blanks and axxis ultimates, ? about shimms..
- Clicking IAC Valve
- Squeal when braking...
- Yellowing head light lenses...
- Torn Rack'nPinion Boot - Suggestions?
- How To Check If You Have Limited Slip.
- Buy a switch and I have heated seats???
- Heater side mirror borken
- question for anyone who has (or has opened) 95/96 red/clears...
- MEVI Install
- I finally updated my cardomain!
- performance issues, plz help
- What do you commonly replace on your suspension?
- bose (? & f/s)
- Passenger Seat
- Water pump questions
- Popping noise when turning/CV axles
- new KS, Air & fuel filter, plugs, and o2 sensors...bad gas mileage WHY?!?
- Its time for new wiper blades
- Where to buy ECU? or ECM for M/T 95 MAX
- question about ES bushings
- tokico setup help!
- Need to find neat rocker switches to put instead of coin holders?
- ECU code 0201 (1320)
- how much will these run me
- How harmful are this codes?
- Wonder how certain wheels might look on your ride?
- question about lethear
- exhaust question
- Another Stalling Case
- headlight problem
- Ugh....I have a speed limiter
- Tokico Illumina Kit + 5th gen 17" wheels: Pics and mini-review: 56k beware
- Heated seat swtich question
- New Wine . . Electrical or Alternator?
- Engine cover for 2k1
- 00VI Help
- LED Gauge Mod concern
- 2000 Maxima Random Tech High flow Cat
- lets see the single sexiest pic of your car
- Need help identifying parts and problem.
- Oil leak, dont know where its coming from.
- Failed CT Emmissions NOx level bad??
- HID's w/o projectors?
- Idle problems
- All who run with 18's
- Cefiro's with Helios HID's
- Just did my brakes, ABS light is now on.
- Amplifier wiring help
- Coil overs just on rear?
- need help and advice on used stillen kit!!
- question about ECU CODES PLEASE HELP
- Engine rattling while in "D"????
- A max I saw today....
- POST pics of AE style headlights on black 4th g..
