- Grounding
- Can some one make me a signature
- 00vi question
- A few questions: EGR, tranny leak, ABS light
- Eurolights high wattage prices
- HELP, sunroof stuck open!
- Rattle? blown cat?
- New CF MEVI Cover made by Ionic Dynamics
- Clucth pedal problems...please help!
- Anyone Have K-sport coilovers?
- ludalip body kit?
- electrical help
- O2 Rear / Clean?
- Squeeky suspension... What could be the problem?
- CE Triple Gauge pod question
- Loosing Coolant but no visible leaks!
- 5th gen wheels on a 4th gen
- not burning all fuel?
- For everyone w/PS2 in their Max....
- Brembos and metalmasters = squeeky brakes
- Idle sticking at 800 rpm sometimes...
- Cd Changer Model Number
- Wasnt to shure where to post this!
- Hard 1-2 shift, hesitant 2-3 shift...
- thing for sale
- Mice in engine bay/car.
- 95-96 clear corners
- axle and stereo question?
- Heater fan problem
- What Bi-xeon's projectors/HID's to go with?
- G35 Exhaust Sound On A Max?
- Pics of my Lexus Yellow Capsule Mod
- anyone else's seat belts retract very slowly?
- Do 95-96 gauges use 194 bulb?
- Check engine light came on
- Loose Trunk Hinge
- NOPI in Tampa
- what i did with blue led's
- How much does the OEM plastic MEVI cover cost?
- ce 95-6 red/clears
- Help Adding Transmission Fluid
- Electrical problem...
- Driver side mirror cracked
- Yet another spring question
- Probally a stupid question, CV
- side impact airbags
- whats wrong with my car
- supercharger help
- Just installed my headers
- 9007 HIDs in 4th gen ?
- Stabilizer link question
- ECU problem
- Engine light on, pulled code 0505???
- Map of 4th Gen owners?
- Valve body???
- Trouble Starting Car
- 99 Maxima SE ECU Codes P0138 and P0139
- Annoying rattle/creaking sound...
- Trunk Question
- Online manual
- Clutch Bleeding
- CV joint replacement
- VQ30 internals
- Ebay Parts?
- Alternator is going bad
- will a 5th gen dual tip muffler fit the 4th gen?
- Clear Coat for Red Clears
- Oil Pump
- Bose Head Unit Help
- Vb
- grounding kit strangeness, thoughts?
- Diamond Corners, fitment?
- My first winter with the illuminas, quick question
- addco RSB any good?
- I need an overhaul :(
- Won't shift into OD?
- Need help 03 OEM TE 17"
- Steering fluid and automatic tranny and clicking
- Getting another Max today!
- for those w/ D2s
- need answer quick
- I've read about 'hard' starts, but SQUEEEEL! vroom?
- Tachometer (RPM) help - stays at 0
- Axle Hop
- Picture Or Better Description of O2 Sensor Connector Locations
- Anyone here had a balljoint seperate whiles driving?
- e-brake light is messed up
- IACV Cleaning and Coil Packs
- Off the top of your head, tranny fluid???
- Red/Clear tails anyone know where to get them cheap?
- Does 99 se limited max have ABS
- Monroe Or Gabriel?
- help--exhaust question
- ECU code, did the check and it is undefined
- New Brakes Screech in Reverse
- Upgrading Factory Alarm
- all with stillen front lip
- What kind of car did i buy
- Reverse sensor switch on manual tranny help
- how do i know if my key has a chip in it?
- 4th gen radio in a 3rd gen maxima
- Fed and Cali Spec Y PIPE difference
- so i got pulled over for legal tints
- Right rear suspension noise
- 95 Maxima or 98 Infiniti i30t?
- Phantom Grip
- 5spd shifter bolts...where to get them?
- need help fast.
- Symptoms for bad battery or bad alternator?
- I'm 100% positive my car is cursed...
- Brakes
- Rough Starting
- Pilot Bearing
- Celica Seats
- recalls?
- All those with MEVI or had a MEVI step in
- Console Lights
- corner light removal?
- Bad Smell
- NO Clutch Fluid
- Cefiro Sills
- Who has a maintenance manual?
- need an exhaust
- Who has an owner's manual?
- SFC's and LTB's ?
- Idle pulley nut rusted and wont budge any suggestions?
- fog help
- put in a 300zx fuel filter and now some concerns
- starting problems help please
- Are 4th gen (i.e. 95-99 I30's) VLSD manual trannies prone to having bearing probs?
- two axles, 3 hours labor, $430?
- HELP! replacing bulb on auto climate control
- How many of you all have just the stillen front lip?
- Would you replace knock sensor, if you have no code ?
- I am so $crewed !!!!
- WTF just did 9007 conversion and it looks the same.. need help
- How to paint calipers?
- Wrecked max this weekend
- Quick question
- " Sheet Metal "Noise coming from wheels?
- I broke my power antenna today.
- M I L CODES 1302 & 803
- car will not start
- 02 sensor?
- hard starting
- fan is on all the time???
- Retrofitted HID TL Bi-xenon Projectors
- Bose from 2000 Infinity G20
- car idles low at when stopping
- Iacv Cel ???
- discreet shift light
- 9004 to 9007 confusion
- suggestions for new muffler or exhaust system...
- Question about ECU Codes...Oh God
- Po740?
- Where do you guys get your control arm busings!!!
- Need help with shocks.
- Can't fill up Tank
- Trouble downshifting into 1st or 2nd (New transmission)
- roof spoiler
- Another Great exhaust! ...video inside
- KYB AGX's
- good lowering springs Prefer Eibachs??
- how much to change autotragic into manuel????
- Car cover: Decent for e-bay?
- omg this sucks
- Dual Exhaust
- Anyone with Unorthadox Racing pulley notice that it's really loud?
- Stillen front lip
- where can i get a oxygen sensor for cheap.
- noises from 5spd trans. not the diff gears
- 02 sensor plug for greddy sp2
- how to tell if mileage is accurate
- STALLING persists...security system ?????
- ok, here's what happened
- part hanging
- Gauge Cluster
- 3 alternators later
- how much do stock 16" 97-99 SE wheels weigh?
- Noob ground strap question ('96 GXE)
- How much longer will the clutch hold?
- need help ASAP
- hows the quality of the KYB strut mounts?
- lowering a stock '95??
- Engine Temperature Gauge Problem
- molded rubber/plastic floor mats anyone?
- Voltage Stabilizer . . .
- Car shakes at idle
- Headlight harness
- $200 supercharger (well kinda) . . .
- upper strut bearings
- Choosing between Eibach's and H&R's
- Post pics of LEDs in your 4th gen cluster
- can't get darn ebrake handle off!
- Projectors question
- Suspension Nightmare!!!!!!
- SRE short throw shifter
- My Lights Won't Cut Off
- after cleaning throttle body and IACV
- Aftermarket Fog Light Fitting
- Piaa's
- 3rd gen owner thinking of upgrading
- A new, and very sexy addition!!!
- Car won't start - fuel pump or alarm?
- Alternator went, what did you pay for a replacement and labor?
- H3 Harness for high wattage lights?
- need a quick response cooling issues
- Removing ac compressor
- cheapest place for H&R springs for a 96?
- Clutch problem PLZ HELP GUYS
- 11:1 - Inhibitor switch
- High flow Cat's do you get gains?
- JDM Black Chrome Diamond Cut Bumper Lights
- Cattman Y-Pipe GD (Coming Soon)
- whistling noise above 100mph?
- will 5th gen intake fit in our cars?
- Screw size to remove rotors
- Morality in a gauge swap...
- It's VQ weather.....
- Kyb Gr2 Shocks/struts
- struts on trunk lid? instead of bars?
- Help, Car Is Sputtering
- is it just me?
- 95 Max SE - cruising 40mph, floor it, revs to 6500rpm, but car takes a sec to go...
- Check engine light = fuel injection system
- rear light bulb?
- Need Spindle for my 97 maxima
- Help! maxima sometimes stalls when I come to a stop
- Tie Rod Installation - 98 5 speed
- Repair shop horror story....
- Front Right Turn Signal
- 300zx Rotors and Calipers
- For those who are lowered with kyb AGXs
- Yokoham Avid H4s
- valve body question
- Budget Y-Pipe vs Home Made
- 95 vs 97 Interior - Easy Swap?
- the 00VI
- Need help! My RPMs play at idle....????...
- B&M or CE STS?
- Installed 5th gen clutch...still confused
- AWD Maxima
- Which of these strut bars should I get?
- car won't start...suggestions?
- SPRINGS? Stock SE?
- Humming Sound from Left Front Wheel
- Problem Fitting Foglights into Bumper
- Good deals on struts lately?
- help choosing tires for 95 Max SE (215/60R15)
- 9004 lights burning the connector
