- Ahh Need Help
- Installing new fender tommorow!!!
- Anything to know before buying a 98?
- Exhaust paint
- How to Install Battery?
- eBay floormats...tell me what you think
- Courtesy Nissan Variable intake manifold on sale!!
- Exhaust Question, opinions wanted
- Pics Of Smoked Tails on Black Dirrrrty 97 max
- Blower speed #3 not working.
- Has anyone tried to pull their foglights apart?
- Does anyone have pics obx catback installed!
- 1997 Maxima - Knock Sensor
- Freezing cold out and car won't start.
- Slow clutch
- hand-brake and battery lights are ON
- intermittent hard starting?
- Need Help: RPMs dropping too low
- Sounds like a diesel?
- Parking Brake gone!? :( How do I fix it?
- Air Bag Light is blinking!!!
- has anyone here ever installed these exact gauges?
- where to buy apexi rev/speed meter mount stand?
- bulb size (fog)
- Auto climate control question
- Will 96 SE gauges easily replace 95 GLE gauges?
- oil pressure gauge...
- Selling my 2nd Gen Alty & going for a max...
- Mechanical Temp. Gauge any ideas
- Anyone have the redlinemax red/clears for 97-99 max?
- I need a new clutch
- how to remove glove compartment
- Engine rebuilt?
- Fogs
- Winter beater?
- Help;2-10 ecu code
- Cylinder 3 Misfire, please help
- A few updates n pics
- Carbon Fiber hoods in the winter???
- Auto Tranny Problem...Slipping?
- lights
- Simple Maxima Video we did over the weekend
- What yr is your MAXIMA? WHAT do U have under the HOOD? PLS REPLY
- poor gas mileage
- Question regarding tinting out tails
- A bulb already burnt out in my dash...
- Which to fix first 97 Max?
- red/clear taillight
- reverse indiglo or SE gauges?
- Can't stop crankshaft from spinning!!!
- Computer upgrades--whats the best? suggestions?
- Hunter balance machine
- Groaning During Wheel Turn
- High flow fuel pump affecting performance?
- keycode for 95 max
- hood support pistons gone bad
- illuminas adjustment
- what is the revlimiter at
- Headlight harness install. I gotta a wireing question.
- Questions on Cattman Headers and y pipe
- who sells ngk spark plugs
- blue smoke out of my max
- Limited Slip?
- GR-2's and the dust boots
- Budget Y-pipe HELP
- clutch problem
- Wondering how much my Max weighs and take a guess at HP ?
- Chipped NATS key reset. Why?
- Cattman Headers and y pipe?
- Gas Smell when I turn the heater on
- Piad $20.25 for a fuel filter, should I have got a 300Z one instead?
- Front sealed needed when replacing Crankshaft Pulley.
- Need opinon on rear body kit
- Best Cat-back exhaust
- Best Size Exhaust?best Brand?
- Blower Problems
- Broken B-pipe hanger, now what?
- weather stripping advice needed
- Best Side Skirts?
- CV joint repair price
- just installed stereo now i have static in my speakers
- Central Jersey Maxima Meet!!!
- power steering,Im retarded
- whats the best springs for that soft ride?
- 1998 maxima
- Bolts to remove rear rotors?
- 'Drop Sensor Mod' - need heellllllpppp
- Reposting this question again. (gas pedal vibration)
- headlamp replacement in 96
- very noisy while running Help!!!
- Perfomance Chip
- Need answer to a simple question
- Maxima meets in So.Cali
- Can I have pics of different colours?
- how to beat a G35
- body kits
- skyline body kit
- about HID
- How To Disassemble your Bose Head Unit (95-96) plus a discovery...
- K&N Cone Filter part #?
- CEL P1447 - What to fix for EVAPpurge flow monitor fault?
- Well, I think I'm out $2500
- My girlfriend blew the headers on her '96 Max what next?
- pricing question
- Oil Leak - Nooooo. Help.
- Skyline Body Kit
- Body Kit Question.
- Questions about changing driveaxle
- Scratches are killing me!
- Need to replacing rear brake caliper, any how-to's?
- Suspension Parts Replace or Reuse
- Which one is better? KYB or Tokico?
- Ahh man .. Advice needed - O2 and INJ system CEL codes.
- Part out or sell as is?
- Oil Pressure Gauge
- Need to check on a 4th Gen for a friend...
- Dead Battery
- i need cool interior mods 95 max
- Which bulb is Brighter??
- Lower Control Arm Install Help
- RPMS dropping
- Misfire in cylinder 3
- DIY VB mod?
- Need a ECU and have some questions...
- Aftermarket fenders (redline max/custommaxima)
- Change Tranny Results
- priming oil pressure
- I'm Tryin To Find Best Write Up On Stereo Installation With Bose
- Throttle position sensor?
- Dash lights out
- 98 & 96 clear plastic piece
- loose coil springs?
- My car hit 100K
- Changing Belts..Idler pulley stuck!!!???
- exhaust, intake, headers
- Voting for Maxima.org's calendar is taking place now!
- Trust these ebay obx springs?
- ARRRRRRG!!! My sister hit both cars in the yard!!
- Will be buying a Max soon, what should I look out for?
- HELP!!! What do I do?
- Fit #194 bulbs in you dash if you have a 98 or 99 maxima
- Tein/Sprints cause driveshafts wear cause they are sooo low???
- What Is Wrong With My Brakes!!!!!
- Is there a link to take apart the dash???
- Beware kyb gr2 + weapon r coilovers
- are all maximas pre wired for power seats???
- Dome light switch in door jam fell into the body!!!
- snow tire size?
- Fualt Codes, P0420, P1447. Help!
- New to brakes...will this fix my squealing?
- Interior Dash Re-Color
- HIgh idle RPM
- Sway & Strut Bars
- Y-Pipe Question
- Missing Screws for Y-Pipe
- New Custom Shift Knob (pics)
- Help installing O2 sensor
- Need HELP!! Doing full GXE to SE conversions, 95.
- Emblem residue
- 5 Speed Swap DONE.... almost. A few questions.
- Door lights
- Question about tire sizes...
- Parents agreed to buy a '97-'99 max, help?
- Fuel Injector HELP
- 1996 Black Housing Headlights???
- More power
- Need some help ASAP guys...car f'd up
- offset on 19s ?????
- FSTB Help Needed
- Antenna height (PICTS)
- Anyone using the Bosch Super 4 Plugs?
- Idle problem with my '95?
- Keyless entry remote broken
- upper intake manifold gasket
- "Mingle Noise" diagnosis from dealership
- cruise control
- i need some help!!!!PLEASE READ
- New Corners And Tail Lights (pics and questions)
- cefiro?
- Drop resistor mod
- smashed side view mirror
- Can I get just a WS muffler?
- Re: Body Kits
- RE: Lighting
- For those 97-99 owners that want to change the color of their dash lights
- Adjusting Idle ???
- Looking 4 B & M short throw shifter reviews
- Skyline Headlights
- what shoucl my car idle at?
- Wheel size and proformance 15" or 16"?
- Dallas Taillight Mod ?'s
- factory alarm ????
- turn signal problems
- Rust around fuel nozzle area
- DTM done...[PICS]
- Brake noise?
- My shiet is quiet again!!!!!!!!!!! WOOOT!!
- led for speedometer
- Seat belts don't roll back up!!
- MEVI came and went!!
- Has anyone seen the smoked out euro turn siginals??
- couple questions
- CV Axles/Boots
- Body Kit Install Blues :(
- Crankshaft Position sensor???
- Not gap platinum plugs?
- Tail in rear light combo (Altezzas) WILL NOT WORK
- Suspension question...
- What is the perfect led for window switches? (color, wavelength..)
- wheel well problem
- PICS!! Alternator Replacement Needed??
- Anyone know where I can buy new headlights (The whole thing?)
- evap small leak, vent control valve
- Car won't start! Is it fuse,battery,or what??
- Convert to 98 speedo on a 95 se
- Energy Suspension - bushing install Q
- windshield washer failure
- 2000 manual transmission in a 95 maxima
- JWT ECU just came in!!!
- downstream O2 sensor near failure
- code 1008
- Drivers side window switch-led conversion
- Toyota Celica A/T shifter on 4th gen Max
- WHat is worng with my tail light
- what kind of a racing steering wheel should I get?
- taillight wiring question.............
- OBX Type H help
- Just got back...14.26@97mph in the automagic
- Had some trouble tryin' to change my belts...
- Oil on plugs, please help me :(
- Only get spark in cyl 3 and 5!!
- Twin Power!!
- awesome headlights, 2 bulbs *PICS*
- Chimes on '99 SE
- Hit 110mph then hit fuel cut off
- Throttle Linkage: Cables and Connectors
- Oil in muffler
- Electrical problems
- what needs to be modified to make an Apexi WS catback work on a 97 MAx ?
- What Type of Maxima Am I Looking At???
- Bumper modification to fit 2k2 muffler
- Are the rear mirror covers removeable?
- sick of my max
- Stainless Steel Brake Lines.......I Like Em!
- Homelink security system ?
- Transmission is about to explode
- Looking 4 Audio/Video of different exhaust setups:Lets hear it !
- Weapon-R coilovers any good?
- '97 GXE Won't Start
- Fit 194 bulbs in 99 max, fixed my front end, new door lights.. *PICS*
