- Cheapest place to buy H&R springs??
- Auto shifter to high
- Hood Struts
- CEL and 87 octane?
- new pic of my car
- Stick clutch question
- electical problem
- 87 Octane Fuel
- Radiator Leak
- Hi-Wattage headlight bulbs!!!
- 1995 remote system question
- fuse problem and headlight bulbs...
- Anyone have pics of their wood dash kit?
- frankencar intake
- Which one is better?
- How's the ride with a GR-2 / H&R setup?
- help bad misfire
- Tein-S on 18's
- best wheel size
- I have an idea....can you put a little breather filter on......
- ever wish forum was split into mecahnical and all other?
- Stock Intake question
- Stillen or Greddy?
- Help: Odometer stopped working.
- Temperature control
- Finally got pics of my smoked red-clears and sidemarkers *pics*
- which non-headlight bulbs is the brighest
- switches
- brembro rotors cross drilled and slotted CRACKED WTF!!
- non linear clutch feel
- Instrument Cluster Compatibility
- Shooting Incident?
- Exedy Stage 1 Clutch
- TPS not reading 100 at WOT
- How to adjust front toe in?
- motostorm udp
- Cel 0901 ..
- Bosch Spark plugs ok?
- 97 Max, GC's and agx
- how is your braking system function?
- 96 MAXIMA GXE Calipers for only 78US?
- Where to buy ACT clutch ??
- Great used Max but whats wrong with the clutch?
- speed limiter removal
- installing catback.....beginner....SCARED!
- Calipers Freeze up? Is my mechanic right?
- Cold Weather Auto Trans Warning
- question for Jime?
- Weird clutch feel....don't know whats wrong
- Trying to install Xenons. *Please help*
- Rebuilding rear brake calipers - problem
- Another MAx out of the running =(
- Need to troubleshoot A/C
- red/clear 95-96 maxima tail lights
- About to buy shocks and springs, what else do i need?
- HEADERS and Y-PIPE
- 97 GXE what to check before purchase
- Air cond leak rate?????
- ignition coils from Autozone
- Intake Velocity Stack
- Wat is a drop resistor????
- On 20's I want to lower it
- Where To BUY!!
- Phantom Grip?? Where can I find this??
- calipers painted?
- what is most comfortable shocks/struts?
- what bulb???
- Intake sound difference
- Redline Max Skyline Front Bumper
- Resistor pack replacement
- Our cars are old, PERIOD
- yea.. ANOTHER g-tech q
- 5th gen projectors in 4th gen write up?
- Will wider tires help get rid of understeer?
- Intro on my 4th gen and me. A few questions.
- Problem with wheel studs , please help.
- WTB:300zx injectors
- How do you put leds in cup holders?
- A/C Screwed, Evaporator?? Unclear answers
- 95-96 tail light idea
- New Pix - Few crappy Movies - and a question!
- Lowering plus rims, and Camber question??
- hoods available for 1995 maximas?
- Dropzone N1 coilovers..
- Tinted Tails Write-Up
- 97-99se steering wheel diameter please
- HeadLights/Parking Light bulb suggestions!!!
- NGK copper plugs
- Where is the write-up for changing the defroster and hazards lights to leds?
- Clearance light issues
- Help...fuel filter hoses won't come off.
- Anyone running stock SE springs and Illumina's?
- Installed the Greddy SP exhaust
- Quick ? about maxima.org stickers
- ***Dont know what y pipe i have!!!!!***
- which springs are better?
- Max vs. 2.2L 94 Accord
- help! check engine light on
- Maxima newbie question/ impression
- Short ram v.s. cai
- How to change bulbs for gauge turn signals
- Do Denso platinum plugs need gapping?
- 99 SE Knock Sensor Replacement
- 97 Maxima Cold Start problem
- Is the horn supposed to sound when you lock the car via remote?
- Shaved door handles...
- motostorm s5 grill
- TOOK some new picture, check em out!
- MTX 24pt. coilovers
- Weird problem with check engine light.
- overriding rev limiter?
- Brake question
- Need help finding out which ground is bad
- Adding LSD to my 5-speed?
- It is done. The Maxima is Gone.
- engine and tranny oil
- Anyone have pictures with hyperblack bumper lights?
- I am shaking fcuking mad, little help with KS, before I break something
- Help - '95 w/ 190,000
- ECU Code but can't acquire solution to problem.
- Belt Changing Instructions - need link
- New here, a few questions
- Daytime running ligts
- whats the ticking noise
- MSD mod on my MAx
- What's Injen's inline air diffuser for?
- Desicions...Desicions...PR or Injen CAI. What do you like?
- Power Steering Fluid
- Camber kits.
- Help me choose..post
- Tailights
- What are the ideal shift points for our 5spd?
- Gas Prices Going Higher.......
- Speedometer pinion location on tranny
- Help, I need new struts
- Potentially Damaged Wiring ?
- Any kills tonite? I got one
- Tokico kit has bigger drop than I expected.
- What kind of bulbs do you need for turn signals inside the car?
- gauge bulbs and wax question
- problem with taking out the grill
- We can't figure out what's wrong!
- in need of airbox help quick
- Tinted Tails (pics)
- Window Up Using Remote Control
- Replacement rotors ?? Will warp like OE????????? or not?
- Quietest B-pipe?
- Need a High Output Alternator - Anyone with Suggestions?
- Fitment Question on seats
- Led lights problem
- anyone in Herndon, VA
- Why is my airbag idiot light flashing?
- parking bulbs
- I'm about to order and replace front wheel bearings...
- ? for those who have MEVI
- Gas light stays on for how long?
- floor jack
- ECU Code solenoid and knock sensor
- hwlp! Which wiring harness
- ecu error
- Maxima, 300zx same engene?
- quieting WS ypipe
- pics of my car
- 4th gen stalls on startup when I put it in gear
- Just ordered my GReddy SP2 Exhaust.
- Starts Very Hard
- Hows the ride with Sprint springs and KYB's?
- 97 and 99 airbox the same???
- Security Alarm Installation Guide ...
- Do think if i just put Side skirts .....
- motostorm grill
- How to remove headlights? (97)
- Whats are the lowest springs u can get?
- Estemated HP for Cardomain site
- help with steering wheel install... tips?
- Possible started problem and ECU code 0302
- Difference between a 99 or 99.5 y pipe? Is there
- KS replacement problem
- Anyone else had a Vehicle Speed Sensor Problem
- How do I program Key fob for my '97?
- I need help with turning climate control blue!!!
- airbox sensor
- Cat converter size
- P0340 cam sensor code
- tips for aftermarket steering wheel install
- Silverstars, Nokyas, Eurodezigns ?'s
- strut bars / y-pipe
- play in accelerator pedal?
- How well do you know your fuse box?
- What do you guys think of this setup??
- racing tip thats worked for me
- CARS with HID
- Do you really have to disconnect the battery for the auto to adapt?
- suspension question
- Projectors Update
- De-modded the max..feels like $h!+...
- 91 Octane with TS or JWT ECU
- finally finished replacing my clutch
- Dash lights problem !!!
- Mail order wheels.....be careful
- Rear brake info requested...
- What would you do?
- Subframe Connectors
- SE stock or TOKICO HP STRUTS fro GXE ???
- ECU code 05 05 help
- struts and springs?
- warpspeed y vs budget y -pipe need help
- Help!!! No Fog Lights!!!!!
- Who knows how to make turn signals blue?
- are all CAI the same
- Squeeky Suspension!
- custommaxima y pipe - NOT cattmann - anyone have info?
- adding grounds?? improvment? write up/how 2
- Intermitant surging/dying/no start
- decisions decisions decisions
- Is magna flow exahust good or not??
- got my budget y-pipe installed today....
- JUST installed INJEN and OMG !!!
- Lag in RPM's around 3k?
- VQ35 internals in a VQ30
- Ugh. Messed my Fuel Gauge needle up.
- Vincetti's Maxima
- Techno Square ECU upgrade for $380!!
- Super black, what is it supposed to look like?
- Squeaking/whistling noise...
- Mevi
- HELP WITH INJEN !!!! ( i beg u)
- After KS replacement milage is still bad
- Grill for 96-96 Maxima
- '97 GLE funky factory alarm
- Trans. Fluids Affect on 1/4 times
- Just received my Budget y-pipe BUT.....
- Bad MAF ground = VQ runs like poo
- New Rims, what do I need?
- Body-colored Splash Guards? ? ? ?
- ANY Tokico springs and struts on your max.....
- Squeaky Pulley?
- anyone know how to install camber bolts?
- I Love The Org Soo Much That I...
- vehicle speed sensor, and auto trans signal to ECU
- i need the 1 800 # for budget exhaust
- My Review of Mobiletek's VB mod..
- Woah $75 for Porterfield R4S pads...
- What are the best springs to go with!
- Huh? Body Control Module
- Check out some new pics of my '99 showing off my AE lights and more...Dial up beware.
- Pretty Nice 5spd Max on Ebay
- battery relocation write up?
- to sell or not to sell....
