- Car lowered-- pics
- audo hookup
- 5speed questions
- Accident: Max Vs Deer
- horrible ride help
- Why rpms, would be lower with y-pipe?
- 5sp convertion shop(s) in the West?
- Tint
- CV Boot Replacment or CV Shaft Replacment???
- What to check when missing power ?
- Make the horn honk on the factory anti-theft system
- hollow metallic rattle?
- Just installed rear sway bar.
- how to install I30 autodimming mirror?
- Need a Billet Grille. Help!!!
- I really can't take it anymore :(, please read.
- what do you guys think of the Diamond Plate Floor Mats
- Maxima Vandalized :(
- AGX vs Gr-2
- Oil Leak
- 0510 ecu code... whats that?
- 4th Gen. Maxima for first car
- Best Performance exhaust to buy
- how much $ am i looking to spend on an underdrive pulley install?
- Leatherseats.com installation, DIY or Professional Installation
- power seats stuck need help
- anyone has pics of deep evergreen with CF lip and/or CF eyebrows???
- 2 Qs
- MY HOW-TO Install a 2001 Mitsubishi Galant GTZ Spoiler on a 1995-1999 Nissan Maxima
- just installed Tein H Tech and rattling
- Max broken into. AGAIN!!!
- Hanabi ballast compatibility
- 95-99 Nissan Maxima Coilovers/Damper/Shocks/Springs Kit
- Power Steering ?s
- what do you guys think about these corners?
- The end of an ACT's life? How to tell?
- Knock with 91 octane?
- Noise from the front right wheel
- oxygen sensor
- seat swap and dash question
- how to search previous threads
- Battery problem, I think?
- any other corner bulbs other than polarg?
- 3000GT Throttle Body Upgrades & HELIX POWER TOWER help
- Installs on Y-Pipe, Cat, and Full Exhaust
- "Slack" in power seat?
- link for 300ZX brake upgrade??
- creaky suspension
- I was hoping to find a buyer for my new side skirts
- Looking to Purchase a 97 SE (Need Some Help)
- Vibrating Noise HELP!!
- Has anyone not wrapped there springs?
- Dynamat and QuietCar
- Finally made my Max a webpage, check it out.
- turn signals keep blowing fuses
- Using the self diagnosis....
- CEL on...Cannot read codes
- Misfire / Ignition Coils? / Testing? / Other ?
- Cefiro door sills or Maxima sills???
- ACDELCO jack and stands
- Check engine light is not on when turn to on position
- is the custommaxima y pipe worth getting?
- Gaskets needed for removing and replacing intake manifold, TB??
- Cefiro lights installation
- Installing coilovers right now help!
- Help my check engine light is on ?
- My loss someones gain
- Looking into possibly gettin HIDs
- ECU CODE 0307?? Closed Loop Control? WHATIS IT?
- PIAA for fogs and headlights, what about headlight corners?
- How did you intall your AE dead pedal?
- Pro Kit on SE Struts
- What size socket do I need to get the front CV axle nut off??
- .ORG Merchandise
- radiator hose?
- Firewall Getting threw the firewall
- Looking for ECM for 98 Maxima to buy
- How do you turn on your foglights WITHOUT the headlights coming on too?
- Will this fit?
- Engine Service Soon light on!!! and y pipe question
- Sprak Plug Gap?
- knock sensor life
- ebrake not completly released?
- do they make quaife atb's for auto's???
- first maf--now tps--codes question
- Carbon Fiber Front Lip
- Cruise Control Switch
- sensors are dead
- 95 Cigarette lighter no longer works.
- where is the cheepest place to get lights to match HIDS? which brand is good?
- B-Pipe extension peice & : Lose or Gain power?
- Power Seats-- Pre-wiring??
- A little more CF for my car....check it out...
- OBX Coilovers
- what is WOT, and how do you 'drive wot'
- Need Help with Axle Instalation
- New Pics of Max for Spring time
- How many people running Eibach Camber bolts?
- Rear Kits
- pin stripe removal
- K&N drop in filter worth the $$ for automatic?
- Saw yellow fog lights today...NICE
- Evap Canister Vent Control Valve
- Radars
- stock exhaust
- 1999 max
- Remote for maxima
- Installed my Y pipe today......ohh man..
- 2001 pathfinder throttle bodies
- Need advice on these ECU codes.
- Power windows & locks not working. HELP
- tein s springs with agx
- I need quick help with a fuel filter!!!!
- Is this worth it?
- I need a New Knock sensor.
- SFC Stage II clearance issues
- Tranny Upgrades??
- Will a muffler of a 98 fit my 96
- WRONG CAT .. Please HELP !!!
- Serpentine Belt Replacement Instructions
- Removed power steering
- Help with install
- Clutch experts: clutch sounds and feel
- Need O2 sensor advice
- which ground wire kit is better?
- is there a way to adjust trunk torsion bars (or whatever they're called)??
- Weight Reduction
- tein-s on 18's
- **pics** New custom Flowmaster Dual Exhaust installed!! **pics**
- URGENT Deep rattle, tapping on pulley side of engine
- Rear Sway Bar on NYC condition?
- knock sensor question
- URGENT Deep rattle on pulleys side of engine
- Tranny drop and Flywheel install
- anyone know how to take seat panels off???
- My friend added a Maxima HomeLink to his Camaro
- Frankencar intake
- How to install Amp kit???
- re painting rear and front bumper
- How do I determine ignition type????
- 97 Starter?
- Air Conditioning Intake Question
- Power Steering Belt Change Help
- Magnaflow Dilemma
- O2 sensor removal??!!
- Code 0103: engine coolant temp sensor. Where is it?
- Deal or Not
- Jet Performance ECU Upgrade Opinions
- Undefined ECU?
- rd1925 injen intake
- get 97 bumper tomro, waht to do with fogs
- Automatic in need of mods
- HELP:reinstalled BOSE HU, now no audio,clock,antitheft, door open signsl
- "Wrrrrrhh" sound at startup, idler pulley?
- Clutch Questions
- [Update] installed HID and newest Pict.
- backup lights
- ECU 0304 and 0103 question....
- should I change mufflers
- In cabin micron filter
- Painted my stock 5 spoke SE wheels Charcoal w/ polished lip *PICS*
- Mcallen Texas Meeeet
- rear disk brakes
- Pathfinder TB install - idle voltage issues?
- JWT Popcharger: A worthwhile mod?
- CV Joints replacement-GRRRRR! and installation
- need some info on springs
- Tested KS w/ unclear results.
- The mystery bracket? Its gotta do something!
- will this fit my car?
- PPL with the 0302 SES code step in....
- Warpspeed Y-pipe
- Help me Settle Dispute
- EGR Cleaning
- Whistling/Chirping Sound???
- Pics of 350Z seats in my Max
- Red/Clear Tails: CustomMaxima or RedlineMax?
- y pipe dyno plots
- 95 super black paint?
- Short Shifter?
- Which model Y pipe???
- Round 2: Got My HIDz, Am Lovin it *pics*
- remus exhaust
- remus exhaust
- Opinions on the OBX Catback!
- Where do you put your Radar Detector?
- Condesation in the Headlights!!
- Since a lot of people have been wanting to hear a stock max with just y-pipe...
- Foggy Headlights
- weird problem
- New shoes, what do you guys think?
- Rims: To buy or not to buy?
- pistons
- stalling? wtf?
- Rear Bushings?
- Highbeam Switch for DRL
- re-key door locks and igniton?
- help! air temperature sensor
- Automatic shift knob selection
- What aftermarket spoilers look good on max?
- Air Bag light blinking
- How do i know if struts are blown?
- front and rear different?
- Question about rear brakes on 1999 GXE.
- fuel treatment + fuel injector cleaners ?
- Tranny rebuild kits...
- Wheel Bearing Replacement (not repack)
- Can I tell if strut mounts and boots are bad before going to shop?
- B-Pipe
- Simpler way to get ur corners brighter
- Service at the Nissan Dealer
- Bosch spark plugs
- moving drivers seat further back
- Intake Adapter Sizes
- Where to Find.....
- What to do for exhaust?
- She's gone...
- who is the maxima that did the G35 sedan led taillight mod?
- new body kit arrived!! woo hoo!!
- please help !
- Pathfinder Thottle body?
- Automatic Climate Control
- Will GC coilovers all fit 95-2003
- Black mats in tan interior
- Is a Maxima a RICER???
- Good and Affordable HID?
- Poll: Rice Or No Rice??
- Back Lights
- Push Bars for a Maxima?? ANYONE MAKE THEM??
- ahhh...new sparks definatly worth it.
- Headlight problem
- OK why is my idle swingin
- WHOA!! 1200 RPM idle today!
- Automatic Tranny Gear Selector
- Ignition coil
- Ground wires pros/cons??
- ***Hacked Airbox Complete*** Video/Sound Clip Included (need host)
- i have progress springs will kyb gr2's go with them
- Adjust ECU to new y-pipe
- Powersteering belt
- The last straw
- *picx* just got my HIDz *picx*
- Just Installed EVo 5's
- Headlight Bulb?
- help installing gc coilovers *kinda long*
- engine prob
- Hissing sound when i DONT hold down clutch?!
- Line pressure solenoid valve assembly replaced - tranny still sick...
- I am putting black leather seats in my Max with tan interior.
- Exhaust from hell...
