- condensation after using AC
- vibration past 100 mph
- Adjusting the TPS?
- no good mechanics or bad install?
- Code Reader Recommendations
- 1999 Maxima - puff of white smoke on startup
- how do i make certain my shocks are blown.
- would like to attempt myself
- VQ engine question.
- Changing the alternator
- R headlight bulb exploded, silverstar or xtravision for 9007
- what do u guys think of my ride? cardomain UPDATED!
- WANTED:pic of ionic front,stillen sides,rear
- VCV Valve
- What could be the cause?
- Is Adding Speed Chip To Cai Good?
- would like to know personal experences with tein coilovers
- Exhaust opinions
- UDP Causing Bad Engine Timing??
- california car?? What is the diff??
- post pics of your sarona version 1 kit
- I have an idea!! Will this work??
- Uphill battle from 2-5 gear
- 00/01 5Spd Tranny in 4th Gen?
- Who had to replace fuel injectors?????
- MAF or MAF Wiring? HELP PLEASE!!!
- 0302 Code - need advice
- heated seats
- 5th gen clutch?
- Please help with wiring
- few elementary questions
- shocks for my eibachs
- 6th gen gauge cluster in a 4th?
- spoiler loose
- I had my 1st breakdown today :crying:
- i have an aluminum dash kit now and i want to buy a new carbon fiber dash kit
- o2 question on 99 SE
- pics of tein s-techs w/agx drop
- AC compressor ?
- 98 maxima racing video
- New Shoes, Exterior done what ya think?
- oil for cone filter?
- GRR!! sick of this performance loss
- Dash Kits...
- Just another Black 4th Gen
- Is it the starter?
- Ignitions Relay Location?
- are 1995 all OBD 2
- FRONT O2 test???
- Problem with the tranny and accelerator
- How do you Program Stock Keyless entry Remote?
- rear heated o2 sensor
- Rattling on engine
- Power Inconsistancy
- can some1 make me a sig???
- Trouble Starting... HELP PLEASE
- Air Condition Recharging
- car cranks but wont start?
- LEDs in Gauges 3mm or 5mm?
- GRR! Left windows down....rained last night!
- pinging b/w 3K-4K rpms + old matress noise in suspension
- Front suspension issues
- Window Motor or Regulator ???
- Need Help Asap (rear Strut Boot)
- Help - inspection issues
- EVAP Canister??
- Replaced Injector... Still Problems
- Trans Temp Gauge ?
- Heated Seats
- tips on putting auto tranny into storage
- The secret button to start question...
- Problems with starting.....
- Paint Colored B Pillars
- Adding ABS to non-ABS Maxima?
- In the middle of replacing auto trans. What else should i replace?
- Quickie about KS...
- Front Sway Bar or bushings
- Oh Cool, Black Maxima Is Lowering His Car Finally!
- disabling trunk release?
- Help ***ASAP
- Extending O2 sensor wires
- What to do??
- looking for ideas.
- How much would a auto tranny with 44k sell for?
- can dynamat reduce 'bees in a can?'
- does it seem like i need a front end alignment?
- dyno shop in philadelphia
- Trans Question
- Signature on Posts?
- knock sensor part #
- Probabilty of an axle breaking
- Bad timing chain tensioner effect on timing?
- tripometer
- TPS closed
- Battery & Alternator problem
- 1995 VLSD driver side axle
- Is this supposed to happen?
- A couple theories put to rest - 5th gen 3rd gear and VIN # on engine block
- may be crazy, but might just work..
- any REAL Carbon Fiber dash inserts?
- A32 Bushing Set
- A maxima saga….
- Dealership says: Only way to reset 0409 - O2 sensor error code is to have them do it!
- Which Exhuast??
- sputtering muffler
- few questions
- 4th gen 5sp; 7.32 0-60?
- WANTED: Pic of 4th gen w/ stillen lip only
- missfire need help 96 max
- electrical problem
- Is this a description of 'bees in a can'?
- Molding m3 lip spoiler
- A video from today
- Pics of H&R/Illumina drop
- Lug nuts size
- Please help...
- shocks!
- Trouble Starting. Not starter or battery
- does this seem like a lemon?
- battery and brake lights on?
- Exhaust stainless?
- Just got my car back from exhaust place, Borla installed
- 99 Standard Maxima Humming on Deaccel? anyone?
- New air filter?
- Do I need an alignment after front struts are replaced?
- About to buy rear calipers for 95 GLE ... Unloaded/Semi-loaded/loaded ???
- car still wont start
- SLR side mirror for my maxima
- 280hp NA 95 maxima on fleabay
- knock sensor...
- Knock sensor...
- Will Infiniti I30 5-Speed fit my Max SE?
- New Steering Wheel Options???
- painting headlights not ae style
- swap question
- Spolier light out
- AFtermarket Spoiler
- Indiglo Gauges
- "You blew out your exhaust padding" ????
- Diagnostic assist
- DO I need new strut mounts
- ebay body kit
- HELP! How to torque Illumina center bolt on rear.
- Small tranny leak...
- Cheaper tail lights
- help from those of you with tokico illuminas
- Rear strut bolt torque amounts...???
- CAr wont turn over after throttle body cleaning and intake cleaning please help
- Billet Grilles for 4th Gen Maximas - Any Interest?
- P1441 CODE(long!)
- Shift Linkage...
- HELP! Car is rusting
- Anyone with Carbon Fiber Front Lip install write-up??
- Which fuse controls the 3rd brake light?
- Help..too many codes
- A/C Compressor or Bearing Going Out.
- way to make hood stand???
- Headlight problem
- noise when going in reverse
- how to remove my ecu??
- paradox spolier type X
- Weird Idle Issue after manual swap...
- Drivers's door thunks when shut
- Rear Valve Cover Seals..>Where to Buy ??
- Feedback: Performance & Emissions after Y-pipe install
- Anyone Not Carrying The Cheapo Spare?
- Magnaflow: Recommended or Not?
- best fitting rim
- I agree. WTF, Haynes Sucks!
- i want to do retro fit projectors
- somewhat crappy morning
- Where can I get dijmple/slotted rotors?
- Ok.. got the car up, wheels off... Wtf? Haynes sucks.
- Looking for Blackmax415? (TL projectors)
- Stupid jacking question, need quick answer.
- B-Pillars Done!!! pics inside
- 3rd Brake Light?
- How loud??
- ever had your speedo die on you?
- Who has the brightest H3 fog light bulbs, step in
- What in the world is a Vacuum Cut Bypass Valve?
- bad odors and cleaning
- those with moon roofs step inside..........
- TopSpeed Stainless Y-pipe
- Exhaust Question
- Fluidyne A/T Cooler
- Please help with clutch problems!
- 99SE, 3 Codes, 1 Newbie, where 2 start?
- Uuuhhhh, does anyone know??
- Road Debris
- 150k needs some serious help - Tune up?
- How-to: Google search??
- Did my Microvision Screen...BURN OUT?! Please help a 5th genner!!!
- HELP QUICK! Starter Died...
- Anyone try one of those oil filter relocation kits?
- KYB Dustboot Fitment
- Pending axle failure?
- 95 to 99 front end
- short video clip of my max [56k poison]
- HELP! Illumina/Stock Rear Strut Problem!!
- need help choosing muffler
- help interior lights dont turn on
- ATTN ORG Post all PICS of polished and painted engine bays here!!
- New Coilovers....Noise from suspension
- A/C Problem in 96...lol...
- an AC problem in my 96 PLZ HELP!
- View Poll Results: How many miles do you (did you) have on your fac clutch?
- Maxima stock ride comfort issue - gxe
- all who polish valve covers...
- Tightening spolier
- TPS - noise or no noise
- BM Shifter Group Buy
- 0505 ECU code - WTF?
- Hey everyone is this Trans worth it?????????
- gold 4th gen max on rt7. this morning??
- fixed shaking b pipe problem
- Greddy SP2 or OBX catback
- your opinion...
- 95-99 Nissan Maxima Carbon Fiber Hood
- Header and Y pipe connections
- quality paint for my "wheels" what brand?
- just bought new dc bumper lenes
- ypipe question ( 02- sensors)
- KYB adjustable shocks struts what do you drive on?
- Where to get hand brake cable?
- Is my car worth a 5spd swap??
- ***help***
- click noise when applying brakes
- is there a write up for doing led tails?
- 95 to 99 swap bumper help
- Brake Upgrade
- where can i get new things to hold open my hood?
- From the Cat-back Rusted open...
- 5 speed
- UR UDP in process of install need some help
- Muffler tips
- xbox under passenger seat
- autolock feature
- Help needed! . PICS. LOOK
- 1995 maxima gxe self diagnostic code 53
- Lost low end power
- Code 1104
- Car jerks hard when letting off and stepping on gas
- Painting tips?
- What do else do i need to add to my list to make my car run as good as it did factory
- Help with cluch problem!
- TINTED TAILLIGHTS? who has them? pics?
- Failed Emissions ... Pic posted
- Missfire Cylinder 1
- Squeak when making full turn
