- Keyless Remote Not Working
- '96 Maxima Shuts Off While Driving/Have To Pump Gas To Start It
- PS Pump change pointers?
- here's why my starters keep going bad
- Looking to turbo my maxima
- Using throttle body for idle
- Axle seals
- H3 bulbs (fog light)
- A/c issue 1999
- Ecu problems relocate?
- More problems with my 1997 maxima. p0171 code
- Steering rack buhsings recommendation
- Engine turns off
- Is my transmission finally going? Weird loud high pitched sound when romping in 1st
- new weird starting issue
- CV Axle, Control Arm, Inner Tie Rod Questions
- Pleeasse HELP! New battery/alternator. Car DIED.
- Argh "service engine soon" light just came on
- Difficult start. Need mechanic gurus! Vid link inside
- Titanium Wheel Paint for '99 Limited - where to find?
- Parting out '99 Max; have '98 Max - what to save?
- 95 rack and pinion
- Door Lock Actuator Part #
- Did my rear brakes(they were really bad) but didn't get any Ebrake back? WTF?
- TCS Diagnostic Question
- biggest diameter tire on stock max
- Progress RSB Bolt Kit Question
- Fuel Inhibitor on 1999 SE
- A/C not blowing cold, low side line warm
- What's causing my Steering Wheel to Shake? (Only answer if you have experience)
- 97 Maxima
- CODE 0701, 0201, 0304, can't make it go away!
- P1445/1447
- Bottom Motor mount
- Poll: Autozone Alternators
- CV Joint Replacement ?'s
- a/c suddenly disengaged
- Viper alarm remote not working?
- Recommended lowering shock/strut combo?
- If you were going to install Z32 calipers, what color would you want them to be?
- Need help asap 95 maxima
- car shut off while driving and wont start
- Firestone Auto Scared
- Nissan fuel filters
- Left turn indicator issues
- Fixin on the maxi
- Strange catalytic converter failure/replacement options
- Upgrade Problem... stuff
- Hesitating around 3500 RPMs?
- Question about passerger side Axles. Are Auto/Manual ones different sizes or spines?
- Brake rotors for '99 SEL
- Where to buy new steering wheel?
- universal consult < $50 (prefer < $25) need imvs diagnostics done
- Strange connector under steering wheel?
- 1997 Maxima GLE overheat only when the A/C is on
- Is it okay to run with out power steering?
- Torsional play/clicking from driver axle not related top torn cv boot!
- BCP Cold Air Intake... any experiences, advice?
- Will 5th gen front struts fit on a 4th gen?
- Seat Belt Pretensioner Fired
- Best tire size for 17" rims
- Door lock actuators...
- help with headers!
- Need some advice on my motor swap
- might have been beaten to death, don't know
- neg cable grounding
- iacv welded to throttle body adapter
- can a coil pack spring go bad?
- leaking LH coolant drain plug?
- Question about setting base idle for 00vi swappers with 5th gen tb and iacv...
- 4th gen metal radiator options
- Windshield Question
- Auto trans out of commission??
- Rear brake won't release
- Transmission leaking from driver side axle input shaft seal
- Suggestions 99 max
- Maxima Won't Start - Electrical
- Car shakes/vibrates slightly above 70mph?
- Clutch Pedal Adjustment question
- Strange AC problems
- sunload sensor replacement
- Team Mad Maxima's Lemons race car
- Help needed 3.5 swap from maxima gurus
- What tools for Bank 2 Sensor 1 O2 sensor?? No room!!!
- Little lip extension for front bumper?
- Removing rear speaker shelf?
- rear strut few questions
- what is a heated oxygen sensor?
- q45 massair flow
- Will a 98/99 Instrument Cluster trim fit a 96 maxima?
- unplugged connectors?
- Door Sill Under Body Rust
- Spring question
- Seafoam on Sale!
- Question on Gasket Kits
- 1999 maxima lowering kits???
- Front axle part Q - and Seafoam!
- Oil pan gasket
- Snapped a Lug Nut on the wheel Stud
- Will airbags and control unit from 98 work in a 99 model?
- Transmission check engine code issue
- low idle/semi loss of power
- replacing front end of a 95
- 99 radio problem, ground related?
- Front end swap ftom 95 to 00-03
- Can my engine fall out?
- 98 max engine swap help
- Blower fan slows down then ramps back up
- car won't start - battery? starter? gremlins?
- Car won't stay running
- Throttle body /high idle
- Rough Start Up
- Coolant leak still after water pump replaced
- No lower spring isolators, and matillic groaning
- No clutch pedal after slave cylinder replaced
- So, I was browsing on good Ol' craigslist and find this..
- Eibach progressive springs
- Another door locking problem...ive been searching!
- Is this too much play in CV Axle? (video inside)
- P1320 , coil packs are less, than a month old
- I need a little wiring help
- Overheating issue
- jdm vq30 from cefiro
- need help with cruise control
- Accidentally hooked up the jumper cables backwards, car won't start,no lights on dash
- Changed valve cover gaskets, now car stalls on idle
- VQ30 Samurai and VG bolt pattern??
- maxiscan ms300 says " link error" on my 95
- How to resecure this brace on the fender?
- Coolant reservoir tank?
- 1999 SEL 5MT Water Damage Concerns
- Emergency Help. Experts please respond. Stuck and need to fix and get back home.
- Rear brake calipers freezing
- 96 Max auto, no start no crank single click
- Stepped on clutch pedal and now cruise control flashes
- What did you do to your maxima to day n whats next!!
- FML! 99 SE-L Imomobilized + AAA Fail
- Door panel removal/front speaker install?
- Vapor Canister Purge Valve
- Removal of front grille
- Audio fuse issue
- 97 Maxima... inputs on upgrading the speakers
- Need Help with Parasitic Drain Off Fuse #40
- 4th gen San Andreas mod
- Horrible speakers - embarrasing
- getting 25.5MPG - not bad for a clunker
- 97 Maxima Caught Fire
- Brake pad fell off
- EMERGENCY: CALLING ALL 4TH GEN EXPERTS. CKPS issue
- Setting Th-points on VAFC.
- Resident Nissan Technician
- Needing input on a rim
- Oil leak while running, parts advice needed, timing seals, what else while in there?
- best struts for a 3" drop?
- Car Won't Start
- Cabin fans wont work in lvls 1 2 3.
- Help Please!!! 99max auto Fsm wire color is different
- V8 swap ?
- Clock/Radio randomly not working after installing starter
- Radiator question. 99 SE-L
- Car was stolen, HOW?
- Oil Filter?
- Airbag and ABS lights on dash
- My maxima doesn't wanna start
- Dead New Batterty/Possible dead alternator-Need Advice
- Looking for rims ny area
- 1998 infiniti door chime wont work
- Fed or cali spec?
- Does mavi or 00vi Add horsepower???
- Gear problems?
- Picture of inside of drivers door
- help with reds\clears
- Illuminated Automatic Shifter Bulb?
- installed y pipe now thinking....
- Anyone replace their Auto-climate Unit ?
- Did I pay a fair price? (newbie driver)
- I give up on this dipstick.
- axles - should i buy new or reman?
- Part # Help
- Are 5th gen and 4th gen parts the same? Similar?
- Which danged resonator
- looking for more horsepower.
- Keyless entry remote NOT working? New member
- Fuel filter
- I got a couple questions....tranny, axels
- E.S. motor mount inserts work on transmission and front side mount?
- Recommended Parts Replacements When Changing Water Pump
- bbk for 95
- Power Stop K662 Front/Rear Ceramic Brake Pad and Cross Drilled/Slotted Combo Rotor On
- hid's stopped working ///
- Maxima 1998 - Oil Filter Cover Replacement
- A/C Problem
- Bronze Medallist Award - Thank you .org
- Brake and Battery dash lights on???
- My Alternator Saga Continues
- ECU Mapping
- 95 Maxima stalls while moving.
- Is $1,000.00 a fair price to pay to have a stock engine installed?
- front end shake. so lost
- Alternator Removal Help/General alternator q's..the saga continues
- power stearing cooling system ?
- transmission seal !?
- Help!
- Gauge cluster or fuel sender unit?
- Been a fun ride, but saying goodbye to the Maxima
- head gasket or water pump
- 1997 Nissan Maxima - Vibrating please help
- 96 max emission fail help!
- P1440 troubleshooting steps needed
- Car Shakes Bad ~20-30 MPH
- can you recomen an Aftermarket air filter for my 97 SE?
- &$^*# coolant leak
- Help, replacing water pump O-rings and problems
- Keyless entry not working in a weird way
- Installed aftermarket LCA, alignment way off..help please
- OBX catback? Where to buy from?
- new starter cranks but car wont start
- 99 max tranni problems - need help please
- Need help !!! Idiot mistake here !
- Dies in middle of start... then starts?
- Maintain or run until death
- picked up an air intake temp sensor at a yard today
- Parking brake
- I need help asap! Please
- Maxima A32 stall on LPG while driving
- Blue Tooth OBDII scanner not so good?
- Urgent!! Maxima 1995 won't start, can't move seats, lock doors, open windows, 0 power
- poly steering rack bushings
- starting issues .. ive searched
- Opinions welcome. Should I sell or fix my Max?
- Horrible Sound w/ video
- Keeps blowing (#40) Fuse
- How Do I Make the A/C Ice Cold?
- o2 sensor bung 97 maxima
- New here but, Alarm Lights and Mysterious Coolant
- coilovers
- Fuel pump and MAF on the way out?
- Sunroof when closing vibrates. Annoying. Want to fix
- 96 Nissan maxima hard starting ??
- Anyone had any luck swapping I30 seats and to their passenger side Maxima w/manual
- 98 nissan maxima se need help!:)
- Strut bearing question?
- New member, 98 GXE!
- 1999 Nissan Maxima - Idler Strut Nut gone?
- How long can Nissan A/C compressors/water pumps generally last?
- 5 PSi at warm idle
- Brake Caliper V spring
- Where to buy OEM strut boots?
- s13 seats
