- Changed Rear Brakes- Oil Leak??
- quick question on headlight
- Anyone here have megan springs?
- Question
- Difference Between These Corner Lights?
- another odd problem, please help.....
- gauging intrest on 2000 VI
- How does your engie start?
- Weird Question
- How many quarts of ATF do I need?
- drive belt pulley fell off while driving
- Suspension Part Interchangable? '98 Struts/Shocks/Mounts on '96
- Clutch Problem
- Auto Climate gurgles
- Spring Question
- Leak what could it Be? Trans????
- Blower Motor resistor
- rear shock assembly...creek
- Putting Max Up For Winter
- Exhaust diagram..
- 4th Gen Carbon Fiber Trunk (Ebay Find)
- My E-brake is stuck
- Wheel lug nut wont come off
- Strange start when cold?
- 2nd and 3d gear pull
- Clearance Light (parking light) Fitment issues
- FMS Search for steering linkage removal
- 98 SE suspension noise in right rear
- water pump part#
- seat replacements
- Rear suspension diagram?...
- ABS; why doesn't it work properly?
- front page
- 95-96 Red/Clear by Klearz.com
- question about lowering maxima as much as poss.
- My Maxima is on its last breath!!!
- oil change ... please help me (97 max)
- 4th gens on coilovers step in...
- Factory Alarm
- two codes 1001 and 0901 changed the O2s and knock and still there any suggestions?
- is it coil???
- Not starting. Not Happy
- service bulletin EC90-004
- whats jon sutter pm name?
- Got the chance to really flog the Max tonight...
- Problem starting my car needs pushing
- hmmm.... knocking upon cold start?
- ugh... i don't know what else it could be.
- Nissan FAST program...link ??
- check out this winner.. 275hp? stock? sorry pal
- Tokico Hp's or Illuminas on stock SE springs?
- Challenge: Clutch disc destroyed...
- How to Replace Power Steering Pump [Sticky Me Please]
- advanced posters beware
- 'Sacked Out Emblems!!! PICS!!!
- maxima heater
- Hard to open rear doors
- maxima class
- Heater Dont Work
- Buying new airbags, do i need a new module with it too? or can i use the old one?
- car jerks at 1800 rpm in 1st and nuetral...please help
- traction control?!?!?
- How often should the coil packs be replaced?
- Can i use 5th or 6th Gen Keyless entry remotes???
- You gotta be kiddin me....
- Alarm went off, How do I cut it off????
- replacing the left axle (half-shaft)
- Heat- Can You Use Recirculaton?
- D1 help!!!!
- Weird thing happened to me with the speedo
- H&R/Illumina w/ RSB
- For Sale: New H-Tech springs, in sealed box, $135(+$35 shipping)
- Rear Veiw Mirror
- Getting 0201 with 0608 codes please help!
- IACV-- what's the best way to clean this sucka?
- odometer recalibration?
- Temp Sending Unit? I think....
- 0101 & 0403: need advice
- OBDII on a 95?
- Maxima is finally in the shop!
- Goodridge vs Technafit SS Brake Lines
- Looking For New Rotors
- Starter Grease
- Problem with my friends car
- Help me decide my next mod... Headlights
- Throaty Throttle Question!
- xenon bulb question
- 5th gen seats fit in 4th gen????
- No heat still!!!!! Help......
- idle is too high, how to fix?
- Flickering LED's
- Reverse Lights
- Uhhhh??? ECU LIGHT QUICK FIX!!!!! and... I'm done modding.
- solar battery charger?
- problems running shortly after cold start
- Oil leak
- good transmission places?
- is this the right part?
- look at this maxima
- Wheel Weight?
- how to get window motor out with window stuck up?
- Question on AIR FILTER
- MY Connectors ARE Melting
- I30 front on a max
- Questions about the 9004-9007 conversion
- 0201: Ignition Signal Circuit, car shakes, what cyclinder is it?
- tranny problems
- Another cold starting question
- Resetting ecu?
- help
- need help
- RPM Signal
- Power Steering/Rack Question.. Please read/help!
- what to look for in alignment shop?
- Terrible Sound - Need your help
- Indiglow gauges or LEDs?
- How to install a power steering hose high pressure
- too fast start...very lengthy
- 4g3n vs 5th
- Alignment Problems
- my 96 max has no spark
- Reason for Maxima's Premature tire wear? Who has some snow tires?
- Can someone post a pic of the EGR passage?
- radiator fan problem
- WTF is this???
- dimming lights
- Winter warm up...
- 4th gen automatics
- problem found. can i fix this myself?
- CD Stereo Swap - Loss of Volume/Power
- clutch problem
- what kind of exhaust??
- Flywheel question, need a response back quick
- engine experts chime in, need help!
- wire routing guide
- Exhaust suggestions
- Speaker wiring headache
- 5 speed flywheel removal
- Does anyone need a carfax?
- Y-pipe and OBDII Inspection
- Cruising RPMs?
- How do you know if you car has keyless entry?
- Help! Rear Caliper Bracket
- codes 0407 and 0101 - please help!!!!
- Bulbs
- Oil/Grease all over wheel
- What color is your radiator?
- Need Control Arm FAST!
- Alternative to stock clutch line???
- If Hella FF50 = H7 and stock = H3, swappable?
- Chariot vs V8's and more: 1/8th mile drag videos !
- Side marker lights
- Buy A New Or Fix Up Old Max..
- Please help
- where to get a new spare tire...
- POwer Acoustik 7" Monitor Install???
- Opinions on Sylvania bulbs
- Those with the yellow capsule mod please step in....
- Microvision 7in TV screen in 4th Gen headrest?
- Parking my 1996 until april..did i forget anything?
- maxima car clubs
- "Headlights On" Warning - Upgrade?
- Wtf is this sh!t about power axle?
- License plate lights?????? HELP!!!!!
- Rear Tailights Dont Work But Flashers Do What Do I Do
- catalyst converter
- Question about IACV
- overheating
- Intake Gasket
- DTM Taillight + 24/7_Flavor mods combined
- Failed emissions inspection!
- help in a few things.
- Did I just kill my Max?
- Does this work or is like the Ebay chips?
- Is it worth switching gas now?
- Water injection
- How much would it cost to...
- maxima doesnt wanna start
- How to clean out debris inside headlight?
- 2 questions
- Power Seat question
- Paint code
- MT venting fluid out of vent tube
- cold starts....even colder driver!
- MAP / BARO and Absolute Pressure CEL questions...
- 00/01 Ecu??
- Ran Out Of Gas
- 95/96- to 97-99 gauges?
- Installed new taillights and ran into issue sadly need help
- Finally found out wrhats wrong with my car, how much would it cost to fix?
- HELP!! MY TRUNK WON"T OPEN!!!!
- Best free mod ever
- Foglights on a GXE???
- need help, cyl 1 and 3 are misfiring
- need a good mechanic in BK or Queens
- DropZone Coilovers???
- O2 Sensor Question
- Rear drivers side brake grinding?
- Difference between locking and non-locking transmission
- Passenger axle is STUCK...need help!
- Need help deciding!
- Coil Packs
- I need two codes ran
- Injectors
- i changed my ks (pic)
- Coolant Leak - Water Pump?
- Starting problem...sensor?
- Hard starting once every 3 to 4 weeks
- Trouble Spots for the Maxima
- EGR Solenoid Valve
- Clutch master cylinder issues
- 6 month old battery doesnt start car
- Gasoline smell in car when heater is turned on
- Anyone have a carfax account open?
- Front passenger window problem
- can anybody run this VIN # for me
- Car hesitates at 2000-2500 rpm acceleration? bad coils?
- where is the turn signal relay located under the dash?
- Steering wheel cover's?
- Optima.....
- Spec stage 1
- does autozone sell knock sensors?
- clearance and signal bulbs to match 6000k HID's ?
- Finally Got Some Suspension Probs Resoved!!! (kinda long)
- Soo.. Clutch blew out, trans broke, Pushed my car home..
- guage problem
- Paint Rear Window Spoiler/Wind Deflectors ?
- different wheels from Nissan
- Car problems
- window install instructions for RPS
- It goes creaaaakkk, when I turn the wheel while stopped to the far left
- Ghost ECU codes
- Can't get car into gear
- Fuel Cut off during deacceleration in manual ----> converted?
- Difference b/w Walker & Bosch O2 sensor
- What can I do about rust starting to bubble and show around the spoiler supports?
- Bose question
- wtfenginesqueal.mpg - video
- Removing Door Moldings
- Rear Manifold bolt size?
- Projector Advice...
- Rip-off or Reality?
- starter opinion
- Brake Light and Gas Light... Problems
- Need help! Car shuts off when placed in reverse orDrive when first startup in morning
- squealing noise help please
- quick question
- How To Fix Scratched And Fogged Headlights, This Works!!!!!
- 9004-9007 coversion Wire help
- fan blower stuck on speed 4
