- help!!! need the right size of screw for clear corner...
- Zex/nos
- squealing from new brake pads
- Who should i talk to at $tillen for best S/C price?
- Oil anti-drainback valve ? Horrid clatter at startup
- Installation of Koni's
- ---===ATTNENTION!!! Nissan Prices for 2002 Vehicles===---
- Modification FAQs...
- Maxus Hotel Info---> Must Read
- Bumper Paint Fade
- K&N or similar
- For my maxima/I30 Brethren.....Free car fax
- Engine Restore
- '95 air speed gauge only works on setting 4 NEED HELP : Daniel
- tv for maxima on ebay?
- Springs reccomendation eibach? sprint?
- What's the deal with the G-Tech/Pro?...
- Strut bars and rear sway bars
- Removing Visor Warning
- Horse Power
- aftermarket driving/fog lights CHEAP!
- Should I take a look at this maxi?
- nightmare at the body shop
- Whats a RT Cat
- Steering wheel switch from 97 to 95
- Tire contact patch pressure vs. size
- Warming up a cold engine
- These Sounds at Startup Normal?
- Sounds like a diesel
- 97 Auto GXE VS 5spd Eclipse GSX
- cold air intake questions
- Intake Adapter
- 99 auto. trans. problems
- So how bad is it to drive with 2/3 of the fst bolts?
- Racing with my auto stock this friday.... Tips?
- Need a quiet free flowing muffler, any ideas?
- any good instructions for mesh grille???
- Mirrow Tinting
- N E 1 have stock or clear bumpers available??
- Need suggestions for mods...probably been asked a million times already
- security led, how to change it?
- Aftermarket clutch and STS ?s
- some help koni adjustables /sprints springs
- What size tip of muffler do I need for my Max?
- Ohio Meet
- Pulled rear Decals off, but they left marks
- O/D Button Not Responding
- What cars have you beat?
- I was going to get a catback exhaust system, can I still get a y-pipe with this?
- cv joint => leak
- Mobil1 site updated
- where can I buy the service manuel
- is there a camber problem with Sprint/Tokico?
- Squeeking Clutch>>...
- which is faster
- who wants $150 to install my Y-pipe and RT Cat?
- Cams Coming Out
- need the LINK explaining how to rewire my blinkers
- Koni Adjustables..... MY KIDNEYS!!!
- AGX/KYB Shocks
- for all people with rims
- Need Help
- aaaaahhh. I thought it was safe with a torque wrench!
- ecu swap question for Daniel or whoever
- air questions.... somebody PLEASE help
- Three easy questions, two for DBM and one for nitrous users.
- APEXi Fuel Controller ?'s ?'s ?'s ?'ss
- Pic of my new rims!!
- fading panels between windows, where can I get the carbon fiber kit?
- beware wood kits
- WHich tire size will fit?
- What is the best Exhaust system?
- Fast and Furious Maxima ^^ REPRESENT!!!
- Transmission... Caughing?
- Power Seats Installation
- 1157 clear glass super white
- Daniel : Shaking car...
- just in: Weapon-R coilovers(first impressions)(kinda long)
- Thoughts about Apex springs??
- 95 to 97 front end switch??
- Just Installed New third brake light on spoiler
- Removing Seatbelt Warning from Visor!!
- Dissapointed in Stillen Y-pipe...
- 3/4 clear 1/4 red tails
- What does the B-pipe and Y-pipe do?
- Auto Maximas - RPM's at start up?
- Intake Vaccum Lines
- Help Needed - 5sp Shift Knob Removal
- Is a Stillen Exhaust a bolt on or weld installation
- Tail Light Assembly Part number?
- Car Manual - 1998 GLE
- What suspension part could be damaged. . .
- How to remove hinged storage door
- Floormats Question
- Oil Comsumption
- Got Indiglow needles installed (pics)
- Use rear suspension from Max for I30?
- Texas Heatwave Car Show
- Sidemarker Wiring
- Manual Transmission
- Blue type 168 bulbs.. where?
- Requesting some help on pictures..
- HELP!!!: my sunroof will not close....
- VQPOWER.COM is up...
- Clutch
- Will tires become harder to balance when they have a lot of miles on them?
- 6000 RPM question again !!!!
- indiglo
- How do I set the alarm wih only the Key ??
- 5spd Conversion DONE!
- Exhaust Leak Fixed!
- x-drilled rotors
- 20,19 or 18 inch rims
- Where can I find a Bose Schematic
- Engine stalling
- Performance Mods: Bad for your Car ??
- autometer gauges
- koni adjustables
- Keyless Remote Question
- Aftermarket Filter and air temp sensor - help
- 11 second car???
- FS: One set of 95/96 Altezzas-$165 shipped
- This Is Bad Rpm Gauge Went Dead After Indiglo Install
- SE wheel weight
- indiglo gauge needle stuck!
- Indiglo gauges for 98 SE that fit?
- where can I get Cefiro or Nismo badges...????
- Is there a SMX grille for the 97-99 MAX?
- Altezzas on blue max
- Engine won't turn over
- PLZ help my needles are sticking after the install of indiglos
- 97-99 Max Altezza's, any date?
- Mobil 1 Synthetic 10W-30 ??
- Stillen Exhaust
- altezza connections
- Where to find Z3 Fender cuts?
- Quick Question
- Upgrading stock Bose in 99 - stereo people help
- Some Basic Questions
- Clock display keeps going on and off.
- max vs. bonneville
- Tint: worth doing yourself?
- exhaust and FSTB question
- My car SQUEELS...
- Daniel B Maxima...got a question
- Max sighting in Greenway shopping center, Greenbelt MD
- K&N Filter & Temp. sensor reset
- Jump'n Car Lighter!!!!!!
- New Hood or scoop?
- Clear Headlights
- Green or Black Maxima near Brooklyn
- Oil?
- New Brakes! Help
- meineke mufflers vs. OEM muffler
- Instrument Panel Light Bulb # For Year 99
- ok q for u guys
- Lexus GS300 vs Max 5spd+ a damn honda
- Keyless Entry Question
- Blue Window Tint
- Opinions on brake pads....
- Maxima of the Month Needs Boost
- Cefiro?
- Can clearing out tail-lights mod work on '96?
- Max and I30 similarities....
- Best Headlight Bulbs???...
- Inside Nissan's oil & gas filters
- Changing a dash light...
- Is Redline Synthetic MT-90 good for my car?
- 16 X 7 wheels with +50mm offset....will it work?
- Glove Box Light
- Help me out i lost....
- Need some advice on brakes ( Stillen X-drilled & Axxis Pads)
- Has anyone ordered these?? indiglos...
- Rewire fog problems.....
- Attn: All 16" 225x50 size tire owners on stock rims!
- no more indiglo gauge for 1998 max?
- A Dent In My Hood!!!!!!!!!
- question about exhaust hangers...
- Ok. Seriously. Getting the light off the plastic on the 95/96 ClearTAILS!!!!!HELP
- muffler suggestions
- anyone heard of the tornado thing on TV
- Keyless Entry
- M 3 front fender gill pieces for maximas
- need help with indiglo gauge
- help to install indiglo's!!!!
- looking to buy a 4th gen
- Park to Reverse
- For those w/ Koni's, here's an expereince I'd like to share.
- Altezza light done!
- ECU -- code help does 0505 make sense?
- would these tires fit?
- Back to that E-brake light again .......Daniel
- Indiglo Pedals
- which brake pad?
- just road killed an acura 3.2TL
- GForce ECU in 97 Maxima 5 Spd
- To those of you with 97-99 Deep Evergreen SE
- Average Max Owner Age?
- Hey Dan
- 5th Gen Tail
- Virginia Maxmaniacs ~ sign here
- Step lights, where to get em?
- daniel martin, quick question plz
- 5-Speed shifting difficulties.... what could be wrong?
- wiring harnesses...needed???
- Expert painter's expertise for max (black side door thing)
- Euro type sfty lite
- 5 spd troubles me!
- Replacement Tires for 99 Maxima ES
- TIRES !....and a lil lowering question
- Poor exercise in judgment - Speed kills.
- Adjustable ride height suspensions?
- where can i find RT cat online?
- Need Help..CAI install
- Intake Q and GTR sign Q please look~!
- Whistling sound when changing gears on high rpm's?
- Valve Stem Light, Legal?
- Questions about tranny rebuild?
- MIL Light
- Joshua Dash Kit
- good price???
- Done With blue dash..now onto center consul
- Matching all Exterior lights..suggestions plszz
- anyone have 19" on their car?
- performance shop in so cal
- BMW 330i Vs. Max SE 5-speed
- my first try drag racing at atco raceway...
- 18x8.5 in rims
- SKYLINE R32-33 Blank Key for maxima?
- I need Paint Code to the Dark Evergreen color on a 97
- Instalation of Courtesy FSTB, if you have experience w/ courtesy, etc. please read
- 1st picture of my max
- Best Battery?
- Automatic Transmission Cooler
- Problem I need to fix before 90 days. HELP!
- Anyone with Metal Matrix brake pads?
- Best 9004 bulbs???
- Quick OD Button Question
- Sprint And Koni
- Anyone installed an ignition kit??? (Daniel)
- How much can I sell my max for?
- Sounds like lifters knocking when AC is on
- Bolb color in clear tail lights
- tune up parts
- Ground Control Coilovers Inquiry
- How does this deal sound...95 se
- Strange engine noise, not sure if anyone can help.
